Software Support => controls.dat => Topic started by: kelkyko on December 09, 2017, 08:44:35 am
Hi,
I'm trying to play atari football on MAME and am having the same problem with calling plays. I have an X-arcade tankstick hooked up to the game. It all works, I just can see and don't know what buttons cycle through the plays. I'm running version 2. It doesn't show the plays on the screen. Any help appreciated!
I also heard there is a version that has the plays on the screen to cycle through. What is the ROM name for that version.
Thanks in advance.
Best regards,
Kelly
Not sure if version 2 means Revision 2 (atarifb) or Atari Football II (atarifb2).
In atarifb, to select plays, press your normal Button 1 (CTRL, Left Mouse Button, Joystick button 1). If you want to see the playbook art, that's provided as a Bezel, which is part of MAME's artwork system. (Search for MAME Bezel Artwork for more info)
You likely only need to grab the artwork zip from http://mrdo.mameworld.info/mame_artwork_ingame.php (http://mrdo.mameworld.info/mame_artwork_ingame.php) and add it to your mamedir\artwork directory.
