Arcade Collecting => Miscellaneous Arcade Talk => Topic started by: geecab on October 11, 2011, 04:00:33 pm
No schematics/printouts existed for the Starwars cockpit version so I designed it myself.
Hope you enjoy!
I need to get out more...
Sa-weet!
Very cool. I think you should stay in more and build some others!
That looks neat. I wonder if a sharpie would be enough to simulate the t-molding.
Would you mind sharing the link where you downloaded the files?
Thanks for looking :)
Try here for defender and galaga printouts...
http://www.wayoftherodent.com/pa/pa_staff.htm (http://www.wayoftherodent.com/pa/pa_staff.htm)
For Starwars I designed the printouts myself. I had to use various pictures of the real thing I found on the web to put these together. They are a bit tricky to follow, for example I didn't outline the corners of the black strip that becomes the seat/screen etc (as it was a bit difficult to work out exactly where the corners should be in 2D), so I decided just to print a long strip out and make it up I went along! Anyways, I have attached my printouts so good luck and enjoy!!
Nice work. :applaud: :applaud:
