Software Support => GroovyMAME => Topic started by: alex2005 on April 01, 2017, 11:58:31 am
Is there a way to emulate MVS 4 slot in MAME? So that I could for instance load 4 games and let the MVS run these 4 games at once, using the "select" button to go from one to another.
Yes, up to 6. Command: "mame64 neogeo -cart1 miexchng -cart2 wakuwak7 -cart3 etc..."
I use a bat file. It's a great attract mode to leave a cabinet in.
I did a quick search this morning, falling in the same footsteps. Except that the emulation starts in settings mode.
I tried several bios without success. Any advice ?
PS : you can also specify these command line inside neogeo.ini file in ini folder.
cart1 mslug1
cart2 mslug2 etc...
looking good, thanks!
I tried it and seems to work fine.
Only a last question: how do I switch from one game to another?
I have they keys for "next game" and "previous game" set, but it just doesn't seem to do anything?
@funkykochise do you have the service dipswitch ON in the mame settings?
I will try again, no dipswitch modified.
I believe you just need to credit before game change.
edit: I did a quick test, with different mame version, removing cfg and nvram : still stuck in settings. Anyway, I'm not after multislot. It doesn't really matter. It's much more for educational knowledge :)
Just hit the tab key and look through the controls. Mvs board has support for next and previous game, but harness sold only utilized one of them.
I'm currently finishing a really cool multi slot style attractmode layout. It would be neat to be able to select 4 slots from the front end and launch them together in mame, but haven't quite figured that out.
https://vimeo.com/211240313/description
