Software Support => GroovyMAME => Topic started by: NinjaZero on January 01, 2019, 01:00:07 am
Downloaded new build ver 0.205 and it crashed with my settings, so I installed to a new directory and ran the emulator with -cc with the only change in ini - I made was the rom folder location. Then re-ran the emulator with HLSL and it ran fine, took a while trying to find what setting was causing the problem and it looks like it is enabling Frame Delay & HLSL causes the instability in Full-Screen. I normally run the game with Frame Delay 7 but as soon as I enable Frame Delay 1, emu will hang and eventually crash but works when the emulator is started -Windowed.
Calamity, here is the output I see, let me know if I can try anything else or if you need more debug. My system is Win7 / Nvidia (latest driver).
[EDIT]
See Post #4 for the current log.
Do you have -hlsl enabled? It's known to cause a crash due to frame delay in 0.205.
Aside of that, your monitor configuration is wrong (monitor range taken from someone else's monitor?)
I had accidentaly left my own mame.ini in GM's package, that's where you got that odd crt range, sorry :D
It seems like I can either have HLSL or Frame Delay enabled but not both without crashing at launch? BTW, I fixed my monitor settings back to auto and I noticed I got a different exception when it crashed. The previous version (.204) worked great with HLSL enabled and Frame Delay 7. Let me know if there is anything else I can do.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
D:\Downloads\groovymame64>mame64 -v samsho
SwitchRes: v0.017m, Monitor: lcd, Orientation: horizontal, Modeline generation: enabled
SwitchRes: Using default vfreq range for LCD 59.000000-61.000000
SwitchRes: \\.\DISPLAY1: NVIDIA GeForce GTX 1050 Ti (PCI\VEN_10DE&DEV_1C82&SUBSYS_62533842&REV_A1)
SwitchRes: Device key: System\CurrentControlSet\Control\Video\{04BF2CB1-39E4-4AD5-AEF2-9C2AB6266339}\0000
Video chipset is not compatible.
Switchres: Searching for custom video modes...
Switchres: [ 1] 640x 480 @ 60 : system mode
Switchres: [ 2] 640x 480 @ 72 : system mode
Switchres: [ 3] 640x 480 @ 75 : system mode
Switchres: [ 4] 720x 480 @ 56 : system mode
Switchres: [ 5] 720x 480 @ 60 : system mode
Switchres: [ 6] 720x 480 @ 72 : system mode
Switchres: [ 7] 720x 480 @ 75 : system mode
Switchres: [ 8] 720x 576 @ 56 : system mode
Switchres: [ 9] 720x 576 @ 60 : system mode
Switchres: [ 10] 720x 576 @ 72 : system mode
Switchres: [ 11] 720x 576 @ 75 : system mode
Switchres: [ 12] 800x 600 @ 56 : system mode
Switchres: [ 13] 800x 600 @ 60 : system mode
Switchres: [ 14] 800x 600 @ 72 : system mode
Switchres: [ 15] 800x 600 @ 75 : system mode
Switchres: [ 16] 1024x 768 @ 60 : system mode
Switchres: [ 17] 1024x 768 @ 70 : system mode
Switchres: [ 18] 1024x 768 @ 75 : system mode
Switchres: [ 19] 1152x 864 @ 60 : system mode
Switchres: [ 20] 1280x 720 @ 60 : system mode
Switchres: [ 21] 1280x 768 @ 60 : system mode
Switchres: [ 22] 1280x 800 @ 60 : system mode
Switchres: [ 23] 1280x 960 @ 60 : system mode
Switchres: [ 24] 1280x1024 @ 60 : system mode
Switchres: [ 25] 1360x 768 @ 60 : system mode
Switchres: [ 26] 1366x 768 @ 60 : system mode
Switchres: [ 27] 1600x 900 @ 60 : system mode
Switchres: [ 28] 1600x1024 @ 59 : system mode
Switchres: [ 29] 1600x1024 @ 60 : system mode
Switchres: [ 30] 1680x1050 @ 59 : system mode
Switchres: [ 31] 1680x1050 @ 60 : system mode
Switchres: [ 32] 1920x1080 @ 60* : system mode
Switchres: [ 33] 1440x 900 @ 60 : system mode
SwitchRes: Found 0 custom of 33 active video modes
SwitchRes: Creating automatic specs for LCD based on VESA GTF
SwitchRes: Monitor range 65962.00-68198.00,59.00-61.00,0.741,1.157,1.898,0.015,0.045,0.507,0,1,1080,1080,0,0
SwitchRes: -resolution was forced as 1920x1080@60
SwitchRes: Entering switchres_modeline_setup
SwitchRes: v0.017m:[samsho] Calculating best video mode for 320x224@59.185608 orientation: normal
SwitchRes: [ 640]x[ 480]_[60=60.000000Hz] - locked
SwitchRes: [ 640]x[ 480]_[72=72.000000Hz] - locked
SwitchRes: [ 640]x[ 480]_[75=75.000000Hz] - locked
SwitchRes: [ 720]x[ 480]_[56=56.000000Hz] - locked
SwitchRes: [ 720]x[ 480]_[60=60.000000Hz] - locked
SwitchRes: [ 720]x[ 480]_[72=72.000000Hz] - locked
SwitchRes: [ 720]x[ 480]_[75=75.000000Hz] - locked
SwitchRes: [ 720]x[ 576]_[56=56.000000Hz] - locked
SwitchRes: [ 720]x[ 576]_[60=60.000000Hz] - locked
SwitchRes: [ 720]x[ 576]_[72=72.000000Hz] - locked
SwitchRes: [ 720]x[ 576]_[75=75.000000Hz] - locked
SwitchRes: [ 800]x[ 600]_[56=56.000000Hz] - locked
SwitchRes: [ 800]x[ 600]_[60=60.000000Hz] - locked
SwitchRes: [ 800]x[ 600]_[72=72.000000Hz] - locked
SwitchRes: [ 800]x[ 600]_[75=75.000000Hz] - locked
SwitchRes: [1024]x[ 768]_[60=60.000000Hz] - locked
SwitchRes: [1024]x[ 768]_[70=70.000000Hz] - locked
SwitchRes: [1024]x[ 768]_[75=75.000000Hz] - locked
SwitchRes: [1152]x[ 864]_[60=60.000000Hz] - locked
SwitchRes: [1280]x[ 720]_[60=60.000000Hz] - locked
SwitchRes: [1280]x[ 768]_[60=60.000000Hz] - locked
SwitchRes: [1280]x[ 800]_[60=60.000000Hz] - locked
SwitchRes: [1280]x[ 960]_[60=60.000000Hz] - locked
SwitchRes: [1280]x[1024]_[60=60.000000Hz] - locked
SwitchRes: [1360]x[ 768]_[60=60.000000Hz] - locked
SwitchRes: [1366]x[ 768]_[60=60.000000Hz] - locked
SwitchRes: [1600]x[ 900]_[60=60.000000Hz] - locked
SwitchRes: [1600]x[1024]_[59=59.000000Hz] - locked
SwitchRes: [1600]x[1024]_[60=60.000000Hz] - locked
SwitchRes: [1680]x[1050]_[59=59.000000Hz] - locked
SwitchRes: [1680]x[1050]_[60=60.000000Hz] - locked
SwitchRes: [1920]x[1080]_[60=60.000000Hz]
rng(0): 1920 x1080_60.000000p 0.000000 [fract] scale(6, 4, 1) diff(0.00, 17.04, 0.8144) ratio(6.000, 4.821)
SwitchRes: [1440]x[ 900]_[60=60.000000Hz] - locked
SwitchRes: [samsho] (1) horizontal (320x224@59.185608)->(1920x1080@60.000000)
SwitchRes: Modeline "1920x1080_60 0.000000KHz 60.000000Hz" 0.000000 1920 0 0 0 1080 0 0 0 -hsync -vsync
SwitchRes: Setting option -rotate
SwitchRes: Setting option -noror
SwitchRes: Setting option -autoror
SwitchRes: Setting option -norol
SwitchRes: Setting option -noautorol
SwitchRes: Setting option -keepaspect
SwitchRes: Setting option -unevenstretch
SwitchRes: Setting option -nounevenstretchx
SwitchRes: Setting option -noblack_frame_insertion
SwitchRes: Setting option -syncrefresh
SwitchRes: Setting option -notriplebuffer
SwitchRes: Setting option -waitvsync
SwitchRes: Setting option -filter
Video: Monitor 65537 = "\\.\DISPLAY1" (primary)
Direct3D: Using Direct3D 9Ex
Physical width 1920, height 1080
Direct3D: Initialize
Direct3D: Configuring adapter #0 = NVIDIA GeForce GTX 1050 Ti
Direct3D: Adapter has Vendor ID: 10DE and Device ID: 1C82
Direct3D: Using dynamic textures
Direct3D: YUV format = RGB
Direct3D: Max texture size = 16384x16384
Direct3D: Device created at 1920x1080
Direct3D: Initialize HLSL
Direct3D: First store options
Direct3D: HLSL initialized
Direct3D: Restore options
RawInput: APIs detected
DirectInput: Using DirectInput 8
stream_buffer_size = 37888
DirectSound: Primary buffer: 48000 Hz, 16 bits, 2 channels
Input: Adding keyboard #0: Standard PS/2 Keyboard (device id: \\?\ACPI#PNP0303#0#{884b96c3-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding keyboard #1: HID Keyboard Device (device id: \\?\HID#{00001124-0000-1000-8000-00805f9b34fb}_VID&000205ac_PID&022c&Col01#8&1380
e5b2&0&0000#{884b96c3-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding mouse #0: HID-compliant mouse (device id: \\?\HID#VID_1BCF&PID_0005#8&1777981f&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding lightgun #0: HID-compliant mouse (device id: \\?\HID#VID_1BCF&PID_0005#8&1777981f&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd
Input: Adding joystick #0: Controller (XBOX 360 For Windows) (device id: Controller (XBOX 360 For Windows) product_028e045e-0000-0000-0000-5
04944564944 instance_47e6c450-5dc0-11e8-8001-444553540000)
Input: Adding joystick #1: Controller (XBOX 360 For Windows) (device id: Controller (XBOX 360 For Windows) product_028e045e-0000-0000-0000-5
04944564944 instance_058eca50-5dc3-11e8-8001-444553540000)
Region ':cslot1:maincpu' created
unzip: opened archive file D:\Arcade\Mame\roms\samsho.zip
unzip: found D:\Arcade\Mame\roms\samsho.zip ECD
unzip: D:\Arcade\Mame\roms\samsho.zip has no ZIP64 ECD locator
unzip: read D:\Arcade\Mame\roms\samsho.zip central directory
unzip: closing archive file D:\Arcade\Mame\roms\samsho.zip and sending to cache
unzip: found D:\Arcade\Mame\roms\samsho.zip in cache
Region ':cslot1:fixed' created
Region ':fixedbios' created
unzip: opened archive file D:\Arcade\Mame\roms\neogeo.zip
unzip: found D:\Arcade\Mame\roms\neogeo.zip ECD
unzip: D:\Arcade\Mame\roms\neogeo.zip has no ZIP64 ECD locator
unzip: read D:\Arcade\Mame\roms\neogeo.zip central directory
unzip: closing archive file D:\Arcade\Mame\roms\neogeo.zip and sending to cache
Region ':zoomy' created
unzip: found D:\Arcade\Mame\roms\neogeo.zip in cache
Region ':mainbios' created
Region ':audiobios' created
Region ':cslot1:audiocpu' created
Region ':cslot1:ymsnd' created
Region ':cslot1:sprites' created
Optional device ':cslot6' not found
Optional device ':cslot5' not found
Optional device ':cslot4' not found
Optional device ':cslot3' not found
Optional device ':cslot2' not found
Optional memory region ':audiocpu' not found
Optional memory region ':fixed' not found
Optional memory region ':sprites' not found
Optional memory region ':maincpu' not found
Optional device ':audiocpu:finder_dummy_tag' not found
Optional device ':systemlatch:finder_dummy_tag' not found
Optional device ':screen:finder_dummy_tag' not found
Optional memory region ':palette:finder_dummy_tag' not found
Optional device ':audionmi:finder_dummy_tag' not found
Optional device ':soundlatch:finder_dummy_tag' not found
Optional device ':soundlatch2:finder_dummy_tag' not found
Optional memory region ':ymsnd.deltat' not found
Optional memory region ':ymsnd' not found
Optional device ':ymsnd:finder_dummy_tag' not found
Optional device ':watchdog:finder_dummy_tag' not found
Optional device ':upd4990a:finder_dummy_tag' not found
Optional memory region ':saveram' not found
Optional memory region ':cslot1:ymsnd.deltat' not found
Optional memory region ':cslot1:audiocrypt' not found
Starting Samurai Shodown / Samurai Spirits (NGM-045) ':'
(missing dependencies; rescheduling)
Starting Motorola MC68000 ':maincpu'
Starting Zilog Z80 ':audiocpu'
Starting 74HC259 Addressable Latch ':systemlatch'
Starting Video Screen ':screen'
Starting palette ':palette'
Starting Neo-Geo Sprites (optimized) ':spritegen'
Starting Input Merger (all high) ':audionmi'
Starting Generic 8-bit latch ':soundlatch'
Starting Generic 8-bit latch ':soundlatch2'
Starting YM2610 OPNB ':ymsnd'
Starting Watchdog Timer ':watchdog'
Starting uPD4990A RTC ':upd4990a'
Starting NVRAM ':saveram'
Starting Speaker ':lspeaker'
Starting Speaker ':rspeaker'
Starting NeoGeo Memory Card ':memcard'
Starting SNK Neo Geo Edge Connector (Controller) ':edge'
Starting SNK Neo Geo Arcade Joystick ':edge:joy'
Starting SNK Neo Geo controller port ':ctrl1'
Starting SNK Neo Geo controller port ':ctrl2'
Starting Neo Geo Cartridge Slot ':cslot1'
Starting Neo Geo Standard Carts ':cslot1:rom'
Attempting to parse: ArcadeGuns.cfg
Attempting to parse: default.cfg
Attempting to parse: samsho.cfg
Direct3D: Frame delay: 1, First scanline: 0, Last scanline: 1079, Break scanline: 1079, Delay scanline: 108
renderer::end_frame(), probably missed retrace, entered at scanline 83, should break at 1079, realtime is 0.000000.
renderer::end_frame(), probably missed retrace, entered at scanline 88, should break at 1079, realtime is 0.016743.
Direct3D: Get texture target - not found - 320x224:0
Direct3D: Create texture target - 1440x1080
Exception at EIP=000007feed124189 (not found): ACCESS VIOLATION
While attempting to read memory at ffffffffffffffff
RAX=0002a8b608000008 RBX=0000000000000000 RCX=0000000011738718 RDX=0000000000000000
RSI=000000001173c320 RDI=000000001173c328 RBP=000000000021f8a0 RSP=000000000021f7a0
R8=000000001173c328 R9=0000000000000005 R10=0000000000000001 R11=000000000021f848
R12=0000000011738718 R13=0000000000000000 R14=00000000113789f0 R15=000000001139a540
Stack crawl:
000000000021f840: 000007feed124189 (Direct3DShaderValidatorCreate9+0x164ad)
000000000021f8d0: 0000000002bf2890 (not found)
000000000021f960: 0000000002bf9ed6 (not found)
000000000021fa10: 0000000002bfa42c (not found)
000000000021fa90: 0000000002ba378a (not found)
000000000021fb10: 0000000002ba95b2 (not found)
000000000021fb80: 0000000002badc64 (not found)
000000000021fbf0: 0000000002b6ea56 (not found)
000000000021fc40: 0000000002b6c3a0 (not found)
000000000021fce0: 00000000045f087d (not found)
000000000021fd60: 00000000045bb3a5 (not found)
000000000021fde0: 00000000045be9e5 (not found)
000000000021fe90: 00000000045b6f65 (not found)
000000000021ff30: 0000000004571adc (not found)
000000000022f210: 0000000002c124aa (not found)
000000000022f4c0: 0000000002c80894 (not found)
000000000022f630: 0000000002c80d55 (not found)
000000000022f690: 0000000002c1044a (not found)
000000000022fe50: 0000000008fe749d (not found)
000000000022ff20: 00000000004013f7 (not found)
000000000022ff50: 000000000040152b (not found)
000000000022ff80: 0000000076d459cd (BaseThreadInitThunk+0x000d)
000000000022ffd0: 0000000076f7a561 (RtlUserThreadStart+0x0021)
Yes, because the previous version didn't save the frame delay slider. Next version will fix this hopefully.
After further testing, it seems like the game runs fine when started in -Windowed mode. I can then hit Alt-Enter to go into full-screen mode and even change the Frame Delay Slider. The game works fine with Frame Delay and HLSL enabled, I just have to start in windowed mode then go full screen. Hopefully, this is something that's pretty easy to fix.
Yes, it is.
I guess the fix will be in .206?
