Main => Project Announcements => Topic started by: Acorn on May 22, 2005, 10:01:58 pm
I have started a new Guncon2 driver, to aid those of us who were unable to use Smog's Guncon2Mouse (http://lightgun.splinder.com). As time went on, it evolved in to more than just a hack, and can now work with any guncon2 compatible lightgun (those working with Smog's and those not due to the "Rolling X" problem).
You can visit the WinGun site at http://guncon.acornscity.com .
Features:
# Support for all Guncon2 compatible lightguns
# Functions just like a mouse and keyboard, only this program is required to run
# Works with your television, no special modifications required!
# Works with arcade monitors with little or no modification
# Lets you use a gun with the Rolling X problem normally
# Support for autocalibration, and gun type detection
# Allows you to tweak settings on the fly to get the gun calibrated just right
# Detects when the lightgun is not pointed at the television and releases control of the mouse.
# Allows you to remap the buttons on the lightgun to different mouse or keyboard buttons
# Two offscreen firing modes, either map offscreen firing to a button or use MAME mode
Please post your comments and experiences with the program here or in the forums on its site.
looks great
but does it work with Arcade VGA graphics card?
rchadd: yes, it does!
With reservations.
You must have the feed from the card at some point inbetween the computer and tv in a format that the guncon2 can read. This format is standard composite rca. My understanding is that there is a "jpac" converter that works fine, but if not, you can build your own circuit as discribed in the excellent guide located at:
http://intruderalert.myarcade.org/GUNCON2.htm
Hopefully this helps you!
how is this different than smog's driver? i guess i need some more info...
My project differs from Smog's in a few ways.
First, Smog is a more learned programmer - and has made a "better" driver. Not in usability yet, but that will come. You should try his before you try mine, unless you need a feature mine supports.
Mainly, my program supports guns which are having the "Rolling X" problem to some extent - a problem where the guns would return bad coords, rendering them unusable with smogs driver. My program implements an AI that can guess where the pointer should be, allowing you to use them while we work out how to actually fix the problem. That is its main purpose.
My program also differs from smogs in that it supports mapping gun buttons to keyboard keys, although again, his will have this at some point I'm sure. WinGun also allows you to shoot offscreen in mame without making mame use a button for it.
WinGun, as of yet, has no support for multiple guns. This will come, but if you need it now smogs driver already has some support for them.
Smog's driver also has a "sensitivity" option - I can't get it to work in his driver, and have no clue what it does, but mine does not and probably will not have it.
If you have any more questions, let me know!
A new version has been released with tons of new features!
Check it out at http://guncon.acornscity.com
It is time yet again for another version! A huge update this time, adding support for:
# Screen Brightening
# Support for multiple guns! Up to 4 guns will now work at the same time.
# Macros!
And tons more! Head over to http://guncon.acornscity.com for more information and the download!
Acorn,
Apologies to start with for asking what is possibly a very stupid question but I have no idea how these things work (but here goes anyway !) :
I have a normal SCART TV and an ATI card. Using a home-made cable I go from VGA to SCART and use some software called Power Strip to set resolutions. Will this driver work with this setup ?
hope thats enough info !
Buks
EDIT : Just checked this site - http://intruderalert.myarcade.org/GUNCON2.htm and it has details on creating a cable for an arcade monitor - do you think that seeing as you use VGA-out (rather than TV-OUT) with an arcade monitor that I need the same thing ?
Just for extra info - the VGA SCART cable HOWTO is here - http://ryoandr.free.fr/english.html (just in case people don't know what I'm talking about !).
Thanks again,
Buks
Unfortunatly, I don't think it will without modification - not because of the driver, but because of the Guncon2 gun's requirements. At some point, the gun must have an input as composite (RCA connector). I'm not sure how you would change yours to work... I'm not an expert on these things, however other forum users will be more knowlagable in hardware areas :) Try posting in the Guncon2 Driver is here (Bacon is tasty) thread in the Main Forum!
Thanks Acorn - I was just editing my previous post to include some extra info so I'm not sure if that helps or not.
i'll go look in the other forum you mentioned though.
thanks for taking the time !
Buks
Wow!
Let me say good job!
I dowloaded the other driver, and then installed yours and it works perfectly. I have two lik-sang guns. I have been playing house of the dead 2 all night long!
Now here is a question. Is there a way via batch file or something similiar where I can turn on and off the auto reload and auto fire? Say one game I want it and one game I dont?
Thats about all I have now... I love it! Keep up the good work.
Chris, I believe you will enjoy the upcomming version :)
In it, support for multiple profiles and hot swapping profiles (based on button presses) are the main new features. You can use it to enable/disable/change any setting or group of settings whenever you press a button!
I may also add a command line switch to disable/enable features - currently the only command line switches are -m to start minimised, and -c to enable configuring of guns not currently connected.
Hey acorn, love the driver. It seems to track/calibrate my guns better than smogs driver. However the guns will not work in Mame32 0.99 (tried several games pointblank, area 51)there is no response at all. Any ideas? With Smogs driver the guns would register in mame and I coudl play but I have to point the guns about 1 inch to the right of my target to actually hit it...
Hey! You are the second person that has reported having this problem - and it worked with the old version (0.2B). If you, or someone that has that problem is willing to get on and work with me (see Contact page of my site for my IM information) I can probably fix it!
It works fine in every version of MAME that I have tried btw, but with my new logging feature its easier to track down bugs that occur for other people.
Sure when I get some free time I will drop you an email (hopefully this weekend I will be free). One other thing I noticed is when calibrating at the part where you shoot at the targets with the gun 1 inch from the screen one of my guns you shoot the first target and sometimes get to shoot the second target, then it just kicks you out like you clicked cancel. Only my Gunman light gun does that. My official Namco Guncon II does not it can shoot every target without trouble and finish the calibration properly.
Thanks, I would appreciate your help in solving this, it is an issue for a few people - but I don't have any guns that are causing it myself so I havn't been able to diag. it.
Note though: I don't have an e-mail listed; IM me - or if you can't, I can provide an online IRC client. Real time chat is usually necessary to solve these problems! Thank you much for your interest :)
A couple questions.
1) Is the calibration needed each time?
2) Anyone know how to configure it so I can use two guns with House of the Dead 2?
WinGun V0.7B has been released! Check http://guncon.acornscity.com for full details - this time, bugfixes and lots of features YOU have been requesting, including (but in no way limited to) support to turn autofire/autoreload on/off with the press of a button!
I think you will enjoy the improved screen brightening as well :)
Chris: No, calibration is not required every time. In fact, you should only have to do it once ever for each gun.
Try "The Troubleshooter" at http://thetroubleshooter.home.mindspring.com/ for multiple guns in games that don't support the second player using a mouse. Some people report slowdown in firing with it, your milage may vary.
WinGun v0.8B has been released. I recently bought a second gun, so I've had a chance to test myself and improve multiple gun support!
A lot of the littler features that have been requested here and on my forums have now been implemented - keep the requests comming!
Check out the new version at http://guncon.acornscity.com !
Acorn,
Buks
Buks - actually you may find your setup works, as with your setup you are not using a VGA signal at all, but a 15.75Khz RGB signal. (unless its some fancy HDTV mode - then I'm not sure)
So the syncs that are coming out your card are the correct frequency for the gun. Also, seeing as you are using a radeon, you will find that there is an option in the driver to output composite syncs. (Display properties->Advanced->Displays->Monitor->Adjustment (I think)). Set this to composite, then in theory your H-sync pin on the Vga card will now be outputting a 15.75Khz composite sync - which is exactly what the guncon needs on it's yellow composite RCA connector.
So you need to connect the H-sync pin to an RCA connector and thats probably it.
silver it will not work, apart the composite you must take in account the polarity and the voltage of the signal that are different between VAGA-SYNC and COMPOSITE-SYNC (that is what the gun expects)
Bucks, it is not a matter of driver you choose. If you use the hardware configuration you are saying you must build a very little circuit to make the gun work. You can find all the infos on my site or intruderalerts one (http://intruderalert.myarcade.org/GUNCON2.htm)
Ah yes you are quite right....
I've noticed that you have contol over the polarity of the syncs in ATI drivers (display/monitor/adjustments or something similar). You would want to set them negative.
As for the voltage yes - VGA syncs are 5V (TTL level) and composite around -300mV I think. I'm successfully sending 1V syncs at the moment from my circuit and that works ok (an error on my part, as composite is 1Vpeak-peak, but the syncs are not). However, I know the chip on the Jpac that produces composite sync does not pull down the voltage. I don't own a JPAC so the real thing may adjust it.
Anyway, I tried the composite out on my radeon for the guncon - and it does not quite work - I can track in the x-axis only (so it probably is not dealing with vertical syncs too well....?)
I experienced same problem with my GunCon1 ... Don't know why but Y coords did not give valid values. I've tried on both composite TV out and VGA with adaption circuit but with no results. I've never had this problem with GunCon2 although.
Do you really trust that program ? How can you know it is doing what it says ?
Thanks for the feedback on that - missed it before. Interesting re guncon1's not giving y values - mine are switchable guncon1/guncon2... I don't suppose you happen to know that if the gun can not detect a Vsync, would it work at all (I'm guessing not).
RE: the catylist drivers and composite sync. Well I know they work on the card I'm using (radeon 9500) with recent catylists as I've actually had the VGA port hooked up to a waveform monitor (I was doing this to compare the output of the VGA to the circuit I was making). Turning the syncs + or - or composite in the displays drivers all worked fine. In composite sync mode it sends the composite sync out on the H-sync pin if I recall correctly...
Composite sync does not work with the circuit I made, you need the syncs seperate. I have not tested using powerstrip to output a 15Khz signal and turning on composite sync and feeding that directly to the guns. Obviously there are voltage differences (5V in VGA) but as andy warne had the circuit working with 5V Hsyncs it may well work. I'll try and get round to giving it a try sometime....
It could work, if you feed the 5v to that micro you showed on the other thread. Feeding directly to the gun It could or it could not ... On my gun it does not.
I don't know why you need it, but if you have a composite sync you can separate it with an Lm1881.
Smog, Acorn..
is there a reason why there are 2 "competing" guncon2 implementations for windows ? Can't you guys get together and combine your effort?
just wondering...
Joe: It was tried, earlier, but fell through.
As we can see with the most recent release, competition is a good thing. You can choose the best, and the best is brought out rather than having to settle.. or only take what is thrown your way :P
For both authors this is a "pet" project. I don't think the guncon2 drivers are the only projects either of us is working on at the moment as well.
OK.... Sorry this is long... but I want to get all of the pertinent details in here...
I'm REALLY close to having my GUNCON2 set-up work.
Here's my set-up:
I am using two Scorpion 3 guns.
I have an NVIDIA FX 500 graphics card.
The VGA output goes to a custom cable that allows me to tap off pins 10 (SGND), 13 (HSYNC) and 14 (VSYNC). These are then fed into the custom circuit here:
(http://img263.echo.cx/img263/9388/circuit0rm.jpg)
...to generate a composite sync signal.
I have also built a circuit to provide the Scorpion 3s with +5v and +9v through a pair of hacked PS2 extension cables.
Everything hooks up nicely. I have a clean picture on the screen at either 800x600 or 640x480 resolutions.
The driver recognizes both guns.
I thought I was home free... but not quite.
When I try to calibrate the guns, the cursor "wraps" across the bottom and left edges.
The top and right edged seem to be "hard"... the gun recognizes them fine.
The left and bottom edges, however, are not recognized properly.
When the gun is at roughly the center of the screen, moving from far right to left, the cursor is already on the left edge. If I keep moving left, the cursor wraps to the right edge. By the time I get to the left edge, the cursor is near the center of the screen.
Similarly, when moving from top to bottom, as the gun reached about 3/4 way to the bottom of the screen, the cursor wraps off the bottom, back on to the top, and continues to about 1/4 way down by the time the gun reaches the bottom of the screen.
When the gun is tracking the cursor in a usable area of the screen, it's PERFECT... no jitter, no unexpected movements / jumps.
I feel like the circuits I built must be working... or I wouldn't be as close as I am.
Seems like a (probably obvious) calibration issue.
Anyone else had this problem, or know of a solution?
You've entered a rather grey area on these guns that I've come across but have no time to test (and won't for a while).
Basically, although you are using that circuit to make a composite sync, you are still running at 31KHz. (Unless you are outputting something fancy via powerstrip, but it doesn't sound like you are). Most of the time I've tested this, the guns go crazy and can't track at all (I have scorpion3's too).
I'm guessing - and its a large guess - that the vaguely good results you are getting is because the guns are in 100Hz mode. I'm amazed it works at all, as they are designed to recieve a 15Khz signal while looking at a 50/100Hz tv.
The only success I've had with what you are doing is: 1) outputting a 15Khz signal from the pc directly, using powerstrip. You will need a monitor that can cope with this though (which a standard VGA monitor can not)
2) Builing a circuit that converts the syncs from 31Khz to 15Khz and feeding that to the gun. I used a chip off a Jpac which can be bought seperately from Ultimarc.
There is more info and a wiring diagram on both the driver projects I believe.
However, it is interesting you have partial success as it is - have you tried selecting "rolling X" mode and calibrating with that in the driver?
Also - when you say no jitter - do you mean none at all? I always had more jitter than I expected, but never had anything to compare it to....
I have spoken to Andy at Ultimarc. He agreed that his JPAC "small chip" should work in my situation; also suggested (as you did) that I need to "divide the sync in half". He has posted a new diagram for a circuit for the chip on his web site:
www.ultimarc.com/images/guncon.jpg (http://www.ultimarc.com/images/guncon.jpg)
I have ordered his chip, and will build a circuit for it when it arrives. That being said, I would be interested in knowing / learning why mine isn't quite working, and how I might be able to change it to make it work.
I am not doing anything special with the PC output. Just setting resolution with the nvidea driver to 800x600 @ 60 Hz refresh.
I have tried setting rolling X and calibrating; it is no different.
I also sent Acrons a file from his driver log; he said the behavior was not something he had seen before; not like rolling X. I posted that dump file from the gun on his site in the support forum if you want to take a look.
As for the gun tracking, it is VERY smooth in "following" the gun. by that I mean it moves at constan speeds that vary with, and are in the same relative direction that the gun is moving. No jerkiness... at least on an all white screen.
That being said, because of the wrapping, the cursor is only near where the gun is actually pointed in the upper left area of the screen.
Someone (I think you) mentioned the signal not being "terminated" by the guns... could this be the problem; If so, how would I terminate it?
As you may have guessed, I'm pretty adept at building the circuit, given a plan... but I really have no understanding of why / how it does what it does.
I'm willing to experiment on this; If I en up going with the JPAC route and the circuit I put together would be useful to someone else (for their own use, if they can't build it thenselves) or for research, I'll work with them.
The significant point here is this:
Even though you are sending a composite sync, you are sending a horizontal sync signal which is at 37Khz. The gun was designed to work at 15.7Khz. I would expectic highly erratic behaviour - if any behaviour at all - using this.
Not sure why it nearly works for you - could be something to do with you gfx card or your monitor.
Termination - whenever a video signal is connected to a peice of equipment - say into a monitor - it is connected via a resistor that is almost 75Ohms (In Tv world anyway). This is called termination. It effects the level of the voltage coming in. Incorrect termination say on a monitor can result in no picture, or a picture thats horribily bright. With my bodge test circuit I found that feeding the Hsync directly to the composite input of the gun was erratic until I plugged the passthrough of the gun into a tv and turned it on. However, I would not expect this to be an issue as it was probably related to how I had set my circuit up.
I notice Andy has modifed the circuit slightly, grounding a couple of extra pins - thats interesting, as I was having issues with the pull-down level when it was blanking out alternate syncs ( I built another flip-flop circuit to clean up the output) - this might improve things...
so how is the quality of the gun so far? does it work for anyone yet, so that you can just point and click? it seems like everyone is still having problems...
If I use mine against a TV set, it is every bit as accurate as my ACTLABS guns. They are definitely "point and kill".
PLUS, with the GUNCONs, I can use two (or 3 or 4) guns at once, AND have SW control of various calibration profiles, rapid fire, and auto-reload.
Once I get these working with my D9200, they will be FAR better than the ACTLABS.
Given the cost of the guns, and the cost of building the circuits to make them work, it'probably still a bit cheaper for the GUNCONs also.
My opinion is the driver is excellent. I've had a fair few problems setting them up (and still have) but most of the time its been down to me not reading the faq and readme..... DOH ! I never do read manulas though :)
Games like Duck Hunt in MAME track very well. Probably not 100% accurate but pretty close (for my setup anyway). Other games just don't seem to work but thats usually because they have a dark background. Flashing the screen is supposed to fix this (I think) but I've spent more time on the games that work so maybe its just that I havent configured stuff correctly.
I'm using RGB-SCART to a Daewoo 17" TV. I've had problems with any resolution other than 640x480 but the graphics on GTA:SA look excellent with all the settings ramped up (not a lightgun game though so off topic... ). This is something to do with overscan but seeing as I play games too much I have no idea what this means or if I can fix it :)
Just a quick note, my domain (acornscity.com) expired. 5-7 years ago I registered with a company that was good at the time, but isn't anymore. They want $20 to renew. I've started a transfer to 1and1, but it may take a while. In the meantime, the site is still up if you care to go there - http://12.219.44.141/guncon . This is hosted on a computer at my home, since the one 1and1 is hosting constantly references acornscity.com (this one is usually my test site). I think it is fully functional.
I have also registered www.guncon2driver.com - it will be available in 2-3 days, and become the "official" domain shortly after.
Sorry for the confusion!
With reservations.
I know this thread is old, but that link seems to be down. Any idea where I can find that guide at? Thanks!
is there a place i can get this driver?
I asked here a while ago and nobody replied so i had to use the EMS topgun driver... it works well, try that
Well that sucks, i need his driver, EMS won't work with the Namco guns... i assume
I was thinking of getting some of these for an upcoming project, I got to the end, and saw that it was gone, so I checked the Wayback archive and grabbed the driver, I have attached it below. I hope this helps. A question, are these the best guns for MAME, or are the ACT labs the best? I like the possibility of switching from a TV based display to a real arcade monitor, and not needing to replace both guns.
Here is the last page archived:
http://web.archive.org/web/20080213100641/http://www.guncon2driver.com/
I always try the archive first, sometimes .exe and .zips get archived too, that was the case here. I just zipped the .exe, but if you are weary of .exes like I am, you can open it with 7-zip. :)
Here the version info from the release.txt:
--Version Log:--
Versions are counted like this:
A = Alpha
B = Beta
D = Development
R = Release
0.0X will be the alpha releases
0.X will be the beta releases
0.XX will be development releases, and eventually X.XX
X.X will be releases
V0.82B
Fixed a critical bug with multiple guns and the new by USB port connection code.
Fixed a couple other trivial bugs, like one with the input que (was executing one "blank" instruction every loop. Had no effect on gameplay), and insta-timeout on program start (again had very little effect, since the guns still all reconnected).
Changed Quick Calib so it will work when used from the key select menu directly under button config.
Spent the day researching and trying stuff out, implemented a system that shouldn't depend on the usb interface you are connected to. Woot. If you have old INI files, you don't need to replace them, but you might want to recalibrate to take advantage of this feature.
V0.81B
Fixed a critical input bug that was preventing extended periods of play.
Fixed the screenflash issue where the guns that wern't primary wern't flashing when both players fired at once. Also with this fixed the issue where in drag/autofire mode guns that didn't have their triggers depressed could turn off the flash.
Decided that checking for updates every time you entered the menu was too annoying. It only checks when you start the program now, or go into about. I may change this back or to something else depending on feedback.
Corrected one "Select Key" issue where L was being mapped to I.
V0.8B
Added a new interface for mapping buttons to gun keys. It is a visual representation of a keyboard, useful for those of you with no keyboards connected or those having trouble with the "Get Key" function. Includes mouse mappings.
Under macros, added the ability to switch quick calibration on and off (with a gun button press). This allows you to recalibrate using Edge Calibration at any point in time (even in game!).
Added support for "Mouse4" and "Mouse5". But before you get all excited, mame doesn't seem to recognise them (though windows does). Remember any game that supports edge clicking (like Area51) will work with Click Edge for the second gun's reload now, and most other games support mapping reload to whatever you want.
Added a hidden (no interface to change it) option in WinGun.ini. Allows for all guns to track. Doesn't always work. See readme.txt under "Editing the INIs".
Proper support for command line parameters. This is mostly an internal thing - but the side effect is you get more of them :) Also, you can use multiple parameters now.
Also for command line support added single instance checking! If you open a second copy of wingun, the command line parameters used will be passed to the first copy and the second copy closed. Woot!
Added command line parameter -loadprofile (or -lp). You can use this to load a profile for any gun by gunnum, and profilenum or name! See readme.txt user "Command line parameters" for usage information!
Automatic version checking! WinGun will now check to see if the version you are running is the most recent, and if it isn't, display a balloon tooltip (which you can click to get information about the newer version). This feature can be disabled under the new about screen, and requires an internet connection to work at all.
Where it made sense replaced the nasty messageboxes with cute balloons. Woot.
Gun connections are now mapped to a USB port - meaning if you have more than one gun connected, and reopen the program, the guns shouldn't reconnect in a different order. It also means that you can have only one gun plugged in, and if that gun is using the settings of Gun #2, Gun#2 can be enabled when Gun #1 is not. May sound complex, but it fixes a lot of the "weird" issues some of you have been having with multiple guns. Note about this: Your guns should be connected to one interface to make the best use of this possible. See Readme.txt under "USB".
Output of mouse and keyboard events redone to a que system. Some disadvantages, but many more advantages - mostly for people with 2+ guns. They should work much more as expected now, being able to test myself was a huge help! Overall, multiple guns work 100x better.
Click Edge now performs whatever is assigned to Main Trigger - at the edge of the screen.
Threads terminated in a different manner - people with 1 gun shouldn't end up with wingun reporting 2 connected guns anymore.
Installer added. Fun. Pretty. Includes uninstaller. And shortcuts.
V0.7B
Singlefire mode fixed, trigger detection fixed (was a simple line of debug code left in, sorry to any it affected!)
1/3rd of the offscreen shot detection secondary AI enabled. This is not really useful if Screen Brightening works for you, but if it doesn't it should help a little.
Changed the way the screen flashes based on the current gun mode (single now flashes almost instantly, drag still stays bright for as long as you hold the trigger down)
MAME Mode was renamed "Click Edge" - a lot of people were having trouble understanding that "MAME Mode" for offscreen shots was just a button press with an associated location (the edge of the screen). Hopefully this will help.
Added the ability to map any button to "Click Edge" (Use Scroll Lock when getting a key)
Added button presses to Data.txt logging. Fixed a bug in data.txt logging, you can now log all guns at once and it will work
Added the ability for users to modify the time between autofire shots, and the number of shots between an autoreload. Autoreload is now mapped to whatever offscreen trigger is mapped to as it should be, instead of being limited to "mame mode". Yes, it will run a macro even.
Added support for multiple, loadable profiles!! Along with this comes with a profile manager, and the ability to create and edit profiles from in the UI. A profile contains (up to) all settings for a certain gun, as well as the global settings.
Profiles are now hot-swapable! This means a couple of things: First, you can set a button on your gun to cycle through a list of 2 or more profiles, loading and activating all the settings in each profile as you switch to it. Second, you can create a kind of "Shift" button. Instead of cycling though, it loads a second profile only for the duration of the button press!
Added more console logging, in autocalibration and other places (easier to see problems).
Added the ability to define which buttons are rapidly fired in autofire mode, and which ones are only pressed once in autofire mode.
Fixed a couple of existing "quirks", such as not being able to enter a negative number in the centering boxes.
Fixed many bugs, such as the "spaces in ini" bug that was causing crashes after a while.
Updated what I do if "Hide Mouse" is checked. Cursor is reloacated to the bottom of the screen every time a gun fires when it is on now - slightly better at making it look hidden, but without locking the real mouse out from being used.
Screen Flashing has been improved! If your card supports it, it should work almost flawlessly now - even on complete black. Note that for ATI, Radeon 9600+ has been confirmed to work, and for Nvidia, TNT2 and above is confirmed to work. Other brands or older cards may or may not work.
A new fun "fun feature"; Gun Rating! Take the test and see how well your gun scores. This is in very early stages, and will become more reliable as time goes on.
V0.6B
Unfortunatly I did not keep a log of the changes, as I was not planning at the time on releasing further versions. One could say that WinGun has became an entirely new program in the meantime! I will try to list the main changes below:
Support for multiple guns! Up to 4 guns will now work at the same time. Huge, huge thing to get working.
Screen Brightening; causes the screen to flash bright when a trigger is depressed. Very requested, but doesn't work on all video cards.
New autocalibration routine; includes easy to read on the TV instructions, and a new shoot the targets phase.
Updated and further completed interface; includes a tray icon, and many more options. Redid so all menu's will fit on a 640*480 screen.
Completely redone connection method. You can connect a gun and have it detected without user interaction, and if a gun stops sending data WinGun should attempt to reconnect it. Along with this change came many other connection code changes: it should be much more reliable now, and account for many more error situations.
Added an "information" screen that is invaluable for debugging and troubleshooting. Added tons of console output messages for use with it, all timestamped and neat. Added the ability to log console output and gun output to files.
Added support for basic macros in Button Config. Press Ctrl-Alt-Del, click in a specific location, etc. Up to 20 events, which can be delayed, told to execute multiple times, etc
Added Hide Mouse option
Redid, improved almost every internal function. Over 80% of the code for WinGun is different from 0.2B
As noted, did and changed way more than I can possibly remember.
V0.2B
Interface for configuring the buttons. (woot!)
New calibration routine, some tweaks to calibration.
Fixed just about everything I know of that could help the rolling x problem. This is as good as it gets, until we solve it.
Redid the interface.
Added singlefire firemode, and option to switch in the interface
Added the ability to switch between normal and rolling x modes manually in the interface
Added auto-fire and auto-reload. Auto-fire is best not used in duck hunt, I've found.
Fixed a bug where Buttons A-C wern't being read in from the INI and resorting to using the defaults.
Cleaned up code, fixed other random minor bugs
V0.1B
First public release.
Fixed a couple of file write bugs, added in about 10 error messages, and took out some debug code to make ready for a public release. Please note that the interface is brand new, most of the program was written using a console to output errors. It will be improved in the next release.
V0.02A -
Added ini file saving
Added this readme
Changed the routine for finding normal/rolling gun mode. The previous one took 30 seconds for guns that sent information at a slower rate.
Fixed a couple of bugs
V0.01A -
First "release", only tested by one person other than myself.
Awesome, thank you for that.
From what i have found out thus far, I have tested both Smog's Guncon2 driver and the Wingun Driver.
With the official Namco guns:
Smog's Guncon2 driver:
Doesn't track, has rolling x issue
Buttons work in windows, doesn't track well at all (rolling-x issue)
Buttons work in Mame .129
Wingun:
Tracks perfect
Works great in windows, buttons work and register
Buttons don't work in Mame .129
From what i've read the buttons will work in Mame .104, but you can't use 2 lightguns, since it won't track them seperately, so gun2 will shoot where gun1 is sometimes and gun1 where gun2 is.
I ordered some generic Yobo Guncon2 for $22 shipped that i'm hoping to test out this week.
I was considering the ACt Labs, but at $100/pop that just sucks.
I've used the LCD topgun that everyone raves about, but i personally don't like it. YOu have to stand 2-3 times the distance between the infared bars, so on my 27" tv in my arcade, i had to stand about 4-6 ft back before the guns would work, but the light bars are just ugly, there is no way around that.
I like the TV based lightguns because no lightbar and they work great. Just a matter of getting the right driver and mame version.
NP, glad to help.
I have read alot of posts on different light guns, but they are all kind of dated, do you know if there are anymore choices for us yet, other then ACT Labs (I hate the fact they have different models for s-video vs vga), Guncon (I hear there are issues with dual guns, and require some hardware to make them work with vga monitors and don't work in the newest MAME), and LCD guns (They seem like they work for both vga and s-video, but need light strips like the wii, and it woud be nice to know if those light strips work well behind tinted glass, I wonder if it would solve the sensitivity and ugliness issues)
I wouldn't mind paying for Act Labs if they combined the vga and composite together, but since I probably won't keep the tv I use and switch to a multi sync arcade monitor in the future, I'm going to have to wait.
I wish someone would built an interface so we could use actual dual arcade guns on either a s-video tv, or a vga. Even though the real ones are expensive, I like the idea of them being authentic. Like the OptiGun adapter, but able to do S-video.
http://www.nanotechent.com/opti-gun.php
I got both my official namco guns working with mame .129 last night. I'm using the wingun driver. Took me quite awhile and lots of trial and error. But i'm able to use both guns at the same time and everything is working great.
Gun 1 is mapped to mouse1/mouse2 gun2 is mapped to mouse3/mouse4.
That's great, are they guncon 2 or 3, could you maybe post pictures of the ones you have.
I checked ebay, but not quite sure which ones are the right ones.
Also, could you maybe post your mame.ini, so I can get a head start if I can find some?
Gun 1
Tigger=mouse button 1
clip button=mouse button 2
Gun 2
Trigger=mouse button 3
clip button=mouse button 4
In mame 0.129
# CORE INPUT OPTIONS
coin_lockout 0
ctrlr
mouse 1
joystick 0
lightgun 1
multikeyboard 0
multimouse 0
steadykey 0
offscreen_reload 0
joystick_map auto
joystick_deadzone 0.3
joystick_saturation 0.85
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device keyboard
adstick_device lightgun
pedal_device keyboard
dial_device keyboard
trackball_device mouse
lightgun_device lightgun
positional_device keyboard
mouse_device mouse
dual_lightgun 1
I have the Official Namco Guns. I also have generic Yobo brand ones on the way.
I'll take some pics.
Here are some pics.
I run s-video from my video card to my TV, and then i have the guns hooked up to the composite output on my TV, so i'm not breaking my svideo at all, and killing that quality, just using the TV's own output for the guns signal.
I just bought these for $15, for both, new, they do have a usb plug and are guncon ps2 compatible, so hopefully they work as well as yours.
Thanks also for the config, I'm sure it will save me some time and frustration. I was thinking of the same thing with the s-video, I'm glad to see that is does work. It makes me think that the arcade video card from ultimarc that has both vga and s-video might work if I used both of those outputs mirrored (one to a real monitor and the other to the guns, it must be the driver that flashes the screen, I thought it was injecting it into the s-video signal.
I'll let you know my results.
I just bought them from here. Used paypal, so if the site is bogus, all they get is my $15 ;) :P
http://www.gameliquidations.com/StoreFrontProfiles/DeluxeSFItemDetail.aspx?sfid=47611&c=0&i=16812247&ai=y
If they work well, I might try to stuff their guts into some happ red/blue shells. ;D
I have those exact guns on the way already shipped out yesterday. It was $30 on ebay, but $15 for both on their site. :) I ordered them before i got my namco guns working, but i want to test those as well, since they have recoil on them. I might hook up one of each and see how they compare for accuracy and stuff. The namco guns are supposed to be some of the most accurate ones out there.
I have a Nvidia 6200 that i'm using. I might track down an ATI with component output since i have that input on my TV as well.
Unless you are using an arcade monitor or a PC monitor, i wouldn't see why you would need the arcade video card from ultimarc.
My friend just ordered the wells gardner monitor from x-arcade, i'm curious to see if it's worth the extra $400 over the 27" TV i bought, i have a 27a60 from toshiba, which is the best 27" they made at the time, and has power return, so the best of the best as far as a TV is concerned, so i'm curious if a arcade monitor is really worth the extra money. Very curious.
I have the scenario where I have an arcade monitor
I've got an upright cabinet fitted with guns- ex lethal enforcer. I gather the guns will not work with a PC and so I've also ordered 2 new guns from gameliquidations
So what you are saying is that I will need the arcadevga card? I was planning to use a J-pac card as my PC interface but I don't think I understand the interface with the video yet. As I understand what you are saying the guns need to be in the video feed?
How would you recommend hooking them up ?
wingun is available from
http://tinyurl.com/d37kj4
I'll host it for at least the next 12 months
Generic guncon guns seem to work well with Wingun driver, smogs driver didn’t work so well, really haven’t had any luck with that driver at all. All my luck has been with the wingun driver. The generic guns tracked fine with the smog guncon2 driver, however, I had some issues with button mappings. I have to turn dual_lightgun off for smog’s driver to work in mame.
Generic guns work fine just like the namco guns did with Wingun, track fine and button mappings worked well.
I also took a few minutes and did some soldering to wire up the vibration feature on the generic guns, pretty neat. Kind of a nice touch.
swamprat96,
You have the perfect setup for the Opti-gun adapter.
From the way it reads, it also acts like a 24-input ipaq/key-wiz, plus it says it has a built-in amplifier for audio.
It looks like it was designed for your exact situation.
There were supposed to be reviews of it in the review forum, but it never seemed to happen, so I don't know how well it works. I would try to find someone here that owns one and see how well it works.
If I had a real arcade monitor and real guns, that would be the way I'd go.
You would need an ArcadeVGA card though, but you would need that anyway.
So with the opti-gun, arcadevga, and a computer, wire it all up to your existing arcade cabinet, and your done. In theory.
chrisnack, I got my guns last night, took about an hour to get them to work.
I have both working (minus the recoil), but they are frustrating at best.
I have been reading the post:
http://forum.arcadecontrols.com/index.php?topic=48982.0
It's on LCD topguns, I am only to page 22 of 43 so far. It's like a novel. "Will the heroes ever get their guns and led strips to work? Will EMS finish their drivers?" I guess I'll have to wait till I finish reading them all, as I don't want to spoil it by skipping to the end.
So far it seems that style of guns might be better suited, but like I said, I haven't gotten to the end yet.
I have the same issue as most of them (after the hardware, the software they use is the same as with guncons), first gun tracks all jittery, second only tracks when fired (XP limitation?). Calibration sucked for two, until I did them one at a time (plugged in that is). The on screen crosshairs in MAME are about 2 inches to the left (but I have the diff from silverfox to fix that, even though those source changes are supposedly in newer releases of MAME that I have already). At first the gun didn't work at all, then they tracked but didn't fire (then I used mame32 to set the necessary settings in mame.ini), now they just have dead spots here and there, lag sometimes, and they REALLY hate dark areas when dragging (lightgun :P).
Hopefully their LCD topguns end up working out, because guncons SUCK.
Where did you ever find Smogs drivers? I'd like to try them, but his site is long gone, and it didn't get archived correctly.
Why no one (EMS) ever wrote an actual driver that will let you choose whether to emulate a mouse or a joystick is beyond me. I just wish the devs for mame would have put some more work into a better interface for all guns in general, why emulate lightgun games so perfectly, only to have them be used with a mouse or barely work with the only lightguns available for the pc. I'm talking about a two part solution, a simple driver so the guns get detected in windows, that adheres to a standard needed for MAME, and then have mame deal with the calibration and whatnot. It seems like the real issue is with the fact that all these current drivers try to make the guns into a mouse, and since windows doesn't like multiple mice, it seems destined to fail from the start. I should be able to point a gun at the screen all day, and have it do nothing, while in the background the driver is registering what my resolution is and where in that resolution it last saw my gun pointed, just waiting for MAME to ask about it. What good it speed sacrificing, anal-retentive, exact emulation that you can't play? :soapbox:
are you using the guncon driver or the wingun driver?
what guns do you have?
Gun 1
Gun 2
Hi, Would you be able to tell me where i input these settings. Is it in Mame or in the Wingun Driver?
Those settings are in the wingun driver itself
I'm with MacGyver - I'm over these guncons. Maybe the topgun 2 has the distance problem but if they are accurate I'll use them. I have 2 on the way. Like chrisnack I've spent too much money on these guns so if the topguns don't work well I'll either convert it back to the original jamma lethal enforcers or a standard mame cab.
I've tried everything to get the guncon2 guns working. Same as chrisnacks guns and using his ini settings. Difference is I'm using an arcade monitor.
Setup is 26" nanao chassis with mitsubishi monitor 26". Chassis has been overhauled by Joey at Jomac. P4 pentium with 1 gig ram running soft15Khz through an ATI Radeon 600. J-pac is the interface to the cab. Generic yobo guncon2's connected to the second port on the ATI card. Resolution on both video outputs is 640x480. Mame129u5 with MKchamps hiscore diff and no nags. Using the wingun driver - but have also tried smogs guncon2 drivers
I have both guns working in Mame129. I get varied results in different games- Lethal enforcers being the most accurate and lethal enforcers 2 the least. Off screen reload does not work on either. Area 51 is hit and miss. Bang is also hit and miss. Duck Hunt is so far out its unplayable. and so it goes on.
I have calibrated both guns in wingun many times. I've tried calibrating them in the games as well. Basically I can't get more than about 40% accuracy. They just don't track worth a damn in mame.
I really hopy Andy at ultimarc gets a decent product out for light guns because right now I don't think there is a practical solution in emulation. :soapbox: Act Labs are too expensive and have accuracy issues. The optigun adaptor is very pricey and unproven - I have not found anyone who has used it. Topguns work better but have the distance issue and a little flaky near the edges. Guncon2 just does not work - on an arcade monitor - in my experience. The ONLY person I've heard have success is chrisnack- and thats using a brand new CRT TV.
Very disappointing - I'll post my results with the topguns late next week probably. I've avoided the wireless model as it has new issues apparently. :banghead:
My TV isn't brand new, it's a 27a60 from 2002 i believe.
I can't speak to using them with an arcade VGA, i don't know how the signals line up. I've used them on a couple of different tv's without issues using the Wingun driver.
But yeah, i seem to be the only one who has gotten them working.
My buddy is going to try to get them working on his arcade monitor. So we'll see how he fairs.
Hey chris let us know how he goes. I'll hang onto the yobo guns incase he works out something I missed
For the record I didn't use the ArcadeVGA card - I used a standard ATI card with the soft15khz software. I could not get the arcadeVGA to boot with the donor PC as it has onboard graphics
Topguns have arrived and tracking problems are solved. I mounted the led bars top and bottom of the 26" monitor and I've got about a 90cm shooting distance. Still trying to fix off screen reload on lethal enforcers but I'll make a new post for that.
So thats it for me for Guncon2 - the yobo guns will be sold off along with the adaptors etc. Been an expensive learning curve and I still think that if Andy at Ultimarc can come up with a good lightgun solution he'll have a winner. I'll tolerate the topguns until then but they are far from perfect- I agree with chrisnack that the distance issue is not good and the guns don't look robust. However at least these guns track accurately!
I apologize for bumping this old thread. But I have a quick question.
Is there any way to get this working under Windows 7 x64? I have to dual boot between 7 x64 and XP pro on my cab. So if I want to use the gun I have to boot into XP.
Please let me know.
im glad you brought it up.. i have not read most of this information before.. im guessing this is mostly crt.. which is already showing its age..
interesting read :)
chris.
interesting read :)
chris.
Yeah it is for CRT TV's/monitor and arcade monitors only. I'm using it on a CRT TV and seems to work rather decently. Just hate the fact I have to switch to Windows XP just to use it :soapbox:
You've got a GunCon working well enough with MAME? What version are you running?
I'm running Mame 141U1 I compiled it using Headsoft's Mame Compiler x64 but I had to edit the input thingie and change the force controls from 0 to 1 then compile. This should allow any device that's emulating a mouse such as the Wii mote or Guncon 2 to work.
Which input thing? I've looked through emu/input.c, input.h and inputseq.c and none have anything like force controls..
Edit: Nevermind, it's in osd/windows/input.c and the label is force_directinput
I have a pair of GunCons that are recognized and seem to work- but I don't have a CRT to use to test them with!
I apologize for bumping this thread again. But I have a quick question. I'm running S-video from my PC in my cab and I can't figure out for the life of me how to get the Guncon 2 (Namco one) working with S-video. I read in another thread somewhere that someone hooked up the composite single from the Guncon2 into an empty composite input on the TV and it worked. I only have S-video in the back of the TV and one composite jack in the front. I tried that but it didn't do anything. Any ideas? I'd rather not spend any money on an Aimtrak yet or anything else. Please help! :'(
No one knows? I know a lot of people have moved onto the Top guns,Aimtraks etc.. but there are still people like me who use the Guncon2.
Use a s-video to composite cable. Then hook it all up to your tv. It's how I had my pld setup and worked fine. Cheap and easy fix. Something like this:
http://www.amazon.com/StarTech-com-SVID2COMP-S-Video-Composite-Adapter/dp/B0000BZ2WC/ref=sr_1_2?s=electronics&ie=UTF8&qid=1307365786&sr=1-2 (http://www.amazon.com/StarTech-com-SVID2COMP-S-Video-Composite-Adapter/dp/B0000BZ2WC/ref=sr_1_2?s=electronics&ie=UTF8&qid=1307365786&sr=1-2)
Thanks for the reply! I actually have a few of those. The only problem with that is I'll have no way of connecting the S-video cable from the PC to the Guncon2. Any other ideas? There were some links on how to tap into the S-video single but those links are long dead :'(
PC to s-video to composite to guncon to tv.
Ah ok. I have a few of those things laying around like this http://www.svideo.com/svrca1in.html (http://www.svideo.com/svrca1in.html) but I'm not sure how to about hooking them up. I even tried a switch box and it didn't work :(
*Edit* I want to do this using S-video connection on my TV. I don't want to convert S-video to composite and use the composite input on my TV. I have my composite inpu ton the front of my TV not in the back which is kind of strange. So even if I wanted to use composite input I'd have to use the front and it wouldn't work as my bezel wouldn't go on then.
Ok, I tried hacking an old s-video cable of mine I had laying around never used. And I get a black and whit epicture. Besides that the hack worked. But I can't figure out why I'm a black and whit epicture any ideas? This is driving me nuts! lol
Anyone else know? This is driving me mad :'(
I guess I don't understand your issue. If it's that you want s-video quality then I can't help you, but using the s-video to composite will work. If that's all you want, is to use your guncons, that's the way I have done it. I can't remember exactly how to hook it up on the top of my head but basically convert the s-video from the pc to composite, hook that in whatever way it runs to the guncon, and then run that to your tv. Nothing wrong with the quality and it works great.
*edit* I just saw your edit. Getting s-video to the tv might be difficult. I would suggest googling to see if they made a s-video cord for the guncons or just convert the signal back to s-video. Not sure if that will mess the image up though with all those cords.
Yeah, my TV only has composite in the front not in the back. So if I were to hooked it all up through composite I wouldn't be able to put my bezel back on because of the jacks. I guess I'll try hacking another S-video cable. It worked last time though I kept getting a black and white picture for some reason.
I apologize for what it perhaps a SUPER NOVICE question, but these drivers will allow me to use GunCon2's unmodified (*stock) with MAME ?
Simply install the program/driver, plug the guns in via usb, calibrate and reprogram the buttons and I'm good ?
I don't need to alter my guns and add Aim Traks to make them playable with MAME ?
Yes these drivers will most definitely let you do that! If your using a CRT monitor or arcade monitor you'll have to create some sort of hack cable which I'm not sure how to do. Also I don't think these drivers will work with Windows 7. I'm using Windows XP SP3 on my cabinet and it works perfectly. I had hack an old S-video cable to get my gun to work with S-video but it worked.
AMAZING !
Had a rather busy Sunday today and I was unable to accomplish my goal of testing this out.
But I look forward to doing so this week.
I have a PC video card with composite video out and I plan on testing on my TV.
When I complete the intended project I'll use a SONY PVM monitor I have.
Anyone have any tips or tricks, suggestions for which driver I should use ?
The plan is to use this on a MAME cabinet that also features NES, SNES, and really most console gun games.
Looking forward to trying this out tonight.
Really hoping (FINGERS CROSSED) this works well with MAME v.124
And I hope I have no issues using two guns !
Thanks all
My project : http://youtu.be/eWbLU3uZeGg (http://youtu.be/eWbLU3uZeGg)
I should add I plan on using these (this driver) on a PC with Windows XP, a CRT monitor, and MAME v 124 with MaLa.
I'm looking forward to testing this.
Got this installed and started to configure.
It's a real pain in the a**.
Using a TV my resolution is only 800x600, so I can't really read text.
I think I'll need to set it up with the TV and PC Monitor @ the same time.
Gun2 is working ok, gun1 not so much.
Even gun2 the calibration and movement is way off.
It appears to be stuck in the middle.
Going to try Smogs driver.
Can anyone tell me, do I install the driver then plug in the guns ?
Tried Acorn's driver but it kept getting stuck in the calibration mode. It would not move beyond that step, I waited several minutes.
I've moved onto Smog's driver, but it wont see the guns.
When the guns are plugged in they install via windows, but that's where it stops.
Am I missing something ? Any tips, tricks ? Help ?
Hello,
just trying to get my guncon namco np106 to work with wingun on my mj25.. perfect :)
but one question:
looking for great guns with recoil like "desert eagle" but it seem there have just normal Ps2 port, but compatibility with guncon2.
So does it work with an USB adaptator? ;D
thanks !
Edit:
Model 2 emulator issue, can't reload even with right mouse emulated on various button. Any idea?
Any current links to smogs driver ?
Having no luck finding it.
i've installed joytech sharpshooter 2 fine but the gun is not detected :(
I try wingun with my w7 x64 and not install correctly and not recognize my guncon2. Previously i try with guncon2pc driver, i used this with my previous cabinet with xp and works fine but in w7 x64 did not work.
There is another driver for x64?
