Main => Monitor/Video Forum => Topic started by: toilet on May 07, 2002, 05:23:58 am
Title: NVidia TV-Out Questions and Problems
Post by: toilet on May 07, 2002, 05:23:58 am
I have two small problems that are fairly common, though the fixes don't seem to be working with me.
1). When running s-video from GF2 to TV the picture is black and white. I've seen people complain about this, and all they've had to do was in Device Selection set the Output Device to S-Video from Auto-Select. Unfortunately it stays black and white for me.
2). Black borders around left and right side of TV image. I have about 1" ob black on either side of the image on a 32" TV. I've been to the TV MAME page (http://www.trouble-makers.com/kami/emulation) on custom resolutions, and added them fine, but nothing changed at all.
I don't know if it's me or XP or what. I know XP doesn't allow windows to go into any resolution less than 800 x 600. Also, if I launch a SFA (which uses 384 x 224) while connected to my monitor, it still ends up displaying at 800 x 600. Is there some command-line setting I should be adding? I have a feeling it's still being sent at 800 x 600 to the TV, since the video barely flickers or changes size from windows to MAME, however a full screen command prompt utilizes the whole screen.
Testu, I know this is your department, and I'd appreciate any advice you could give. I know you're down with the TView scan converters, but I thought you were able to tweak the black borders with just the hacked resolutions into the NVidia drivers.
Thanks.
Title: Re: NVidia TV-Out Questions and Problems
Post by: Zipper on May 07, 2002, 07:16:02 am
Do you run the S-Video lead into your T.V. through an adaptor into the SCART socket?
Becasue when I did that, I got black and white results.
The only way i could fix it was to plug the S-video lead straight into the S-Video socket.
Post by: toilet on May 07, 2002, 10:31:57 am
Nope, straight svideo to svideo. There's an adapter to convert to generic rca video cable, and that works.
Post by: aramis on May 07, 2002, 12:05:21 pm
the black borders are most likely due to your GF2 card using a Chrontel or Conexant tv-out chip. The solutions are:
- try TVTOOL software...it can fix the issue for SOME flavors of Chrontel/Conexant chips.
- get an nVidia card w/ VIVO, since they use the Philips chipset which does not have the issue to begin with.
- a scan converter might work, I dunno...never used one.
Post by: tetsu96 on May 07, 2002, 12:08:38 pm
It's mainly crappy driver support for the TV out.
Post by: Carsten Carlos on May 07, 2002, 12:11:52 pm
Toilet, I don't know where you are located, but you might have a look at the TV-system choosen in the GF2-properties. In Germany & UK, for example, you have to set it to PAL, in the US & Japan to NTSC. If you got the wrong setting, you'll have a black&white picture. Just a thought.
Post by: toilet on May 07, 2002, 03:57:15 pm
Thanks,
I had the format type set to NTSC-M which is what's listed for US. I'll try reseating it, it was a little jumpy now that I think back on it.
Tetsu96, I know it's a pain typing out these similar posts, but I appreciate it. Everytime another piece of information slips out.
I'm messing with this now on my main pc while I decide what to do for my next project, the console pc. I don't have the room for a cab where I live now, but I'd like to make the machine for it and use it in the living room. I'm planning on building a briefcase-type pc case mod for it, so I can carry it around to friends houses and gatherings. Anyway, I was hoping to keep it as encapsulated as possible which is why I was trying to avoid the scan converter, but I may have to go that route now.
Post by: Howard_Casto on May 07, 2002, 04:20:06 pm
Your real solution, unfortunately is to get a real video card.  Geforces have great 3d acceleration but thier tv-out sucks for air.  Get an ati if yor going to be using tv out period.  It's worth the slower 3d performance as you don't have to deal with invidas stupidness.  I'm currently researching an ati hybrid card that's manufactured by gigabyte.
According to impartial sources, the top model of this series can give performance results similar to a geforce 3 and the middle end version works as well as a geforce 2.  On top of that the 2d performeance blows the geforces away (of course)  and it looks like it uses that wondeful stock ati tv-out chipset.  I'm going to buy one soon I'll let you know if they're any good.
Post by: tetsu96 on May 07, 2002, 05:05:43 pm
Scan converters are pretty small.  The TView I can carry all it's stuff in one hand if need be...  Otherwise, go for a good TV out card.  Radeons are noted for great TV out quality...
I think they do custom resolutions too although good luck getting them to work with the TV out.  Actually, MAME with HW stretch and the sharp effect enabled looks pretty darn good and is probably comparable to running with the custom resolutions assuming you have the CPU power to spare...   ;)
Post by: mattv on May 15, 2002, 05:37:03 am
I'm with Howard on this one
Gforce TV out = Rubbish.
Having said that the new Gforce 4 Ti4200 cards with Tv in / out looks pretty good. Pity they cost 50 bucks more than the tv-out only model.
if you want TV out from a video card something from ATI or Matrox would be a much better choice, and because their 3d performance is (only very slightly) slower they tend to be priced pretty sharply
Post by: Trenchbroom on May 15, 2002, 05:13:01 pm
I recently purchased an 8 MB ATI Rage 3D LCD videocard for $30 new from a clearance house.  For my Celeron 400 MAME cab box it is fine and the output is very good with my 20" TV.  My question is this: is there a real performance increase for choosing newer ATI or Matrox cards over the older ones?  Understanding, of course that the older cards will force you to probably use Win9x, take up a PCI slot, etc.
Everyone talks about Radeons for MAME cabs, but since MAME is so processor-intensive I'm just curious if anyone has experienced a videocard bottleneck by using an older card with 1GB + processors.
Might have to bug my friend to let us do a little experimenting with his 1800XP.
Post by: Rick Osborn on May 16, 2002, 07:56:07 am
I'd have to agree with anyone who says that NVDIA cards suck for TV out.  ATI is the only way to go.
I was just finishing up a MAME cab yesterday and was using a Geoforce 2 card that I had lying around.  I also had an ATI Rage 128 around too.  But, I figured I'd use the NVIDIA since it had 64mb RAM and the PC would be used for PC games and not only MAME.
Well, the TV out was black & white only and there was the black border you mentioned.  No options changes would get me color either.
I installed the ATI and was back in business.
I recently upgrade my personal cab from an ATI Rage 128 to an ATI All in Wonder (which is why I had a spare ATI card).  I did notice a slight improvement in picture quality on the All in Wonder over the Rage.  Something to consider since those cards are very cheap.
Thanks.
Post by: Lilwolf on May 16, 2002, 09:45:34 am
Before everyone trashes the TVout for NVidia...
remember... NVidia makes chips, not video cards.  Each company that make/sells NVidia cards use their OWN video out chip.
So the answer is... some are GREAT!  but many SUCK!
I've seen pictures of some that are as good if not better then ATI's.
Trouble is... which is good?  The VIVO ones use the phillips chip which has great output... but the new Ti4200's use a new phillips chip that was produces to reduce cost... is it good?  who knows.
If you go NVidia, make sure the company you buy from is local and allows for returns... Or get an exact copy from someone who had good luck!
or...
go ATI... and you don't have to worry (dont get the XPert... I hear they had a different chipset or somethign)
Post by: tetsu96 on May 17, 2002, 12:03:18 pm
There's been a lot of good replies and opinions on this thread.  I'll try to sum up the most important points.
1.)  No matter which video card with TV-Out you pick up from which maker, you'll need to use Hardware Stretch for most games likely.  This bothers some people more than others, you'll have to decide on your own.  If you want to run all your games at their native resolutions without any stretch filtering / effects, you'll need either a good scan converter, a RGB connection from the video card straight to the TV, or an Arcade Monitor (again, using RGB).
2.)  If you decide HW stretch is not so bad (or can live with the speed hit from the -sharp effect), then the quality of the TV outs vary.  ATI historically has had great TV-Out for a lot of users on this board, NVidia's had mixed results.  The Brooktree chip is not supported well by NVidia but other TV-Out chips might have better driver support.  Poor driver support results in underscan (not filling the whole TV), the inability to adjust image position / size / etc.
3.)  2D speed and 3D speed are totally different.  GeForces have great 3D speed but they're not the fastest in 2D.  Different driver releases have an effect on the 2D speed, and it even affects rendering custom resolutions (which use no stretching effects whatsoever).  I've heard Radeons are faster in that regard but I've never tested that myself.  I wonder if there's any kind of solid metric which could be used to guage 2D performance...
Personally, I've used a bunch of Video Cards with TV outs and several scan converters.  My own opinion (for my cabs at least) is to go with a scan converter that supports a wide scan range, this should let you use custom resolutions which is as good as it gets next to the whole ArcadeOS / AdvanceMAME setup (which is definately the most exact at the expense of ease of use).  Of course, your mileage may vary...
