Main => Consoles => Topic started by: opt2not on June 01, 2011, 04:57:25 pm
Saw this on the neo-geo forums last night:
http://www.neo-geo.com/forums/showthread.php?225277-Jamma-projects.&p=3204006#post3204006 (http://www.neo-geo.com/forums/showthread.php?225277-Jamma-projects.&p=3204006#post3204006)
Thought it was pretty cool.
Very creatve
I can't see the link, but I've started a DC JAMMA project. Got a fingerboard, hacked a VGA box, and some controllers... just gotta finish wiring.
Here you go:
Currently stuck between contracts, weather is mostly ---steaming pile of meadow muffin--- and boredom is setting in. So I'd thought I'd finally get around to making my dreamcast, which I only bought for this purpose anyway, jamma compatible.
I still need to add a few things, like a switch to kill the internal controllers, for some light gun action. Also adding video out to the jamma edge, so I can get back my scanlines when in 15khz mode.
It is otherwise done.
Jamma connector, Headphone jack, DB9 kick harness connector and cutout for the memory card.
(http://stevensart.com/Arcade/DCJamma/DCJamma_01.jpg)
VGA connector, 15/31khz switch.
(http://stevensart.com/Arcade/DCJamma/DCJamma_02.jpg)
Guts spilled open.
There's two internal controllers with one slot for a memory card.
All of the components that sit on the top metal panel are going to connectors, strip boards. Making everything very easy to take apart when needed.
(http://stevensart.com/Arcade/DCJamma/DCJamma_03.jpg)
And a look inside the gutted modem shell.
(http://stevensart.com/Arcade/DCJamma/DCJamma_04.jpg)
Next up, is a Genesis. This one is going to be a much quicker project to do.
Using an harness going to the Sega CD extension port, instead of adding a jamma connector to the shell.
Im wondering if he's powering this off the 12v line...I'm assuming so.
I really dig his use of the modem area, maybe this will give you some ideas.
Hi
I know this is an old thread but has anyone tried this mod.
I'm a little stuck
Ta
B
The original link threw up all kinds of "don't go there" on my AV. Be careful clicking on the link....
Has anyone tried this mod, I am struggling on how to convert 5v to 3.3v, what did you guys use?
Well resistors will drop voltage, but depending upon what you need that might not be enough.
http://www.learningaboutelectronics.com/Articles/How-to-reduce-voltage-with-resistors.php (http://www.learningaboutelectronics.com/Articles/How-to-reduce-voltage-with-resistors.php)
Just remember, you may have to reduce amperage as well.
I don't have any experience on this particular hack, so I'm Leary about giving any more advice than that.
