Main => Monitor/Video Forum => Topic started by: Onji on October 23, 2021, 06:11:36 pm
I have a K4903 that came out of a moon patrol. I'm considering swapping the tube out.
My current tube is a:
Model Size B&K Socket B&K Heater Voltage B&K G1 Voltage Sencore Socket Sencore Heater Voltage Sencore Bias
19VMCP22 19 23 6.3 50 23 6.3 D
I may pick up this one:
A48QAD220X 19 23 6.3 70 23 6.3 D
As you can see the G1 voltage is higher than my current one.
After a LOT of reading around, folks seem to think that G1 voltage isnt all that important with tube swaps. Some have swapped to higher AND lower values and they've been ok.
Is that the case?
I just want to be certain.
thanks
I... think you're right. I believe the G1 gets compensated when you turn up the G2 Screen pot (normally on the flyback).
Thanks @buttersoft yeah I'm leaning more towards the "it'll be fine" side so far.
Err, it occurs to me that you didn't mention yoke impedances and inductances. Those need to match between the tubes.
