Software Support => GroovyMAME => Topic started by: Jonny G on March 27, 2012, 03:55:36 pm
Well Groovy MAME was the best find I ever had in the whole of today!
Been getting the usual tearing and sound sync issues with standard MAME on my cab, but just installed Groovy and tested a few different game types and it looks to have nailed every one. GM 145u4 seems to run fine on my Hantarex MTC9000 with the default monitor config and Arcade VGA 9250 (good because I was really unsure how to set up a custom one).
However I am fond of tinkering with stuff so I'm just going to go through the steps I did. Would anyone be so kind as to tell me if I've done everything correctly and maybe inform me if there's any other little tweaks I could make? (Maybe with .ini file settings or command line)
1) Uninstalled all ATI drivers from system. (prev installed from Ultimarc CD)
2) Rebooted and installed Calamity's custom drivers.
3) Set desktop res to 640x480 60hz using QuickRes
4) Deleted contents of MAME's "INI" folder
5) Deleted original "MAME.INI" file
6) ran "MAME -CC" to create new "MAME.INI" and made a few edits to suit my cab. (Posted below)
Am I missing anything?
Thanks to Calamity for this awesome build!
# CORE CONFIGURATION OPTIONS
readconfig 1
writeconfig 0
# CORE SEARCH PATH OPTIONS
rompath roms
hashpath hash
samplepath samples
artpath artwork
ctrlrpath ctrlr
inipath .;ini
fontpath .
cheatpath cheat
crosshairpath crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory cfg
nvram_directory nvram
memcard_directory memcard
input_directory inp
state_directory sta
snapshot_directory snap
diff_directory diff
comment_directory comments
hiscore_directory hi
# CORE STATE/PLAYBACK OPTIONS
state
autosave 0
playback
record
mngwrite
aviwrite
wavwrite
snapname %g/%i
snapsize auto
snapview internal
burnin 0
# CORE PERFORMANCE OPTIONS
autoframeskip 0
frameskip 0
seconds_to_run 0
throttle 1
syncrefresh 1
sleep 1
speed 1.0
refreshspeed 0
# CORE ROTATION OPTIONS
rotate 1
ror 0
rol 0
autoror 0
autorol 0
flipx 0
flipy 0
# CORE ARTWORK OPTIONS
artwork_crop 1
use_backdrops 0
use_overlays 0
use_bezels 0
use_cpanels 0
use_marquees 0
# CORE SCREEN OPTIONS
brightness 1.0
contrast 1.0
gamma 1.0
pause_brightness 0.65
effect none
# CORE VECTOR OPTIONS
antialias 1
beam 1.0
flicker 0
# CORE SOUND OPTIONS
sound 1
samplerate 48000
samples 1
volume 0
# CORE INPUT OPTIONS
coin_lockout 1
ctrlr
mouse 0
joystick 1
lightgun 1
multikeyboard 0
multimouse 0
steadykey 0
offscreen_reload 1
joystick_map auto
joystick_deadzone 0.3
joystick_saturation 0.85
natural 0
joystick_contradictory 0
coin_impulse 0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device keyboard
adstick_device keyboard
pedal_device keyboard
dial_device keyboard
trackball_device keyboard
lightgun_device keyboard
positional_device keyboard
mouse_device mouse
# CORE DEBUGGING OPTIONS
log 0
verbose 0
update_in_pause 0
debug 0
debugscript
debug_internal 0
# CORE MISC OPTIONS
bios
cheat 1
skip_gameinfo 1
uifont default
ramsize
confirm_quit 0
# CORE MKChamp OPTIONS
disable_hiscore_patch 0
disable_nagscreen_patch 0
disable_loading_patch 0
# CORE SWITCHRES OPTIONS
modeline 1
monitor cga
monitor_connector auto
monitor_orientation horizontal
monitor_aspect 4:3
monitor_debug 0
monitor_doublescan 1
monitor_dotclock 0
monitor_ymin 0
cleanstretch 0
changeres 1
redraw 0
monitor_specs0 auto
monitor_specs1 auto
monitor_specs2 auto
monitor_specs3 auto
monitor_specs4 auto
monitor_specs5 auto
monitor_specs6 auto
monitor_specs7 auto
magic_resolution auto
powerstrip 0
# WINDOWS DEBUGGING OPTIONS
oslog 0
watchdog 0
debugger_font "Lucida Console"
debugger_font_size 9
# WINDOWS PERFORMANCE OPTIONS
priority 0
multithreading 1
numprocessors auto
profile 0
bench 0
# WINDOWS VIDEO OPTIONS
video ddraw
numscreens 1
window 0
maximize 1
keepaspect 0
prescale 1
waitvsync 1
menu 0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch 0
# DIRECT3D-SPECIFIC OPTIONS
d3dversion 9
filter 0
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable 0
hlslpath hlsl
hlsl_ini_read 0
hlsl_ini_write 0
hlslini %g
hlsl_prescale_x 0
hlsl_prescale_y 0
hlsl_preset -1
hlsl_write
hlsl_snap_width 2048
hlsl_snap_height 1536
shadow_mask_alpha 0.0
shadow_mask_x_count 320
shadow_mask_y_count 240
shadow_mask_usize 0.09375
shadow_mask_vsize 0.109375
curvature 0.0
pincushion 0.0
scanline_alpha 0.0
scanline_size 1.0
scanline_height 0.7
scanline_bright_scale 1.0
scanline_bright_offset 0.0
scanline_jitter 0.0
defocus 0.0,0.0
converge_x 0.0,0.0,0.0
converge_y 0.0,0.0,0.0
radial_converge_x 0.0,0.0,0.0
radial_converge_y 0.0,0.0,0.0
red_ratio 1.0,0.0,0.0
grn_ratio 0.0,1.0,0.0
blu_ratio 0.0,0.0,1.0
saturation 1.0
offset 0.0,0.0,0.0
scale 1.0,1.0,1.0
power 1.0,1.0,1.0
floor 0.0,0.0,0.0
phosphor_life 0.0,0.0,0.0
yiq_enable 0
yiq_cc 3.59754545
yiq_a 0.5
yiq_b 0.5
yiq_o 0.0
yiq_p 1.0
yiq_n 1.0
yiq_y 6.0
yiq_i 1.2
yiq_q 0.6
yiq_scan_time 52.6
yiq_phase_count 2
# PER-WINDOW VIDEO OPTIONS
screen auto
aspect auto
resolution auto
view auto
screen0 auto
aspect0 auto
resolution0 auto
view0 auto
screen1 auto
aspect1 auto
resolution1 auto
view1 auto
screen2 auto
aspect2 auto
resolution2 auto
view2 auto
screen3 auto
aspect3 auto
resolution3 auto
view3 auto
# FULL SCREEN OPTIONS
triplebuffer 0
switchres 1
full_screen_brightness 1.0
full_screen_contrast 1.0
full_screen_gamma 1.0
# WINDOWS SOUND OPTIONS
audio_latency 2
# INPUT DEVICE OPTIONS
hide_cursor 1
dual_lightgun 0
why don't you give ves's unofficial linux live-cd a bash - you might like it even better!
Everything is fine. If you're happy with it, keep those settings.
You may get better results for your monitor by selecting "monitor h9110" both in mame.ini and vmmaker.ini (you'll need to run vmmaker and reboot). These are the settings for the Hantarex MTC 9110.
OK I've made the following changes...
MAME.INI
modeline 1
monitor h9110
VMMAKER.INI
2. MONITOR
; Monitor Type. Valid types: D9800, D9400, D9200, EGA, VGA, MULTI, H9110, PAL, NTSC, GENERIC, CUSTOM
MonitorType = "H9110"
Then run VMMaker where it imported the mame.xml then generated new modelines. Then rebooted. Do I need to do anything else at all other than that? What about the options to import the new modelines in the registry?
The UpdateRegistry option in vmmaker.ini must be enabled when you run VMMaker.
Apart from that, that's all.
does that mean pathing to the drivers location as well or is that completely different?
Did it anyway, all seems to be cool and upgraded the PC in my cab just to be sure. Thanks for the help. I'll be back.
