Main => Driving & Racing Cabinets => Topic started by: synonym9 on October 28, 2013, 09:51:32 pm
Hi guys! :cheers:
I have an offer for a
KONAMI WINDING HEAT TWIN
I dont know anything about that cabinet nor the game.
I looks like a poor version of an Daytona USA to me......but for the price of 150€ I think I should grab it.
What I want to do with it:
Since it got no PCB´s and chassis I think I restore that sucker and emulate the hell out of it.
I am not into 360° games, I have another cabinet for that.
I want to play the typical twin games on it like
Sega Rally
Sega Rally 2
Sega Rally 3?
Daytona USA
Daytona USA 2
Ford Racing
Winding Heat itself
Cruising USA
Cruising World
and what you have else.....
Of course I want Force Feedback (who not? ::) ) and I would like to use the original FFB-motors like that guy here in the forum did....as far as that cabinet got FFB.
From what I found out it got it, and when the motors are commercial-grade and as huge as in an daytona USA than I dont want to change them against a small consumer-grade product.
Is that the right cabinet for my plans?
I read that thread:
Arcade Driving Cab / Steering Wheel / Racing / Information- last update
but did not understand all to be honestly.
For my understanding I only can play Daytona 1 OR 2......Sega Rally 1 OR 2...but not both on one system???
Do I need 2 Computers (no problem if so) and do I link them via network-cable?
How strong should the CPU´s be....Motherboards, RAM´s and so on....?
Can two different games play on each side and will the system understand that it shall link up when the same game is choosen on both sides....
.....also....:
since it got no chassis I dont know if the monitors are in working conditions....as long as I dont see them working they are death for me.
On the other hand...they are burned in FOR SURE.....would be the first driving cab without burn ins I had ever seen.
So what kind of monitors?
Since I am from Europe I come easily by SCART-TV´s but I think that game is a 25- or 31KHz system....and dont want to look for super expensive arcade-monitors that are used as well.
What about 100HRz-ers? I saw a video of a guy that used two Loewe 100HRz in a Daytona USA 2....
Mame, Model 2, Model 3 Driving Cabinet (http://www.youtube.com/watch?v=FW3_C-vNhkY#ws)
but he ran them on 480i .....so I also would need a recomendation in that direction...
Is that $150 per? Or for the pair? If the seat can be cleaned and can adjust back and forth, and so long as there is no moisture damage damage to the wood, I say go for it. It is all based on your local economy and availability. I can't get that around here.
I will see it in person after tomorrow.....
As far as I see the wood is ok...but I dont see more than you on the pictures of course.
150 for both, 300 would be too much. I am even inteded to give only 100 as it got now plastic parts....only some wood and two seats....actually nothing what one could not do DIY...
I tend to have a genuine cab though instead of building one myself....
Usually I just see working ones here, but for emulation and modifying that conditions are just perfect....working ones start at 1000€ here.....
Do you have any idea if it got FFB?
I read that thread:
What part made you think that?
They are playable on different emulators, but can be on the same computer.
Sega Rally 2 is playable on Supermodel emulator, but has some annoying graphics glitches.
Of the games you listed, Sega Rally 3 and Ford Racing aren't supported by any emulator.
Winding Heat still has some glitches in MAME.
For most things. Only a limited number of emulated games are linkable.
Look in the Model 2 setup guide stickied at the top of this forums on how it's done.
The model 2 games and Virtua Racing in MAME(using a custom build) are about it.
The next version of Supermodel (Model 3 emulator) will have networking, but it probably won't be released until April.
Keep your expectations low. Most people experience flickering opponents cars.
I'm yet to set up networking, but am building a twin setup, so I'll be getting to it sometime.
This will give you some idea of what processor you'll need. http://forum.arcadecontrols.com/index.php/topic,130988.msg1342049.html#msg1342049 (http://forum.arcadecontrols.com/index.php/topic,130988.msg1342049.html#msg1342049)
If you want to play stuff newer than the original Daytona or play Ridge Racer using MAME, you'll need a top shelf processor and video card. If you're only worried about Daytona and older, you can get away with a lot less.
According to the manual I looked at online, Winding Heat didn't have force feedback. It just had a centering spring.
If you find this stuff confusing, your best bet would probably be to mount a PC force feedback wheel (whole) in the dash.
Browse the Links to Driving Cab Projects thread and you'll see a few like that, including my old cab.
Thanks for the answers so far....
To use a PC-Steeringwheel would make everything easier from what I understood, but are there ones that are really strong?
People say the PC-Steeringwheels FFB is just a joke compared to the real deal...what do you guys say?
My own research is that it got FFB....see the video:
Winding Heat Force Feedback Test (http://www.youtube.com/watch?v=da24oNpXcSA#ws)
When I am there after tomorrow, can you tell me if I feel when it is a FFB steeringwheel?
I think a FFB-SW would not center when the cab is off.....correct?
Also I should feel the restistance of the motor and there should be a sound/hum while turning the wheel...., right?
Ps.: Ferrari F355 Challange would also be a favorite of mine....especially in the link modus....is it possible?
The one in the video definitely has ffb.
The one without it will still return to center because it has a centering spring.
It would be best to look inside, but it might be possible to feel the "notches" of a belt turning a motor.
Not sure how well it would work if you don't know what you're feeling for.
The arcade version of F355 Challenge doesn't work in any emulator. The dreamcast version is playable using NullDC or Demul though.
It sounds like you lean toward the newer games.
You should set up the software on your current computer to get an idea of what actually works and how well.
Here is what was on my last cab:
http://forum.arcadecontrols.com/index.php/topic,130810.msg1339739.html#msg1339739 (http://forum.arcadecontrols.com/index.php/topic,130810.msg1339739.html#msg1339739)
As far as arcade games that play well with a 270 degree wheel go, there really isn't much more than that.
My new cab only adds a few more, but will have around 40-50 pc games
I Bought a pair of sega rallys like this. When they came were so so trashed and useable. The cabinets were cracked and busted beyond repair, Check the back of the cabinet make sure there inst any bracing. The good thing is for 150 you can break down the whole machine and sell it for parts to recoop costs.
I wanted to go down on 100€....but the guy did not want to accept.
I think I will give him the 150€ since I even found 2 Midnight Run/Winding Heat-Steeringweel-asseblies together for under 100€ and two illuminated Displayheaders (that cab misses the header).
By buying that I even setup a quad-cabinet which I would really like...
Unfortunatelly the headers are not quite cheap....80€ for the one and the other one is´nt really cheaper....shipping additionally....
I wait some days and look if the guy lowers the price...if not I pay the 150€
