Software Support => GroovyMAME => Topic started by: inv on November 10, 2018, 05:00:02 am
Glad to know Switchres is upgraded to v0.017k, so test it quickly.
But I get an error message:
SwitchRes: could not find a video mode that meets your specs
I run groovymame on several lcds, gm works fine with other 60hz lcds, but with this lcd I have no luck.
Logs is here:
SwitchRes: v0.017k, Monitor: lcd, Orientation: horizontal, Modeline generation: enabled
SwitchRes: LCD vfreq range set by user as 50.000000-145.000000
SwitchRes: \\.\DISPLAY1: Radeon RX 560 Series (PCI\VEN_1002&DEV_67FF&SUBSYS_E3481DA2&REV_CF)
SwitchRes: Device key: System\CurrentControlSet\Control\Video\{51131C52-6454-11E8-A606-A842CD4AF0A9}\0000
ATI/AMD ADL init
ADL functions retrieved successfully.
Switchres: Searching for custom video modes...
Switchres: [ 1] 640x 480 @ 59 : system mode
Switchres: [ 2] 640x 480 @ 60 : ATI ADL timing "640x480_60 31.462000KHz 59.927620Hz" 25.170000 640 656 752 800 480 490 492 525 -hsync -vsync
Switchres: [ 3] 640x 480 @ 67 : ATI ADL timing "640x480_67 33.125000KHz 66.784271Hz" 26.500000 640 688 720 800 480 483 487 496 -hsync +vsync
Switchres: [ 4] 640x 480 @ 72 : ATI ADL timing "640x480_72 37.860000KHz 72.807693Hz" 31.500000 640 664 704 832 480 489 492 520 -hsync -vsync
Switchres: [ 5] 640x 480 @ 74 : system mode
Switchres: [ 6] 640x 480 @ 75 : ATI ADL timing "640x480_75 37.500000KHz 75.000000Hz" 31.500000 640 656 720 840 480 481 484 500 -hsync -vsync
Switchres: [ 7] 640x 480 @100 : system mode
Switchres: [ 8] 640x 480 @120 : system mode
Switchres: [ 9] 640x 480 @144 : system mode
Switchres: [ 10] 720x 400 @ 70 : ATI ADL timing "720x400_70 29.261000KHz 69.835320Hz" 25.750000 720 768 800 880 400 403 413 419 -hsync +vsync
Switchres: [ 11] 720x 400 @ 74 : system mode
Switchres: [ 12] 720x 400 @100 : system mode
Switchres: [ 13] 720x 400 @120 : system mode
Switchres: [ 14] 720x 400 @144 : system mode
Switchres: [ 15] 720x 480 @ 59 : system mode
Switchres: [ 16] 720x 480 @ 60 : ATI ADL timing "720x480_60 31.468000KHz 59.939049Hz" 27.000000 720 736 798 858 480 489 495 525 -hsync -vsync
Switchres: [ 17] 720x 480 @ 74 : system mode
Switchres: [ 18] 720x 480 @100 : system mode
Switchres: [ 19] 720x 480 @120 : system mode
Switchres: [ 20] 720x 480 @144 : system mode
Switchres: [ 21] 800x 480 @ 56 : system mode
Switchres: [ 22] 800x 480 @ 60 : system mode
Switchres: [ 23] 800x 480 @ 72 : system mode
Switchres: [ 24] 800x 480 @ 74 : system mode
Switchres: [ 25] 800x 480 @ 75 : system mode
Switchres: [ 26] 800x 480 @100 : system mode
Switchres: [ 27] 800x 480 @120 : system mode
Switchres: [ 28] 800x 480 @144 : system mode
Switchres: [ 29] 800x 600 @ 56 : ATI ADL timing "800x600_56 35.156000KHz 56.249599Hz" 36.000000 800 824 896 1024 600 601 603 625 +hsync +vsync
Switchres: [ 30] 800x 600 @ 60 : ATI ADL timing "800x600_60 37.878000KHz 60.315285Hz" 40.000000 800 840 968 1056 600 601 605 628 +hsync +vsync
Switchres: [ 31] 800x 600 @ 72 : ATI ADL timing "800x600_72 48.076000KHz 72.186188Hz" 50.000000 800 856 976 1040 600 637 643 666 +hsync +vsync
Switchres: [ 32] 800x 600 @ 74 : system mode
Switchres: [ 33] 800x 600 @ 75 : ATI ADL timing "800x600_75 46.875000KHz 75.000000Hz" 49.500000 800 816 896 1056 600 601 604 625 +hsync +vsync
Switchres: [ 34] 800x 600 @100 : system mode
Switchres: [ 35] 800x 600 @120 : system mode
Switchres: [ 36] 800x 600 @144 : system mode
Switchres: [ 37] 832x 624 @ 74 : system mode
Switchres: [ 38] 832x 624 @ 75 : ATI ADL timing "832x624_75 48.387000KHz 74.786705Hz" 48.000000 832 880 912 992 624 627 631 647 -hsync +vsync
Switchres: [ 39] 832x 624 @100 : system mode
Switchres: [ 40] 832x 624 @120 : system mode
Switchres: [ 41] 832x 624 @144 : system mode
Switchres: [ 42] 1024x 600 @ 60 : system mode
Switchres: [ 43] 1024x 600 @ 70 : system mode
Switchres: [ 44] 1024x 600 @ 74 : system mode
Switchres: [ 45] 1024x 600 @ 75 : system mode
Switchres: [ 46] 1024x 600 @100 : system mode
Switchres: [ 47] 1024x 600 @120 : system mode
Switchres: [ 48] 1024x 600 @144 : system mode
Switchres: [ 49] 1024x 768 @ 60 : ATI ADL timing "1024x768_60 48.363000KHz 60.003723Hz" 65.000000 1024 1048 1184 1344 768 771 777 806 -hsync -vsync
Switchres: [ 50] 1024x 768 @ 70 : ATI ADL timing "1024x768_70 56.475000KHz 70.068237Hz" 75.000000 1024 1048 1184 1328 768 771 777 806 -hsync -vsync
Switchres: [ 51] 1024x 768 @ 74 : system mode
Switchres: [ 52] 1024x 768 @ 75 : ATI ADL timing "1024x768_75 60.022000KHz 75.027496Hz" 78.750000 1024 1040 1136 1312 768 769 772 800 +hsync +vsync
Switchres: [ 53] 1024x 768 @100 : system mode
Switchres: [ 54] 1024x 768 @120 : system mode
Switchres: [ 55] 1024x 768 @144 : system mode
Switchres: [ 56] 1152x 872 @ 74 : system mode
Switchres: [ 57] 1152x 872 @ 75 : ATI ADL timing "1152x872_75 67.644000KHz 74.827431Hz" 88.750000 1152 1200 1232 1312 872 875 885 904 -hsync +vsync
Switchres: [ 58] 1152x 872 @100 : system mode
Switchres: [ 59] 1152x 872 @120 : system mode
Switchres: [ 60] 1152x 872 @144 : system mode
Switchres: [ 61] 1280x 720 @ 50 : ATI ADL timing "1280x720_50 37.500000KHz 50.000000Hz" 74.250000 1280 1720 1760 1980 720 725 730 750 +hsync +vsync
Switchres: [ 62] 1280x 720 @ 59 : system mode
Switchres: [ 63] 1280x 720 @ 60 : ATI ADL timing "1280x720_60 44.951000KHz 59.934666Hz" 74.170000 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Switchres: [ 64] 1280x 720 @ 74 : system mode
Switchres: [ 65] 1280x 720 @100 : system mode
Switchres: [ 66] 1280x 720 @120 : system mode
Switchres: [ 67] 1280x 720 @144 : system mode
Switchres: [ 68] 1280x 768 @ 60 : system mode
Switchres: [ 69] 1280x 768 @ 74 : system mode
Switchres: [ 70] 1280x 768 @100 : system mode
Switchres: [ 71] 1280x 768 @120 : system mode
Switchres: [ 72] 1280x 768 @144 : system mode
Switchres: [ 73] 1280x 960 @ 60 : ATI ADL timing "1280x960_60 60.000000KHz 60.000000Hz" 108.000000 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync
Switchres: [ 74] 1280x 960 @ 74 : system mode
Switchres: [ 75] 1280x 960 @100 : system mode
Switchres: [ 76] 1280x 960 @120 : system mode
Switchres: [ 77] 1280x 960 @144 : system mode
Switchres: [ 78] 1280x1024 @ 60 : ATI ADL timing "1280x1024_60 63.981000KHz 60.019699Hz" 108.000000 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
Switchres: [ 79] 1280x1024 @ 74 : system mode
Switchres: [ 80] 1280x1024 @ 75 : ATI ADL timing "1280x1024_75 79.976000KHz 75.024391Hz" 135.000000 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync
Switchres: [ 81] 1280x1024 @100 : system mode
Switchres: [ 82] 1280x1024 @120 : system mode
Switchres: [ 83] 1280x1024 @144 : system mode
Switchres: [ 84] 1360x 768 @ 60 : system mode
Switchres: [ 85] 1360x 768 @ 74 : system mode
Switchres: [ 86] 1360x 768 @100 : system mode
Switchres: [ 87] 1360x 768 @120 : system mode
Switchres: [ 88] 1360x 768 @144 : system mode
Switchres: [ 89] 1366x 768 @ 60 : system mode
Switchres: [ 90] 1366x 768 @ 74 : system mode
Switchres: [ 91] 1366x 768 @100 : system mode
Switchres: [ 92] 1366x 768 @120 : system mode
Switchres: [ 93] 1366x 768 @144 : system mode
Switchres: [ 94] 1400x1050 @ 60 : ATI ADL timing "1400x1050_60 65.316000KHz 59.977962Hz" 121.750000 1400 1488 1632 1864 1050 1053 1057 1089 -hsync +vsync
Switchres: [ 95] 1400x1050 @ 74 : system mode
Switchres: [ 96] 1400x1050 @100 : system mode
Switchres: [ 97] 1400x1050 @120 : system mode
Switchres: [ 98] 1400x1050 @144 : system mode
Switchres: [ 99] 1440x 900 @ 60 : ATI ADL timing "1440x900_60 55.934000KHz 59.886509Hz" 106.500000 1440 1520 1672 1904 900 903 909 934 -hsync +vsync
Switchres: [100] 1440x 900 @ 74 : system mode
Switchres: [101] 1440x 900 @100 : system mode
Switchres: [102] 1440x 900 @120 : system mode
Switchres: [103] 1440x 900 @144 : system mode
Switchres: [104] 1600x 900 @ 23 : system mode
Switchres: [105] 1600x 900 @ 24 : system mode
Switchres: [106] 1600x 900 @ 25 : system mode
Switchres: [107] 1600x 900 @ 29 : system mode
Switchres: [108] 1600x 900 @ 30 : system mode
Switchres: [109] 1600x 900 @ 50 : system mode
Switchres: [110] 1600x 900 @ 59 : system mode
Switchres: [111] 1600x 900 @ 60 : system mode
Switchres: [112] 1600x 900 @ 74 : system mode
Switchres: [113] 1600x 900 @100 : system mode
Switchres: [114] 1600x 900 @119 : system mode
Switchres: [115] 1600x 900 @120 : system mode
Switchres: [116] 1600x 900 @144 : system mode
Switchres: [117] 1600x1200 @ 74 : system mode
Switchres: [118] 1600x1200 @100 : system mode
Switchres: [119] 1600x1200 @120 : system mode
Switchres: [120] 1600x1200 @144 : system mode
Switchres: [121] 1680x1050 @ 23 : system mode
Switchres: [122] 1680x1050 @ 24 : system mode
Switchres: [123] 1680x1050 @ 25 : system mode
Switchres: [124] 1680x1050 @ 29 : system mode
Switchres: [125] 1680x1050 @ 30 : system mode
Switchres: [126] 1680x1050 @ 50 : system mode
Switchres: [127] 1680x1050 @ 59 : system mode
Switchres: [128] 1680x1050 @ 60 : system mode
Switchres: [129] 1680x1050 @ 74 : system mode
Switchres: [130] 1680x1050 @100 : system mode
Switchres: [131] 1680x1050 @119 : system mode
Switchres: [132] 1680x1050 @120 : system mode
Switchres: [133] 1680x1050 @144 : system mode
Switchres: [134] 1920x1080 @ 23 : system mode
Switchres: [135] 1920x1080 @ 24 : ATI ADL timing "1920x1080_24 26.970000KHz 23.973333Hz" 74.170000 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync
Switchres: [136] 1920x1080 @ 25 : system mode
Switchres: [137] 1920x1080 @ 29 : system mode
Switchres: [138] 1920x1080 @ 30 : system mode
Switchres: [139] 1920x1080 @ 50 : ATI ADL timing "1920x1080_50 56.250000KHz 50.000000Hz" 148.500000 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync
Switchres: [140] 1920x1080 @ 59 : system mode
Switchres: [141] 1920x1080 @ 60 : ATI ADL timing "1920x1080_60 67.431000KHz 59.938667Hz" 148.350000 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Switchres: [142] 1920x1080 @ 74 : system mode
Switchres: [143] 1920x1080 @100 : ATI ADL timing "1920x1080_100 112.500000KHz 100.000000Hz" 297.000000 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync
Switchres: [144] 1920x1080 @119 : system mode
Switchres: [145] 1920x1080 @120 : ATI ADL timing "1920x1080_120 134.863000KHz 119.878220Hz" 296.700000 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Switchres: [146] 1920x1080 @144 : ATI ADL timing "1920x1080_144 -157.137000KHz -135.814178Hz" -318.360000 1920 1928 1960 2026 1080 1143 1151 1157 -hsync +vsync
Switchres: [147] 1920x1200 @ 74 : system mode
Switchres: [148] 1920x1200 @100 : system mode
Switchres: [149] 1920x1200 @120 : system mode
Switchres: [150] 1920x1200 @144 : system mode
Switchres: [151] 2560x1440 @ 60 : ATI ADL timing "2560x1440_60 88.786000KHz 59.950035Hz" 241.500000 2560 2608 2640 2720 1440 1443 1448 1481 +hsync +vsync
Switchres: [152] 2560x1440 @ 74 : ATI ADL timing "2560x1440_74 110.240000KHz 73.936958Hz" 293.900000 2560 2592 2613 2666 1440 1448 1485 1491 +hsync -vsync
Switchres: [153] 2560x1440 @100 : ATI ADL timing "2560x1440_100 -94.808000KHz -62.786755Hz" -252.760000 2560 2568 2600 2666 1440 1465 1473 1510 -hsync +vsync
Switchres: [154] 2560x1440 @120 : ATI ADL timing "2560x1440_120 -62.813000KHz -41.188854Hz" -167.460000 2560 2568 2600 2666 1440 1465 1473 1525 +hsync +vsync
Switchres: [155] 2560x1440 @144* : ATI ADL timing "2560x1440_144 -23.765000KHz -15.401814Hz" -63.360000 2560 2568 2600 2666 1440 1447 1455 1543 +hsync +vsync
SwitchRes: Found 33 custom of 155 active video modes
SwitchRes: Creating automatic specs for LCD based on current timings
SwitchRes: Monitor range 77150.00-223735.00,50.00-145.00,-0.126,-0.505,-1.042,-0.295,-0.337,-3.703,1,1,1440,1440,0,0
SwitchRes: -resolution was forced as 2560x1440@144
SwitchRes: Entering switchres_modeline_setup
SwitchRes: v0.017k:[pacman] Calculating best video mode for 224x288@60.606060 orientation: rotated
SwitchRes: [ 640]x[ 480]_[59=59.000000Hz] - locked
SwitchRes: [ 640]x[ 480]_(60=59.927620Hz) - locked
SwitchRes: [ 640]x[ 480]_(67=66.784271Hz) - locked
SwitchRes: [ 640]x[ 480]_(72=72.807693Hz) - locked
SwitchRes: [ 640]x[ 480]_[74=74.000000Hz] - locked
SwitchRes: [ 640]x[ 480]_(75=75.000000Hz) - locked
SwitchRes: [ 640]x[ 480]_[100=100.000000Hz] - locked
SwitchRes: [ 640]x[ 480]_[120=120.000000Hz] - locked
SwitchRes: [ 640]x[ 480]_[144=144.000000Hz] - locked
SwitchRes: [ 720]x[ 400]_(70=69.835320Hz) - locked
SwitchRes: [ 720]x[ 400]_[74=74.000000Hz] - locked
SwitchRes: [ 720]x[ 400]_[100=100.000000Hz] - locked
SwitchRes: [ 720]x[ 400]_[120=120.000000Hz] - locked
SwitchRes: [ 720]x[ 400]_[144=144.000000Hz] - locked
SwitchRes: [ 720]x[ 480]_[59=59.000000Hz] - locked
SwitchRes: [ 720]x[ 480]_(60=59.939049Hz) - locked
SwitchRes: [ 720]x[ 480]_[74=74.000000Hz] - locked
SwitchRes: [ 720]x[ 480]_[100=100.000000Hz] - locked
SwitchRes: [ 720]x[ 480]_[120=120.000000Hz] - locked
SwitchRes: [ 720]x[ 480]_[144=144.000000Hz] - locked
SwitchRes: [ 800]x[ 480]_[56=56.000000Hz] - locked
SwitchRes: [ 800]x[ 480]_[60=60.000000Hz] - locked
SwitchRes: [ 800]x[ 480]_[72=72.000000Hz] - locked
SwitchRes: [ 800]x[ 480]_[74=74.000000Hz] - locked
SwitchRes: [ 800]x[ 480]_[75=75.000000Hz] - locked
SwitchRes: [ 800]x[ 480]_[100=100.000000Hz] - locked
SwitchRes: [ 800]x[ 480]_[120=120.000000Hz] - locked
SwitchRes: [ 800]x[ 480]_[144=144.000000Hz] - locked
SwitchRes: [ 800]x[ 600]_(56=56.249599Hz) - locked
SwitchRes: [ 800]x[ 600]_(60=60.315285Hz) - locked
SwitchRes: [ 800]x[ 600]_(72=72.186188Hz) - locked
SwitchRes: [ 800]x[ 600]_[74=74.000000Hz] - locked
SwitchRes: [ 800]x[ 600]_(75=75.000000Hz) - locked
SwitchRes: [ 800]x[ 600]_[100=100.000000Hz] - locked
SwitchRes: [ 800]x[ 600]_[120=120.000000Hz] - locked
SwitchRes: [ 800]x[ 600]_[144=144.000000Hz] - locked
SwitchRes: [ 832]x[ 624]_[74=74.000000Hz] - locked
SwitchRes: [ 832]x[ 624]_(75=74.786705Hz) - locked
SwitchRes: [ 832]x[ 624]_[100=100.000000Hz] - locked
SwitchRes: [ 832]x[ 624]_[120=120.000000Hz] - locked
SwitchRes: [ 832]x[ 624]_[144=144.000000Hz] - locked
SwitchRes: [1024]x[ 600]_[60=60.000000Hz] - locked
SwitchRes: [1024]x[ 600]_[70=70.000000Hz] - locked
SwitchRes: [1024]x[ 600]_[74=74.000000Hz] - locked
SwitchRes: [1024]x[ 600]_[75=75.000000Hz] - locked
SwitchRes: [1024]x[ 600]_[100=100.000000Hz] - locked
SwitchRes: [1024]x[ 600]_[120=120.000000Hz] - locked
SwitchRes: [1024]x[ 600]_[144=144.000000Hz] - locked
SwitchRes: [1024]x[ 768]_(60=60.003723Hz) - locked
SwitchRes: [1024]x[ 768]_(70=70.068237Hz) - locked
SwitchRes: [1024]x[ 768]_[74=74.000000Hz] - locked
SwitchRes: [1024]x[ 768]_(75=75.027496Hz) - locked
SwitchRes: [1024]x[ 768]_[100=100.000000Hz] - locked
SwitchRes: [1024]x[ 768]_[120=120.000000Hz] - locked
SwitchRes: [1024]x[ 768]_[144=144.000000Hz] - locked
SwitchRes: [1152]x[ 872]_[74=74.000000Hz] - locked
SwitchRes: [1152]x[ 872]_(75=74.827431Hz) - locked
SwitchRes: [1152]x[ 872]_[100=100.000000Hz] - locked
SwitchRes: [1152]x[ 872]_[120=120.000000Hz] - locked
SwitchRes: [1152]x[ 872]_[144=144.000000Hz] - locked
SwitchRes: [1280]x[ 720]_(50=50.000000Hz) - locked
SwitchRes: [1280]x[ 720]_[59=59.000000Hz] - locked
SwitchRes: [1280]x[ 720]_(60=59.934666Hz) - locked
SwitchRes: [1280]x[ 720]_[74=74.000000Hz] - locked
SwitchRes: [1280]x[ 720]_[100=100.000000Hz] - locked
SwitchRes: [1280]x[ 720]_[120=120.000000Hz] - locked
SwitchRes: [1280]x[ 720]_[144=144.000000Hz] - locked
SwitchRes: [1280]x[ 768]_[60=60.000000Hz] - locked
SwitchRes: [1280]x[ 768]_[74=74.000000Hz] - locked
SwitchRes: [1280]x[ 768]_[100=100.000000Hz] - locked
SwitchRes: [1280]x[ 768]_[120=120.000000Hz] - locked
SwitchRes: [1280]x[ 768]_[144=144.000000Hz] - locked
SwitchRes: [1280]x[ 960]_(60=60.000000Hz) - locked
SwitchRes: [1280]x[ 960]_[74=74.000000Hz] - locked
SwitchRes: [1280]x[ 960]_[100=100.000000Hz] - locked
SwitchRes: [1280]x[ 960]_[120=120.000000Hz] - locked
SwitchRes: [1280]x[ 960]_[144=144.000000Hz] - locked
SwitchRes: [1280]x[1024]_(60=60.019699Hz) - locked
SwitchRes: [1280]x[1024]_[74=74.000000Hz] - locked
SwitchRes: [1280]x[1024]_(75=75.024391Hz) - locked
SwitchRes: [1280]x[1024]_[100=100.000000Hz] - locked
SwitchRes: [1280]x[1024]_[120=120.000000Hz] - locked
SwitchRes: [1280]x[1024]_[144=144.000000Hz] - locked
SwitchRes: [1360]x[ 768]_[60=60.000000Hz] - locked
SwitchRes: [1360]x[ 768]_[74=74.000000Hz] - locked
SwitchRes: [1360]x[ 768]_[100=100.000000Hz] - locked
SwitchRes: [1360]x[ 768]_[120=120.000000Hz] - locked
SwitchRes: [1360]x[ 768]_[144=144.000000Hz] - locked
SwitchRes: [1366]x[ 768]_[60=60.000000Hz] - locked
SwitchRes: [1366]x[ 768]_[74=74.000000Hz] - locked
SwitchRes: [1366]x[ 768]_[100=100.000000Hz] - locked
SwitchRes: [1366]x[ 768]_[120=120.000000Hz] - locked
SwitchRes: [1366]x[ 768]_[144=144.000000Hz] - locked
SwitchRes: [1400]x[1050]_(60=59.977962Hz) - locked
SwitchRes: [1400]x[1050]_[74=74.000000Hz] - locked
SwitchRes: [1400]x[1050]_[100=100.000000Hz] - locked
SwitchRes: [1400]x[1050]_[120=120.000000Hz] - locked
SwitchRes: [1400]x[1050]_[144=144.000000Hz] - locked
SwitchRes: [1440]x[ 900]_(60=59.886509Hz) - locked
SwitchRes: [1440]x[ 900]_[74=74.000000Hz] - locked
SwitchRes: [1440]x[ 900]_[100=100.000000Hz] - locked
SwitchRes: [1440]x[ 900]_[120=120.000000Hz] - locked
SwitchRes: [1440]x[ 900]_[144=144.000000Hz] - locked
SwitchRes: [1600]x[ 900]_[23=23.000000Hz] - locked
SwitchRes: [1600]x[ 900]_[24=24.000000Hz] - locked
SwitchRes: [1600]x[ 900]_[25=25.000000Hz] - locked
SwitchRes: [1600]x[ 900]_[29=29.000000Hz] - locked
SwitchRes: [1600]x[ 900]_[30=30.000000Hz] - locked
SwitchRes: [1600]x[ 900]_[50=50.000000Hz] - locked
SwitchRes: [1600]x[ 900]_[59=59.000000Hz] - locked
SwitchRes: [1600]x[ 900]_[60=60.000000Hz] - locked
SwitchRes: [1600]x[ 900]_[74=74.000000Hz] - locked
SwitchRes: [1600]x[ 900]_[100=100.000000Hz] - locked
SwitchRes: [1600]x[ 900]_[119=119.000000Hz] - locked
SwitchRes: [1600]x[ 900]_[120=120.000000Hz] - locked
SwitchRes: [1600]x[ 900]_[144=144.000000Hz] - locked
SwitchRes: [1600]x[1200]_[74=74.000000Hz] - locked
SwitchRes: [1600]x[1200]_[100=100.000000Hz] - locked
SwitchRes: [1600]x[1200]_[120=120.000000Hz] - locked
SwitchRes: [1600]x[1200]_[144=144.000000Hz] - locked
SwitchRes: [1680]x[1050]_[23=23.000000Hz] - locked
SwitchRes: [1680]x[1050]_[24=24.000000Hz] - locked
SwitchRes: [1680]x[1050]_[25=25.000000Hz] - locked
SwitchRes: [1680]x[1050]_[29=29.000000Hz] - locked
SwitchRes: [1680]x[1050]_[30=30.000000Hz] - locked
SwitchRes: [1680]x[1050]_[50=50.000000Hz] - locked
SwitchRes: [1680]x[1050]_[59=59.000000Hz] - locked
SwitchRes: [1680]x[1050]_[60=60.000000Hz] - locked
SwitchRes: [1680]x[1050]_[74=74.000000Hz] - locked
SwitchRes: [1680]x[1050]_[100=100.000000Hz] - locked
SwitchRes: [1680]x[1050]_[119=119.000000Hz] - locked
SwitchRes: [1680]x[1050]_[120=120.000000Hz] - locked
SwitchRes: [1680]x[1050]_[144=144.000000Hz] - locked
SwitchRes: [1920]x[1080]_[23=23.000000Hz] - locked
SwitchRes: [1920]x[1080]_(24=23.973333Hz) - locked
SwitchRes: [1920]x[1080]_[25=25.000000Hz] - locked
SwitchRes: [1920]x[1080]_[29=29.000000Hz] - locked
SwitchRes: [1920]x[1080]_[30=30.000000Hz] - locked
SwitchRes: [1920]x[1080]_(50=50.000000Hz) - locked
SwitchRes: [1920]x[1080]_[59=59.000000Hz] - locked
SwitchRes: [1920]x[1080]_(60=59.938667Hz) - locked
SwitchRes: [1920]x[1080]_[74=74.000000Hz] - locked
SwitchRes: [1920]x[1080]_(100=100.000000Hz) - locked
SwitchRes: [1920]x[1080]_[119=119.000000Hz] - locked
SwitchRes: [1920]x[1080]_(120=119.878220Hz) - locked
SwitchRes: [1920]x[1080]_(144=-135.814178Hz) - locked
SwitchRes: [1920]x[1200]_[74=74.000000Hz] - locked
SwitchRes: [1920]x[1200]_[100=100.000000Hz] - locked
SwitchRes: [1920]x[1200]_[120=120.000000Hz] - locked
SwitchRes: [1920]x[1200]_[144=144.000000Hz] - locked
SwitchRes: [2560]x[1440]_(60=59.950035Hz) - locked
SwitchRes: [2560]x[1440]_(74=73.936958Hz) - locked
SwitchRes: [2560]x[1440]_(100=-62.786755Hz) - locked
SwitchRes: [2560]x[1440]_(120=-41.188854Hz) - locked
SwitchRes: [2560]x[1440]_[144=-15.401814Hz]
rng(0): out of range
SwitchRes: Setting option -noswitchres
Video: Monitor 65537 = "\\.\DISPLAY1" (primary)
Direct3D: Using Direct3D 9Ex
Physical width 2560, height 1440
Direct3D: Initialize
Direct3D: Configuring adapter #0 = Radeon RX 560 Series
Direct3D: Adapter has Vendor ID: 1002 and Device ID: 67FF
Direct3D: Using dynamic textures
Direct3D: YUV format = RGB
Direct3D: Max texture size = 16384x16384
Direct3D: Device created at 2560x1440
Direct3D: First scanline: 1, Last scanline: 1440, Break scanline: 1380, Delay scanline: 289
Direct3D: Initialize HLSL
Direct3D: First store options
Direct3D: HLSL initialized
This is a nasty bug, thanks a lot for reporting.
Thanks for the quick reply, Calamity.
Expect the next version to fix this tiny bug! :applaud:
Hi inv,
This issue should be fixed now:
What's new in Switchres v0.017l (November 2018)
- Fix issue where 4K pixel clocks caused an overflow in the modeline engine. Now Switchres can properly pick 4K video modes. However, AMD drivers will still reject custom 4K timings so, until this gets fixed, use the -nomodeline_generation in GroovyMAME when running on 4K monitors.
Hi Calamity,
Congratulations!
The bug is totally fixed, now all things are perfect! :cheers:
On my 144hz 2k LCD monitor, Switchres works well!
