Software Support => Automated Projects => Topic started by: BorgDog on January 20, 2015, 09:53:08 pm
Thanks! :notworthy: I've been reading through a lot of threads on setting up some automated workings, in specific a servo run monitor rotation. Following your advice and using your wonderful startcom MaLa plugin I have my micro Maestro controller telling my Hitec servo to rotate to the correct orientation at the start of each game. I believe I now have the hard part working, I just need to build the rest, only have it sitting on the table at the moment but was so tickled that I got it to work I had to post something! Thanks also to everyone else who posted their servo projects without those threads I wouldn't even have known to try this and be having this much fun :applaud: I've attached my little batch file (name changed to .txt so could upload) just in case anybody cares.
Already started the build thread http://forum.arcadecontrols.com/index.php/topic,143354.0.html (http://forum.arcadecontrols.com/index.php/topic,143354.0.html)
Edit: I've updated the servo.txt file so it now has the correct parameters (at least for my setup) and has an acceleration parameter to slow the servo down a bit.
You are welcome, my friend.
Im glad you found startcom useful, and Im looking forward to seeing your project complete!
:notworthy: :notworthy: :notworthy:
I would not have bothered with automation if it weren't for DaOld Man's Mala plugins.
Hear hear. My rotator setup is still going strong and I literally haven't opened the hood in years.
Old Man(s) rule.
If it weren't for DaOld Man,I would have had a nice simple working arcade cabinet but what fun is that ;D
