Arcade Collecting => Miscellaneous Arcade Talk => Topic started by: adler_0 on August 17, 2009, 11:09:03 pm
Hi, I'm new to the forums and semi-new to arcades. I need help identifying a problem I have with my new punch out!! arcade. My problem can be seen here:
http://omgpics.net/2a <-top screen
http://omgpics.net/2b <-bottom screen
It doesn't play any sounds and the screen does not change. Any help on getting this fixed would be greatly appreciated. Thanks,
~Jesse
At the very least, you have some kind of board fault. Start by metering voltages with a multimeter.
