Main => Main Forum => Topic started by: Sarlo on January 23, 2022, 01:04:42 pm
I'm using the ctrl alt p method to remap the keys to my ipac 4 (old model) from my slikstik. Everything is working fine except my player 1 joystick won't take up/down/left/right. When i mpa other keys it accepts it and says "done"...when I map the joystick keys it says "one". I have pasted the notepad file below if that helps.
*** i-pac interactive programming and test mode ***
t for button test mode
l to list current config
r to reset eeprom to mame defaults
e to save and exit
a to abort
or press switch you want to program
coin 3 = 7
4 right = -
coin 4 = 8
4 left =
start 3 = 9 3 * shift *
4 up = *
start 4 = 0
4 down = +
3 right = l
4 sw 1 = del
3 left = j
3 up = h
3 down = k
4 sw 2 =
3 sw 1 =
4 sw 3 = '
3 sw 2 = 5
4 sw 4 =
3 sw 3 = m
4 sw 5 =
3 sw 4 =
4 sw 6 = ]
3 sw 5 = o
4 sw 7 = \
3 sw 6 = b
4 sw 8 = p
3 sw 7 = t
3 sw 8 = p
coin 1 = 3
2 right = g
coin 2 = 4
2 left = d
start 1 = 1 1 * shift *
2 up = r
start 2 = 2
2 down = f
1 right = tab
2 sw 1 = a
1 left = entr
1 up = `
1 down = f12
2 sw 2 = s
1 sw 1 = lctl
2 sw 3 = q
1 sw 2 = lalt
2 sw 4 = w
1 sw 3 = spce
2 sw 5 = e
1 sw 4 = lshf
2 sw 6 = [
1 sw 5 = z
2 sw 7 = ]
1 sw 6 = x
2 sw 8 = p esc
1 sw 7 = c
1 sw 8 = p esc
done
press next switch or e to exit
exiting...codes saved.
e to save and exit
a to abort
1 up press keyboard key to set.. one
1 right press keyboard key to set.. one
1 left press keyboard key to set.. one
press next switch or e to exit 1 down press keyboard key to set.. one
