Software Support => PowerMAME => Topic started by: 442much on January 10, 2007, 11:52:13 pm
I'm having a problem getting the lighting to work properly in PowerMAME32 0.105. I don't have all of my LEDs wired up yet, but I don't think that should matter. I have Player #1's 7 buttons hooked to inputs 1-7 and Player #2, buttons 1-3 hooked to inputs 17-19. Strange thing is all of my ingame lighting works great for both player #1 and #2 (for the buttons I have hooked up).
The attract mode lighting is what doesn't work properly. For example, when I do a test of the flash.lwa file only Player #1 buttons #1 and #2 light up. All of Player #2 light. Also, when running the attract mode, player #2 buttons fade in and out, but Player #1 buttons never do.
You have to create your own LWA files for your own panel. The flash.lwa and other lwa files are just there as a reference and are for my panels particular layout.
That first post sounds familiar. ;) Mike, could you or anyone else please explain the setup of the LWA files. I've messed with the numbers and tried all that I know, and I can't make up or down of it. :dunno
Could you both send me your key to button mappings and your key to LED mapping?
I thought I quit this job. :)
