Main => Main Forum => Topic started by: lokki on November 23, 2004, 03:29:22 pm
Which one is most useful for building a cab? and I guess which one is more practical to have around the house?
Assuming you could only have one, which would it be?
Seems a lot of people use the reciprocating saw for their Cabs.
Reciprocating saw is very efficient and versatile but gives you very little control and precision.
Circular saw is powerful and straight but doesn't allow you to cut curves.
If you could only have one, it would have to be a jig.
I guess I should have also added Which is better for a begginer?
Maybe I'm picturing something different but I can't imagine using a reciperocating saw (I'm thinking like a saws-all) for making a cab. You just have very little control to make a straight cut.
Now, technically, a jig saw cuts with a reciperocating blade, so maybe it's a confusion of terminology.
Variable speed jigsaw is the way to go, IMO. I used a circular for my first panel, and for me, it just cut a little too fast. Even though it was variable speed, it was really easy to cut too much or too fast. The Jigsaw takes a little more time than a circular, but much more control and precision. I got a Makita for under $100 and I've used it to cut ply, MDF and plexi with good results.
I thought the difference between the reciprocating saw and the jigsaw was just the size of the blades. (jigsaw using smaller thinner blades)
This is a reciprocating saw. It's not made for precision.
(http://www.powertoolsonline.net/ProductImages/tools/1201-1250/TL1226.jpg)
Its made for death and destruction!!! And sawing crap that you wont really see.
Everyone must have their tools confused. Maybe this will help:
Reciprocating saw:
The blade moves back and forth (reciprocation)
(http://www.aeg-pt.de/internet/aegptde.nsf/Files/USE980Xx300y200.jpg/$FILE/USE980Xx300y200.jpg)
Saber saw:
Just like a reciprocating saw, but made for cutting on flat surfaces.
(http://www.girr.org/girr/tips/tips6/tool_tips/jigsaw.jpg)
Jigsaw:
Just like a saber saw, but mounted on a table.
(http://www.woodking.com/7010.jpg)
Bandsaw:
Similar to a jigsaw, but the blade is a continuous band that moves in one direction.
(http://www.inlandcraft.com/PIsheets/images/10555.gif)
Circular saw:
A miniature handheld table saw.
Cannot cut curves.
(http://www.tlc-direct.co.uk/Images/Products/size_3/DW62.JPG)
This should help clear some things up.
Remember that many people call a saber saw a jigsaw, but now you know better.
As for the question, I reccoment a saber saw and circular saw for building a cabinet.
If you can only choose one, go with the saber saw.
Trimoor, that picture you posted and called a sabre saw says jigsaw right on it! ;)
I thought the terms were interchangeable, regardless of the mount.
Saber saw:
Why does it say Jig Saw on the side of the tool? ;)
That's funny. The blue one is a saber saw in my book. Black one is a jigsaw.
Buy a circular saw for around $80 & a jigsaw for around $20. Then you're good to go.
I would have to agree with the Jig Saw if I had to choose. A circular saw (or Skillsaw as another name for it) is used to cut straigtht lines. Its good for cutting the straight runs on your cabinet with a straight edge clamped to the workpiece. You could use a Jigsaw with a straightedge and get the same result, just a little slower and you will go through more blades.
Well, I learned it like I posted, but I guess it's more of a cultural linguistic thing.
DeWalt calls the blue one a reciprocating saw, but calls the black one a jigsaw.
As for the black one; from thefreedictionary.com:
saber saw
n.
A portable power jigsaw used to cut straight or curved lines in wood, plastic, or soft metals.
I can see how anyone could be confused with a definition like that.
i would get both a circular saw, and a jig saw if i could, but a circular saw will cut a straight cut, which i can not do effectivly with a hand tool, but i can cut a curve with a coping saw.
How awesome is that straight edge? Looks like it has a heap of adjustment. I will have to look around for one of those before I start cutting.
For
Reciprocating saws, aka Sawzalls, are awesome tools.
They're great for demolition work because the blades are cheap and cut through nails.
They're great for home construction to cut out the openings for windows and doors.
They're great for places where you can't get any other saw blade. With practice you can make pretty good cuts. I don't think I would use one for making any piece of furniture though.
Bob
Xiaou2, so you say that a Rotozip is better than a Jig Saw?... hmmm it makes me wonder, I was going to get myself a Jig.... but now I'm confused... I thought that a Rotozip was like a rotary tool, just like a dremel, am I Right?
*edit* added another question
I would buy the cheaper circle saw and the more expensive jigsaw. I bought a cheap jigsaw and I am not happy with it, but my cheapo circular saw cuts it right up (after replacing the shoddy blade it came with).
I thought the blue one was called a Sawz all. ;)
I cut my whole cab with a Jig/Sabre saw. I had to do alot of sanding on the longer cuts to make the lines. Currently I have a Circular saw and a Jig/Sabre Saw. That's what I would get.
While a Rotozip is a rotary tool... its not built quite the same as a dremel.
That is a name brand of them.
