Main => Lightguns => Topic started by: Garavar on June 02, 2019, 05:11:53 pm
Purchased Aimtrak lightgun and followed all the directions to config.
Aim and shooting are fine but when I aim off screen to reload the crosshair moves to corner of screen and a mouse pointer appears next to it. I pull the trigger which should be reload and I hear the windows chime from my pc. The crosshair then completely disappears. Then when I press the trigger again the crosshair appears at center of screen. I have to aim at the crosshair to take control of it again or else it won't move. If I don't and press trigger anywhere else I'll continue to hear the chime. During all this my gun still won't reload until it does so at random.
Does it in all games. Can't figure out what's happening. Any advise would greatly be appreciated.
Update - if I turn off Bezels it works fine. No idea why that works. I would love to keep bezels on, any ideas would be greatly appreciated.
I recall reading about this exact same problem.
From what i recall, the issue is with the bezels(using rocketlauncher) making the emulator run in borderless windowed mode, causing this issue.
Sorry, but i don't know of a way to fix it besides running in true fullscreen.
