Main => Woodworking => Topic started by: battlecat on February 18, 2009, 08:19:49 pm
Hello:
I have been working on my recreation of a MS. Pacman Cocktail cabinet based on Kyle Lindstrom's plans. I have used 3/4 plywood so that it will be pretty sturdy. What I need to do now is figure out how to mount a computer monitor (its all I have) upside down to the top 3/4 inch plywood. I also need to figure out how to calculate the size and location before I cut out the hole for the monitor. I would like a snug solid fit.
I see that in a "real" MS. Pacman cocktail cabinet the monitor has a beautiful mount. I do not of course have that since I cannot sadly afford a real arcade monitor.
Any suggestions, ideas, or links to sites that may have solved this issue?
battlecat
Mock it up out of 2x4 sticks or cardboard or something. You can get good measurements for a very precise fit that way.
Are you decasing or just mounting it with the case intact?
