Main => Retail vendors => Topic started by: HaRuMaN on February 18, 2013, 10:46:13 am
Title: CNC Cut Bartop Kits - Orders Open! New Models Available!
Post by: HaRuMaN on February 18, 2013, 10:46:13 am
http://www.harumancustoms.com/
Shop is here:
http://shop.harumancustoms.com/
1/2" Black melamine, simple constuction, blank or pre-cut admin and control panels.
No painting or sanding required!  Just assemble and go!
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=279604;image)
Big thanks to degenatrons for the original CNC file that I have working from and modifying.  This is an open-source project, by the way.  Feel free to take the plans and modify them for you own use as you see fit.  By taking the plans, you are agreeing to the Creative Commons BY-SA 3.0 licensing, found here:
http://creativecommons.org/licenses/by-sa/3.0/us/ (http://creativecommons.org/licenses/by-sa/3.0/us/)
Here is my current revision of the CNC plans:
https://docs.google.com/file/d/0B7Rqi_4oIj-wbDVtaWlLQ1NTQk0/edit?usp=sharing (https://docs.google.com/file/d/0B7Rqi_4oIj-wbDVtaWlLQ1NTQk0/edit?usp=sharing)
Here is the widescreen version:
https://drive.google.com/open?id=0B7Rqi_4oIj-weFlwQ05NekFlRkE (https://drive.google.com/open?id=0B7Rqi_4oIj-weFlwQ05NekFlRkE)
Here is the link to the open source / open hardware project run by degenatrons:
http://kadevice.tk/forum/viewtopic.php?f=51&t=305&p=1364#p1364 (http://kadevice.tk/forum/viewtopic.php?f=51&t=305&p=1364#p1364)
Title: Re: CNC cut Weecade Kits - Ships to continental US
Post by: HaRuMaN on February 18, 2013, 10:46:30 am
Specs:
Hardware:
Fits a Horizontal 17" 4:3 LCD monitor nicely.  Can fit a Horizontal 19" 4:3 LCD, but it's tight.  17" is the recommended size.
With a 17" monitor, a microATX motherboard, ATX power supply, and standard 3.5" hard drive fit.
Control and Admin Panels:
Comes in 2 options, drilled or undrilled.
Drilled has a standard 6 button Street Fighter layout, with 2 buttons for start and coin.  Admin panel has 3 buttons drilled.  Hole sizes are 1.15" diameter and will fit Happ buttons.
If you want a different layout, order the undrilled.  I have found that a 2 player 6-button layout MAY fit, but would be very cramped.  2 player 4-button is less so.
Control panel dimensions are: 17.72" X 6.19"
Monitor mount panel:
Drilled for both 75 X 75 and 100 X 100 VESA mounts
Speaker Panel:
Drilled holes for 2 speakers, hole pattern is 3.79" in diameter.
Overall Dimensions:
Height: 21.43"
Depth: 18.6"
Width: 18.72"
Weight:
Melamine kit only: ~21 lbs
Post by: HaRuMaN on February 18, 2013, 10:46:41 am
Pics of kit pieces:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=278183;image)
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=278185;image)
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=278187;image)
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=278189;image)
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=279497;image)
Post by: HaRuMaN on February 18, 2013, 10:46:53 am
Basic assembly instructions:
Lay out one side flat, pocket cuts up:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=279491;image)
Fill each of the five 1/4" deep pockets with a liberal amount of wood glue.  Don't be stingy.  Insert each of the tabbed panels into the deep pockets:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=279493;image)
Place the other side on top (with NO glue yet), aligning the tabs into the slots:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=279495;image)
Place a heavy weight on top, wipe up the excess glue with a damp paper towel.  Wait for an hour or so.
After the hour or so has passed, take the weight off the cabinet, and carefully remove the unglued side.  Place the unglued side down, fill the five 1/4" pockets with a liberal amount of glue, and carefully guide the tabs into place.  Again, set a weight on the assembled cabinet, wipe up the excess glue with a wet paper towel, and leave for ~24 hours in a warm place.
Couple of other views:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=279600;image)
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=279602;image)
Once completed and dry, lay the bartop face down (marquee & control panel area closest to the ground).
Once down, place the plexiglass inside, one side will rest on the back of the speaker panel, the other side will rest on the batons for the control panel.
Attach the monitor to the VESA mount panel using M4-.07 machine screws (25mm length).  Place the monitor & panel inside the bartop resting on the plexiglass.  Adjust the placement so the monitor is visible.  Use the included angle brackets to attach the panel to the inside of the cabinet.
* NOTE : The included screws with the brackets are a little too long and will poke out of the cabinet if you use them as is.  You either need shorter screws or use some spacers (like washers).
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=130522.0;attach=292317;image)
Usually the monitor is enough to hold the bezel plexiglass in place.
For the marquee plexiglass, you can find aliminum L channel at Home depot, cut to size, and paint.  There are also places online that stock black plastic L channel.  You will need a piece for top and bottom.
Post by: Malenko on February 18, 2013, 11:20:04 am
I have a version 1.0 and it was pretty good, this is version 2.0 and seems a ton better. I have done a lot of business with Haruman and I have never had a bad transaction yet.
Post by: HaRuMaN on February 18, 2013, 11:23:13 am
Thanks for that.
Post by: yotsuya on February 18, 2013, 11:49:51 am
HaRuMaN has hooked me up with V1 and V2 (pickup tomorrow  :gobama). Super trustworthy. I know the work that goes in to getting these done, sorting the parts, packing them up, and shipping them out, and this is totally worth it.
Post by: wp34 on February 18, 2013, 12:03:25 pm
Seems like a real good price.
Post by: HaRuMaN on February 18, 2013, 12:08:05 pm
Thanks.  I had to hunt around for a CNC service that were reasonable, the first two I contacted wanted between $200 & $250.  That almost killed the project dead in the water.  Glad I kept looking, though.
Post by: yaksplat on February 18, 2013, 01:10:11 pm
So if you put all of the profits into building your own CNC, you could really be on to something....
Post by: HaRuMaN on February 18, 2013, 01:11:31 pm
The thought HAS crossed my mind, to be sure.
Post by: yaksplat on February 18, 2013, 02:29:43 pm
I officially financed my entire cabinet build this way.  It completely improves the wife acceptance factor.
Post by: Ginsu Victim on February 18, 2013, 08:57:34 pm
Pics coming soon.
WHEN?!??!?
Sorry, I just really want to see what you're up to.  ;D
I like the price and your work has always been excellent.
Post by: ghostrider on February 18, 2013, 10:14:12 pm
Interesting, cant wait to see pics.
What size screen do you plan to accommodate?
Vertical or Horizontal?
Any Custom options (control panel, larger screens, etc.)?
Post by: 404 on February 18, 2013, 10:55:44 pm
very interested. have so many questions
are custom sizes available or would they be just one size?
how wide, high, deep are they?
what kind of screen range would you have with this kit?
what kind of board options would it support? itx, matx, atx etc
what kind of buttons would it support
single player or two player?
Post by: HaRuMaN on February 19, 2013, 09:04:37 am
Please see second post for more details, I just updated it.
Post by: ChadTower on February 19, 2013, 09:53:54 am
At the very least it's a way to get yourself a free CNC machine....
...if you could just manufacture the free time to build one.
Post by: HaRuMaN on February 19, 2013, 09:57:07 am
Could always get my CNC guy to cut the CNC parts for me...
"Hey, what are you making with this?"
"Nuffin..."   >:D
Post by: yotsuya on February 19, 2013, 09:59:06 am
You could pay those dumpster divers extra to load it in your machine, too!  :cheers:
Post by: gonzo90017 on February 19, 2013, 07:45:34 pm
Can't wait to see some pics.
Post by: PL1 on February 19, 2013, 09:07:27 pm
You could always ask Yvan256 if he'll share his files (http://forum.arcadecontrols.com/index.php/topic,113763.0.html).
The individual pieces parts look so unassuming.  >:D
Post by: yotsuya on February 19, 2013, 11:12:10 pm
Yeah, PL1 is right, just tell them they're artistic coasters...   :laugh2:
Post by: HaRuMaN on February 21, 2013, 11:04:20 am
Updated 3rd post with kit pictures, next I will get some assembly photos as I put it together.
Post by: jmike on February 21, 2013, 12:22:07 pm
Wow! These look great. Can't wait to see one put together.
I've bought several arcade related parts from HaRuMaN in the past, he's very reliable and highly recommended.
Post by: HaRuMaN on February 21, 2013, 12:23:27 pm
Thanks!  :cheers:
Post by: Ginsu Victim on February 21, 2013, 03:31:55 pm
I like what I see. Any chance of a picture showing it assembled?
Post by: HaRuMaN on February 21, 2013, 03:33:02 pm
Yes, going to assemble this one soon, I'll be taking pictures of the process.
Post by: Ginsu Victim on February 21, 2013, 03:55:11 pm
Dance, monkey, dance! Do our bidding!
(http://princessworld.edublogs.org/files/2011/02/a-dancind-monkey-q44vr1.gif)
Post by: HaRuMaN on February 21, 2013, 04:06:32 pm
Lol, for a sneak preview, you can look here:
http://forum.arcadecontrols.com/index.php/topic,124529.msg1335152.html#msg1335152 (http://forum.arcadecontrols.com/index.php/topic,124529.msg1335152.html#msg1335152)
Imagine it in sexy black melamine, and without the batons.
Post by: Malenko on February 21, 2013, 05:47:01 pm
no batons? That was my is a brilliant idea!
Post by: leapinlew on February 21, 2013, 05:59:41 pm
I put together two version 1 kits. They were good and the transaction was flawless.
WOULD BUY AGAIN!!!!!!!!!!!!!!!!!!!!!
Post by: northerngames on February 21, 2013, 06:21:05 pm
I know your just getting into these but is any of the sideart guys lurking around jumping in to get some custom direct fit artwork going on for these or is there already something like that out there for them already?
Title: CNC cut Weecade Kits - Ships to continental US
Post by: j2obin on February 21, 2013, 06:39:25 pm
Taking orders?
Post by: HaRuMaN on February 21, 2013, 08:32:48 pm
Almost ready to take orders, will probably do so starting sometime next week.
Post by: Ginsu Victim on February 21, 2013, 09:45:50 pm
You planning on doing this for a while? I may not be able to place an order until August or September.
Post by: HaRuMaN on February 22, 2013, 08:35:07 am
Yeah, my CNC guy is fine with smaller runs, too.  As long as he doesn't close up shop (which it doesn't look like he will, he's always busy), I should still be doing this.
Post by: jammin0 on February 22, 2013, 03:37:26 pm
These look sweet.  So . . . batons on the CP, and have you done the VESA mount yet?  I'm assuming you would screw in batons and then glue to that?
I can't wait to see people start making these.  I might have to order one or two when I sell something to generate some cash.  Love the finish.
Post by: HaRuMaN on February 22, 2013, 03:53:34 pm
There are fatter batons for the monitor mount.  It's up to the user on where to mount it (due to varying monitor sizes, etc).  I forgot to show the batons in the first set of pics, I'll through them up later.
Post by: bamaholic on February 22, 2013, 04:39:51 pm
I'm going to jump on the bandwagon and say this kit looks awesome. I'm always looking for a new project and this may be it.
Post by: Goz on February 22, 2013, 09:22:24 pm
I can post a pic of my mostly assembled V1 I am planning on wiring controls tomorrow and setting some more of it up.
Post by: HaRuMaN on February 25, 2013, 09:20:21 am
First few posts updated with some more pictures.   :cheers:
Post by: tippers79 on February 25, 2013, 01:51:49 pm
Hi do you have pemission from the designer of these
kits ive seen these before on another site.
Im pretty sure he would be pissed off if he hasent given you resell rights !!
Post by: HaRuMaN on February 25, 2013, 01:57:37 pm
And who would that be?  Surely not the kits you signed up here to sell.
I have permission from the guy who gave me the original CNC file that I have modified a lot, he is well aware of what I'm doing.
Post by: tippers79 on February 25, 2013, 02:09:19 pm
Not talking about the kits i sell...We both know who im talking about i
have these plans also,if you changed them why not be creative and design your own its not hard !!!
Yeah of course he did so you give him a cut then lol.
Post by: yotsuya on February 25, 2013, 02:14:23 pm
To be fair, HaRuMaN is doing this as a service to those who don't have the space/tools/knowhow to cut these on their own. He's never passed these off as anything but a precut kit for convenience.
Post by: jammin0 on February 25, 2013, 02:15:47 pm
Unless you're Apple, I don't think you can enforce someone copying the shape of your design.  It's not like there's that much to it.  I could see if HaRuMaN was selling his plans but he's not.  He's providing a service in selling this kit.  There is some serious innovation with the batonless design going on too.
If I were the creator of the Weecade I would just be glad that my name was so commonplace now and that everyone is making them.  Imitation is the highest form of flattery right?  Not that HaRuMaN needs me to defend him.
Post by: tippers79 on February 25, 2013, 02:17:30 pm
Fair point but not his plans to start with mate !!
The guy who did these spent a lot of time and work getting it right.
Be creative use your brain and do your own simple !!!
Post by: yotsuya on February 25, 2013, 02:19:31 pm
You mean like this:
http://www.ebay.co.uk/itm/ARCADE-MACHINE-BARTOP-MACHINE-MAME-1-PLAYER-DIY-FLATPACK-/160835393414?_trksid=p2047675.l2557&ssPageName=STRK%3AMESELX%3AIT&nma=true&si=MGpY9KmOBM4XhyhAJE%252FYOdHu9R4%253D&orig_cvip=true&rt=nc (http://www.ebay.co.uk/itm/ARCADE-MACHINE-BARTOP-MACHINE-MAME-1-PLAYER-DIY-FLATPACK-/160835393414?_trksid=p2047675.l2557&ssPageName=STRK%3AMESELX%3AIT&nma=true&si=MGpY9KmOBM4XhyhAJE%252FYOdHu9R4%253D&orig_cvip=true&rt=nc)
How is that any different?
Post by: tippers79 on February 25, 2013, 02:22:46 pm
Not talking about weecade mate ...keep your nose out
These are someone elses cad file which he has got hold of.
Im sure he will see this post
Post by: yotsuya on February 25, 2013, 02:24:29 pm
Degenetron?
Maybe you missed this, mate:
Post by: tippers79 on February 25, 2013, 02:41:49 pm
yeah ok lol
Post by: degenatrons on February 25, 2013, 04:15:16 pm
Just to clarify things.  I'm happy for Haruman to use the CNC plans (which I originally created based on Koenigs work).  He's made some neat improvements and these are being contributed back to the open source project which benefits everyone.
Post by: Ginsu Victim on February 25, 2013, 04:41:04 pm
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=130522.0;attach=279534;image)
Post by: HaRuMaN on February 25, 2013, 04:49:06 pm
BOOM!
Lol.  My eyes!
Post by: ChadTower on February 25, 2013, 04:55:59 pm
BOOM HEADSHOT (YFM Mashup) (http://www.youtube.com/watch?v=joBb73M_-_8#ws)
Post by: 404 on February 26, 2013, 08:30:12 am
You mean like this:
OT but that's a very good deal there. hard to compete with that price point if you ask me.
Post by: HaRuMaN on February 26, 2013, 01:35:14 pm
First few posts updated with assembled pictures.   :applaud:
Post by: HaRuMaN on February 28, 2013, 02:07:52 pm
So, pretty close to opening orders for these, just looking at a way to better protect the pieces during shipping, think I have a good solution (thanks to Malenko)  :cheers:
Post by: CWorley on March 01, 2013, 09:00:26 pm
I know you mentioned that 19" is a tight fit, but any chance a Dell 2001fp 20" lcd would sneak into one of these?
Post by: HaRuMaN on March 02, 2013, 09:40:15 am
If you can get me some width, height, and depth dimensions, I can check.
Sent from my GT-P3113 using Tapatalk 2
Post by: CWorley on March 03, 2013, 11:25:01 am
Sure.  The dimensions are 17 5/8" x  13 7/8" x  3" (WxHxD).
Post by: HaRuMaN on March 04, 2013, 11:23:37 am
Width wise it fits, barely.  17.72" available.  Height, you could may get away with it, you may have to shorten up the CP a bit...
Depth might work.  At the edge, you have 1.5" between the speaker panel and the baton for back piece...
Decasing might help, too.
Post by: Malenko on March 04, 2013, 11:32:31 am
or dremel the sides.
Title: CNC cut Weecade Inspired Kits - Ships to continental US - Preorders OPEN!
Post by: HaRuMaN on March 04, 2013, 11:35:00 am
Ok, let's go ahead an open this up for orders.  I'll keep the window open a couple of weeks, or until I get 10 orders, whichever happens first.
Continental US only for now.
Send me a PM with the following information:
Quantity:
Slot cut (Y/N):
Marquee / Bezel polycarbonate included (Y/N):
Blank or drilled CP and Admin panel:
Email address:
Shipping address:
And I will send you a PayPal money request with the details.
Payment will be required up front, as these are cut to order.  I will update this thread with all details as they update.
Title: Re: CNC cut Weecade Inspired Kits - Ships to continental US - Preorders OPEN!
Post by: HaRuMaN on March 05, 2013, 08:33:53 am
3 / 10 orders taken, 7 slots left.   :applaud:
Post by: e78990 on March 05, 2013, 09:39:27 am
hello - i m interested but I am not able to PM you?
Maybe I havent posted enough on the forum yet? not sure. Can you send me a PM so I can order one of the kits?
Thank you
Post by: HaRuMaN on March 05, 2013, 09:44:59 am
Thank you
PM sent.
Post by: HaRuMaN on March 05, 2013, 11:56:42 am
Updated the first post, polycarbonate will now be available for the marquee and bezel for an additional $30.
Post by: HaRuMaN on March 06, 2013, 02:17:08 pm
4 / 10 orders in, 6 spots left.   :applaud:
Post by: yotsuya on March 06, 2013, 03:15:14 pm
If you're on the fence, guys, these are great quality. I'm using one to build a machine for my god-daughters' birthday in June.
Post by: rablack97 on March 06, 2013, 08:33:42 pm
In cowboy blue no doubt >:D
Post by: rablack97 on March 06, 2013, 08:36:48 pm
Haruman,
Question on your melamine, is there any reason you went with the particle board?
I've sourced some 3/4 melamine with the MDF core.  It's not available in 5/8 though...
Was it weight?
Post by: yotsuya on March 06, 2013, 09:17:39 pm
She is a Cowboys fan, actually. I like to tease her by telling her the Cowboys haven't been in the Super Bowl since she's been alive.
Post by: rablack97 on March 06, 2013, 10:06:20 pm
 :laugh2: :laugh2: :laugh2:
Good one
Post by: SNAAKE on March 07, 2013, 12:25:46 am
whatever happened my idea for using the asus 23" evo monitor? can you make one to fit that monitor? you'd get lot more sales from srk too(can only guess). I am buying one if you can.
Post by: HaRuMaN on March 07, 2013, 08:38:47 am
I will look into that.
Post by: HaRuMaN on March 07, 2013, 08:40:19 am
Haruman,
Was it weight?
I'm using 1/2" for these kits, as far as I know, the melamine coated particle board is the only material available in the side.
The CNC cuts are razor sharp, though.
Post by: ArcadeNerd on March 08, 2013, 12:56:13 am
I've got enough parts sitting around to throw a little something together and these look pretty nice.  I'll give one a shot :)
Post by: HaRuMaN on March 08, 2013, 08:35:19 am
Invoice sent, thanks!
Post by: HaRuMaN on March 11, 2013, 10:56:50 am
Hey, get me some dimensions and I will work on it for you.
Amazon says it is:
21.6" x 13.8"
Newegg says it is:
21.61" x 16.1"
Let me know depth, too...
Post by: SNAAKE on March 11, 2013, 09:26:40 pm
its 22"x14"x2.5"
21.7 if you wanna get real picky. but Id go with 22"x14". this is the least laggy lcd and available.
Title: Re: Re: CNC cut Weecade Inspired Kits - Ships to continental US - Preorders OPEN!
Post by: HaRuMaN on March 11, 2013, 10:47:26 pm
its 22"x14"x2.5"
Cool, thanks. What kind of layout for the buttons / joysticks would you want?
Post by: SNAAKE on March 12, 2013, 06:33:04 pm
Cool, thttp://forum.arcadecontrols.com/index.php?action=post;quote=1342289;topic=130522.80;last_msg=1342289#hanks. What kind of layout for the buttons / joysticks would you want?
personally? Id go go with last 6 buttons from the OG hori sticks. this here.
or maybe you can have the option for american and japanese layout.
Post by: HaRuMaN on March 12, 2013, 08:06:34 pm
Wouldn't you want 8?
X,Y,A,B,Lb,Rb,Lt,Rt?
And 3 admin per player for guide, back, and start?
Title: Re: CNC cut Weecade Inspired Kits - Ships to continental US - Orders Closed!
Post by: HaRuMaN on March 14, 2013, 11:32:31 am
Orders closed for this round, stay tuned for round 2.
I am close to finishing the plans for SNAAKE's cabinet, will be sending them on to my CNC guy for an estimate.   :cheers:
Post by: HaRuMaN on March 15, 2013, 09:52:03 am
Should be picking these up on Monday, and then working on getting the slots cut and packing them up for shipment!   :cheers:
Post by: rablack97 on March 15, 2013, 10:08:35 am
congrats on your sell out!!!!! :applaud: :applaud: :applaud:
Post by: HaRuMaN on March 15, 2013, 10:44:20 am
Lol... didn't quite sell out, but that's ok.  Once these are out the door, will be opening orders again.
Post by: HaRuMaN on March 18, 2013, 04:22:36 pm
Oh, SNAAKE!
You're in luck...  2 can be fit onto one sheet, so it's not gonna be too crazy costwise.
Post by: jmike on March 18, 2013, 06:08:59 pm
Very nice. 2-player style.
Post by: SNAAKE on March 18, 2013, 06:19:46 pm
yes I may be in the market for a kit. you can customize the controls tho? not a fan of 8 buttons setup. its too cluttered and generally is useless. 6 button is good enough. I will send you a note if/when I am ready to place an order and discuss further business :burgerking:
Post by: HaRuMaN on March 18, 2013, 07:50:14 pm
Sure can.   :cheers:
Post by: HaRuMaN on March 19, 2013, 12:22:35 pm
Sure can.   :cheers:
8 buttons dropped in favor of 6 buttons:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=285841;image)
Post by: HaRuMaN on March 19, 2013, 03:15:11 pm
If anyone else is interested in the wide kit shown above, let me know.  It's based around this monitor:
http://www.amazon.com/ASUS-VH236H-23-Inch-Full-HD-Monitor/dp/B002453K5G (http://www.amazon.com/ASUS-VH236H-23-Inch-Full-HD-Monitor/dp/B002453K5G)
Title: CNC cut Weecade Inspired Kits - Ships to continental US - Orders Closed!
Post by: macattack on March 19, 2013, 05:17:54 pm
Pretty tight on those plans, not so bad if he is laser cutting, but routing even with a 1/8" bit is going to be tough without a vacuum bed. There is little to no room for tabs to hold parts in place. That said if he's got a vac bed no problem ;)
www. Xtremepinball.com
Post by: HaRuMaN on March 19, 2013, 05:22:50 pm
He has a 3-phase power CNC rig with a 18HP vacuum bed.  It's quite impressive.
Post by: yotsuya on March 19, 2013, 05:23:11 pm
I've seen the guy's setup. Not an issue!  :cheers:
Post by: BadKarma on March 23, 2013, 06:50:47 am
Haruman, I am very interested in one of your weecades but I can not PM you, as I have just joined the site. Could you please shoot me an email and I will reply with the required information?
blaine.lippe@gmail.com
Title: Re: Re: CNC cut Weecade Inspired Kits - Ships to continental US - Orders Closed!
Post by: HaRuMaN on March 23, 2013, 11:13:16 am
Email sent!
Post by: ArcadeNerd on March 23, 2013, 02:46:01 pm
Any word on the ones you were going to get this week?
Post by: HaRuMaN on March 23, 2013, 09:11:41 pm
Got them in, going to do the slot cutting and packing this weekend!
Post by: jmike on March 23, 2013, 10:11:55 pm
 :cry: wish I had the cash to get one of these beauties.  :cry:
Hopefully I'll be able to get one in the next order.
Post by: BadKarma on March 24, 2013, 04:54:38 pm
What is the viewing size between the speaker mount and the CP?
Post by: EvilEmuOfDoom on March 24, 2013, 08:38:30 pm
Any estimate one when you're taking orders again?  :)
Post by: 05SRT4 on March 25, 2013, 08:17:00 am
I cant wait to get mine., Ive wanted to build a weecade type bar top for awhile but I'm terrible with wood working. I have a quick question about the CP. Will the  ServoStick  (http://www.ultimarc.com/servostik.html) Joy stick fit okay in this? Thanks for any information.  :cheers:
Title: Re: CNC cut Weecade Inspired Kits - Ships to continental US - Orders Open!
Post by: HaRuMaN on March 25, 2013, 09:58:33 am
Now.   :)
Post by: EvilEmuOfDoom on March 25, 2013, 10:23:02 am
Now.   :)
PM Sent :)
Post by: HaRuMaN on March 25, 2013, 10:41:17 am
Taking a look at that, I believe it will.
Post by: heinekenlvr on March 27, 2013, 02:08:14 pm
Where you guys getting your 1/2" t-molding from? T-molding.com has two colors available ...white and black.  Are there are other sources available for different colors??
Also...is the cost of the 2 player the same as the one player?? $140
Post by: HaRuMaN on March 27, 2013, 02:17:17 pm
As far as I have found, there is only white or black in 1/2" T-molding.  It may be possible to dye the white using something like RIT dye, I may try to experiment with this at some point.
The wider, 2 player bartop (optimized for a widescreen LCD) base price is $155, slot cutting is $10 extra, and I don't have any polycarbonate available for it.
Post by: HaRuMaN on March 27, 2013, 02:19:02 pm
Just dropped off the first batch for pickup by FedEx.  Will be sending tracking numbers out via PM.   :cheers:
05SRT4, and EvilEmuOfDoom, I have your kits in hand, will be do the slot cutting and packing this weekend.   :applaud:
Post by: EvilEmuOfDoom on March 27, 2013, 02:59:31 pm
Sweet!  I just ordered a Vision Pro CGA LCD for it.  I plan on using it mostly as a test rig but also when I feel like playing games in the house when the garage is too cold ;).  Granted, once my kids see it I'll probably have to order another at some point...
Post by: lowgunn on April 01, 2013, 10:11:05 am
Hi HaRuMaN,
I'm interested.  Please PM me  details you  may need.
thanks
Post by: lowgunn on April 01, 2013, 10:49:44 am
How weird, I've been monitoring this thread and thought it said it was open again.  Must be wishful thinking.  Sorry for the post.
Post by: HaRuMaN on April 01, 2013, 10:56:47 am
Oh, no, you were correct.
Work has got me extremely busy this month, so I'll probably not be taking any new orders until maybe the last week in April or so, will update the thread then.   :cheers:
Post by: lowgunn on April 03, 2013, 12:46:36 pm
hi,
What's the widest that you can make it?  I was reviewing the dimensions and did it change much when it was changed to accommodate the asus monitor.  The layout seems like it should have enough room to give one or two more inches.  Just thinking of more shoulder room for two player games.
thanks
Post by: SNAAKE on April 09, 2013, 08:14:07 am
I am still trying to order the 2 player version but I dont get a reply from haruman  ??? let me know when more orders open up. I fixed my paypal and everything.
also can you share the cad file/plan for the 2 player version in case I have to whip out my jigsaw and power drill :burgerking:
Post by: HaRuMaN on April 09, 2013, 10:53:34 am
hi,
thanks
It went from 17.74" to 22", really not enough room on a sheet to get much more.
Post by: HaRuMaN on April 09, 2013, 10:54:43 am
Orders are paused for the time being, work has got me slammed and I cannot get anything else done at the moment, I will let everyone know when I'm able to take orders again.
Orders that have already been paid have been shipped out.   :cheers:
Post by: 05SRT4 on April 12, 2013, 03:06:46 am
Just got my kit!
Packaging was nice and tight, no shipping damage on any corners.
Kit contained all the correct pieces showed in the preview.
I'm really looking forward to starting building!!
Thanks HaRuMaN  :cheers:
Post by: lowgunn on April 12, 2013, 12:13:01 pm
Is that 22" edge to edge or 22" just on the control panel.   Thanks!
Post by: HaRuMaN on April 12, 2013, 12:38:33 pm
Just on the control panel.
Post by: HaRuMaN on April 12, 2013, 12:40:35 pm
Just got my kit!
I'm really looking forward to start building!!
Awesome, thanks for the order!  :applaud:
Post by: EvilEmuOfDoom on April 13, 2013, 10:58:22 pm
Got mine today!  Packed VERY well too, seriously impressed :).  I started putting it together and can't wait to play around with it!  Sadly, my CGA monitor that came in last week or the week before was DOA and had to be sent in for warranty replacement and I don't know when I'm getting it :(.  I plan on using mine as a jamma test bench as well as playing games on it.
Thanks again HaRuMan!  My friend Josh came over while I was starting assembly and really wants one now too ;)
Post by: Malenko on April 16, 2013, 08:25:22 am
got mine too, perfect condition, excellent packing!
Post by: 05SRT4 on April 16, 2013, 09:28:15 am
What PC Specs are you guys going? I'm still not sure what i'm going to put in mine.
Post by: Malenko on April 16, 2013, 09:43:19 am
no idea yet, might not even run a PC (theres always DC, xbox, 360,etc)
I got it because it was such a great deal and Bonnie's Pink Box turned out so well (version 1.0 kit from Haruman)
Post by: sharpfork on April 16, 2013, 10:57:42 am
I'd love to see some unboxing pics.
Post by: HaRuMaN on April 16, 2013, 11:00:56 am
I have a boxed pic:
Post by: Malenko on April 16, 2013, 03:01:11 pm
I only took 1
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=130522.0;attach=287774;image)
Post by: bzbee on April 19, 2013, 08:43:52 pm
This is awesome! Do you have a waiting list?
Post by: sharpfork on April 19, 2013, 08:54:15 pm
Great packing job!
SIII + Cyanogen + Tapatalk 2
Title: Re: CNC cut Weecade Inspired Kits - Orders Open! New Widescreen 2P Available!
Post by: HaRuMaN on April 24, 2013, 09:51:52 am
Orders open again.  Also have a new widescreen kit with two players available!  Designed to fit this monitor:
Title: Re: CNC cut Weecade Inspired Bartop Kits - Orders Open! New Widescreen 2P Available!
Post by: HaRuMaN on April 24, 2013, 11:32:49 am
I am also working a new design for a vertical kit.   :applaud:
Post by: SNAAKE on April 24, 2013, 09:39:58 pm
booyah! I am getting one too :applaud:
(possibly lot more depending on how things work out for me)
Post by: retrostark on April 24, 2013, 10:01:15 pm
am i getting this right you are just selling the wood cut-outs? if so you are smart. people can save a lot of time by using your kit.  :applaud:
Post by: HaRuMaN on April 25, 2013, 09:24:08 am
Yes, just the wood.  Plexiglass can be included, too.   :cheers:
With the simplified assembly, these kits do save time.
Post by: bzbee on April 25, 2013, 09:41:05 pm
I would like to place an order but I'm too new a member to send PMs. EDIT:- Looks like all I needed was 2 posts! PM coming!
Post by: HaRuMaN on April 26, 2013, 09:24:59 am
Order received, thanks!  :cheers:
Post by: SNAAKE on April 26, 2013, 09:50:17 am
call the 2 player version WeeWeeCade :lol
Post by: HaRuMaN on April 26, 2013, 09:52:18 am
Thanks, I just spit my coffee everywhere...   :laugh2:
Post by: lordnacho on April 26, 2013, 11:15:07 am
Think it could fit a Dell 2408WFP?
http://www.amazon.com/Dell-2408WFP-UltraSharp-Widescreen-Definition/dp/B0018LJYFC (http://www.amazon.com/Dell-2408WFP-UltraSharp-Widescreen-Definition/dp/B0018LJYFC)
22 x 8.2 x 15.6 inches
The Asus is
21.6 x 8.7 x 16.1 inches
Tempted.  I've got enough pc parts gathering dust as well.
Post by: HaRuMaN on April 26, 2013, 11:24:33 am
The Asus is
Yes, I would think it should.
Post by: lordnacho on April 26, 2013, 01:54:52 pm
What size monitor for the vertical?  I've got another spare 19"
And any ETA?
Post by: HaRuMaN on April 26, 2013, 01:59:22 pm
And any ETA?
Still working on the plans for the vertical.  I was planning on 19" being the default size, with a 20.1" being a tight squeeze.  Gonna try to have them drawn up by Monday.
Post by: northerngames on April 26, 2013, 03:11:30 pm
I am looking at a new VW246H as I type, will it fit the same as the VH236H? think I am a inch bigger but monitors are weird like that and may be the exact same.
or do you have dimentions for the 2player setup? if this will fit I wll do the 2 player instead of the original just becuase I have this monitor here that may fit perfect already.
22-1/2" X 13-1/2" X 3"-4" depth
Post by: HaRuMaN on April 26, 2013, 03:29:44 pm
The 2 player is 22" wide internally...
You maybe could decase it?
Post by: northerngames on April 26, 2013, 03:34:12 pm
it is actually 22-1/4" if the screen overlay is all one peice it could probaby be decased and clear the 1/8" on each side as the plastic itself is probably close to that alone.
now sure how it would look in there with no screen bezel and the display butted right up on the sides of the cab though.
Post by: HaRuMaN on April 26, 2013, 03:43:01 pm
Check out Malenko's build using my kit and a 20" 4:3, edge to edge in there:
http://forum.arcadecontrols.com/index.php/topic,131913.msg1354043.html#msg1354043 (http://forum.arcadecontrols.com/index.php/topic,131913.msg1354043.html#msg1354043)
Post by: HaRuMaN on April 26, 2013, 04:27:26 pm
Messing around with sketchup, gonna make a parts list for each bartop:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=288372;image)
Post by: Malenko on April 26, 2013, 04:27:47 pm
I left the bezel on the monitor too
Post by: northerngames on April 26, 2013, 06:16:00 pm
mine would have to come off to fit.
I think I will just stick with the 17" instead I want to keep it small anyhow and I would rather have a more squared off screen then the wide screen.
is there any cheap 17" squared lcd monitors with high res?
call me silly but I dont even know what the 4:3 / 16:9 difference is I know my res's and p/i's though lol.
cab does look good though Malenko and the work looks good too HaRuMaN
Post by: HaRuMaN on April 27, 2013, 01:37:00 pm
I got a dell 17" for mine for like $35, looks awesome. 4:3, btw. Thats the squared one. 16:9 is the wide one.
Post by: Malenko on April 27, 2013, 02:34:15 pm
my screen is "squared off" its a 4:3 monitor not a 16:9 wide screen. Its a tight fit and not the greatest monitor, but with the SGL rom craftymech its perfect for the application. I didn't buy the monitor that in mine for the application, I am just using parts that are sitting around :)
Im still working out how Im gonna position the guts inside for ease of use and what not.
Post by: SNAAKE on April 28, 2013, 05:12:53 pm
excited about that weeweecade :burgerking:
and malenko your setup must be lagging like kray!  :dizzy: I know that monitor isn't native VGA.
Post by: northerngames on April 28, 2013, 06:40:29 pm
good to know and not sure how I never knew the difference in the two  :laugh2:
even when I bought this I wanted a 4:3 but went with this vw246H 16:9 and it is great as a pc monitor and hd gaming with 2ms but the classic's look too weird for me on it.
I think a 4:3 with the slg will give me the look I am after though and should be perfect size at 17"
going from the nanao in true 15k to a 16:9 hd just aint the same for me after seeing the two and being use to playing them all native as opposed to now.
Post by: HaRuMaN on April 28, 2013, 07:20:40 pm
Yeah, here is a 17" 4:3 in my MDF prototype (running a DC with VGA cable):
Post by: Malenko on April 28, 2013, 08:00:43 pm
not really. I mean I have no problems playing the games I want. I'm not in a street fighter tourny doing frame cancels and what not, I'm playing sonic the hedgehog on a Genesis emulator and button mashing some Soul Calibur. The monitor was the right price, free ;)
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=288524;image)
Post by: retrostark on April 28, 2013, 08:49:41 pm
nice work malenko. i love sonic!
Post by: retrostark on April 28, 2013, 08:51:05 pm
isn't $140 a bit much just for wood?
Post by: yotsuya on April 28, 2013, 09:12:22 pm
It's not if you don't have the time, tools, or technical know-how. And shipped? No one who's bought one is complaining.
Post by: 05SRT4 on April 28, 2013, 11:49:07 pm
Exactly!! I'm not the best with wood tools nor do I have the right tools on hand. Buying wood and all the tools would of cost way more. Plus I would of messed it up or it would of came out crappy. I think the price is perfect. I am very happy with my purchase, cant wait to post some build pics.
Post by: Malenko on April 29, 2013, 09:20:14 am
Its cost versus worth. For me, I dont have the tools or the time so 140 is a bargain for me. If you have access to the tools and the lumber then you wouldn't be in the market for kit anyway. The 2.0 kits are pretty amazing mang.  And for comparison's sake, there is another guy selling flatpacked bartops for $150 , so its pretty consistent pricing across the board (PUN!)
Post by: candre23 on April 29, 2013, 09:25:51 am
You're not just paying for wood, you're paying for pre-cut, pre-laminated wood.  If you don't already have woodworking equipment or space to do the cutting, this is a fantastic value.  This is half the price of mameroom's flat-pack bartop kit.
OP: I want to order one but I cannot send PMs (probably because I just registered).  Your flair says you're a mod, can you fix this?
Post by: HaRuMaN on April 29, 2013, 09:51:23 am
I think you just need one more post to PM.   :cheers:
Post by: candre23 on April 29, 2013, 10:03:36 am
Then this can be my 2nd post :)
I sent you an email with my order request.  Thanks for getting back to me so quickly.
Have you considered a pedestal kit to turn this into a full-size cab?  Four holes in the bottom of the bartop and top of the pedestal plus four sets of bolts/washers/wingnuts would tie everything together nicely, and it would still be easy to break down for transportation.
Post by: HaRuMaN on April 29, 2013, 10:13:12 am
Thanks, invoice sent.
And that's not a bad idea.  I'll see what I can come up with.  Probably make a "universal" one, so it could go with the standard or the wide bartop.  I'll probably work on plans for that after I finish the vertical cabinet plans.
Post by: candre23 on April 29, 2013, 12:05:56 pm
Payment sent.  Couple questions:
Do you (or anybody else) have any pics of the 2-player version assembled?  What kind of room do we have to work with for the PC?  Will a microATX board and standard PSU fit, or do we have to get a nanoITX board and external PSU?  Is there enough room vertically for a full-height video card?  Is there room to drill in another pair of button holes (2 rows of 4 total) for both players? Do you happen to know where I stuck the box of arcade controls I bought 12 years ago?
Post by: yotsuya on April 29, 2013, 12:07:21 pm
I build one of the v1 machines using a standard size ATX motherboard, regular hard drive, and full size PSU. It's certainly doable.
Post by: HaRuMaN on April 29, 2013, 12:13:36 pm
No pics yet, this is the first run of the 2 player kit.   :cheers:  Design is just a derivative of the 1 player, so assembly will be exactly the same.
Post by: SNAAKE on April 29, 2013, 01:04:58 pm
I am good with woodworking too but this is just easier/quicker :cheers:
and malenko what exactly is that scanline thing? which model? I may need one.
Post by: mcseforsale on April 29, 2013, 02:14:28 pm
Post by: HaRuMaN on April 29, 2013, 02:15:46 pm
Post by: Malenko on April 29, 2013, 02:35:56 pm
Check out Crafty Mech's Sale thread, and PM him that you want the same one Haruman and I have.
As for guts:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=280964;image)
I took the lid of the PSU to make it fit under the controls. This is the 1 player cab (V1.0)  so I'm sure there's a lot more room in the 2p version.
Post by: candre23 on April 29, 2013, 02:42:25 pm
Thanks.  That pic gives me a better idea of what I'll have to work with.
PC bits ordered.  Assuming I can find my old buttons and joysticks, I should have all my bases covered.
Post by: HaRuMaN on April 29, 2013, 03:48:17 pm
Little preview of my build with a melamine kit:
Title: CNC cut Weecade Inspired Bartop Kits - Orders Open! New Widescreen 2P Available!
Post by: bamaholic on April 29, 2013, 04:02:25 pm
Can anyone offer any tips for getting the monitor mounted and angled correctly?  So far my only plan is to hold the monitor in the opening and eyeball the angle to mark the mount position the best I can. I've been holding off mounting the monitor because I know I'll end up with half a dozen unused holes before I get it right.
Post by: HaRuMaN on April 29, 2013, 04:06:25 pm
Mount the monitor to the VESA mount board, place cabinet on side, put monitor + mount inside.
I used blue painters tape to mark where the mount should go.  Took the monitor off the mount, placed the mount back inside (no monitor), drilled and installed screws.   :cheers:
Post by: bamaholic on April 29, 2013, 04:13:28 pm
Brilliant!  Thanks for the tip.  I knew there had to be a better way.
Post by: yotsuya on April 29, 2013, 05:17:09 pm
Dammit, Malenko, your photos have convinced me! PM sent, order placed!!!
Post by: bzbee on April 29, 2013, 08:46:47 pm
Any recommendations on decent speakers?
Title: Re: Re: CNC cut Weecade Inspired Bartop Kits - Orders Open! New Widescreen 2P Available!
Post by: HaRuMaN on April 29, 2013, 09:11:44 pm
I have some USB powered rosewill speakers in mine that work pretty well. I'll try to find the model number for you. They were pretty cheap, too.
Post by: northerngames on April 30, 2013, 01:06:17 am
did you get that cable from that link I posted?
Post by: HaRuMaN on April 30, 2013, 09:27:29 am
Yes I did, that cable works great, btw!   :cheers:
Post by: HaRuMaN on April 30, 2013, 12:15:57 pm
Here's a link to that cable, btw, if anyone is interested:
http://www.aliexpress.com/item/Wholesale-DC-VGA-BOX-Cable-dreamcast-vga-box-cable/495794790.html (http://www.aliexpress.com/item/Wholesale-DC-VGA-BOX-Cable-dreamcast-vga-box-cable/495794790.html)
Post by: northerngames on April 30, 2013, 01:03:33 pm
cool.
I am going to order another as a spare.
the vga box's are sickening on ebay anymore.
after playing it like that there's no going back to anything else for me, alot of the games even look better then ps2 and xbox games to me.
there is also ways to force most into vga off a disk even if there were not intented too and still look perfect.
Post by: Articus on April 30, 2013, 11:32:47 pm
Howdy!  First time poster here.  I ran into this forum by following a link in the KADE forum.  And I got to say, thank you for making this kit available to us.  It looks great!  Im wondering if you could make a kit of this stand alone bar-stick:
http://kadevice.com/forum/viewtopic.php?f=51&t=325 (http://kadevice.com/forum/viewtopic.php?f=51&t=325)
I think it would be a great idea for those that have very limited space but still want the arcade experience.
I for one would buy this!!  Its an excellent design by Degenatrons of the KADE Team, and I think he would be open to others using it, but I want to ask for his consent first.  If he allows this to be used, would you do it?  Any one else interested?
Once again, thank you
Post by: HaRuMaN on May 01, 2013, 09:24:31 am
Hey, if Degenatrons is cool with it, I wouldn't mind adapting it for my CNC guy.   :cheers:
Post by: candre23 on May 01, 2013, 12:42:45 pm
Can't find my box of old controls, so it looks like I'll be ordering new ones.  Does anybody know if there is enough room between the joystick hole and the button holes on the 2P cab to fit an ultimarc E-stick?
Post by: HaRuMaN on May 01, 2013, 12:48:52 pm
There is 3 and 1/16" between the center of the joystick hole and centerline of the first buttons.
Post by: degenatrons on May 01, 2013, 05:22:38 pm
Hey,  these plans are open and I'm cool for you to make use of them and improve them as you see fit.  Great if you can contribute to make it better and to move the project forward.   Idea is to have the barstick thing compatible with the weecade bartop so the control panel and marquee can be easily interchanged and reused on a portable unit.
Post by: Articus on May 01, 2013, 05:35:09 pm
AWESOME!!   :D :D :D   Thank you both!!
HaRuMaN, please PM me after you get an estimate from your CNC guy so we can work out the details.
Post by: HaRuMaN on May 01, 2013, 05:35:57 pm
Will do.  Will take a little bit, I'll have to modify the plans for my method.   :cheers:
Post by: SNAAKE on May 01, 2013, 07:55:17 pm
so any ETA on my weeweecade :bat
Post by: HaRuMaN on May 01, 2013, 07:59:40 pm
Looks like my cnc guy will cut tomorrow or Friday, and then after that I'll need to slot cut and pack after that.
Post by: wesbrown18 on May 01, 2013, 08:03:54 pm
Any chance of a Verticade kit?
I've been looking at options to play with vertical games.  I already have a full-size Blast City cabinet for horizontal games, but I'd like to have a true four-way joystick with a vertical monitor for games like Donkey Kong and Pac Man.  I have a Dell 1905 FP that I'd like to put in vertically with a scanline generator. :)
Post by: HaRuMaN on May 01, 2013, 08:10:56 pm
Yes, as a matter of fact. I have a couple of new designs in the works,a vertical cabinet is one of them.
Post by: candre23 on May 01, 2013, 09:03:26 pm
So a vertical cabinet, a control-panel-only cabinet, and a full-height pedestal are all in the works.  You're a busy beaver!
Post by: yotsuya on May 01, 2013, 09:15:00 pm
He's trying to out-CoryDee CoryDee!!!
Post by: Articus on May 01, 2013, 09:36:36 pm
Some thing like the design I linked below, with a rotating monitor would eliminate the need for separate (horizontal/vertical) cabs.  I do think it could look better and control panel seems too close to the monitor, but I like the idea!
http://youtu.be/jxbgnTcCrW8 (http://youtu.be/jxbgnTcCrW8)
Post by: Ginsu Victim on May 01, 2013, 10:26:02 pm
^That is hideous.  :angry:
Post by: yotsuya on May 01, 2013, 10:50:44 pm
+1. Ugh.
Post by: Bartopia on May 02, 2013, 12:47:50 am
Can't send you a PM as I just joined the forum- how can I get in touch with you? interested in a widescreen kit...
Post by: wesbrown18 on May 02, 2013, 12:53:26 am
+1. Ugh.
+1 - the rotating monitor isn't even centered when vertical!
Post by: Tonza on May 02, 2013, 04:24:18 am
Wow, awesome project. But is this available only in the US?
Post by: HaRuMaN on May 02, 2013, 09:28:35 am
I could try to figure out shipping for you, however, I know it would be pretty expensive.  I shipped one of these to Canada and the postage was $80.   :banghead:
Post by: HaRuMaN on May 02, 2013, 09:29:14 am
I think you have enough posts now...
Post by: lowgunn on May 02, 2013, 03:24:44 pm
Any specs for the the type of t-molding we should pic up and how long.  thanks!
Post by: HaRuMaN on May 02, 2013, 03:34:40 pm
1/2" T-molding, 20 ft.   :cheers:
Unfortunately only comes in black or white at that size, but I've been thinking about picking up some white and attempting to dye it using RIT dye.
Post by: candre23 on May 02, 2013, 03:44:16 pm
Possibly easier/more consistant than dye is SEM color coat spray paint: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&N=-1&isNodeId=1&Description=sem+color+coat&x=-889&y=-112 (http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&N=-1&isNodeId=1&Description=sem+color+coat&x=-889&y=-112)
It's very flexible and durable, so it will not flake off like most paint when you bend the molding.  I've used it for painting RC car bodies, and it's great.
Post by: bzbee on May 02, 2013, 04:56:53 pm
Is that 20ft enough for the widescreen version too?
Post by: HaRuMaN on May 02, 2013, 04:58:11 pm
Should be.  That majority goes on the sides, and those shapes haven't changed.
Post by: Articus on May 02, 2013, 08:56:54 pm
@ Ginsu Victim- Im new to this forum and I did not want to insult the original creator (in case he's a member here  ;) ).  But I have to agree with you, hence "it could look better."  I just really liked the idea of a rotating monitor, so I posted.
your reaction . . .  :D   HAHAHA!
Post by: Ginsu Victim on May 03, 2013, 01:33:21 am
^People on here have done rotating monitor setups that don't require you to ever touch the monitor.
As for offending anyone on here, we've all done it at some point (some of us more than others).
Post by: SNAAKE on May 03, 2013, 01:33:38 am
soo who's selling t-molding these days?
t-molding.com ?
Post by: Bartopia on May 03, 2013, 01:34:43 am
Did you look for 1/2" T-molding here (http://www2.archpro.com/cgi-bin/worderc?confc=B2C&s=105-667-*&catalog=120129&target=top)?
105-667 comes in multiple colors, but they say 250 ft roll in one spot, but make it look like it can be ordered by the foot on the order page...
if it's a 250 ft minimum, any group of 10 people want to split a roll of red with me?  :laugh:
Post by: candre23 on May 04, 2013, 07:10:34 am
Interior dimensions on the 2P version - is it exactly 22", or is there a little wiggle room?  I found a 24" 1080p LED TV with a vesa mount that's 22.08" x 14.31", and I'm hoping that will fit.
EDIT: Ordered it anyway.  $135 shipped was too good a deal not to take a bit of a gamble.  Lets hope it fits.
Anybody know if the 1/2" particle board is beefy enough for blind hole inserts for mounting the joysticks, ore are through-bolts necessary?
Post by: Malenko on May 04, 2013, 10:39:06 am
mine are in with 3/8th lathing screws
Post by: northerngames on May 04, 2013, 05:59:58 pm
I know it was mention prior and I wanted to see what these would kinda look like on a stand and checked ebay and they had some stands that made them look more like a full size.
if you were considering them and if it were me I would rather have a stand where the stand is larger at the base where the bartop itself would fit into the stand.
that way the whole thing just looks like a desk when not in use, maybe throw granny's fancy doyley over it etc.  :laugh2:
it would keep it put away looks clean dust free and could be locked with a tumbler lock and key perhaps too.
Post by: yotsuya on May 04, 2013, 06:49:38 pm
I  :dunno, if you're going to do all that, why not just build a full-size game???
Post by: northerngames on May 04, 2013, 08:09:55 pm
you would have to ask those that are interested or perhaps email some off ebay and ask them why they bought them over a full a cab.
me I can't tell ya what others were thinking but perhaps maybe they dont have the room for a full size cab or cabs but it dont seem like a bad optional piece to those that do want them as it was mentioned prior already.
asking that is kinda like the bartop itself and the same silly question would apply.. why that over a full cab then?
but now onto me personally I already have a full 26" nanao cab and a 39" showcase and I now want a bartop becuase either of them will fit in my pc/lab/mancave.
but I would think if it were me and they were available instead of the bartop hoggin a shelf or pc desk it is now in the corner inside the base with a monitor or shelf on top of it so no space is lost now becuase I can put something on it if it were me though.
a slide out keyboard drawer would not hurt the looks for it all either and give it more of a desk look.
sure the showcase would fit but is also would be like parking the truck in the living room.
another good example is if you only own a car it's a ---smurfette--- driving down the road with it on the roof  :cheers:
another example have you ever tackled and tugged a full size cab up your 2 flights of apartment stairs at 56 years old all by yourself without a scratch to either?
just a couple reasons why some may want one off the top of my head for ya.
in the end it comes down to prefference of the end user friend and there is already a market for them apperently.
Post by: sharpfork on May 05, 2013, 02:10:50 am
Quote from: yotsuya
Why stifle creativity?
Post by: yotsuya on May 05, 2013, 02:52:22 am
The main reason for bartops/desktops is a lack of floor space. If you're going to build something big enough to house the bartop, then I still think that makes the floor space argument moot. But whatever. Create away.
Post by: HaRuMaN on May 06, 2013, 02:32:29 pm
Whee!
Post by: yotsuya on May 06, 2013, 02:37:08 pm
More sawhorses?  :laugh2:
Post by: HaRuMaN on May 06, 2013, 02:47:31 pm
Yep.  I'm collecting 'em.
Post by: SNAAKE on May 07, 2013, 01:28:41 pm
dont forget to ask me for address. still not decided where this is going. I am not home during the days on weekdays.  :banghead:
Post by: jmike on May 07, 2013, 01:49:43 pm
You can send it to my house.  ::)
Post by: SNAAKE on May 07, 2013, 10:32:12 pm
sure..then you can put it together and bring it to me. I will update your slim xbox :lol great deal!!
Post by: cdf12345 on May 08, 2013, 02:17:59 pm
Anyone working on a template for custom graphic printers?
Post by: Aphextwin on May 11, 2013, 09:38:31 pm
Great prices! Will pick up a 2 player widescreen very soon.
Post by: HaRuMaN on May 13, 2013, 11:20:31 am
All orders in, slots cut, let the packing commence! O0
Post by: cdf12345 on May 13, 2013, 11:21:51 am
Nice!
Now I get to sit in front of my mailbox like a puppy!
Post by: yotsuya on May 13, 2013, 11:50:07 am
Picking mine up today. Damn you, Malenko!!!!  :soapbox:  :laugh:
Post by: opt2not on May 13, 2013, 02:05:32 pm
Put the kids to work! :P
Post by: HaRuMaN on May 13, 2013, 02:10:00 pm
Lol.  The 7 month old will just drool on everything, and the 3 year old will get bored after 2 minutes.
Post by: yotsuya on May 13, 2013, 03:19:56 pm
Just picked up my third (!) HaRuMaN Special. What service- he even washed my car for me while I waited.  :cheers:
Post by: HaRuMaN on May 14, 2013, 11:29:15 am
Some pics of the standard kit...
That's a microATX mobo, standard ATX power supply, 3.5" HD, and 17" Dell LCD in there:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=289361;image)
Side shot:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=289363;image)
Flash on:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=289365;image)
Flash off:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=289367;image)
Post by: opt2not on May 14, 2013, 02:01:55 pm
:o
Looks rad!
By the looks of the insides, a person *could* put a dedicated board in there, w/ scaler.
Now, to only get my hands on one... ;)
What's your status of the vertical version?
Post by: HaRuMaN on May 14, 2013, 02:11:24 pm
:o
Looks rad!
Vertical will probably be designed and prototyped early June.   :cheers:
Post by: Malenko on May 14, 2013, 02:27:29 pm
I'm helping with the design and hope to have a working prototype prior to then :)
Post by: PsychoAU on May 14, 2013, 07:04:15 pm
Hopefully this batch ships soon...  I have all these pushbuttons and computer parts laying around waiting for a home...
Post by: SNAAKE on May 14, 2013, 07:17:16 pm
oh  yeah I am trying to touch my weeweecade too :hissy:
Post by: Articus on May 14, 2013, 08:45:05 pm
That cab looks awesome!
Post by: yotsuya on May 14, 2013, 08:57:45 pm
I have an AWESOME animated gif for you to do that to......
Post by: HaRuMaN on May 14, 2013, 11:16:21 pm
Yours shipped today actually.   :cheers:
Post by: HaRuMaN on May 15, 2013, 02:51:35 pm
Each kit that is shipping out now includes a pair of these:
(http://cloudfront.zorotools.com/product/full/1WDD2_AS01.JPG)
This is an alternative (and probably easier) method to attach the monitor mount board to the inside of the cabinet walls.  Also included are 12 screws.
Post by: yotsuya on May 15, 2013, 02:56:21 pm
You got a photo of it in action?
Post by: HaRuMaN on May 15, 2013, 03:13:34 pm
No, but Malenko should.  It was his idea.   :cheers:
Post by: Malenko on May 15, 2013, 03:17:37 pm
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=289423;image)
2 screws into the vesa board, 2 into the weecade's side. Pardon the dirt, I dont really care enough to wipe down the cade prior to the photoshoot ;)
Post by: SNAAKE on May 15, 2013, 05:56:23 pm
nice.
guessing mine comes with this thing? thx!! :applaud:
Post by: HaRuMaN on May 15, 2013, 11:09:28 pm
nice.
Yes, it does. I'll pm your tracking number.
Post by: HaRuMaN on May 16, 2013, 09:44:45 am
All remaining orders are shipping today!   :applaud:
Post by: yotsuya on May 16, 2013, 11:43:48 am
I forget, how much t-molding is needed?  Thanks.
Post by: HaRuMaN on May 16, 2013, 11:44:50 am
20 feet, you'll end up with a little extra.
Post by: HaRuMaN on May 17, 2013, 12:49:04 pm
Here's how I lit the buttons:
Post by: lordnacho on May 17, 2013, 02:24:08 pm
Are pedestals still in your master scheme?  Think you said maybe after the vertical bartop.
I'm flip flopping between that and a bartop or a full slim.  I'd build but I'm in NYC, so can't really be routing outside.
Post by: HaRuMaN on May 17, 2013, 02:30:20 pm
Yes, they are.  Plans for the vertical are almost done, pedestal to follow.   :cheers:
Just out of curiosity, any features you'd like to see in a pedestal?
Post by: yotsuya on May 17, 2013, 02:33:44 pm
Thanks for the answer!
Post by: lordnacho on May 17, 2013, 02:46:22 pm
Stability would be high up...hyper kids.  Other than that not too picky.  Two player/6 buttons each/trackball.  Coin door slot would be very nice.  Maybe an area for hidden admin buttons.
Post by: HaRuMaN on May 17, 2013, 03:09:24 pm
Noted.  None of that should be too difficult...   :cheers:
Post by: yotsuya on May 17, 2013, 03:10:17 pm
You might want to consider a projector shelf, as well.
Post by: HaRuMaN on May 20, 2013, 01:15:55 pm
Hmm, good idea
Post by: yotsuya on May 20, 2013, 02:47:15 pm
Hey, everything's going together nicely on mine. Just waiting for the CPU to come in.
Where did you get the channel for the plexi?
Post by: HaRuMaN on May 20, 2013, 03:22:56 pm
http://displayproductsonline.com/?___store=default (http://displayproductsonline.com/?___store=default)
They have all kinds of stuff.  Their L-channel makes a good marquee retainer, too.
Post by: cdf12345 on May 21, 2013, 12:12:38 am
Are the 2player models shipping yet , or have just the single player been going out so far?
Post by: HaRuMaN on May 21, 2013, 09:29:37 am
All orders have shipped, 1p & 2p.  :cheers:
Post by: cdf12345 on May 21, 2013, 09:40:37 am
That is awesome! *high five*
Post by: Nephasth on May 21, 2013, 10:09:33 pm
I can't see ---steaming pile of meadow muffin---.
Post by: Malenko on May 21, 2013, 10:20:11 pm
2 3" (I'm guessing 3 inch) cold cathodes vertically mounted between the 3 vertical rows of buttons, clear buttons, black plungers.
Post by: Nephasth on May 21, 2013, 10:26:22 pm
Thanks man.
Post by: HaRuMaN on May 21, 2013, 10:59:57 pm
Bingo!
Post by: SNAAKE on May 22, 2013, 10:23:43 pm
finally touched my weeweecade :burgerking:
(http://www.thesharkguys.com/wp-content/uploads/2012/10/Borat_Great_Success.jpg)
Post by: cdf12345 on May 22, 2013, 10:51:09 pm
Is there any way we could get a couple of more pictures explaining the final steps of finishing off the control panel, back panel and monitor mount panel.
I can't figure out how the control panel top will be secured. Same with the back panel. I'm also a little confused about the new metal hardware for the versa panel.
Maybe a little more in depth pics and description would help?
(I have the 2 player widescreen version)
Btw the packing was impeccable!
(http://i.imgur.com/Eai0JrJ.jpg)
(http://i.imgur.com/reLISsk.jpg)
Post by: jmike on May 22, 2013, 11:10:39 pm
Pics or it didn't happen.  ::)
Post by: 05SRT4 on May 23, 2013, 02:52:58 am
I'm still trying to figure out how I am going to do my CP to. Maybe instead of gluing in the bottom have both pieces one piece with a hinge at the bottom?
I was looking at hinges at Home Depot that allow a overlay but it seemed like you would need to dig into the sides to much, plus the mounting area look big and may get in the way.
Post by: cdf12345 on May 23, 2013, 04:06:40 am
My primary concern is being able to access the underside of the buttons later (where the wiring is) there's not a whole lot of room there. So ideally a way to easily remove or access the CP underside would work great.
Post by: lowgunn on May 23, 2013, 08:04:56 am
HaRuMaN, what's the dimension for the plexi screen and marquee for the wide screen and normal sized kit.  OSH is going out of business near my area and their having a huge liquidation sale.  Planning to get them before they sell out.  Thanks again for the awesome kit.
Post by: Malenko on May 23, 2013, 08:15:44 am
I use industrial Velcro to attach my control panel top to the batons. You could drill 2 holes on each side and use a joystick nut and bolt as well.
I can try to take pictures tonight.
Post by: 05SRT4 on May 23, 2013, 09:25:02 am
I think I will try this to, I just bought some Industrial Strength Velcro to mount my Power Supply.
Post by: degenatrons on May 23, 2013, 10:55:34 am
A simple way to make the control panel removable is to make access holes in the bottom panel and secure control panel from the underside.
A quick sketch to help explain what I'm talking about:
(http://i.imgur.com/WkzmObb.jpg)
This makes for a sturdy fix with no visible screws.
The small semicircular cutouts can then be used to plug the holes on the underside if required.
Consider updating the CNC plans to include the access holes in the bottom panel.
Post by: cdf12345 on May 23, 2013, 12:44:21 pm
My cat has claimed the first game on the new cabinet, she even brought a milk ring as a "quarter" to save her spot.
(http://i.imgur.com/bKMnxtd.jpg)
Post by: stoopid2001 on May 23, 2013, 01:02:43 pm
Hey, I'm interested but can't pm yet.  Can you email me?  Thanks!
Post by: HaRuMaN on May 23, 2013, 05:44:21 pm
Excellent idea! Why didn't I think of that? :o
Post by: HaRuMaN on May 23, 2013, 05:46:14 pm
Excellent! My cat does the same thing with the milk rings, lol
Post by: Danky21 on May 24, 2013, 11:56:43 am
These are some great looking kits HaRuMaN! Would you mind sharing the dwg file for the 2 person cab? I only see the 1 person up above.
I would like to modify them a bit (if you don't mind) to fit a 20.1" 4:3 Dell 2001FP while retaining the 2 person control layout, and I'm afraid the 1 person design is just a bit too small for that sort of application.
Post by: PTD on May 24, 2013, 08:16:34 pm
Can I still order?  I am new and I just register this forum just so that I can order this cool cabinet.
Post by: HaRuMaN on May 24, 2013, 10:24:09 pm
@Danky21, I'll get it up soon
Post by: 05SRT4 on May 25, 2013, 12:27:43 pm
Hey guys, just wanted to show some shots of my build so far. HaRuMaN I am very excited about this build I know I would never be able to get a cab to look this good with my wood working skills. With this kit you saved me a ton of money and time!!  :cheers:
(http://s19.postimg.org/el73r9ran/DSC01337.jpg) (http://postimg.org/image/el73r9ran/)
(http://s19.postimg.org/98i9d53e7/DSC01339.jpg) (http://postimg.org/image/98i9d53e7/)
Post by: HaRuMaN on May 25, 2013, 01:53:43 pm
That's look great! Thanks for the pics and the feedback!
Post by: TheOne on May 25, 2013, 06:26:33 pm
Does anyone have a link to the build diagrams for this bartop?
Thanks.
Post by: JDFan on May 25, 2013, 06:55:29 pm
Thanks.
The .dwg file is in the first post of this thread - you just need a program that can open AutoCAD DWG files - for example this one : http://download.cnet.com/Free-DWG-Viewer/3000-18496_4-127820.html (http://download.cnet.com/Free-DWG-Viewer/3000-18496_4-127820.html)
Post by: stoopid2001 on May 26, 2013, 10:47:39 am
Anyone have a pic of the two player version assembled?
Also will these type buttons fit depth wise?
http://www.ebay.com/itm/HAPP-14-BUTTONS-JOYSTICKS-JAMMA-ARCADE-WKS-W-MAME-TM-/380195640715 (http://www.ebay.com/itm/HAPP-14-BUTTONS-JOYSTICKS-JAMMA-ARCADE-WKS-W-MAME-TM-/380195640715)
Post by: HaRuMaN on May 26, 2013, 12:14:14 pm
Yes, standard Happ buttons will fit.
Post by: billmcse on May 26, 2013, 05:01:02 pm
Can you put anything over the melamine to protect it? Also, what are you guys using, if anything, on the top of the control panel since that will obviously get the most wear?
Post by: bzbee on May 26, 2013, 09:51:28 pm
@Danky21 :- I'm curious what dimensions you'll need to modify to fit the 2001fp. Please LMK, thanks!
Post by: cdf12345 on May 26, 2013, 10:25:49 pm
What kind of solutions is everyone coming up with to secure the plexiglass and the marquee?
Post by: Malenko on May 27, 2013, 09:01:13 am
Screen plexi for me is held in with friction, bottom rests against the top of the control panel, the top is between the screen and the speaker panel. Marquee I use aluminum L brackets from Home Depot. a 36" piece is like 3 bucks. cut it into 2 17.75" pieces, drill holes for screws and mount. I also painted them gun metal grey.
This is a version 1.0 kit (with batons and no melamine):
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=281951;image)
I did the same technique to put plexi over the control panel. But for this monitor, since its a touch screen, the plexi is lag bolted into the LCD bezel.
Post by: dubleon on May 28, 2013, 12:33:35 pm
Also really interested in what  the 2 player plans look like :) Does anyone have any pictures of the completed 2 player? Also if anyone has any good suggestions RE: Admin buttons and speaker system for a PC MAME please PM me :) Thanks!
Post by: billmcse on May 28, 2013, 05:45:39 pm
Batons seem to be a tight fit. I'm afraid of tapping them with a hammer as I don't want to chip the melamine off.
Post by: Danky21 on May 28, 2013, 07:03:31 pm
Perhaps HaRuMaN can chime in, but it looks like as long as the circled edges are lengthened a few inches (along with the curve) it should be able to accommodate a 20 inch 4:3 screen.  This would also allow for a bezel rather than running right up to the edge, no offense Malenko. The next issue is fitting as much onto a sheet of melamine, but at the bare minimum it should be possible to fit 3 total cabinets onto 2 sheets.  Would anyone else be interested in this size if it was an option?
(http://i.imgur.com/CnXeyLJ.jpg)
Post by: dubleon on May 29, 2013, 02:05:29 am
So its a modified 2 player weedcade that fits a 20.1" 4:3 Dell 2001FP screen? I might be interested  :)
Post by: Malenko on May 29, 2013, 07:30:22 am
Why would I be offended, lol
What I did works best for her touchscreen based machine, and by best I mean it works and wasnt a pain. I did the same thing with my dreamcast based machine to fit the 20" monitor I put in there. The plans are community based, so anyone who wants to improve on it could and should.
The next change I was going to discuss with Haruman was adding a bottom panel to the back and making the back door smaller (similar to the top part of the V2 backdoor) so you can run power wires or USB ports and not have them be part of the door.
Post by: PTD on May 29, 2013, 12:18:44 pm
How do you guys smooth out the edges?  From the default cabinet, it looks like the edges are not smooth and looked exposed.  I saw the above picture from Malenko's cabinet that it has  nice black smooth edges.
Post by: JDFan on May 29, 2013, 12:32:03 pm
The edges are covered with T-molding or other pieces of the cabinet that are covered with the Melamine so that the exposed edges shown in the default cabinet are not shown when assembled. IF not using T-molding you could also buy strips of black Melamine edging which is backed with glue so it can be added to the edges and then trimmed to make a clean edge. For Example This ( http://www.amazon.com/home-improvement/dp/B00315PNAI (http://www.amazon.com/home-improvement/dp/B00315PNAI) ) which has 25 feet of 7\8" edging for about $8.
Post by: PTD on May 29, 2013, 12:57:26 pm
Thank you JDFan.  Now you know how much I know about carpentry and that is why I will be ordering this nice arcade cabinet kit from HaRuMaN.  ;D
Post by: 05SRT4 on May 30, 2013, 03:47:26 am
How are you guys managing the power cable in the back? A simple hole at the bottom or are you using an adapter or grommet?
Never mind just read  This article. (http://forum.arcadecontrols.com/index.php/topic,132601.0.html[url/)
Post by: HaRuMaN on May 30, 2013, 09:38:31 am
I mounted a power strip inside mine and just cut a little hole in the corner of the back piece.
Post by: cdf12345 on May 30, 2013, 09:48:29 am
I like using something like these male power socket connectors that feed into a smart strip.
http://www.amazon.com/gp/aw/d/B00843KZP0/ref=mp_s_a_1_3?qid=1369921566&sr=8-3&pi=SL75 (http://www.amazon.com/gp/aw/d/B00843KZP0/ref=mp_s_a_1_3?qid=1369921566&sr=8-3&pi=SL75)
(http://i.imgur.com/hDRnHiu.jpg)
Post by: Danky21 on May 30, 2013, 05:06:30 pm
That's my goal at least.  I'd like to implement a few changes to the 2P design:
1: Increase height to allow for 20.1" 4:3, while leaving the width the same to keep the 2P setup.  A 20.1" screen would have a ~3" bezel, a 19" would have a ~3.5" bezel
2: Ideally the height would be added using Malenko's idea of a bottom panel in the back of the cabinet, so any wiring would not need to go through the door
3: Add a piano hinge between the 2 back panels, possibly with an arcade cabinet style lock at the top to hold the door shut?
4: Implement degenatrons' method of attaching the CP using holes in the underside of the cabinet, and screwing into tee nuts in the bottom of the CP.
5: Retain the current 2P footprint so that this taller "not-so-weecade" is compatible with any pedestal that is designed for the 2P "weeweecade"
Post by: cdf12345 on May 31, 2013, 02:42:57 am
Do you have a picture of this zoomed out a bit?
Post by: HaRuMaN on May 31, 2013, 07:16:11 am
@Danky, once I get back to my computer on Monday, I'll take a look at your plans.
Post by: Malenko on May 31, 2013, 07:58:41 am
I can take one after work when I get home.
Post by: cdf12345 on May 31, 2013, 09:23:32 am
That would be awesome, thank you!
Post by: PTD on May 31, 2013, 11:52:51 am
HaRuMaN,
I am new at this arcade building thing and I have been reading up (and watching youtube videos) on how to build an arcade machine.  The hardest part for me is the wiring the buttons.  Is there anyway that you can sell the cabinet with preinstalled buttons on the panel which is hooked up with an ipac (etc...) so that all I have to do is build a computer with working hyperspin/games and all I have to do is just plug in and play?
Post by: JDFan on May 31, 2013, 12:11:01 pm
HaRuMaN,
IF you use an Ipac or similar encoder the wiring is actually very simple -- Just a matter of running a daisy chain wire with connectors for each button switch to the ground connector of each button and then to the ground connection on the Ipac - and then one wire each to the NO (normally Open) connection on the switch and back to the correct connector on the IPAC (ie. Up switch on 1P joystick to 1 Player Up connection on the Ipac) Just take your time and run one wire at a time and you wont have any problems with doing it. On the button switches there are 3 connection points - 1 for the ground - 1 NO and 1 NC - you connect only 2 of them ( The Ground and the NO) If you hook it up to the NC and ground instead of NO the button will always be sending a pressed signal except when you press the button which is not want you want so do not use that connector (it is labelled on the switch).
It really is a lot easier than you think because there are so many connections that looking at a completed panel looks difficult but when wiring it one connection at a time it is actually fairly simple. If you can do the Computer setup you'lll have No Problem  wiring the CP !
Post by: PTD on May 31, 2013, 11:05:22 pm
I have never wire the buttons before so that is why I thought it is difficult.  I can build a top-of-the-line desktop computer completely from scratch in under 30 minutes so I guess I can give it a try.
Post by: retrokid on June 01, 2013, 05:01:36 am
Superbe work there matey
Sent from my GT-I9100 using Tapatalk 2
Post by: bzbee on June 02, 2013, 11:30:09 am
Woodworking newb here. What's the best way to cut the wood for this? I tried drilling a hole big enough for a coping saw, but it was a bit slow going. I ended up going with a Dremel sanding wheel, and cut off too much on one side, so it doesn't look the greatest ...  :badmood: :badmood:
Fortunately this was a piece of scrap I was practicing on.
Post by: 05SRT4 on June 02, 2013, 02:05:52 pm
To cut sharper corners I use a bit like this on my dermal - http://www.dremel.com/en-us/Accessories/Pages/ProductDetail.aspx?pid=561 (http://www.dremel.com/en-us/Accessories/Pages/ProductDetail.aspx?pid=561)
Post by: solid187 on June 02, 2013, 08:54:43 pm
My WIP. I think I''m going to keep this one simple with a black and white theme. Not quite sure yet.  :dunno
Post by: Malenko on June 02, 2013, 09:36:16 pm
sorry it took so long, I forgot :/
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=290497;image)
Post by: cdf12345 on June 02, 2013, 11:31:47 pm
Did you not use the two other pieces of wood that was included for the vesa mount board?
In the original instructions there are two pieces of wood to glue to the vesa panel then mount, I can't tell if you still used these and they're on the other side of yours or not.
Post by: Malenko on June 03, 2013, 07:54:41 am
No I didn't use them. Typically they form a U around the monitor, but the monitor I used was too big for that (20" 4:3 monitor) so instead of those 2 pieces of wood I used the metal corner braces.
Post by: HaRuMaN on June 03, 2013, 10:31:06 am
Back from vacation!  Got a couple of new prototypes coming in later this week from the CNC, one's that barstick, and the other is a surprise...   ;)  :applaud:
Post by: fantoboy on June 03, 2013, 04:46:02 pm
Just ordered two!   :D
Post by: HaRuMaN on June 03, 2013, 04:47:25 pm
Order received!  I'll be placing my next order with my CNC guy in a couple of days.   :cheers:
Post by: jmike on June 03, 2013, 07:57:15 pm
A surprise?? Okay subscribed.  :applaud:
Patiently waiting.  :badmood:
Post by: fantoboy on June 03, 2013, 08:33:28 pm
Is there a template I can use to set up my artwork?  I got the two player version.
Post by: Malenko on June 03, 2013, 09:01:14 pm
I know whats in the pipeline  >:D
Post by: cdf12345 on June 03, 2013, 09:10:18 pm
I was looking for this too. Something for the sides work be perfect.
Post by: cdf12345 on June 05, 2013, 03:29:21 am
Thanks again for the photos. Just a warning for anyone else using these brackets: the screws included are too long and when I mounted my monitor the screw tip came through the wall of the cabinet. So I recommend finding slightly shorter screws on your own and not using the ones included.
Post by: Malenko on June 05, 2013, 09:59:51 am
I use 1/2" lathing screws, I should have specified. Hope the damage isnt bad :(
Post by: HaRuMaN on June 05, 2013, 10:07:08 am
Alternately you could use a couple of washers to space the screws back a bit
Post by: yotsuya on June 05, 2013, 10:17:18 am
That's what I did.
Post by: cdf12345 on June 05, 2013, 11:02:08 am
It just barely broke through. I think it will be fine once I put a decal over it.
Post by: PTD on June 05, 2013, 07:50:37 pm
Is there any place that sells 1/2" t-molding that has different colors instead of just black or white?
I just realized that gamemolding.com only offers black or white color in 1/2" size :-(
Also, do you guys take the bezel/covering of the monitor off to save space or do you just mount the monitor in its original form?
Post by: HaRuMaN on June 05, 2013, 09:58:03 pm
Unfortunately, 1/2" T-molding only comes in black or white.  I've been meaning to buy some white and attempt to dye it to see if I can get some different colors that way.
I left my monitor (17" 4:3) intact.
Post by: cdf12345 on June 05, 2013, 11:19:49 pm
What is everyone using for a backplate hinge/solution?
Post by: 05SRT4 on June 06, 2013, 03:25:26 am
I am using the same hinge as Malenko, got mine at Home Depot check here.
 (http://www.homedepot.com/p/Everbilt-1-1-2-in-x-12-in-Nickel-Continuous-Hinge-14629/203339969#.UbA34thK3ag [/url)
Post by: PTD on June 06, 2013, 06:56:09 pm
I planned to put a touch screen monitor in this bartop arcade.
However, I don't know a solution to getting a border that would be flush with the monitor.  Normally you have a plexiglass in front of the monitor to protect it but since it is a touch screen and I will be playing some games with touch screen capability (using Windows 8 with PC games), I don't think that putting a plexiglass in front of the monitor is ideal.
Any suggestions ?
I am talking about the wide screen 2-player version of this arcade.
I am looking at this monitor from Dell:
http://accessories.us.dell.com/sna/productdetail.aspx?c=us&cs=19&l=en&sku=320-9738 (http://accessories.us.dell.com/sna/productdetail.aspx?c=us&cs=19&l=en&sku=320-9738)
(http://oi44.tinypic.com/2wg9cty.jpg)
Post by: Malenko on June 06, 2013, 07:36:46 pm
cut a square out of the inside of the plexi. Go back a page or 2, that pink machine is my fiancee's and its running a touch screen (she loves spot the difference , hidden object games, and Plants VS Zombies)
Post by: cdf12345 on June 06, 2013, 07:37:56 pm
Speaking of plexiglass, what kind of mountsis everyone getting for theirs?
Post by: PTD on June 06, 2013, 07:54:29 pm
This is what I plan for my build.
Please advise:
I will be getting the 2 player wide screen version from Haruman
1.  Monitor:  Dell S2240T, 21.5-inch Monitor touch screen
2.  ASUS Maximus IV Impact motherboard:
(http://www.hardwareluxx.com/media/jphoto/messe-galerien/computex-2013-asus-maximus-iv-impact/ctex13-asus-rog-impact-05-950x536.png)
3.  Micro ATX power supply:
http://www.amazon.com/gp/product/B005CP07BA/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=ATVPDKIKX0DER (http://www.amazon.com/gp/product/B005CP07BA/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=ATVPDKIKX0DER)
4.  CPU: Intel Haswell Core i5 4670K
http://microcenter.com/product/413251/Core_i5_4670K_34GHz_Socket_LGA_1150_Boxed_Processor (http://microcenter.com/product/413251/Core_i5_4670K_34GHz_Socket_LGA_1150_Boxed_Processor)
I hope that getting the Haswell CPU would have enough GPU power to not need a dedicated graphic card.  If it is too weak to play PC games such as Street Fighter 4 PC game, then I will add in a low profile graphic card.
5.  8 GB of RAM
6.  I will use Hyperspin as my front end.
Other accessories such as joysticks, buttons, ect....for the control panel is still deciding on which one to get.
I want to build a bartop arcade that can use touch screen as well as play PC games such as Street Fighter 4 and Street Fighter vs Tekken, etc... without any problem.
So what do you guys think so far?  What do you suggest for the buttons and joysticks?
Post by: HaRuMaN on June 07, 2013, 04:52:52 pm
Well, have a couple more prototypes in hand, will be checking them over this weekend.
First is the degenatron's designed barstick, modded to use the tab / slot construction method.
Second is my own creation, an MVS inspired design, single player, 4:3 monitor.
I should be posting some pics this weekend!
Also, I just submitted a set of vertical plans to my cnc guy for prototyping.   :cheers:
Post by: Articus on June 08, 2013, 09:57:26 pm
Im looking forward to your pics!
Post by: billmcse on June 09, 2013, 08:39:05 am
Has anyone hinged the control panel???
Post by: HaRuMaN on June 09, 2013, 01:37:42 pm
MVS inspired single player:
Post by: sharpfork on June 09, 2013, 04:24:06 pm
I like the look of this one.   :)
Post by: HaRuMaN on June 09, 2013, 05:27:22 pm
Thank you!  I've got another 'original' coming in a few days, as well.   :cheers:
Post by: sharpfork on June 09, 2013, 06:44:51 pm
I have a couple I'm working on too, all classic inspired.  Fun stuff!
Post by: HaRuMaN on June 11, 2013, 11:19:22 am
Here is the degenatron's bar stick laid out. (There is a pocket missing on of the sides, a new one had been cut, will get tomorrow).
Other than that everything fits great!
Title: CNC Cut Bartop Kits - Orders Open! New Models Available!
Post by: Articus on June 11, 2013, 12:27:49 pm
Barstick looks great!!  Well done!  I cant wait to see it built.  how much for this kit?  also, is there any way to add pinball flippers (one on each side)?  And is it possible to have an option to switch from 2player to 1player+trackball control panels?
Thank you for the awesomeness!
Title: Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
Post by: HaRuMaN on June 11, 2013, 12:32:18 pm
Still waiting to hear back from my CNC guy on what the final cost per kit will be, then I can come up with a price.  Box will be quite a bit smaller, and lighter, so that will help on shipping costs.
Right now I'm guessing it'll be under $100, by how much not quite sure yet.
I can add pinball holes, and can make a cp for 1 player with trackball.
Post by: dubleon on June 11, 2013, 06:10:48 pm
Anybody have any art for the 2 player kit installed? If so, can I see a pic? Also, is there an ETA on delivery of the next batch? Thanks!
Post by: tron84 on June 11, 2013, 07:24:08 pm
The MVS & bar stick look great  :cheers: :applaud:
What is the biggest size screen that can go in them?
Post by: HaRuMaN on June 11, 2013, 07:28:08 pm
The MVS should hold the same screen as the standard, so 17" or 19". A 20.1" should just make it, but it would be tight. Those are all 4:3's, btw.
The bar stick is just a standalone, so no monitor.
Post by: tron84 on June 11, 2013, 07:43:04 pm
Ok thanks man...
Have not seen the bar stick before, I like that idea that you can use any size monitor.  ;D
They look great, cant wait to see a pic of an assembled one of both and the price of them.
Great job again, they look very nice.
edit: I see you have the mvs price up :) thx
Post by: PTD on June 11, 2013, 11:14:54 pm
So do you use a wireless hdmi transmitter/receiver to use with the bar-stick ?
http://www.amazon.com/Nyrius-Transmitter-Streaming-Satellite-NPCS549/dp/B009E6R89C/ref=sr_1_1?ie=UTF8&qid=1371006688&sr=8-1&keywords=wireless+hdmi (http://www.amazon.com/Nyrius-Transmitter-Streaming-Satellite-NPCS549/dp/B009E6R89C/ref=sr_1_1?ie=UTF8&qid=1371006688&sr=8-1&keywords=wireless+hdmi)
(http://img.rakuten.com/PIC/48770593/0/1/300/48770593.jpg)
It would be nice just to bring the bar-stick and wireless hdmi kits to another house for instant game play to any hdtv.
Post by: HaRuMaN on June 12, 2013, 12:54:54 pm
New website & store up & running!
Note it's still a work in progress, so it's a bit rough around the edges, but the cart is active.
Will be getting better pictures, descriptions, etc in the near future.   :cheers:
http://www.harumancustoms.com/ (http://www.harumancustoms.com/)
Post by: Articus on June 12, 2013, 07:34:50 pm
Im liking the site, good job!
Post by: degenatrons on June 12, 2013, 08:15:43 pm
Ok thanks man...
Here are some pics of the prototype to give you an idea of what it looks like assembled.  I've since added a lip to the bottom of the marquee in the original plans - to separate CP from marquee.  It needs to be painted.
(http://i.imgur.com/okIMl3nl.jpg)
(http://i.imgur.com/bUkqZ3nl.jpg)
Post by: tron84 on June 12, 2013, 10:31:28 pm
Ok thanks man...
Thanks for preview,
looks good, that will be a nice controller to have for the family room tv  ;D
ahhh luv the elevator action in the pic, classic game  :cheers:
Post by: HaRuMaN on June 14, 2013, 12:54:04 pm
Price for the barstick set, going to be $85 shipped.   :cheers:
Post by: cdf12345 on June 14, 2013, 01:02:59 pm
Nice!
Post by: dubleon on June 14, 2013, 04:13:04 pm
Can I have an ETA on the 2 player kit please? Thanks!
Post by: HaRuMaN on June 14, 2013, 04:32:24 pm
Kits have been cut & picked up, I will be slot cutting & packing this weekend, should get them in the mail Monday, delivery around Friday using Fed-Ex home.   :cheers:
Post by: dubleon on June 14, 2013, 07:59:34 pm
Thanks man!
Post by: stoopid2001 on June 14, 2013, 10:27:52 pm
I feel a sick day coming on!
Post by: HaRuMaN on June 15, 2013, 10:47:19 am
Barstick side fixed, everything dry-fit together.
Post by: HaRuMaN on June 16, 2013, 05:46:21 pm
Started a Facebook Page...   :D
https://www.facebook.com/HarumansCustoms (https://www.facebook.com/HarumansCustoms)
Post by: PTD on June 17, 2013, 01:50:51 pm
Questions on the 2-player widescreen version:
1.  Which joystick is recommended for the control panel?  I am considering the OMNI2 joystick at GroovyGameGear but RandyT said that it "will need 2.25" clearance below the bottom surface of the upper panel."  Will this joystick fit the control panel.  I want to get it with the SmoothJoy™ Switches installed.  I like quiet joystick and buttons.
If the OMNI2 joystick cannot fit, what is your recommendation on a good joystick that is quiet.  Price is not a concern.
2.  Which buttons should I get?  I prefer quiet and soft buttons.  I don't need LED.  I need buttons that would fit the 2-player bartop.  Price is not a concern.
3.  I have decided to get Ivy Bridge CPU/motherboard instead of Haswell.  Would this power supply fit?
http://www.amazon.com/FSP-Certification-FSP400-60GHS-85--R/dp/B005CP07BA/ref=sr_1_6?ie=UTF8&qid=1371490124&sr=8-6&keywords=micro+atx+power+supply (http://www.amazon.com/FSP-Certification-FSP400-60GHS-85--R/dp/B005CP07BA/ref=sr_1_6?ie=UTF8&qid=1371490124&sr=8-6&keywords=micro+atx+power+supply)
4.  I will have gamecube/wii/ps2/dreamcast emulators and PC games such as Street Fighter IV and Street Fighter vs Tekken, and other PC games in the Hyperspin front end so I need a powerful graphic card.
Will this fanless graphic card fit in the itx motherboard in this bartop cabinet ?
http://www.amazon.com/gp/product/B007M8SGJA/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER (http://www.amazon.com/gp/product/B007M8SGJA/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER)
5.  I plan to get this monitor:
http://www.amazon.com/ASUS-VS239H-P-23-Inch-Full-HD-Monitor/dp/B008DWITHI/ref=dp_ob_title_ce (http://www.amazon.com/ASUS-VS239H-P-23-Inch-Full-HD-Monitor/dp/B008DWITHI/ref=dp_ob_title_ce)
Will it fit?
Thanks.
Post by: HaRuMaN on June 18, 2013, 11:41:54 am
This kit was designed for a widescreen 23" monitor, so I would think that should fit.
The available width is 22", the specs say that monitor is 21.7" so you should be good.
That joystick should fit as well.  At the midpoint, there is about 3.2" of clearance, gets wider as you go back, a little shallower as you come forward.
The other components will depend on your monitor and the space it takes up.
Post by: HaRuMaN on June 18, 2013, 11:46:00 am
Vertical kit arrives today from the CNC shop.  Excited to see this one.   :applaud:
Post by: HaRuMaN on June 19, 2013, 09:50:43 am
Some pictures of the new MVS bartop I'm assembling:
Post by: bzbee on June 19, 2013, 10:28:59 am
The MVS kit looks great! Is it also limited to 19" monitors or are the vertical dimensions any different?
Post by: HaRuMaN on June 19, 2013, 10:47:53 am
19" would be the recommended size, but you should be able to squeeze a 20.1" 4:3 in there...  I think...
I have a Dell 2001FP (20.1") I'll try to stick in there, see how it fits.
Post by: dubleon on June 19, 2013, 04:10:45 pm
Still on for friday delivery? :)
Post by: HaRuMaN on June 19, 2013, 04:21:56 pm
Yup!  :cheers:
PM sent with tracking info.
Post by: HaRuMaN on June 20, 2013, 10:01:40 am
Preview of what's next:
Post by: creeperkillr on June 20, 2013, 01:50:22 pm
i got a 4x8 cnc id be more then happy to make them during the summer
Post by: Articus on June 20, 2013, 02:06:04 pm
HaRuMan, any status on my order?
Post by: HaRuMaN on June 20, 2013, 02:10:20 pm
Yes, I have your order complete, barstick with pinball flippers added, and a second control panel with 1p & 50mm trackball hole.  I ordered some smaller boxes so I can get these sent out, I'm hoping to get the boxes today.  If not, I will just dig around and find a box to ship it in.
Post by: Articus on June 20, 2013, 02:20:58 pm
Thank you!  I cant wait!!  :)
Post by: tron84 on June 20, 2013, 09:00:32 pm
Order placed  ;D
Guess I have to sit & drink my beer & get some games in, while I wait for it to come  :cheers:  ;D
Thanks again Haruman   :applaud:  ;D
Post by: opt2not on June 21, 2013, 03:12:40 am
Vert-top in the hizzy?
Title: Re: Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
Post by: HaRuMaN on June 21, 2013, 09:56:17 am
Ding ding ding!
Post by: stoopid2001 on June 21, 2013, 01:31:06 pm
Got my 2 player today, Thanks HaRuMaN.  Here are some unboxing pics-
http://imgur.com/a/XMapc (http://imgur.com/a/XMapc)
Post by: HaRuMaN on June 22, 2013, 07:01:38 pm
Awesome! Have fun assembling it!
Post by: HaRuMaN on June 22, 2013, 07:02:50 pm
I have another MVS kit on hand if anyone wants to order... ;)
Post by: cdf12345 on June 22, 2013, 09:04:00 pm
Do you have any templates that would be useful for printing graphics?
I don't know what program you're using to layout your cuts but having exact dimentions for the sides would be really helpful when creating artwork for the side of the cabinets.
Post by: HaRuMaN on June 23, 2013, 11:40:22 am
Vertical assembled!
Post by: HaRuMaN on June 23, 2013, 02:36:10 pm
Now that's starting to look like a Neo Geo!
Post by: dubleon on June 23, 2013, 07:59:47 pm
+1 for 2 player graphics template, thanks!
Post by: Articus on June 23, 2013, 08:23:02 pm
These are based on the weecade.  Cant you just use those CAD drawings for the template needed?
Post by: PTD on June 23, 2013, 11:35:56 pm
Even so,  I don't have the CAD based on the weecade.  I have the 2-player cabinet and also need the template to ask the graphic designer to do the graphics.
I have seen a lot of people as for this but so far we don't have the template/exact size,dimension for the 2-player version.
Post by: Malenko on June 24, 2013, 08:51:58 am
Im sure he'll post them, don't you have the physical panel and a tape measure?
Post by: HaRuMaN on June 24, 2013, 09:45:01 am
The sides on the 2 player weecade are exactly the same as the 1-player.
Post by: HaRuMaN on June 24, 2013, 10:51:17 am
Try this for the standard:
Post by: HaRuMaN on June 24, 2013, 10:56:14 am
Try this for the wide:
Post by: HaRuMaN on June 24, 2013, 11:17:10 am
Bartop row...
Post by: Malenko on June 24, 2013, 11:42:04 am
These are taken from his plan pictures he posted, inverted so its black lines on white, and scaled up.  The lines are a little yucky, but that why you cover them with art.
Post by: ebarlow99 on June 24, 2013, 01:15:33 pm
love the 3 designs!! look great!
Post by: JDFan on June 24, 2013, 01:19:52 pm
Just a suggestion but you might want to change them to 300PPI instead of 72 --- figure if they are being used for artwork you'll want at least a 300PPI final image and some users may not realize they need to adjust it before drawing up the art for printing. Also if you want to clean up the holes if using a 300PPI image using a brush size of 338 pixels will place a 1-1\8" Diameter circle with a single mouse click where desired.
Post by: Malenko on June 24, 2013, 01:43:25 pm
Feel free to do all that, Im at work using MSPaint :p
Post by: JDFan on June 24, 2013, 02:03:41 pm
OK here you go (Note : don't have one to verify sizing is correct so if someone could test print and verify dimensions prior to using as a template - just to make sure it would be helpful for others !!:
Post by: HaRuMaN on June 24, 2013, 02:04:49 pm
OK here you go :
Hey thanks for that! My photoshop skills are severely lacking... lol
Post by: JDFan on June 24, 2013, 02:49:00 pm
OK here you go :
Had a bit of time so went ahead and did the sides also in case others needed them -- Just need someone to print a test copy and verify the dimensions are correct (went by the 21.43 inchx18.6 measurements in the posted files and added a 1\2 inch border around the oputside - so they should be correct but would be best to get confirmation before using for sending out for final printing !! (IE> Use at your own risk as I do not have a panel to test the dimensions are correct so PLEASE print a test print to verify before investing $$ for printing art using them !!)
Post by: HaRuMaN on June 24, 2013, 02:57:21 pm
(http://cdn0.meme.li/instances/300x300/39079363.jpg)
Post by: opt2not on June 25, 2013, 12:42:23 am
What are the dimensions on the verty?
Post by: HaRuMaN on June 25, 2013, 09:12:29 am
Is awesome a dimension?  :P
15" wide X 20.81" deep X 26.14" tall
Post by: HaRuMaN on June 25, 2013, 10:30:54 am
First post updated with vertical pricing.   :cheers:
Post by: stoopid2001 on June 25, 2013, 12:10:51 pm
I'm having a fit issue with a mag stik plus on the 2 player-
With the stik "installed" it will hit the 2 buttons on the admin panel, not letting the control panel sit forward enough.
(http://i.imgur.com/3gjdiqfl.jpg)
(http://i.imgur.com/fi5FLA4l.jpg)
Post by: HaRuMaN on June 25, 2013, 12:13:25 pm
You may have to find shorter barrel buttons to place there.
Post by: stoopid2001 on June 25, 2013, 12:23:54 pm
I just emailed paradise arcade for some length measurements.  They sell short and long (standard) barrel buttons but don't list the dimensions on their site.  Hopefully the pics will help the next noob when choosing parts! :laugh:
Post by: degenatrons on June 25, 2013, 01:01:31 pm
I workaround this problem with these black washers,  they're about 6 or 7mm wide.  You get these with the thinner LED button sets.  Can be adapted for regular buttons by cutting of the lip on the inside.
(http://i.imgur.com/QV6imTVl.jpg)
Post by: HaRuMaN on June 25, 2013, 02:52:43 pm
First customer to order a MVS-inspired kit gets free red vinyl for the sides!   :cheers:
Post by: cdf12345 on June 28, 2013, 01:38:35 pm
I was just about to post the exact same issue with the 2player bartop
(http://i.imgur.com/mIud06o.jpg)
I would recommend flipping the admin panel on the 2 players so the button slots are not in front of the joysticks.
Post by: stoopid2001 on June 28, 2013, 01:47:56 pm
My 2 player admin panel is the other config.  Inspired by degenatrons washers, I cut a piece of 1 1/4 pvc pipe to use as washers.  Paradise arcade sells short barrel buttons that are 54mm instead of the 60mm standard ones.  I don't think the 6mm would have solved the problem though.
(http://i.imgur.com/1Kinrca.jpg)
Post by: rablack97 on June 28, 2013, 02:10:21 pm
I feel the pain here,  I use Degenatrons plans for scratch builds and Jstik/button placement drives me out of my mind.
Your gonna have to modify your plans to lengthen the height of the CP to push the Jstiks further up to accomodate those buttons, most folks use the standard long barrell buttons.
I started putting buttons on the sides.
I would think 80mm should be big enough to support any jstik and still give you room for your buttons.
(http://i.imgur.com/RALnptY.jpg)
Oh yeah, gonna get me that nintendo looking genius contraption you done went off and designed  :)
Post by: HaRuMaN on June 28, 2013, 02:16:26 pm
This directed at me?  Whatchoo talkin' 'bout?
As for the admin buttons, I used short barrels on mine, not sure where I got them from, they were in my parts bucket.
Ultimarc gold leaf buttons look short, but I don't have a measurement for those.  Naturally, I can adjust plans a bit so this is less of a headache for future buyers.
Post by: rablack97 on June 28, 2013, 02:17:35 pm
OK here you go :
I just had something similar to this done recently.  The printed recommended a 3/4" bleed line and a 3/4 padding/cut line.
So what you would have is 3 shapes, 1 inside the original and 1 outside of the original....
Decent results.....
Post by: rablack97 on June 28, 2013, 02:23:49 pm
The black one man..........I LOOOOOOOOVEEE THAT....
http://forum.arcadecontrols.com/index.php?action=dlattach;topic=130522.0;attach=291772;image (http://forum.arcadecontrols.com/index.php?action=dlattach;topic=130522.0;attach=291772;image)
I would adjust it, nothing like some Happs button  :)
Post by: HaRuMaN on June 28, 2013, 02:25:12 pm
Ahh the vertical.  Yeah, that one is my favorite I've made so far...   :cheers:
Post by: rablack97 on June 28, 2013, 02:27:43 pm
Fix that depth though man, i refuse to go short barrel and use spacers, you fix that you can put me down for one of those....
Post by: HaRuMaN on June 28, 2013, 02:39:02 pm
Sounds good to me.   :cheers:
Post by: HaRuMaN on June 28, 2013, 02:40:21 pm
Sneak preview of what's next...   ;)
Post by: rablack97 on June 28, 2013, 02:42:34 pm
is that a viewlix?
that looks like a darn jigsaw puzzle....
Post by: Nephasth on June 28, 2013, 02:46:01 pm
How much is that? :o
Post by: HaRuMaN on June 28, 2013, 02:46:11 pm
is that a viewlix?
Ding ding ding...
And, yeah, jigsaw puzzle-ish to be sure.  But, if the end result matches what I have in my head, will look good.   :applaud:
Post by: HaRuMaN on June 28, 2013, 02:47:00 pm
Don't know yet, plans are with my CNC guy, he has to take a good look at them and let me know.
Post by: rablack97 on June 28, 2013, 03:05:18 pm
I'm starting with ther vert first, that viewlix is for grown folks only....... :dizzy:
Post by: HaRuMaN on June 28, 2013, 03:29:44 pm
Fixed.  Moved the admin buttons, moved some buttons on the CP, no interference now (on the vertical).  :cheers:
Post by: lowgunn on June 28, 2013, 11:48:26 pm
is that a viewlix?
Ding ding ding...
How am I gonna explain the viewlix to the wife....
Post by: TheDude on June 29, 2013, 03:46:35 am
Hey, you've got a nice selection of bartops !
I'm especially interested in the upcoming viewlix-shaped one !
You should be granted a medal for bartop accessibility to the masses ! ;)
Post by: yotsuya on June 29, 2013, 11:34:46 am
That's a full-size Vewlix, not a bartop.
Post by: rablack97 on June 29, 2013, 11:56:29 am
What size monitor does the vert hold and how much?
Sent from my PC36100 using Tapatalk 2
Post by: HaRuMaN on June 29, 2013, 01:28:22 pm
I designed it to fit a 17" Dell LCD, rotated of course.  1708fb is a good one as it's meant to be rotated.
Kit is $180 shipped, add $10 for slot cutting.
Post by: rablack97 on June 29, 2013, 11:03:00 pm
What about the guts...micro pc boards only or can a decased xbox fit....
Post by: HaRuMaN on June 29, 2013, 11:05:18 pm
Plenty of room in the vertical, I would think a decased xbox would be fine.   :cheers:
Post by: rablack97 on June 29, 2013, 11:45:48 pm
okie dokie, oh yeah 1ply2 or 2...
Post by: HaRuMaN on June 29, 2013, 11:49:34 pm
1 player.
Post by: rablack97 on June 29, 2013, 11:55:45 pm
hmmm, 1plyr + t-ball, or is that pushing it...
Post by: HaRuMaN on June 30, 2013, 01:15:37 am
That may be. I could always include the normal control panel, and then a blank one for you to play with.
Post by: TheDude on June 30, 2013, 01:18:57 am
It looks so, my humble apologies  :lol
Post by: lowgunn on June 30, 2013, 02:51:43 am
Hmmmm why not a bartop viewlix?   I think that could look pretty awesome.
Post by: TheDude on June 30, 2013, 04:21:53 am
termin8tor is building one at the moment and a guy from another acade forum also  does ! ;)
Post by: PTD on June 30, 2013, 09:54:12 am
Can someone create this?
(http://i1310.photobucket.com/albums/s643/GeektaM/acrylic_bartop_zps2876c036.jpg)
Post by: rablack97 on June 30, 2013, 09:58:10 am
Yeah that's Selfie's masterful acrylic job isn't it.
Ah ok cool.......waiting on some money on a job i just completed....i'll pm you when ready..... :cheers:
Post by: HaRuMaN on June 30, 2013, 07:32:08 pm
Cool deal...
As far as other projects go, next is that Vewlix (full size) and then a mini-virtual pin.  After that, I can look at other designs.
The acrylic one is pretty cool, but I currently have no way of bending that stuff.
Post by: HaRuMaN on June 30, 2013, 10:15:28 pm
Playing around with the vinyl cutter. Need to order some transfer paper, very hard to line up otherwise.
Title: Re: CNC cut Weecade Inspired Bartop Kits - Orders Open! New Widescreen 2P Available!
Post by: lowgunn on July 02, 2013, 02:40:00 pm
Cathode vs Multi Colored Led strips (~$30) on amazon?  what do you guys think?  I'm debating about white or red cathodes then my coworker brought this into the equation.   Will led strips give the same glow effects?  thanks in advance.
Post by: HaRuMaN on July 02, 2013, 02:44:59 pm
This is what I used:
http://www.ebay.com/itm/350726861639 (http://www.ebay.com/itm/350726861639)
total of like $12.50 shipped.
Post by: HaRuMaN on July 03, 2013, 03:38:34 pm
More MVS progress:
Post by: HaRuMaN on July 03, 2013, 03:39:18 pm
From the front:
Post by: HaRuMaN on July 03, 2013, 03:40:36 pm
Hooked the Xbox up while waiting for my rgb to vga adapter:
Post by: Articus on July 03, 2013, 04:14:49 pm
By rgb, you mean component (YPBPR) cables?  If so, wich vga adapter do you recommend?
Post by: HaRuMaN on July 03, 2013, 04:18:54 pm
This is what I'm talking about:
http://www.ebay.com/itm/330605923350 (http://www.ebay.com/itm/330605923350)
I'm using to convert the signal from a real Neo Geo motherboard for this project.
Post by: bzbee on July 04, 2013, 04:22:39 am
From the front:
Is this still the 19" LCD?
Post by: HaRuMaN on July 04, 2013, 11:47:03 am
From the front:
No, this is a 20.1" Dell 2001FP.  It just fits, no decasing.   :cheers:
Post by: SNAAKE on July 05, 2013, 04:33:53 am
doesn't have to be a plastic cabinet tho. wood version of that cabinet would still be really nice.
but I need to stfu and put together the cabinet I already bought lol.. :dizzy:
Post by: rablack97 on July 05, 2013, 08:03:43 pm
Ha you got shafted too....i just ordered the same damn board yesterday then came across it cheaper.....
http://www.ebay.com/itm/CGA-EGA-YUV-to-VGA-Arcade-Video-Converter-Genuine-Gonbes-brand-USA-seller-/231001639496?pt=LH_DefaultDomain_0&hash=item35c8c54a48 (http://www.ebay.com/itm/CGA-EGA-YUV-to-VGA-Arcade-Video-Converter-Genuine-Gonbes-brand-USA-seller-/231001639496?pt=LH_DefaultDomain_0&hash=item35c8c54a48)
If you not in a hurry you can bid on the same board from HK and China, starting at 18.88
Post by: PTD on July 06, 2013, 01:27:12 am
How do you guys secure the power supply?  Securing the power supply in the computer case is easy because of the screw holes of the computer case but I don't know a good way to secure the power supply.
Post by: cdf12345 on July 06, 2013, 06:11:28 am
Cool deal...
A mini pin would be amazing, I have a setup right now that I just haven't gotten around to building a box for. 19" 4/3 back glass and 24" playfield. I really hope your design can accommodate a 24" playfield. It probably wouldn't be too hard as there should be more room to work with compared to a bar top mamecab.
Post by: rablack97 on July 06, 2013, 10:57:16 am
i use l brackets, there are some wider ones from Home depot or lowes that have like 3 random holes so you can screw into the PSU and then into the actual machine....
these are coollll
(https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcQZkgjQREQUReYqRV_vRlSWUMAkVF-nTwifNJyu9QlVNvpXsxwR)
Post by: JDFan on July 06, 2013, 11:23:19 am
L-brackets work well but I've also used Velcro strips.
Post by: 05SRT4 on July 06, 2013, 02:20:47 pm
PSU, AMP, and CP are all held by Velcro on mine. Works great and is awesome for if you need to remove or make changes.
Post by: HaRuMaN on July 06, 2013, 10:10:32 pm
Some MVS progress, transfer tape makes all the difference:
Post by: HaRuMaN on July 06, 2013, 10:11:40 pm
Running the neo geo motherboard:
Post by: HaRuMaN on July 07, 2013, 01:22:50 pm
More vinyl goodness:
Post by: tron84 on July 07, 2013, 01:31:13 pm
Looking good, Mr. Carter!!!!  :cheers: ;D
Nice work.... :applaud:
Post by: yotsuya on July 07, 2013, 02:46:40 pm
The Sweathogs approve. :cheers:
Post by: tron84 on July 07, 2013, 04:28:43 pm
Well I got my barstick in yesterday.  I got it put together last night.  Now I need to get the parts for it & the marquee. Then figure out something for a colored 1/2" t-mold.  Might try to see if the dye takes to it or not. ;D  I am kicking around of doing Kung Fu Master for this, one I love that old school game.  I grew up playing it in the day.  Plus the marquee is pretty cool.  ;D  My other thoughts are Rampage or Raiden, well see.
But here she is, its pretty.... Thanks Huraman looks great!!! :cheers:
Once it is finished, I will update.
(http://i.imgur.com/HdV0f9R.jpg)
(http://i.imgur.com/YYkCzya.jpg)
(http://i.imgur.com/azkKje0.jpg)
Post by: PTD on July 07, 2013, 05:58:03 pm
How do you place and secure the motherboard to the bartop cabinet ?
Post by: bzbee on July 07, 2013, 06:31:02 pm
That looks OUTSTANDING!!! I can't wait to see the finished product.
Post by: 404 on July 07, 2013, 06:31:36 pm
You can try automotive vinyl dyes on a white piece of t-molding. it's 1000x better than most of these paint cans that are supposedly made for plastic.
Popular brands are SEM, VHT, Plasticote, Color Bond and dupli-color.
Post by: tron84 on July 07, 2013, 07:06:31 pm
Ok, thank you for the info. :cheers:  That is good to know, will give it a try.
Post by: 404 on July 07, 2013, 07:16:54 pm
have no idea if it will actually work on t-molding but i do know that lots of guys that paint vinyl and plastics swear by it. worth giving it a shot.
Post by: HaRuMaN on July 07, 2013, 07:33:52 pm
Just used a few wood screws to secure it to the bottom. One part of the micro-atx mobo peeked out from under the monitor and just under the cp.
Post by: tron84 on July 07, 2013, 07:34:18 pm
It is worth giving it a try.  Something out there has to dye the T-mold. ;D  I just cant believe that there are only black & white for 1/2" T-mold.  Found red, grey & charcoal but have to get 500'.  No thank you, dont need that much 1/2". ;D
Post by: HaRuMaN on July 07, 2013, 07:34:38 pm
More MVS goodness:
Post by: 404 on July 07, 2013, 08:14:28 pm
I know SEM sells a variety of colors and sells them in bare bottles so they can be fed into HLPV guns. The bare bottles can also be mixed.
If it works, bet those guys looking for the elusive sky blue t molding for their Journey cabs would want to give it a shot  ;D
Post by: sharpfork on July 07, 2013, 09:35:43 pm
It is great to see Degenatrons' barstick design in other folks hands.  I'm curious what y'all think of the form factor of a screen less bartop with arcade elements like marquee and t-moulding.
galaxy SIII-cyanogen-tapatalk 4 beta
Post by: tron84 on July 07, 2013, 11:12:24 pm
I like the form factor. Being able to use it on different tv's & monitors. The marquee part is what sold me. I already had a dual stick setup. Then seeing the barstick, I was like I want that.  ;D  So the shape of it, the marquee & put some small side art on it.  It will look like a lil arcade machine. No screen of coarse. :cheers:
It will be a very nice setup once mine is finished. :cheers:
So +1 in my book for the barstick, I am digging it so far.  I cant wait to get it done.  Thanks to everybody involved in this project.
Post by: opt2not on July 08, 2013, 02:49:52 am
More MVS goodness:
Oh snap, that looks pretty rad.
Post by: HaRuMaN on July 08, 2013, 11:00:53 am
Inside, still need to tidy up the wires:
Post by: HaRuMaN on July 09, 2013, 07:57:36 pm
Now with SLG installed:
Post by: PTD on July 10, 2013, 10:18:41 am
Has anyone tried to use Raspberry Pi with ipac2 for your bartop arcade?
Post by: HaRuMaN on July 10, 2013, 10:20:03 am
Not that I know of, that would be pretty cool if someone tried it.
Post by: rablack97 on July 10, 2013, 03:01:57 pm
i have a question, why didn't you just go with 5/8 on the bartsick, so it doesnt limit folks to just 2 colors on t-molding...
Post by: HaRuMaN on July 10, 2013, 03:16:25 pm
On the barstick?  I could check if my CNC guy could get it.  Demand on the barstick has been fairly low, though...
I am ordering some white T-molding for my MVS build, I will be playing with the scraps to find a good method for dyeing or coloring.
The widescreen has been the best seller by far (which has surprised me, quite frankly).
Post by: Malenko on July 10, 2013, 03:18:28 pm
I know cause the vert is BALLER
Post by: rablack97 on July 10, 2013, 06:53:30 pm
oh yeah i forgot your doing melamine....only comes in 1/2 and 3/4 black on both sides.
I have some experience with the rit dye, really depends on the material.  Some plastics will not absorb the dye....You might get lucky with the t-mlding though....
here's a tut to help you out....
http://bmx-forum.com/t/183272/how-to-dye-plastic-parts-with-pics (http://bmx-forum.com/t/183272/how-to-dye-plastic-parts-with-pics)
widescreen monitors are easier to find than the 4:3, most folks dont wanna chance buying an older 4:3 monitor....might as well by the wide and play all your games strectched......
i have to craigslist all my monitor purchases getting harder to find now for a descent price.....
Post by: HaRuMaN on July 12, 2013, 09:22:23 am
More MVS progress:
Post by: HaRuMaN on July 12, 2013, 09:23:08 am
Detail:
Post by: opt2not on July 12, 2013, 02:21:53 pm
That sure is purdy!  :applaud:
Post by: HaRuMaN on July 12, 2013, 02:36:12 pm
Thanks!  Not a bad CPO attempt, considering I just used red vinyl as the base, and then cut the white out and put on top.   :D
Post by: PTD on July 13, 2013, 02:37:38 pm
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=279604;image)
Can you tell me what type of button controls people normally put in the 2 holes in the top right area of the top panel (not the joystick and the 6 action buttons) and the 3 holes in the front of the panels?
Is it for "1 player", "2 player" for the top side and "pause", "coin", and "start" for the front side of the panel?
I am planning to use Hyperspin for the 1-player.  I want to know how I will do the wiring for the ipac mini.
Thanks.
Post by: yotsuya on July 13, 2013, 04:00:42 pm
Those slots are for HaRuMaN to hold his Pez dispensers while he plays.  :gobama
Post by: HaRuMaN on July 13, 2013, 04:23:43 pm
Lol.
I put credit & player 1 start on the top panel, power, pause, and P2 on the admin.
Post by: stoopid2001 on July 15, 2013, 12:10:10 am
Did anyone cut the provided plexi?  What did you use?
Post by: HaRuMaN on July 15, 2013, 09:29:59 am
Why would you want to?
Post by: HaRuMaN on July 15, 2013, 09:38:14 am
White t-molding installed:
Post by: ebarlow99 on July 15, 2013, 12:26:50 pm
sweet looking! great job!!!
Post by: stoopid2001 on July 15, 2013, 12:44:36 pm
It wont fit the way I set it up.  I need to cut about 2 inches off.
Post by: HaRuMaN on July 15, 2013, 01:06:52 pm
Thanks!  I'm really having a lot of fun with this one.   :cheers:
Post by: ebarlow99 on July 15, 2013, 02:34:24 pm
looks really good.....always wanted one!!
Post by: HaRuMaN on July 15, 2013, 02:54:06 pm
PM me your email address and I'll send you an invoice...   ;)
 :laugh2:
Post by: ebarlow99 on July 15, 2013, 03:11:12 pm
hahaha I do need to reverse engineer it  :cheers:
no really awesome looking!!!
Post by: PTD on July 15, 2013, 11:31:52 pm
Question:
How do you hook it up so that you only use one cord to plug into the electrical outlet to power up the monitor and the computer?
The monitor has one electrical cord and the power supply has another power cord.  I don't want to have 2 power cord coming out of the arcade bartop and have to plug in two cords.
How do you guys do the wiring?
I am new at building these things so please bare with me :-)
Post by: JDFan on July 15, 2013, 11:57:06 pm
Question:
I went the easy way on my bartop and used a power strip inside the cabinet to plug in the monitor and PSU and have the cable from that run to the outside - That way you also have the surge protection offered by the power strip. (Note : not the cleanest application as I forgot to leave room for the PSU inside when scaling down from the original plans and wound up cutting a hole in the back for the PSU to gain the extra 1\2 inch of room needed to be able to put the back in place but worked out OK.
(http://i212.photobucket.com/albums/cc189/JDFanning_bucket/ROBOTRONFinished_zps8e16a848.jpg)
Others open the PSU case and solder the monitor wire straight into the PSU input so the one cord powers both - same can be done by using one of the adapters like in this pic and soldering both wires to it (which also allows the cord to be removed at the case.
(http://www.ebanggood.com/uploadfiles/facep/250v-15a-iec-60320-c14-power-supply-plug-adapter-100445n.jpg)
Post by: HaRuMaN on July 16, 2013, 03:42:53 pm
^ I used a power strip inside my last bartop.  Only one cord coming out.
In other news, I pick up the first vewlix (Harulix?  :P) kit tomorrow.   :cheers:
Post by: ebarlow99 on July 17, 2013, 09:19:30 am
I use one of these and cut the end of a power strip and wire that into it.....so only the power cord out the back
http://www.ebay.com/itm/EMI-Filter-with-Fuse-IEC-Socket-Power-Switch-Built-All-in-One-/330797579818?pt=LH_DefaultDomain_0&hash=item4d05127e2a (http://www.ebay.com/itm/EMI-Filter-with-Fuse-IEC-Socket-Power-Switch-Built-All-in-One-/330797579818?pt=LH_DefaultDomain_0&hash=item4d05127e2a)
also use one of these....for the back.....has headphone jack in it also
http://www.ebay.com/itm/4-Ports-USB-2-0-HUB-with-Audio-In-Desk-/370838225622?pt=US_USB_Cables_Hubs_Adapters&hash=item5657ae42d6 (http://www.ebay.com/itm/4-Ports-USB-2-0-HUB-with-Audio-In-Desk-/370838225622?pt=US_USB_Cables_Hubs_Adapters&hash=item5657ae42d6)
Post by: rablack97 on July 17, 2013, 10:37:45 pm
too darn exppensive....
I use these and these
http://www.ebay.com/itm/10pcs-NEW-Snap-in-Universal-AC-Power-Socket-SWITCH-FUSE-Socket-FUSE-/300678269018?pt=LH_DefaultDomain_0&hash=item4601d2485a (http://www.ebay.com/itm/10pcs-NEW-Snap-in-Universal-AC-Power-Socket-SWITCH-FUSE-Socket-FUSE-/300678269018?pt=LH_DefaultDomain_0&hash=item4601d2485a)
http://www.ebay.com/itm/10PCS-Snap-in-Universal-AC-Power-Chassis-Socket-W-Led-/120749224783 (http://www.ebay.com/itm/10PCS-Snap-in-Universal-AC-Power-Chassis-Socket-W-Led-/120749224783)
cheaper and work great....
Post by: HaRuMaN on July 17, 2013, 11:02:16 pm
Muahaha
Post by: tron84 on July 17, 2013, 11:12:22 pm
Muahaha
 :applaud: :applaud: :cheers:
That looks SWEET, I like I like.
Post by: tron84 on July 17, 2013, 11:32:26 pm
Well I thought I would update on the Barstick.  ;D
Tried to dye the tmold, no go on what I tried with.  I am not done trying yet but I installed the white tmold on it for now.  I kind of like for what I have done so far, still want a blue to match this.
I got the plexi cut for $2 at the mom & pop hardware store in town, for the marquee. Gameongrafix did a great job again printing it.
Arcadeoverlays, I had do my custom size side art.  Todd was great there, it looks great & it was mailed in two days. So here is what I have done now.  ;D
  Kung Fu Master  tribute....
(http://i.imgur.com/UIb8PcC.jpg)
to much flash on this shot but the colors pop, my mini side art.
(http://i.imgur.com/vl0k9v8.jpg)
I dont have the marquee mounted yet, so I can get the light in there. It is just resting on it.
(http://i.imgur.com/eCi1b6f.jpg)
Post by: opt2not on July 18, 2013, 12:04:48 am
Muahaha
Crazyness!  :applaud:  ;D
@tron84
That's gonna look sweet when it's finished!
Post by: tron84 on July 18, 2013, 12:11:45 am
@tron84
Thanks opt2not...
Post by: PTD on July 18, 2013, 02:00:54 am
Do you that one for both monitor and power supply since it has a total of 6 prongs ? (3 prongs for the monitor and 3 prongs for the power supply)
Also, how do you guys make the monitor and the power supply turn on at the same time?  My monitor has a button for on/off so when I mount the monitor inside the bartop cabinet,  how can it be turned on without pushing the on/off button of the monitor.  The same goes for the power supply.  I just want to push the power button outside the cabinet and both the monitor and the computer will turn on automatically at the same time.
Post by: jmike on July 18, 2013, 06:59:57 am
Harulix?      :notworthy:
Wow! What's the screen size for that beauty?
Post by: HaRuMaN on July 18, 2013, 08:49:00 am
32" LCD.   8)
Post by: jpS14 on July 18, 2013, 10:21:04 am
I'm going to want one of those Harulix kits. I better put money aside now.
Post by: HaRuMaN on July 18, 2013, 10:32:57 am
 :cheers:  :afro:
Post by: stoopid2001 on July 18, 2013, 10:46:31 am
The Harulix does look damn good.  Why no melamine for it?
Post by: HaRuMaN on July 18, 2013, 10:49:56 am
It'll be more apparent as I assemble it...  Melamine just wouldn't work for the way this is going to be put together.  I'll be posting pictures as the build progress.
Post by: JDFan on July 18, 2013, 11:13:28 am
I believe on those the 3 silver connectors are the ones used for the wiring (both monitor and PSU hook to the same 3 connectors ) the other brass ones are actually used to wire the LED light inside the switch (which could also be wired with the monitor and PSU wire - so you'd have 3 wires to each of the silver connectors.
As far as both turning on at the same time since you are wiring both directly to the switch it would turn on both when it is turned on -- Most monitors will turn on without pressing the button on the front if you did not press the button to turn it off (ie. if the monitor is turned on and you disconnect power or turn off the switch on a surge protector ar in this case the switch you are adding once power is restores (ie. you turn that added switch back on) the monitor will turn on -- There are some that require the button on the front of the monitor be pressed in which case you'd need to build with some way of accessing that button but the majority of monitors now do not require that and as long as the monitor was on when the power was turned off by another switch once it is turned back on the monitor will power up ( To test plug your monitor in - turn it on - unplg the cord from the wall outlet (do not turn off the monitor) - plug the cord back in and see if the monitor comes back on (if it does the monitor will be fine to use without needing to press the on button on the monitor - once it is pressed once it stays on and will come back on each time power is present until the button is turned off by pressing it)
For the computer you will want to run the 2 wires that go to the power on switch jumper on the MOBO to a momentary switch (you can use an arcade button like the green one I did shown in the pic posted of my bartop above) So the 2 wires that normally run from the MOBO to the front of the case to the power on button run to that green button just like any other button wire is connected (1 to negative 1 to NO)
 By doing this once you plug the system into the wall power goes to that new on\off switch you installed -- If you turn the switch on power goes to the monitor (which powers on as long as the button on the front of the monitor was not pressed to turn it off) - then you press the Green button which turns on the computer (just like it would if you had the computer inside a case and pressed the on button) and the computer and monitor both come to life -- Then when finished you press the green button again (Be sure in windows you set the on\off button to "SHUT DOWN SYSTEM" in the power options so that it correctly shuts down windows rather than just shutting off power without shut down of the OS) - wait for the system to turn off and then turn of the power switch wich turns off the monitor and the remaining power to the system. Then when ready to play again you turn the power switch back on which turns on the monitor and press the green button to boot the system.
Post by: Goz on July 18, 2013, 12:35:49 pm
I think I'm going to need a bigger bar.
Post by: HaRuMaN on July 18, 2013, 03:23:13 pm
Hmm...
Post by: HaRuMaN on July 18, 2013, 03:23:52 pm
Oh yeah...
Post by: degenatrons on July 18, 2013, 04:08:58 pm
Oh yeah...
Your chair needs padding for comfortable book reading sessions.  A few minutes "Where's Waldo?" should be ok.  :lol
Post by: PTD on July 18, 2013, 05:00:55 pm
Is there anyway to miniaturize the Harulix to make it a bartop?
The full size one looks so big.
Post by: HaRuMaN on July 18, 2013, 05:03:36 pm
Yeah, it's designed to hold a 32" LCD.   ;D
I've been asked that by a couple of people, so yes, I will look into it.   :cheers:
Post by: HaRuMaN on July 20, 2013, 01:27:23 am
Whee
Post by: PTD on July 20, 2013, 01:44:15 pm
I wonder why no company make arcade bartop cabinet out of aluminum like we see with computer cases?  Those computer cases are light and tough.
If they can make many computer cases out of aluminum, they can certainly create many styles of bartop cabinet.
But then again.....arcade bartop is only a niche market and not many people are into it.  That is why there is not a lot of demand for it.
Post by: Ginsu Victim on July 20, 2013, 04:16:07 pm
Sounds too noisy. Wood is easiest for everyone to modify themselves once they get a kit.
Post by: HaRuMaN on July 22, 2013, 03:31:49 pm
Putting together the marquee box
Post by: HaRuMaN on July 22, 2013, 03:32:36 pm
Control panel detail:
Post by: Unstupid on July 27, 2013, 02:03:56 am
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=130522.0;attach=292880;image)
Wow!
Post by: PsychoAU on July 29, 2013, 03:59:43 pm
What are the interior dimensions of the marquee area on the standard (non-widescreen) kit?  I am interested in finding a small LCD monitor to put in there to display the marquee image of the current game and was just wondering what would be able to fit in there (to even begin looking to see if something that size is even made).
Also, after building the kit this past weekend, there were several things I had to learn through trial and error that you should probably list in the first post.  Namely, I had to take several trips to the hardware store to find the right screws to work with the VESA mount.  I knew the standard VESA screw size is M4-.07, but had no idea on what length to get since it had to go through 1/2" of wood.  I found that at least 25mm works (20mm wasn't long enough to reach the threads on my particular monitor).  You might want to list that screw size in the first post to help others tackling this build.
Also, I didn't know ahead of time how the monitor plexi would fit in there, so the monitor I have has to mount in a way where it is all the way up against the back of the speaker panel.  This prevents the plexi from sliding up between the monitor and the speaker panel.  So now I need to cut it short to sit over the monitor.  It would have been helpful to know how the plexi was supposed to go in this kit before I did all that.
Anyway, the kit was relatively easy to put together, but those small details would have been nice to know ahead of time.
Post by: HaRuMaN on July 29, 2013, 04:03:04 pm
Noted, I will get those details up.
I believe the interior marquee area on the standard kit is 17.75" X 3.5"
Post by: lowgunn on July 30, 2013, 11:47:49 pm
How's the viewlix coming along?
Post by: HaRuMaN on July 31, 2013, 09:41:36 am
Good! Marquee box done (not sanded yet):
Post by: HaRuMaN on July 31, 2013, 09:42:46 am
Playing with the CP:
Post by: HaRuMaN on August 01, 2013, 03:08:23 pm
So... if anyone else is crazy enough for one of these Vewlix kits, I'm gonna say $600 shipped.
Post by: spiderpig on August 02, 2013, 09:31:02 am
Do you have any pictures of the vertical version for 180 bucks? Is it full size vertical?
I'm looking for a cabinet that can hold a monitor 22 inches wide.
Post by: HaRuMaN on August 02, 2013, 10:04:34 am
The vertical is a bartop that can hold a 17" 4:3 vertically.
I do have a widescreen bartop that can house up to a 23" widescreen LCD (it's also 2 players).
Post by: spiderpig on August 02, 2013, 02:50:30 pm
how much for the wide one?  Also, how hard would it be to build a stand for it to make it like a full upright?
Post by: HaRuMaN on August 02, 2013, 02:56:15 pm
The wide one is $160 (or $170 with slot cutting).  Polycarbonate (plexiglass) for the monitor area & marquee are an additional $40.
I have had requests for stands, but haven't had the chance to draw one up & get it prototyped yet, but it is going to be coming soon.
Post by: spiderpig on August 02, 2013, 03:31:07 pm
How soon?  I'm in no hurry at this point.
Can you also appox the cost of the base?
Also, for the wide, what are the dimensions for the control panel?
Post by: HaRuMaN on August 02, 2013, 07:45:47 pm
Couple of weeks? Cost will depend on the cnc shop and shooting costs, so I'll let you know.
The wide control panel is 22" wide, I will check the depth
Post by: HaRuMaN on August 08, 2013, 11:37:30 am
Sneak peek of what's coming up...
Post by: HaRuMaN on August 08, 2013, 11:39:05 am
Control panel is 6.19" deep.
Post by: Unstupid on August 08, 2013, 03:05:41 pm
http://forum.arcadecontrols.com/index.php?action=dlattach;topic=130522.0;attach=294397;image (http://forum.arcadecontrols.com/index.php?action=dlattach;topic=130522.0;attach=294397;image)
I'd rotate that control panel side vertical like the other 3 just incase you ever plan on cutting this thing out with a woodgrain finish like prefinished plywood.
Post by: HaRuMaN on August 08, 2013, 03:11:22 pm
Ack.  You're absolutely right.  This is gonna get cut from a woodgrain melamine, and that panel would not look right.  Good catch.
Post by: floriske.nl on August 09, 2013, 09:51:17 am
First of all Thx Degenatrons and HaRuMan for keeping these plans "open source"  :notworthy:
Since I have my own CNC router I'm planning on converting the plans to 12mm panels instead of 1/2" (12.7mm) so I can route them myself.
However I've got a question about the plexiglass bezel:
I can't find details on the size and how this is positioned inside the cabinet so I was wondering if the way I interpreted it in this drawing is correct?
https://www.dropbox.com/s/0n0yypvqx883wo2/Plexiglas%20Question.jpg (https://www.dropbox.com/s/0n0yypvqx883wo2/Plexiglas%20Question.jpg)
Post by: HaRuMaN on August 09, 2013, 09:59:03 am
I can't access dropbox from here... can you post it?
Post by: floriske.nl on August 09, 2013, 10:07:06 am
Hope this works
Post by: JDFan on August 09, 2013, 10:08:28 am
Post by: HaRuMaN on August 09, 2013, 10:22:20 am
I extend the plexiglass a bit more behind the speaker panel & behind the control panel.  When I install the monitor, the pressure is enough to hold the plexi in place.
Post by: floriske.nl on August 09, 2013, 10:26:50 am
Ah ok, so more like this:
Post by: HaRuMaN on August 09, 2013, 10:30:41 am
A little bit more behind the control panel and you've got it.
Post by: floriske.nl on August 09, 2013, 10:44:55 am
Even below the corner of the CP or still on the narrow side like I did?
Thanks a lot for your quick answers. I've already started converting the file, also adjusting the basic shape a tiny little bit so a few of the angles are a little bit more logical (in my opinion that is).
Wil post it here when done of course!
Post by: HaRuMaN on August 09, 2013, 11:22:19 am
Even below the corner of the CP?
Yes.
And yeah, post when you're done, I'd like to see it.   :applaud:
Post by: dextercf on August 09, 2013, 11:36:00 am
(edit: cut away the blablabla)
This right here, is what I need! :D
As a norwegian, the source for 1/2" materials (imperal measurements) is none existing.
Would be cool if you where to share these when done!
Post by: floriske.nl on August 09, 2013, 01:06:44 pm
Yes.
Ok, clear. Thanks!
And while I'm at it, may I ask which thickness you use for the plexi.
Will post for sure when I'm done, in respect to the gnu license as well.
@dextercf: no worries, it will appear here.
Post by: HaRuMaN on August 09, 2013, 01:46:11 pm
1/8"
Post by: r3animation on August 10, 2013, 05:44:27 pm
Since I can't PM yet, emailing you an enquiry. :)
Post by: nitz on August 11, 2013, 01:03:47 am
I'm coming to terms with the fact that my woodworking sucks and I don't really have enough free time to do a proper project anyway...so considering a kit. :)
So we've gone from bartops to vewlix to cocktails...what are the chances of a cabaret or full-size upright kit being done? :) An Atari style cabaret in woodgrain melamine would be sweet.
Post by: TKW4rr10r on August 11, 2013, 01:33:27 pm
Looking at Wide kit for my Samsung 2343bwx, would look nice in there. Have to clear my plate of some other projects first, though.
A -PROPER- Atari cabaret kit would be incredible! I have one that's getting dismantled anyway (centipede, water damage), so I can provide any measurements if needed. Was just going to re-cut the sides, but I'd pay to be a guinea pig for this. I eventually wanted to make a Major Havok cabaret ("eventually" meaning maybe by 2015, ha!), which would require some tweaking to make it a horizontal Atari cabaret. Oh the possibilities, make this happen HaRuMaN!
Speaking of kit ideas, looks to me the bar-top style you're missing is a mini-Nintendo.  ;)  Thinking a good alternative for some Fix-it-Felix clones, so more old uprights can stay original. Been itching to make one for my 3 year old, but can't bring myself to mess with my DK Jr. And cheap Nintendo cabs are nonexistent in the south east. Now a kit like that could be a big seller.
No need to thank me, just send me a prototype for testing.  :lol
Post by: nitz on August 11, 2013, 04:45:46 pm
Two folks interested in an Atari Centipede style cabaret - what do you say HaRuMaN! ;D
Post by: HaRuMaN on August 11, 2013, 04:54:14 pm
What can I say, the public has spoken.  I'll see what I can come up with.   :cheers:
Post by: TKW4rr10r on August 11, 2013, 05:06:17 pm
(http://assets0.ordienetworks.com/misc/swansonsmile.gif)
I'm so excited! Keep me posted if I can help in any way.
Post by: nitz on August 11, 2013, 05:14:51 pm
Sweeeeet!! I'm excited too.
I checked out your website and didn't see anything about this so I should probably ask...please tell me you ship to Canada.
If not, I've got relatives stateside who could probably act as middleman, but I'm thinking it's gotta be cheaper to just go direct.
Post by: HaRuMaN on August 11, 2013, 05:46:52 pm
I /could/ ship to Canada, but it gets pretty pricey.  I shipped just a regular bartop to Canada, and it cost $80.   :o
Post by: Rick on August 11, 2013, 06:05:18 pm
Sweeeeet!! I'm excited too. I checked out your website and didn't see anything about this so I should probably ask...please tell me you ship to Canada. If not, I've got relatives stateside who could probably act as middleman, but I'm thinking it's gotta be cheaper to just go direct.
Hey Nitz, I approached Haruman directly and asked him if he would mind if I could jump in to assist. He said it was ok, so I'll be direct and brief. I will be throwing my hat in the ring to produce bartop and full-size cabinets for the Canadian market shortly, and would be interested in producing the cabinet shell you're looking for, if you are interested.
I do continue to support Haruman's great work, and want to let everybody know that I am not attempting to steal away any of his customers. Everyone who has purchased from Haruman in the past knows that his products, pricing and service are top-notch, and without equal. My only aim is to help open the arcade gaming hardware market a bit more in Canada.
Now that I've sidetracked the thread significantly, and definitely more than I originally intended, I'll go open my own thread and stop hijacking Haruman's. (A big, BIG thank you to Haruman for understanding, and giving me the opportunity to post this message.)
SMOKE BOMB!!! /me exits
Post by: tron84 on August 11, 2013, 09:56:06 pm
Well after many delays, I got some more work done on the Barstick.  I mean my vinyl got lost in the mail for 25 days w/ a tracking number.  Ummmm really  :timebomb: it fell of the grid.  My Led light bar, came in w/ pieces rattling inside. So that is being sent back.  I swear the post office hates me.  :banghead: :angry:
So the marquee is still not mounted, waiting on my new light.  The Cp is just laying on there also right now. But here is the gist of it now.
(http://i.imgur.com/0czLNj8.jpg)
(http://i.imgur.com/HXOms0I.jpg)
Post by: HaRuMaN on August 11, 2013, 10:23:51 pm
Wow man, that is really slick!  Can I steal those pictures as examples for my website?
Post by: tron84 on August 11, 2013, 10:34:36 pm
Thanks man  :cheers:
Yes Brother go ahead & use them, it is cool w/ me.  ;D
The Chinese symbol on the CP. I cut out of the bezel & had it printed up but the blue made it darker than should be. So I will just roll with that for now.  ;D
With all of my post office problems, this is taking longer than need be for me.
I cant wait to get my Marquee lit up.
Post by: nitz on August 11, 2013, 10:59:01 pm
You know, shipping/customs charges is the main thing that has held me back from getting a kit up until now. I'd finally given up on there ever being a Canadian supplier of this stuff, so decided to just bite the bullet and pay up - but of course if a Canadian source for these is becoming a reality, that would be better for me.
Good on you Rick for asking Haruman's permission before posting that, and good on you Haruman for allowing him to post it. You're both upstanding guys.  :cheers:
I'll leave this discussion now and pick it up with Rick.
Post by: HaRuMaN on August 12, 2013, 09:52:09 am
(http://cache2.artprintimages.com/LRG/53/5316/O2BYG00Z.jpg)
Post by: HaRuMaN on August 12, 2013, 04:30:48 pm
If you can give me some pics with dimensions, I can get this started...
Post by: Rick on August 12, 2013, 04:41:11 pm
In working with Nitz, I've come across this Sketchup, which seems close to the original specs (http://sketchup.google.com/3dwarehouse/details?mid=d63d68d9310a036b10145cc1b33dac39 (http://sketchup.google.com/3dwarehouse/details?mid=d63d68d9310a036b10145cc1b33dac39)) and this page (http://ggdb.com/GameByName.aspx?c=Coin-Op&s=Arcade&vid=503 (http://ggdb.com/GameByName.aspx?c=Coin-Op&s=Arcade&vid=503)) which details the height, width and depth requirements. I've opened the Sketchup, and it seems to match, but the actual measurements would be very helpful to me as well!
Post by: HaRuMaN on August 12, 2013, 08:57:04 pm
Ignore the legos
Post by: TKW4rr10r on August 13, 2013, 12:25:39 am
Unfortunately I saw this after I left work where I have the cab in storage. There may be slight variations of the Centipede and Tempest cabarets, since the vector monitor needed more venting. Otherwise the sketch-up model looks really spot on... for the exterior. Unless my version doesn't fully support that model, looks like nothing inside except coin mech details.
I'll check this out tomorrow morning and start to compile some measurements for comparison.  PM me if you want any photos e-mailed directly.
Post by: floriske.nl on August 13, 2013, 04:29:02 am
Finished my first 12mm conversion today.
First because after finishing it I figured I should do some stuff different.
In the original design because of the router bit radius panels won't automatically align and might shift a little when placed in the slot. So I added notches in the center of each slot for this.
But just figured it will be a lot easier to use dog- or T-bone fillets instead.  :banghead:
So, back to the drawing board  ;)
EDIT:
HaRuMan, can you tell me if you use any "clearance" in the pockets for the glue/a less tight fit? (hope this makes sense)
e.g. the tab on a panel is 1/4" and the pocket for that tab is a little bit deeper than 1/4"
Post by: HaRuMaN on August 13, 2013, 10:23:39 am
The tab is 1/4" and the pocket is 1/4"
However, the width of the pockets is cut at 0.51" while the material itself is 0.50"
My CNC guy has a VERY precise machine with tolerances in the thousandths of an inch, so I am able to get very tight cuts on mine.  Granted, his machine runs around $80,000, so I guess it had better be great!   ;D
Post by: floriske.nl on August 13, 2013, 01:16:01 pm
Thx!
My machine theoretically has a 0.003125mm accuracy, even if the deviation would be x10 (which I find hard to believe) it still should be enough as well.
Post by: Unstupid on August 13, 2013, 01:44:27 pm
What kind of machine are you using that has tolerances down to a 1/10000"?  just curious  ???
Post by: rablack97 on August 13, 2013, 03:32:30 pm
Hey man, modified the barstick to accept a t-ball and house its own speakers....
Here's some pics to get your gears turning, in case you decide to do a v2. of the barstick...
(http://i.imgur.com/1iEuRtZ.jpg)
(http://i.imgur.com/yrDqX36.jpg)
(http://i.imgur.com/OFz5NW7.jpg?2)
Post by: TKW4rr10r on August 13, 2013, 04:46:11 pm
 I can confirm the measurements with this model:  http://sketchup.google.com/3dwarehouse/details?mid=d63d68d9310a036b10145cc1b33dac39 (http://sketchup.google.com/3dwarehouse/details?mid=d63d68d9310a036b10145cc1b33dac39) are pretty spot on. It took a few trips back and forth to my cabinet (the water damage didn't help) and the sides are on the money. I'm taking the model apart now to see what else needs to be updated. I see no back panel details so here is a quick and dirty ms paint detail (I'm no artist, lol)
(http://i.imgur.com/4qvi49w.jpg) (http://i.imgur.com/PY1scWr.jpg)
Now I just had a makeshift back door with no details on mine. So far looking at others online that 19" x 37.5" panel has no details that I can see.
I also see now taking apart the model there appears to be no top or front details. I'll start getting those together. I may just start taking this thing apart if need be.
Post by: HaRuMaN on August 13, 2013, 04:53:43 pm
Thanks for those.  Good starting numbers....
Now, do you care if this is 1/2" or 3/4"?  I can do either... but 1/2" would be lighter & cheaper to ship.
Post by: TKW4rr10r on August 13, 2013, 05:25:46 pm
I know I would prefer 3/4", only because that's the original construction. Any custom work (like that Major Havoc cabaret I'll get to someday) would be fine with 1/2". Now if it's a catastrophic increase in shipping I'll probably change my tune.  ;)
Would the 3/4" also be black melamine? Not familiar with the stock you use, so is the melamine pre-applied before cutting, or after? Color choices? I know someone else mentioned having it shipped with the wood paneling on the side panels. I actually would prefer white since I'll be doing something similar to this:
(http://farm8.staticflickr.com/7139/7447540162_b7c7f8abf4_b.jpg)
And hopefully this will peak some interest in the same project I want to do:  >:D
(http://api.ning.com/files/Zpxg*qKbq4bCxATDN20C5qyyu60dSqimFS3O9zAGM4RHyjsfEK-s-2AbLlwlscbVRhi*f69k*CeOZBiJWRDBcgPQ3nPIpXkF/MHmini.jpg)
Post by: HaRuMaN on August 13, 2013, 05:31:57 pm
I can do white / black / grey / and like 10 different woodgrain finishes.   :cheers:
Post by: TKW4rr10r on August 13, 2013, 06:23:19 pm
Awesomeness.
Would making just the the sides in 3/4", and everything else in 1/2" make an impact in your shipping? Thought that could be a good compromise - The cabinet still looks the same, and is lighter to ship and move once assembled.
I assume it all depends on how you can lay the parts on 4'x8' sheets, but something to consider.
Post by: HaRuMaN on August 13, 2013, 06:54:27 pm
Awesomeness.
Once I get drawing I can better answer that...  Most likely this will take a couple of sheets anyway, and in your case, sides in white make sense, and maybe everything else in 1/2" black?
Post by: TKW4rr10r on August 13, 2013, 08:36:50 pm
Sounds good. I'll be able to get the rest of the measurements tomorrow.
Post by: floriske.nl on August 14, 2013, 10:12:18 am
My machine ballscrews have a 5mm pitch and is set to use 1600 microsteps/rev which results in 320 microsteps/mm which results in 1:320 = 0.003125mm
As said this is "theoretically" because every machine has it's inaccuracy due to tool flexing etc.
Post by: TKW4rr10r on August 14, 2013, 07:15:42 pm
As promised, more measurements, this time of the front panel:
(http://i.imgur.com/Mjj0knH.jpg)(http://i.imgur.com/wi6X07W.jpg)(http://i.imgur.com/HZa4bBI.jpg)
As you can see in the pics, the front panel extends 1.25" up past the bottom of the control panel to accommodate the piano hinge inside. So total height of panel is 34.75"
The measurements where taken from the front since I haven't had the chance to dismantle this cabinet yet. The dimensions for the coin door overlap where taken into consideration, so the numbers I have are for the size of the whole to be cut, not the outer dimensions of the door itself.
These are preliminary, since I need to very the type of holes needed for the speaker and marquee. Didn't have the chance to see if these are solid holes or if they have a recessed edge.
Post by: floriske.nl on August 15, 2013, 09:51:59 am
Attached is my first 12mm release version.
Edit: Added a "Side cross section" to the file and updated it to "beta 1_2"
Edit 2: Made a dumb error with the joystick positioning calculations. My idea with the lowered admin buttons won't work due to this. Once again: Back to the drawing board  :banghead:
Edit 3: Problem solved! I raised the base of the cabinet with 13.5mm and now the lowered admin buttons do clear the joysticks as intended. (see first sheet of new beta)
Edit 4: In order to fit Happ competition joysticks as well I raised it with another 6,5mm
I hope to be routing a first "test" version in the next couple of weeks (have some other stuff to route first).
Some things I "changed":
• Converted to 12mm material instead of 1/2"
• Converted to 3mm acryllic instead of 1/8"
• Converted the design to using T-bone fillets for the panel tabs and slots
• Adjusted panel angles to more logical numbers (30º, 45º, 5º, 12.5º etc.)
• Adjusted angle between CP and admin panel to 90º
• Enlarged the cp with a few mm so it overhangs the admin button panel
• Added the possibility for mounting/easy alignment of the cp with 6mm doves. Permanent screwing is still posible, added semicircular cutouts for this in the bottom panel (thanks for the tip degenatrons!)
• Added extra ventilation holes in the top back panel
• Added the posibility for mounting the marquee the same way used in my "evo XR cade"
• Added shallow slots in the sidepanels for the monitor bezel acryllic so it can be clamped in between (slots are 1.5mm deep, acryllic needs to be 452mm wide). By slightly bending the acryllic it can still be removed (e.g. in case a new monitor will be fitted). This is experimental but I hope it works.
• Raised the base of the cabinet with 20mm so lower placed admin buttons clear joysticks with a maximum base thickness of 42mm
• Added 6 button layouts + possible admin and pinball button positions.
• and some more stuff
Big thanks to degenatrons and HaRuMan!
As they stated before: This is an open-source project. Feel free to download the plans and modify them for you own use as you see fit. By downloading the plans, you are agreeing to the Creative Commons BY-SA 3.0 licensing, found here:
http://creativecommons.org/licenses/by-sa/3.0/us/ (http://creativecommons.org/licenses/by-sa/3.0/us/)
Title: Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
Post by: XNIF on August 15, 2013, 01:37:22 pm
@Floriske this is starting to look very promising :) I just hope that lowering the adminbuttons won't affect the cabinets aesthetics because it breaks symmetry on the frontside admin panel.
Post by: floriske.nl on August 15, 2013, 01:48:31 pm
That's a choice everyone has to make for themselves of course. I just added the ability, not forcing anyone to use it  ;)
Post by: HaRuMaN on August 16, 2013, 09:52:49 am
Thanks for the measurements, very helpful
Post by: HaRuMaN on August 16, 2013, 09:54:24 am
Floriske, looking good, man. I like it
Post by: floriske.nl on August 18, 2013, 04:52:29 am
After making some minor tweaks to the design I routed a first "test" version yesterday and it turned out 100%. Everything fits like a glove  ;D
(https://dl.dropboxusercontent.com/u/72592758/cnc/fotos/thumbs/IMG_1998.jpg) (https://dl.dropboxusercontent.com/u/72592758/cnc/fotos/IMG_1998.jpg) (https://dl.dropboxusercontent.com/u/72592758/cnc/fotos/thumbs/IMG_1977.jpg) (https://dl.dropboxusercontent.com/u/72592758/cnc/fotos/IMG_1977.jpg) (https://dl.dropboxusercontent.com/u/72592758/cnc/fotos/thumbs/IMG_1982.jpg) (https://dl.dropboxusercontent.com/u/72592758/cnc/fotos/IMG_1982.jpg)
And a picture I took to give you an idea of the size of my evo XR cade:
(https://dl.dropboxusercontent.com/u/72592758/cnc/fotos/thumbs/IMG_1992.jpg) (https://dl.dropboxusercontent.com/u/72592758/cnc/fotos/IMG_1992.jpg)
Post by: Rick on August 18, 2013, 07:52:07 am
Shut. The. Blankity-blank. Up.
 :notworthy:
Post by: steved61 on August 18, 2013, 12:31:23 pm
New Control Panel made for me by HaRuMaN. looks great can't wait to get it. Great man to work with and a good price for quality work.
Thanks again.
Steved61
Post by: HaRuMaN on August 18, 2013, 01:14:21 pm
Post by: floriske.nl on August 18, 2013, 04:03:51 pm
 :notworthy:
Hey! Be nice to me will ya  :laugh2:
@steved61 & HaRuMan: looking good indeed!
Post by: TKW4rr10r on August 18, 2013, 04:50:11 pm
Thanks again.
Steved61
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=130522.0;attach=295097;image)
Nice! But what's the cut-out for right above what I assume is a 3" trackball, to the left of a pair of buttons?
Post by: steved61 on August 18, 2013, 05:10:55 pm
TurboTwist High-Low™ Push-Pull Arcade Spinner Control from GGG.
Steved61
Post by: floriske.nl on August 19, 2013, 10:31:10 am
Since my first test version turned out to be ok I've converted it to a first release version, see attached.
Since I work with Adobe Illustrator instead of CAD software I created a PDF instead of a DXF. Illustrator DXF's are unreliable.
The files are based on my own machine with 60x93,5cm work area.
Post by: HaRuMaN on August 19, 2013, 03:26:41 pm
So I'm making good progress on the cabaret... Question is, how do you want to handle the monitor, and how do you want to handle the control panel?
Post by: TKW4rr10r on August 19, 2013, 05:44:02 pm
I have more measurements, I just have to get back to the office where I have the cabaret (work is a little nuts atm). I can tell you already the top panel is just one piece with a taper cut on both ends. The holes for the speaker grill, marquee and coin door require rounded corners.
I'll provide detail pics and measurements for the monitor mounting board. took a lot of pics of the surrounding areas to showing how it all fits together. I have a control panel, but if you wanted to make something to give anyone else the option for a wooden one, I can take some measurements. I could probably trace a profile and scan/send it to you if that will help.
I know the holes for the coin door and speaker appear to be straight through. The marquee's original measurements are for a recess, with the full hole I'd say .25" smaller on all sides. I'm having a tough time removing the speaker grill and marquee if anyone knows the trick. The screws look like stripped torx or maybe deigned to be similar to rivets.
Post by: Rick on August 19, 2013, 06:29:58 pm
I received these images from a guy on Reddit, after I asked for some input.
(http://i.imgur.com/llnQESi.png)
(http://i.imgur.com/YNn8uv0.png)
Hoping this may help in some way!
Post by: TKW4rr10r on August 19, 2013, 10:37:52 pm
For the side panels, the original sketch model had those spot on, you have to get all the arcs and curves right. Not knocking his measurements, but they can be off depending on where you measure in the arcs.
As far as the front is concerned, I explained the measurements in a previous post. The actual panel extends into the CP area and the holes for the speaker grill and marquee are a little more complex. I'll add some notes to add to the previous measurements and post some related photos in the AM. Did he mention which cab these came from?
Post by: HaRuMaN on August 19, 2013, 10:41:50 pm
I traced the sides directly from sketchup.
Post by: TKW4rr10r on August 19, 2013, 10:54:14 pm
Some notes (will update with pics tomorrow):
Top panel:
- bevel cut on both ends, sits flush to back of cab
- 1.25" below top of side panels
- top face measures 19" W x 22.5" L
- same angle to bevel as top of side panels
To add to the previous post I made about the front panel:
- Speaker grill inner facing hole is 4"W x 7"H. Outer facing side is the 5"Wx8"H
- Marquee inner facing hole is 15.25"W x 3.25"H, outer facing side is 16.5"W x 4.5"H
- small radius corners on speaker grill and marquee
- Coin door remains 7.5" W x x20" H
- larger radius corners for coin door.
Monitor mounting board:
- Total size is 19" W x 23.5" H
- Inner cut out hole measures 15.5" W x 18.5" H
- Inner cut out centered, with 1.75" on either side and also from top of panel.
- Mounting holes for monitor are 5" from each side and 19.5" apart vertically
- Shape accommodates mounting strips from adjacent panels, and is mounted 9.5" back from front edge of top panel.
Bottom panel:
- My cabinet is a little water damaged here, but it seems to be 19"W x 27" L. Once all the other corresponding measurements are done your model should be able to verify.
I guess my next question is, will this be designed to assemble just like the original, with  .75" x .75" strips to mount the panels, or with the same "pocket" design like the other projects here? Pocket design would make for a cleaner, less complicated build. But strength is a concern. Just curious.
Post by: HaRuMaN on August 19, 2013, 11:21:30 pm
I thought about doing pockets, the problem is the sides are flush with the front and back panels, leaving no room for pockets... I could change the design to make it not flush, but then it would not look the same.
Post by: HaRuMaN on August 20, 2013, 01:09:15 pm
Just an fyi, I ended up with an extra MVS kit on hand, so if anyone is interested, I can get it out to you pretty quick.
Post by: TKW4rr10r on August 20, 2013, 01:35:44 pm
Some quick pics before I have to head out on the road again:
(http://i.imgur.com/ObkMYTz.jpg)(http://i.imgur.com/vJ5rrjC.jpg)(http://i.imgur.com/FTAXupl.jpg)(http://i.imgur.com/5oQT0WE.jpg)(http://i.imgur.com/LGrpG51.jpg)
Post by: TKW4rr10r on August 21, 2013, 06:11:20 pm
OK, some more measurements, this time using some good shots of a partially deconstructed cab from an old post in another forum.
(http://i.imgur.com/9HlTuyA.jpg)(http://i.imgur.com/HnhT4cM.jpg)
This is a tempest cabaret, and I choose to show this for it's differences:
Please note the items circled in red. This piece is not in my cabinet and appears to never have been part of it's construction. I believe it to be the lighting mounting plate for the marquee, since the centipedes never had that as an option. Personally, I wouldn't need it, since I have better options for lighting than original, but maybe a single board for the option would not be a bad idea. would add strength to the cab, as well.
(http://i.imgur.com/uLv7WSN.jpg)(http://i.imgur.com/vJ5rrjC.jpg)
Here is what I heard about the tempest and other cabarets with vector tubes having additional venting for the heat they produce. That is the upper rear panel. My centipede is to the right. I think the standard kit should include the panel from the tempest cab instead.
PLEASE let me know if you need any further measurements. As far as construction, I would try for partially pocketed like your other designs, the top, monitor board, and anything else with the exception of front and back panels could be done this way, even some of the blocking strips could be pocketed for added strength. Hope these are helpful in completing your model.
Post by: HaRuMaN on August 21, 2013, 06:47:48 pm
very helpful, thank you...
Post by: floriske.nl on August 23, 2013, 08:29:52 am
Shot a short video of mounting the base of the kit (without glue):
Pre assembling a CNC routed bartop kit (http://www.youtube.com/watch?v=4rA4nbqAClo#)
Post by: HaRuMaN on August 23, 2013, 02:06:09 pm
Uh-oh.. What do I have here?
Post by: Rick on August 23, 2013, 02:08:09 pm
You know, if MY CNC GUY would get back to me with better pricing... ...I still wouldn't be able to compete with your build quality. It looks perfect, man! I can't wait to see the assembly pics! (How many sheets - and of what size - did it take to carve?)
Post by: HaRuMaN on August 23, 2013, 02:16:20 pm
Yeah my cnc guy can make some excellent stuff, for sure!
That was exactly one sheet of 1/2" cherry melamine.
I've got someone working on metal control panels and vents for me, should get them Monday.
The top matches the midway exactly, so existing replacement tempered glass or Plexiglas cab be used...
Post by: Nephasth on August 23, 2013, 02:53:58 pm
Flat pack for PBJ?
Post by: yotsuya on August 23, 2013, 02:57:08 pm
It's too bad PBJ didn't live to see this day.
Post by: HaRuMaN on August 23, 2013, 03:01:56 pm
Haha, yeah, he was dying for a cheaper midway cocktail kit, wasn't he?
Other side:
Post by: Rick on August 23, 2013, 03:04:31 pm
I'm sorry, but I couldn't resist.
It's Peanut Butter Jelly Time!!! (http://www.youtube.com/watch?v=s8MDNFaGfT4#)
Whatever did happen with Pinball Jim, anyway? I've seen the references to him leaving everywhere, but never did find post outlining the root cause. He was still here when I went on hiatus, myself.
(Sorry Haruman. Didn't mean to derail your work!)
Post by: yotsuya on August 23, 2013, 03:51:42 pm
The story is kind of sketchy, but it seems to involve U.S. Marshalls, a Konkey Dong flyer, a one-armed man, and $50 cash-in-hand.
Post by: yotsuya on August 23, 2013, 03:52:56 pm
I thought you were your own CNC Music Factory guy?
Post by: TKW4rr10r on August 23, 2013, 04:29:32 pm
Can't wait to see completed pics. What's this "alternative to coin door" reference on your site about this kit, anyway?
Title: Re: Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
Post by: HaRuMaN on August 23, 2013, 05:45:33 pm
It'll just be a piece of sheet metal, designed to fit over that opening, with a couple of holes as credit buttons, should be pretty cheap compared to a coin door.
Post by: HaRuMaN on August 23, 2013, 05:46:09 pm
Parts laid out:
Post by: HaRuMaN on August 23, 2013, 05:47:08 pm
Dry fit, no glue:
Post by: HaRuMaN on August 23, 2013, 05:47:54 pm
Still dry fit, no glue...
Post by: Rick on August 23, 2013, 05:52:14 pm
Not yet. I'm in the design phase right now. When I have my outbuilding built, then I will have my own CNC machine.
That is one sexy looking box. Nice.
Post by: tron84 on August 24, 2013, 09:46:02 am
She is PRETTY, that is sweet!!!!!! :applaud: :applaud: :cheers:
Looking Good, Mr. Carter!!!!! Nice..... :applaud: :applaud:
You just want all my $$$$ huh  :lol :lol :lol
you take kidneys by chance too?  :lol
Post by: HaRuMaN on August 24, 2013, 02:48:11 pm
No, no kidneys, just cold, hard, cash... O0
Post by: tron84 on August 24, 2013, 03:33:32 pm
Damn, I guess next of kin is out of the question too, huh.  ;D
That did turn out great, would not have expected anything less from you.
I have always loved cocktail tables besides cabinets.  They are nice for chill mode & to put your beers on when playing.  :cheers:  another thing to add to my list. ::) ;D
Post by: Ginsu Victim on August 24, 2013, 04:34:37 pm
How much for the Midway style cocktail kit?  :applaud:
Post by: HaRuMaN on August 24, 2013, 04:43:37 pm
I have to get final pricing from my cnc guy, but it's looking to be under $200 shipped for the melamine kit.
Post by: Brian74 on August 24, 2013, 05:05:16 pm
Haruman, how about one of those red tent nintendo cabs, or some kind of viewlux made the same way? Any plans for some kind of racing cab?
Sent from my SGH-T989 using Tapatalk 2
Post by: TKW4rr10r on August 24, 2013, 06:31:10 pm
A racing cab? The only way I see a CNC kit for one of those if its styled like an early pole position or spy hunter sit down. A lot of parts would have to be sourced, through. And I'm guessing pretty pricey.
The red tents were all metal, not sure how a wooden one would work out. But the idea intrigues me. Maybe some kind of head-to-head bar-top setup? Maybe even just a stand option for those with one or two bar-tops already?
Post by: HaRuMaN on August 26, 2013, 10:46:09 am
So, it's confirmed, the midway cocktail kit (woodgrain melamine) will run $200 shipped. 8)
Post by: HaRuMaN on August 26, 2013, 10:49:46 am
So, New kit designs in progress:
1) Atari cabaret - 80% done
2) mini virtual pin cabinet - 30% done
Other ones in consideration:
Mini-vewlix
Mini-Nintendo
Pedestal
Haven't thought about a racing cab yet... Or a red tent. Let me think about those
Post by: Rick on August 26, 2013, 11:08:33 am
The 'mini-Nintendo' one is a toughy. I've been working on that one myself, and it just doesn't look 'perfect'... It may just be my render, or maybe my measurement conversion is off a bit.
Amazing ideas, as always.
Post by: blashyrk on August 26, 2013, 12:59:08 pm
Love the cocktail kit, do you offer international shipping ?
Post by: HaRuMaN on August 26, 2013, 02:01:44 pm
I can, if you want to PM me with your city, country, and postal code I can tell you how much it would run.
Post by: TKW4rr10r on August 26, 2013, 03:09:53 pm
Mini-vewlix
Mini-Nintendo
Pedestal
NINTENDO BAR-TOP!!!!
Phew, sorry. Killer day at work and had no lunch, a little light headed.  :lol
Can't wait to see the atari cabaret (you got all you needed?). One kit idea that comes to mind that I haven't seen anyone try is the old Nintendo cabaret, ala Donkey Kong:
(http://doc-00-8g-3dwarehouse.googleusercontent.com/3dwarehouse/secure/hhulr73hmmak89paul31eote4ben7ngk/g1kk0i21lsffjngms67ag6l9cdmjq3r8/1377540000000/lt/*/14c80796f521c80533276a8c0b1c862?ts=1319647092000&ctyp=other)
(http://i133.photobucket.com/albums/q57/phetishboy/DSC01384.jpg)
That would be a cool little kit.
Post by: HaRuMaN on August 27, 2013, 10:47:07 pm
I think I have all I need. About 90% done. What kind of material are you wanting to make this from?
That other cabaret is pretty sweet, too.
Post by: TKW4rr10r on August 28, 2013, 06:19:13 am
Would this be one sheet of material or two for the atari cab? I'd say the sides should still be 3/4", but you could make the internals, top, bottom, front, and back 1/2" if this requires two sheets and you want to keep cost/weight down. The "internals" sheet could be black and the "sides" sheet could be white.
I'm not sure how you'll have everything laid out on the material, but the finished look for a normal unit would just be the wood paneling on the sides, all other external surfaces black, with internal black or unfinished. If this all fits on one sheet, you could laminate each side differently (one black, one white or wood grain) and just lay them out so they'll still assemble to get the final look.
Man, it looks like  I need to start repairing the boards for my centipede  ;D
Post by: HaRuMaN on August 28, 2013, 11:35:07 am
It looks like it will take 2 sheets. Problem is, can't fit 2 sides on one sheet, so it will all be 3/4", and it will all be the same material.
I can do a white melamine, or black, or woodgrain... Or if you want something really nice I can do a Baltic birch plywood.
Post by: HaRuMaN on August 28, 2013, 11:50:35 am
Scratch the Baltic birch, can't get in that size...
Post by: yotsuya on August 28, 2013, 12:02:53 pm
Too bad, baltic birch is beautiful.
Post by: TKW4rr10r on August 28, 2013, 01:16:22 pm
Let's go with black melamine. It would be easier to prep just the sides (if needed) for the side art, than painting everything else black.
Post by: HaRuMaN on August 28, 2013, 01:26:32 pm
Sounds good. When my plans are done, I will get an estimate for 3=4" black melamine.
Post by: HaRuMaN on August 28, 2013, 04:18:13 pm
Ok, take a look.
While the main panels aren't tabbed, their supports are, so that should make construction easier.
Post by: HaRuMaN on August 28, 2013, 04:32:11 pm
Also included a panel that will convert it to an LCD monitor...
Post by: TKW4rr10r on August 28, 2013, 05:44:58 pm
It looks great! But there a couple pieces missing:
- Control panel bracket sides (2)
- Control panel back brace (1)
- Cardboard surround / bezel mounting strips (2)
- Monitor bracket backing braces (2)   (these do not need to be the full length of the monitor bracket)
None of that needs to be slotted due to variations of what monitors people use.
(http://i.imgur.com/HXKESiE.jpg)(http://i.imgur.com/uIm0nrV.jpg)
I made some minor adjustments in the layout you had to make any needed space on the sheets (marked in yellow). Not sure how this works with the CNC, just making suggestions.
Also, didn't see in your graphic if any accommodation was made in the recessed cuts for the marquee or speaker grill.
(http://i.imgur.com/ALQc2aj.jpg)
Post by: HaRuMaN on August 28, 2013, 06:42:40 pm
Cool.  I did miss the control panel area.  I'll add that stuff in...
The marquee area and speaker area are drawn to those inside dimensions you gave me.
Post by: Rick on August 28, 2013, 08:15:17 pm
Is this considered a customer commission? I'm wondering if you'd consider a partnership for Nitz' request? Maybe we figure what the design is worth to you, sell it to Nitz (or me) and have me carve it for Nitz, for Canadian distribution?
Maybe this belonged in a PM? Maybe I'm just being transparent.
:D
Post by: TKW4rr10r on August 28, 2013, 08:55:47 pm
OK, the original has the straight through hole in the smaller dimensions, but require a recess of the larger dimension on the outside face to accommodate the glass and metal grill, I'd say 1/4 deep. Sorry for not making that clear before. I think I got both the inner and outer dimensions in the previous posts :
(http://i.imgur.com/wi6X07W.jpg)(http://i.imgur.com/FTAXupl.jpg)
Maybe this belonged in a PM? Maybe I'm just being transparent. :D
I sure hope this isn't a one-off! I'd hate to see so much work going into something just for me. There should be other people in these forums looking for an Atari cabaret. At the very least I'll order another when I start my Major Havoc build.He's got a dedicated customer in me, until I -eventually- get my own workshop that is ;)
Post by: yotsuya on August 28, 2013, 10:18:33 pm
I'm good for one if I can use a 15 inch CRT in it.
Post by: HaRuMaN on August 28, 2013, 10:46:16 pm
:D
We can work something out. :-)
Post by: HaRuMaN on August 28, 2013, 10:48:40 pm
Ah ok, gotcha, I can add a pocket cut to the front no problem.
Yup, not gonna be a one off, will make it available in my store I've it's ready. :))
Post by: HaRuMaN on August 28, 2013, 10:49:58 pm
I don't see why not
Post by: yotsuya on August 28, 2013, 10:51:56 pm
Put it on my tab, bro.
Title: CNC Cut Bartop Kits - Orders Open! New Models Available!
Post by: ron310 on August 29, 2013, 06:33:26 pm
What is the width of that MVS bartop?
Post by: HaRuMaN on August 29, 2013, 06:46:03 pm
Same as the standard bartop, so ~18.82" wide, control panel is 17.72" wide.
Post by: HaRuMaN on August 30, 2013, 03:10:11 pm
Oooh
Post by: Rick on August 30, 2013, 03:15:41 pm
Oooh
Woodgrain is sooooo 80's. (...and that ain't bad.)
:D
Post by: yotsuya on August 30, 2013, 03:32:51 pm
Love woodgrain!
Post by: ghostrider on August 30, 2013, 09:18:43 pm
Is there any way you could build a kit for the Little Ms. Pac-man (http://forum.arcadecontrols.com/index.php/topic,128666.0.html (http://forum.arcadecontrols.com/index.php/topic,128666.0.html)) that Griffindodd (aka Maximus) designed and make it fit the asus 23" evo monitor?  I would be down for one of those for sure.
Post by: particlematt on August 31, 2013, 09:15:18 am
I wanted to say I'm glad and appreciative you're doing this for people like me who want a bartop but aren't in a situation to do the woodwork.
Mini vewlix would be a super rad addition.
Post by: rablack97 on August 31, 2013, 01:01:01 pm
Oooh
Stop it you  :hissy
Post by: HaRuMaN on August 31, 2013, 01:20:17 pm
Oooh
Stop it you  :hissy
Never!
Post by: Rick on August 31, 2013, 01:22:39 pm
Oooh
Stop it you  :hissy
Never!
Get a room, you two! :D
Post by: HaRuMaN on September 04, 2013, 03:13:16 pm
Ok, so I think I got everything, now... Recessed cuts for speaker / marquee, control panel parts, monitor support pieces, and a shelve type thing the cp and monitor assembly rest on...
Post by: TKW4rr10r on September 04, 2013, 10:30:33 pm
It's a thing of beauty, as line art CNC paths go, lol
Post by: HaRuMaN on September 04, 2013, 11:44:17 pm
If you think it looks good, I'll go ahead and put it in for an estimate.
Post by: TKW4rr10r on September 05, 2013, 06:22:40 am
Yeah man looks good to me
Post by: HaRuMaN on September 05, 2013, 08:11:43 am
Awesome
Post by: ghostrider on September 05, 2013, 05:56:18 pm
Any chance of this happening???
Post by: HaRuMaN on September 05, 2013, 10:30:43 pm
I have to get caught up on some other projects, but after that I can take a look.
Post by: steved61 on September 06, 2013, 08:24:58 am
Pedestal?
Steved61
Post by: Rick on September 06, 2013, 09:57:56 am
Pedestal?
Of course! Where else would we put Haruman?
:D
Post by: HaRuMaN on September 06, 2013, 11:14:29 am
Lol. Yes, pedestal is up on the list. :-)
Post by: tron84 on September 06, 2013, 11:21:15 am
Pedestal?
:D
:laugh2: :laugh2: :cheers:
I about spit out my Java when I saw this :D
of course he belongs on there :D
+1 for the Pedestal thou Haruman & the mini pin cab wink wink :)  :cheers:
That cocktail table is coming along Nicely!!!!!! so pretty :)
Post by: mann0mann on September 06, 2013, 10:14:46 pm
Hey Lee, any word on if an xbox original console will fit in the widescreen version?  Hope it will fit without having to remove to the case.  I'm thinking it might if mounted against the back of the monitor support?
Post by: HaRuMaN on September 06, 2013, 10:29:36 pm
I just checked, and no, it will not fit. Sorry...
Post by: tron84 on September 12, 2013, 02:48:56 pm
Well finally the Barstick is finished. :D
I used GGG, GP Wiz40 Max interface.  So down the line rotary joys could be used if decided to be put in here. :D
Thanks again Haruman for the kit. :cheers:
(http://i.imgur.com/Sx9AG0r.jpg)
I do not have the back on it for the pic, so there is some light from the marquee showing on the wall.
(http://i.imgur.com/7bACSDP.jpg)
But on the CP & the top of the Barstick, I did a Data East in a Star Wars font  ;D
(http://i.imgur.com/EV1iR3C.jpg)
Post by: Malenko on September 12, 2013, 06:04:32 pm
that is tits right there, big fat oprah tits  :applaud:
Post by: tron84 on September 12, 2013, 06:17:40 pm
lol  :laugh2:
Thanks man  :cheers:
Post by: degenatrons on September 13, 2013, 02:47:02 pm
Looks sweet!  and good to see the first completed barstick  8)  Hopefully will inspire others to make one.
Post by: Rick on September 13, 2013, 02:49:53 pm
She's a beauty!
Just a question - have you considered rounding the two back corners? In looking at them, the top rear corner looks a bit sharp for my tastes, which led me to think if you did both, the t-molding could be 'joined' in the center of the bottom, and then you wouldn't have as many sharp corners.
Just my two cents.
Post by: tron84 on September 13, 2013, 06:41:43 pm
Thanks degenatrons :D & thanks for the open source plans for it. :)  I hope it will inspire others to make one. :)  I really like the Barstick.  ;D
You can never have to many controllers  ;D
@Rick
Thanks also  ;D
The rear top corner is a bit sharp.  I had to snip a little of the inside track of the Tmold to get it to go on the rear corners.  No biggie thou  ;D
Post by: rablack97 on September 16, 2013, 11:06:45 am
Nice work man on the barstick....
Did you recess the sticks a bit? Cause they look mights short.
I sometimes have to route a recess under the CP so the sticks sit up higher.
Regardless the assembly and completion was well done. :applaud: :applaud: :applaud: :applaud:
Post by: tron84 on September 16, 2013, 02:32:00 pm
Thanks man  ;D
& a shout out again to Haruman for his kits :D
No, I did not recess the sticks.  They are just shorties  :D   normally I just say that after getting out of a cold pool  ;D ::) :laugh: :lol
I like the quick throws of them.  To the top of the ball is 2" from panel.
Post by: Rick on September 16, 2013, 04:13:41 pm
No, I did not recess the sticks.  They are just shorties  :D   normally I just say that after getting out of a cold pool  ;D ::) :laugh: :lol I like the quick throws of them.  To the top of the ball is 2" from panel.
So, these are mounted from underneath then?
Post by: HaRuMaN on September 17, 2013, 10:33:50 am
Yes.
Post by: HaRuMaN on September 17, 2013, 10:40:51 am
So, until I find a good (read cheap) freight option, the Atari Cabaret will be local pickup only...
Post by: tron84 on September 17, 2013, 10:49:44 am
They must have some serious weight to them.  How much was the quote that you said, "umm I dont think so"?
I am sure somebody here knows a good freight option.
Post by: HaRuMaN on September 17, 2013, 10:54:30 am
Well the issue is that anything over 150 pounds gets pushed into freight category (with FedEx) and that basically quadruples the price.
3/4" Black Melamine is pretty heavy, even heavier than 3/4 plywood.  With 2 sheets of melamine, it'd be pretty close to the limit...  plywood should be able to keep under the limit maybe.
Post by: Rick on September 17, 2013, 11:00:13 am
Well the issue is that anything over 150 pounds gets pushed into freight category (with FedEx) and that basically quadruples the price.3/4" Black Melamine is pretty heavy, even heavier than 3/4 plywood.  With 2 sheets of melamine, it'd be pretty close to the limit...  plywood should be able to keep under the limit maybe.
I was thinking about this myself, for my pinball cabinets. If the price is prohibitive, try packaging the larger items separately, to bring the price down. Sure, you'll be almost doubling your regular shipping costs, and increasing the risk of lost/short shipments, but you should be able to get your packages in under the weight limit.
Source: I worked for Canada's largest courier company for over 13 years.
:D
Post by: HaRuMaN on September 17, 2013, 11:06:01 am
:D
Hmm...  that's a thought.  Put the 2 sides together in a largish box, then the rest of the parts in smaller box #2.  Each one would be well under 150 pounds.
Post by: Rick on September 17, 2013, 11:06:59 am
"Thank you for shopping at Rick's Shipping Tips. Helping out the competition since 2013."
:lol
Post by: HaRuMaN on September 17, 2013, 11:11:03 am
:lol
Lol.
Post by: HaRuMaN on September 19, 2013, 03:30:15 pm
Mmm...
Post by: TKW4rr10r on September 19, 2013, 04:40:16 pm
That's incredible!  :o The glass come with the kit? did you paint the black areas around the controls, or where they cut from black stock? Also what size LCD is in that cocktail?
I'm working with a local CNC guy in SC for the Atari kit. I hope to have one cut and some photos up in the next week or so, in case anyone is curious on how the finished product turns out.
Post by: HaRuMaN on September 19, 2013, 05:02:16 pm
Glass not included, but is available online for around $80 shipped.
Those particular control panels were cut from wood, and covered with black cabinet grade vinyl.  Metal pacman control panels (11") will work as well.
The top is designed to fit a 20.1" LCD, a Dell 2001FP.
Post by: yotsuya on September 19, 2013, 06:25:50 pm
HOLY ---smurfing--- ---steaming pile of meadow muffin---, THAT LOOKS AWESOME!
Post by: Nephasth on September 19, 2013, 06:36:04 pm
OMGWTFBBQ!!!
Post by: HaRuMaN on September 20, 2013, 09:54:06 am
Another pic
Post by: Rick on September 20, 2013, 10:08:34 am
Is that price coming from you, or a different source? Any opportunity for smoked/tinted?
Post by: HaRuMaN on September 20, 2013, 10:33:46 am
Nope, different source.  I will look into smoked / tinted.
Post by: HaRuMaN on September 20, 2013, 01:37:41 pm
Flash on
Post by: Rick on September 20, 2013, 01:43:24 pm
With all the money you make from these kits, please consider investing in a better camera.
;) :D
Awesome work, man!
Post by: HaRuMaN on September 20, 2013, 01:49:08 pm
;) :D
Awesome work, man!
Lol.  All the money from the kits, so far, has been going into new kits for the most part.  I have a good camera, cell phone is just more convenient!   :afro:
Post by: TKW4rr10r on September 20, 2013, 06:02:08 pm
I'm curious how a 16:10 22" LCD would work in one of those, or is the width too much for the cabinet? It would be 22 1/8" width.
Post by: yotsuya on September 20, 2013, 06:19:39 pm
You can see how tight the setup is. Not sure a widescreen that big will fit.
Post by: steved61 on September 20, 2013, 08:21:53 pm
Any news on the pedestal design?
Steved61
Post by: Rick on September 20, 2013, 08:46:32 pm
I'd be interested in figuring out how much thinner this would be decased. If it was, maybe it would be closer to the allowable space...
Post by: HaRuMaN on September 20, 2013, 08:47:54 pm
Steved61
I believe I'll have a drawing finished next week... as well as another design that some have been asking for
Post by: Rick on September 20, 2013, 08:49:53 pm
(http://liveforfilms.files.wordpress.com/2010/05/hank-azaria-as-gargamel-in-the-smurfs-movie.jpg)
Cautiously excited!
Post by: HaRuMaN on September 21, 2013, 09:43:01 am
Oooo
Post by: Rick on September 21, 2013, 09:49:30 am
Oooo
(http://cronkitehhh.personal.asu.edu/wp-content/uploads/2012/11/obama-not-bad.jpeg)
Post by: yotsuya on September 21, 2013, 12:17:08 pm
It was very well received, HaRuMaN. Great job on the kit!
Post by: retrogamedude on September 21, 2013, 06:07:31 pm
I ordered a widescreen kit today :)  excited to work on my first arcade
Post by: HaRuMaN on September 21, 2013, 06:12:41 pm
Excellent, your order has been added to the list at the CNC shop, and will probably be going out in a week or so.   :cheers:
Post by: retrogamedude on September 21, 2013, 06:25:50 pm
Awesome glad you saw it, wasnt sure if there was anything else I needed to do.  I look forward to putting it together!
Post by: tron84 on September 22, 2013, 12:35:35 pm
Oooo
That is the SHIOT !!!! :applaud: ;D :cheers:  gorgeous man, very nice job. :applaud:
Are you going to do a bezel for it?
Post by: HaRuMaN on September 25, 2013, 02:23:05 pm
Just another day in paradise...
Post by: Rick on September 25, 2013, 02:27:10 pm
Wuzzat? Bartop back? Something new?
Post by: HaRuMaN on September 25, 2013, 02:28:56 pm
Nothing new, just the back to a widescreen kit.  I actually got to the shop as he was wrapping up so I got see it in action for once.
Post by: retrogamedude on September 25, 2013, 03:11:49 pm
hopefully mine is in there somewhere :)
Post by: HaRuMaN on September 25, 2013, 03:23:04 pm
Actually, yes.  2 wides & a standard were picked up today.
Post by: Malenko on September 25, 2013, 05:46:06 pm
they are gonna flip when they see a pimped out vert.
Post by: HaRuMaN on September 26, 2013, 10:12:20 am
It's gonna be sweet! ;)
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=297352;image)
Post by: tron84 on September 26, 2013, 12:38:38 pm
Nice choice!!!!!  :applaud: :applaud: a mini Ms. Pac  sweet  :o ;D
Post by: Malenko on September 26, 2013, 01:57:45 pm
Galaga and Reuinion art is next on the agenda
Post by: tron84 on September 26, 2013, 09:51:39 pm
me waits in anticipation  :D :applaud: :applaud:
I was waiting to see the Galaga version.... mini cab porn  ::) :o ;D  is it wrong to be turned on by the mini's  ::)  :lol :lol  :cheers:
Post by: Malenko on September 27, 2013, 10:14:00 am
heres a picture from my phone of the WIP in photoshop.  Galaga art is done, Reunion art is almost done.
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=130522.0;attach=297455;image)
Post by: Rick on September 27, 2013, 10:19:26 am
Very, very nice! And damn. I was going to make my Galaxy model into a Galaga bartop. Damn, damn, damn. (I guess I'll just have to paint my cab sides WHITE now...)
A tip of my hat to you, sir. I can't WAIT to see yours complete.
Post by: Malenko on September 27, 2013, 10:36:54 am
or you can paint it black and get Haruman to print you the ones I sent him :)
Post by: Rick on September 27, 2013, 10:38:28 am
Oh no, I'm not taking your sloppy seconds. I'm going a whole other direction now.
(http://www.dragonslairfans.com/galaxian/galaxian-namco.jpg)
Post by: Malenko on September 27, 2013, 10:41:42 am
Well, spoiler, I was working on Galaxian art too and its almost done. :/
Post by: tron84 on September 27, 2013, 11:30:35 am
KIller work man  8) :applaud: very nice.....
That Galaga & Ms Pac are going to be F*in sweet man.  :burgerking: :applaud:
I was going to ask Haruman where he got that printing done. Well now I know he printed it.  ;D
nice galaxian too :D
Post by: HaRuMaN on September 27, 2013, 11:45:32 am
I get my stuff printed at Soul Draw, great quality, great price...   :applaud:
Post by: tron84 on September 27, 2013, 11:53:53 am
ahh ok, Malenko made it sound like you printed it.
I was like daumn Haruman is a lil Macgyver  :lol
Post by: HaRuMaN on September 27, 2013, 11:57:14 am
Hehe.  If I had a large chunk of change I'd be my own arcade game shop...
Wants:
CNC Router
Large Format Printer
Plasma Cutter
Metal Brake
Laser Engraver
Post by: tron84 on September 27, 2013, 12:13:38 pm
Wants:
CNC Router
Plasma Cutter
Metal Brake
Laser Engraver
It would be nice to have all that  :)
I would just be happy with an big arcade  ;D  Like in the golden age type a real one  ;)
Post by: TKW4rr10r on September 28, 2013, 06:15:44 pm
Well that's bookmarked now  ;)
May need to pick your brain on ordering from them eventually.
Post by: Rick on September 28, 2013, 06:31:33 pm
Which product is it you're using. The vinyl sticker?
p.s. The site is AWESOME. Thanks!
Post by: macattack on September 28, 2013, 06:43:17 pm
Interesting vinyl site, grammar on the pages is however atrocious !! Lol
WWW.Xtremepinball.com
Post by: Malenko on September 28, 2013, 08:44:44 pm
My guess was not a native English speaker. Still, its better than my Chinese.
Post by: retrogamedude on September 28, 2013, 10:01:59 pm
Any chance mine will be shipping soon?  Need to request a few days off work so I can build it :)
Post by: HaRuMaN on September 28, 2013, 10:05:00 pm
I got all the slot cutting finished today, these will be shipping out Monday. FedEx home is what I use so you are looking at around 4 days shipping time.
Post by: HaRuMaN on September 28, 2013, 10:09:41 pm
About soul draw, they are located in China, but I usually get my orders about 2 weeks after placing them.
For side art, I get the black adhesive vinyl sticker. For marquees, I get the backlit pvc film.
Post by: TKW4rr10r on September 28, 2013, 10:12:38 pm
Thank you for that, had no clue what the different styles were when reading the site.
Post by: HaRuMaN on September 28, 2013, 10:15:03 pm
Yeah, they have a ton of different stuff there...
Post by: HaRuMaN on September 28, 2013, 10:25:51 pm
New designs coming next week:
Pedestal, mini virtual pin, and Nintendo inspired bartop
Post by: Rick on September 28, 2013, 10:27:34 pm
No full size pin? /sadpanda
Post by: TKW4rr10r on September 28, 2013, 10:37:46 pm
Uh oh Rick, I may have to go local for my Nintendo Bar-top. We'll see how the two compare :angel:
I kind of owe HaRuMaN an order after his work on the Atari model, after all.
I'll add a 2nd LCD to that request of yours (17" + 19") as compensation when I start shipping parts again, if it's any consolation.
Not like anyone will have a hard time selling them  ;D
Post by: Rick on September 28, 2013, 10:45:16 pm
Uh oh Rick, I may have to go local for my Nintendo Bar-top. We'll see how the two compare.
No worries, sir! Save the cost on the shipping, for sure! From the pics alone, you can't question Haruman's build quality.
I appreciate the offer, but I won't hold you to that. It's business, and I totally understand the decision.
Not like anyone will have a hard time selling them.
I hope so!
Post by: HaRuMaN on September 28, 2013, 11:00:04 pm
If I can keep it under 150 lbs...
Post by: Brian74 on September 29, 2013, 12:38:37 am
Wall mount jukebox, something that looks better then that north coast custom one. Dual screen goodness!
Sent from my SGH-M919 using Tapatalk 2
Post by: HaRuMaN on September 29, 2013, 01:09:30 pm
Midway cocktail with alternate black top (add $20):
Post by: HaRuMaN on September 29, 2013, 01:17:39 pm
Wewt
Post by: yotsuya on September 29, 2013, 01:27:25 pm
How much for the map of the 50 states?
Post by: Malenko on September 29, 2013, 01:41:44 pm
tooooo late! I already called dibs.
Post by: yotsuya on September 29, 2013, 01:45:21 pm
Awwwww man!!! I got cash in hand for that potato chip on the floor!
Title: Re: Re: Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
Post by: HaRuMaN on September 29, 2013, 01:49:01 pm
$500
Post by: HaRuMaN on September 29, 2013, 03:56:49 pm
That's a toy potato chip, btw.
Post by: yotsuya on September 29, 2013, 06:58:28 pm
So does that, like, raise the price?
Post by: HaRuMaN on September 29, 2013, 07:12:08 pm
Indeed
Post by: Rick on September 29, 2013, 07:18:55 pm
Indeed
Just so you know, I'm including a snack pack with all of my kits. Yes, that's right.
Mine are all that ... and a bag of chips.
:D
Post by: HaRuMaN on September 30, 2013, 12:02:05 pm
Yes, but I include free pipe insulators that can be used to help keep pipes from bursting in those cold winter months!
Post by: yotsuya on September 30, 2013, 12:12:44 pm
So do those of us doing local pickup get the free pipe insulators? Or is that shipping only?
Post by: HaRuMaN on September 30, 2013, 12:14:56 pm
Shipping only!  Makes for great edge protecting for the melamine.
Post by: Malenko on September 30, 2013, 02:25:13 pm
great idea, just like pool noodles.  >:D
Post by: HaRuMaN on September 30, 2013, 03:48:24 pm
 >:D
Post by: Rick on September 30, 2013, 04:03:33 pm
>:D
Not too shabby. How large is the marquee on that puppy?
Post by: HaRuMaN on September 30, 2013, 04:31:33 pm
>:D
Roughly 4" X 17.75" viewable
Post by: Rick on September 30, 2013, 04:34:12 pm
Sweet deal! When do you hope to have yours complete? (I only ask, since you stole one of my customers away, and I hope he doesn't have to wait too long.)
Post by: yotsuya on September 30, 2013, 04:34:56 pm
Just picked up my 5th (!) HaRuMaN Special (2nd cocktail). The  man is a pleasure to deal with. If you're on the fence, don't be afraid to pull the trigger. Quality stuff here.
Post by: HaRuMaN on September 30, 2013, 04:36:13 pm
Thanks man!  Making chufftember's possible since 2012!
Post by: TKW4rr10r on September 30, 2013, 05:52:41 pm
Nice!
I would recommend something though, and extend the CP panel a bit to sit on top of the front panel, or reposition them. The nintendo cabs had that look and this way one could add the t-molding to match:
(http://[url=http://1.bp.blogspot.com/-NyshNgGQFC4/UUJNI0RZ18I/AAAAAAAAAIY/LxOMuniKHfE/s1600/IMG_2574.jpg]http://1.bp.blogspot.com/-NyshNgGQFC4/UUJNI0RZ18I/AAAAAAAAAIY/LxOMuniKHfE/s1600/IMG_2574.jpg[/url])
This is just going off the CNC sketch and not seeing a completed unit, though. Awesome work as always.
Post by: HaRuMaN on September 30, 2013, 07:42:13 pm
The control panel does sit directly on top of the control panel, the yellow pockets you see on the sides are for the batons the co will rest on.
Post by: HaRuMaN on October 01, 2013, 10:53:09 am
It's ready to be cut now, I have the estimate back from my CNC shop.  For black melamine, it's going to be the same cost as the vertical ($190 shipped with slots cut).  Another customer requested it made out of cabinet grade baltic birch plywood, that's going to be $230 shipped with slots cut.
Post by: HaRuMaN on October 01, 2013, 12:33:35 pm
Fun with sketchup...
Post by: HaRuMaN on October 01, 2013, 01:38:25 pm
@TKW4rr10r, I finally figured out how to move my parts around in Sketchup, so here are a couple of 3D renders to help you visualize:
Front profile:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=297636;image)
And the back:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=297638;image)
Post by: Rick on October 01, 2013, 01:43:33 pm
You missed a spot.
Post by: HaRuMaN on October 01, 2013, 01:50:18 pm
You missed a spot.
You're killin' me.  Where?
Post by: Rick on October 01, 2013, 01:54:11 pm
I'm mostly just jibin' ya, man. BUT, when I looked to the Popeye bartop as well as the actual Nintendo cabs, I noticed there's an unused panel above the control panel... On my design, I made it like an inch and a half. It's purely cosmetic, so really, it's a "to each his own" kinda thing.
Your design looks GREAT. I wouldn't change a thing. (Personally, I like the way yours will support the monitor more vertically. I've noticed most of the true cabs - if not all of them - have a HUGE angle on the monitors.)
Post by: HaRuMaN on October 01, 2013, 02:12:04 pm
I gotcha.  Yeah, I plan on the bezel coming down all the way to the control panel.  As far as the monitor goes, I like more vertical, about 80 degrees, but with the way the kit is designed, and the room available, the angle can be adjusted to whatever the customer wants.  :cheers:
Post by: TKW4rr10r on October 01, 2013, 10:24:58 pm
Yeah that makes a lot more sense. The original drawings threw me off, don't know what I was seeing  :dizzy:
Post by: HaRuMaN on October 02, 2013, 04:13:26 pm
Rick better look out now, I'm unstoppable!   >:D
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=297694;image)
Post by: Rick on October 02, 2013, 04:17:34 pm
Very slick, sir!
(Let me know if you want any help figuring out what's missing.)
>:D
Post by: HaRuMaN on October 02, 2013, 04:24:15 pm
Very slick, sir!
>:D
Say what now?
Sawdust?  Oh wait, I gots lots of that...  >:D
Post by: Rick on October 02, 2013, 04:49:42 pm
 :angry: :timebomb: :censored: ;)
Say what now?
I've read a lot of posts on the virtual pinball sites regarding the holes for the legs, saying it's much to difficult to drill after the cab is built. Beyond that, are you planning on having a hole for any DMD? (Yes, I realize it's just a preliminary sketch. I'm just spitballing.)
:D
Post by: macattack on October 02, 2013, 05:08:40 pm
Assume for this design you are not using melamine with all those exposed edges.
Leg holes are better done ahead of time, i certainly cnc mine upfront.
Monitor location looks pretty low in the cab.
Button placement will likely interfere with monitor, flippers look a little high and forward.
Assume your going for a 2 screen setup.
There should also be a ledge at the front of the backbox.
WWW.xtremepinball.com
Post by: HaRuMaN on October 02, 2013, 05:11:56 pm
Say what now?
No, seriously.  Like 1/3 of my garage is covered...   :dizzy:  I need to clean.
:D
Waiting to hear back from the customer on the DMD.  And as far as the holes for the legs go, how are you planning on having them CNC'ed at a 45 degree angle, unless your CNC shop has a 4-axis setup?
Post by: Rick on October 02, 2013, 05:19:44 pm
I didn't. I have them cut through on both the front and back as well as the sides. The corresponding holes are just large enough for the commonly used bolts, and will work fine to "guide" the bolts through...
(http://i.imgur.com/fuwyzaT.jpg)
From what I've seen, the legs come with both covers and inside brackets, which help to square them up with the rest of the cabinet.
Post by: HaRuMaN on October 02, 2013, 10:52:35 pm
What's the vertical spacing on those holes, center to center? And the radius on the holes?
Post by: cdf12345 on October 02, 2013, 11:30:31 pm
Also what size monitors are you shooting for? I have a 24" playfield 19" 4/3 backglass system just waiting for a cabinet
Post by: HaRuMaN on October 02, 2013, 11:42:14 pm
That's a 24" for both monitors, but I can easily adjust the top for a 19" 4:3 if needed.
Post by: Rick on October 03, 2013, 10:53:39 am
Sure, take all of my secrets...
(http://i.imgur.com/59w9X0u.png)
Post by: HaRuMaN on October 03, 2013, 11:21:22 am
Why, thank you,  You are a scholar & a gentleman.
Post by: Rick on October 03, 2013, 11:22:37 am
No worries! I'd sell you my plan, but it's in 3D, and I've heard you can't read those. (Dig, dig, dig.)
Post by: HaRuMaN on October 03, 2013, 11:49:37 am
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=297706;image)
 :burgerking:
Post by: Malenko on October 03, 2013, 11:54:40 am
weak  >:D
Post by: HaRuMaN on October 03, 2013, 04:49:02 pm
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=297718;image)
Post by: HaRuMaN on October 03, 2013, 04:50:28 pm
And yes, this is 1/2" mdf.  There was no way to do this well in black melamine due to the exposed edges...
Post by: Rick on October 03, 2013, 07:32:37 pm
Now, all that's missing is a PRICE. (And are you planning on routing the t-molding slots around the backbox, or will this be at an additional cost?)
Post by: HaRuMaN on October 03, 2013, 08:30:31 pm
Yeah, I need to get the quote back from my cnc guy. Looks like this design will take about a sheet and a half of mdf.
Slot cutting will be the same deal as my other kits. :-)
Post by: macattack on October 04, 2013, 02:42:46 pm
come on, come on. lets see the saw dust :)
you guys are falling behind ;)
Post by: Rick on October 04, 2013, 02:44:34 pm
come on, come on. lets see the saw dust :) you guys are falling behind ;)
Sorry, but some of us had to design our stuff from scratch.
Post by: macattack on October 04, 2013, 02:54:02 pm
Your right I do have a distinct advantage that I already have a fullsize pin and DK kit that I just needed to reduce. plus not being dependant on other people for the cnc work. Still looking forward to us now being able to cover west coast, east coast and Canada!!
everyone spoiled for options!!
keep up the good work.
Post by: Rick on October 04, 2013, 02:57:06 pm
Still looking forward to us now being able to cover west coast, east coast and Canada!! everyone spoiled for options!! keep up the good work.
You too, sir! And let me be the first to propose the North American Arcade Cabinet Alliance. (Had to add "cabinet" or else, the acronym is "NAAA"... LOL.) PM outbound.
:D
Post by: steved61 on October 05, 2013, 12:23:32 pm
All right stop teasing. Pedestal?
Steved61
Post by: HaRuMaN on October 05, 2013, 12:59:40 pm
Steved61
it's coming O0
Post by: fantoboy on October 06, 2013, 01:22:50 am
So is the 2-player model built around the Asus Evo monitor dimensions?  I'm guessing that would be the recommended monitor to buy?  I'm also a big fighting game fan, so less lag is good.
http://www.amazon.com/Asus-VS238H-P-23-Inch-Full-HD-LED-Lit/dp/B005BZNEVQ/ref=sr_1_1?ie=UTF8&qid=1381036749&sr=8-1&keywords=ASUS+VH236H+Black+23%22 (http://www.amazon.com/Asus-VS238H-P-23-Inch-Full-HD-LED-Lit/dp/B005BZNEVQ/ref=sr_1_1?ie=UTF8&qid=1381036749&sr=8-1&keywords=ASUS+VH236H+Black+23%22)
Post by: HaRuMaN on October 06, 2013, 11:06:34 am
Yes it is. :)
Post by: rablack97 on October 07, 2013, 09:31:44 am
Check PMs please :)
Post by: HaRuMaN on October 07, 2013, 09:52:38 am
Check PMs please :)
Done.  Just got back from vacation.  :)
Post by: rablack97 on October 07, 2013, 12:51:42 pm
Gracias!!!!!! :applaud:
Post by: HaRuMaN on October 07, 2013, 04:30:34 pm
Pedestal?
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=297915;image)
Post by: Rick on October 07, 2013, 04:47:18 pm
Pedestal?
Yes. Now, put me on it.
:D
Post by: HaRuMaN on October 07, 2013, 04:57:12 pm
Pedestal?
:D
Post by: floriske.nl on October 08, 2013, 05:33:55 am
@HaRuMaN:
Can you tell me how deep you cut the slots for the t-molding? And how you limit the cut depth of your slot cutter?
Since the pockets are 1/4" deep and prety close to the edge you might cut into them if you cut at the full depth of a "Standard" slot cutter.
Post by: Rick on October 08, 2013, 08:37:53 am
I'm gonna go out and guess he's using a router table, like I do.
(http://www.woodworkingtalk.com/attachments/f12/22934d1301514926-table-saw-router-please-advise-router.jpg)
It has an open port for the blade, and adjustable back guards, which move forward and backwards, as well as side to side.
Post by: HaRuMaN on October 08, 2013, 09:18:15 am
I do, but that is inadequate for limiting depth of cut, especially on curved / angled pieces.
The standard 1/16" slot cutter, out of the box, cuts the slots WAY too deep, like twice as deep as they need to be.
What I ended up doing was purchasing a larger bearing separately, and replacing the stock (smaller) bearing on the cutter.  That way the depth of cut is always mechanically limited by the slot cutter itself.
Post by: macattack on October 08, 2013, 09:27:47 am
Good tip.
Post by: HaRuMaN on October 08, 2013, 09:29:11 am
Good tip.
Yeah, I wrecked a couple of bartops before I figured that out.   :banghead:
Post by: macattack on October 08, 2013, 09:31:15 am
[/quote]
[/quote]
Lol, I had cut through a number of staples also doing the same.
Post by: Rick on October 08, 2013, 09:32:15 am
Or, you could just exercise more control over the piece you're routing. There's no reason you can't use the table if you're cautious.
Post by: macattack on October 08, 2013, 09:36:04 am
issue is you need to get pretty hands on if you are trying to gauge it, bearing is the way to go.
Post by: Rick on October 08, 2013, 09:40:32 am
Don't make me pull out my Dogbert gif. ;)
Okay, okay. I'll upgrade my bearing.
Post by: HaRuMaN on October 08, 2013, 09:42:38 am
 :dunno
That's great in theory, not so much in practice.  With the bearing swap, I can slot cut a whole bartop kit in about 5 minutes.  When I've got 8 bartop kits to slot, pack, and ship, reducing the slot cutting time is huge.
Post by: Rick on October 08, 2013, 11:41:49 am
(http://24.media.tumblr.com/tumblr_lxainyL5QX1r77ggzo1_500.gif)
;)  >:D
Post by: HaRuMaN on October 08, 2013, 11:47:54 am
You're lucky saint won't let me change people's custom text...   ;) >:D
Post by: Rick on October 08, 2013, 11:49:25 am
That didn't stop you from changing my other post to "Smiling Bob", now, did it?
Post by: HaRuMaN on October 08, 2013, 11:53:33 am
 >:D
I used to be able to change people's usernames, but alas, no more...   :'(
Post by: yotsuya on October 08, 2013, 11:55:37 am
Did Saint give you the "With great power comes great responsibility" speech before he took it away?  >:D
Post by: Rick on October 08, 2013, 11:57:04 am
Yes, and one of these, I suppose.
 :whap
Post by: HaRuMaN on October 08, 2013, 01:26:07 pm
Just for you, Rick:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=298023;image)
Post by: Rick on October 08, 2013, 02:04:53 pm
Yeah? YEAH?! Well... WELL!!! I don't like your vents.
:P
Post by: HaRuMaN on October 08, 2013, 02:10:42 pm
:P
(http://static.fjcdn.com/gifs/haters_fb62b5_2448292.gif)
Post by: floriske.nl on October 08, 2013, 02:32:34 pm
Because I wanted to route a kit this evening and couldn't get hold of a bearing that quick I ended up cutting an acrylic "press on"  adapter ring for the bearing on my cnc router. That worked!
Also been looking into 12mm laminated particle board instead of blank MDF, but that's pretty expensive over here because it's not commonly used.
The kit I just finished is in mdf that has a white ground coat on it (no idea what it's called in English). At least that's s lot better than the normal blank version.
Post by: Rick on October 08, 2013, 02:41:47 pm
But, but, but... I thought you guys invented IKEA?
Post by: floriske.nl on October 08, 2013, 02:54:39 pm
Lol  :laugh2: no no no no no ....... that's in Sweden  :hissy:
15 and 18mm in plain white or (black) woodgrain are quite common, but 12mm plain black isn't. Available in HPL instead of melamine mostly and that's triple the price of the pre coated MDF
Edit: here's a crappy phone pic of the pre grounded mdf (can someone please tell me what it's called in english?  :cheers:) kit before routing the T-molding
(https://dl.dropboxusercontent.com/u/72592758/cnc/fotos/thumbs/20131008_080621.jpg) (https://dl.dropboxusercontent.com/u/72592758/cnc/fotos/20131008_080621.jpg)
Edit 2: Some beter pics
(https://dl.dropboxusercontent.com/u/72592758/cnc/fotos/thumbs/IMG_1852.jpg) (https://dl.dropboxusercontent.com/u/72592758/cnc/fotos/IMG_1852.jpg) (https://dl.dropboxusercontent.com/u/72592758/cnc/fotos/thumbs/IMG_1853.jpg) (https://dl.dropboxusercontent.com/u/72592758/cnc/fotos/IMG_1853.jpg) (https://dl.dropboxusercontent.com/u/72592758/cnc/fotos/thumbs/IMG_1877.jpg) (https://dl.dropboxusercontent.com/u/72592758/cnc/fotos/IMG_1877.jpg)
Post by: floriske.nl on October 10, 2013, 04:33:52 am
@HaRuMaN: maybe this is interesting for you (or maybe not  :dunno)
Because I don't like marquees mounted with angled profiles (looks too plump) I came up with the following mounting method for the marquee on kits with T-Molding:
(https://dl.dropboxusercontent.com/u/72592758/bartop/thumbs/Marquee%20mounting_T-molding.jpg) (https://dl.dropboxusercontent.com/u/72592758/bartop/Marquee%20mounting_T-molding.jpg)
If someone wants a kit without T-Molding I still use the method I also used for Evo XR Cade:
(https://dl.dropboxusercontent.com/u/72592758/bartop/thumbs/Marquee%20mounting%20sample_600px.jpg) (https://dl.dropboxusercontent.com/u/72592758/bartop/Marquee%20mounting%20sample.jpg)
This method can't be used with T-molding because the t-molding slot would run into the top slot for the marquee, cutting of the edge. This could be prevented by mounting the marquee deeper into the cabinet, but think that would look awkward.
Post by: Rick on October 10, 2013, 06:16:58 am
Because I don't like marquees mounted with angled profiles (looks too plump) I came up with the following mounting method for the marquee on kits with T-Molding. This method can't be used with T-molding because the t-molding slot would run into the top slot for the marquee, cutting of the edge. This could be prevented by mounting the marquee deeper into the cabinet, but think that would look awkward.
Now, hold on just a second. I may not have a lot of 'original' ideas, but I'd like to claim at least this one for my own.
(http://www.imgur.com/aIFEzOc.jpeg)
To whit:
Each of my bartop designs have integrated 1/4" slots carved into them to support easy installation of plexi for playfield glass and marquees.
No harm, no foul here though. Even macattack heisted my idea.
Post by: macattack on October 10, 2013, 06:22:43 am
You missed the monitor bracket shape also ;)
Post by: Rick on October 10, 2013, 06:27:31 am
Why, you?!!
:lol
Post by: rablack97 on October 10, 2013, 08:40:58 am
Am i missing something but dont you need 2 pieces of plexi for a marque, you have to sandwich the graphic, right.
The t-molding method sounds promising, the only issue i forsee, is t-molding does not like to pulled in and out of its slot.  Eventually with maintenance over time if you have to remove your marquee, that slot won't be as tight.
Post by: Rick on October 10, 2013, 09:05:37 am
Exactly why Rick's Plexi Slots (TM) are 1/4".
Post by: macattack on October 10, 2013, 09:09:42 am
Think it depends on how far you spanning and the material thickness that was used, if you only spanning a couple of inches and the material is 1/2" or 3/4" then it usually offers enough support to hold it in place. That said sandwiches are nice ;)
Post by: HaRuMaN on October 10, 2013, 09:30:20 am
Why, you?!!
:lol
Yeah, well, that's one design flaw I won't be borrowing...   ;)
Post by: Rick on October 10, 2013, 10:02:27 am
I don't know what you're talking about.
Post by: HaRuMaN on October 10, 2013, 10:06:34 am
MDF isn't good in torsion... and you've gone and removed about 50% of the torsion strength it did have...  ;)
(I'm an engineer in my day job)
Title: Re: Re: Re: Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
Post by: Rick on October 10, 2013, 10:17:19 am
MDF isn't good in torsion... and you've gone and removed about 50% of the torsion strength it did have...  ;) (I'm an engineer in my day job)
Well, if I was concerned someone might want to SIT ON my cabs, maybe that might be a concern.
:D
Post by: HaRuMaN on October 10, 2013, 10:20:22 am
:D
I'm talking about the monitor mount, not the cabinet.  And you'll be hanging a fairly substantial weight on it.  At an angle.
Post by: macattack on October 10, 2013, 10:23:21 am
:D
I agree, but for this application, given the weight it should be fine.
 besides mine are in plywood ;)
Title: Re: Re: Re: Re: Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
Post by: Rick on October 10, 2013, 10:24:26 am
The 27" monitor in my Doom cab is on a similar mount, and weighs significantly more than the 19" monitors I'll be using. I have NO concerns about the mounts.
Post by: HaRuMaN on October 10, 2013, 10:56:58 am
Oh, plywood has a better torsional strength, for sure, given it's layered structure.
Post by: floriske.nl on October 10, 2013, 02:21:18 pm
http://www.imgur.com/aIFEzOc.jpeg (http://www.imgur.com/aIFEzOc.jpeg)
To whit:
Feel free to claim as you like  ;) and I hate to spoil your party, but in what matter does this:
look like your slots in the sidepanels?  :dunno
If you are referring to the other picture instead: I'd hate to spoil that party as well since I've used that method on my Evo XR Cade a few months back as well, and it's also commonly used for placing modular wall panels <- that's where my inspiration came from.
But as mentioned: hate to spoil the party so  :cheers:
Why would you need 2 panels? This is only needed if you use a print on normal paper for the marquee, but since there are a lot of signing companies out there which can simply print the artwork mirrored on clearview vinyl and laminate it with white after that so you get a "sticker" that you can adhese on the back of the plexi I see no need for that.
Pulling out the t-molding won't really be nescesary (that often) if you use LED strip for the lighting.
Does noöne have an answer to my question about what the pre-ground coated MDF is called in English.
Also I'm curious what a standard 1/2" plain black laminated particle board panel costs in the US? (e.g. 8x4 or 10x5 ft). Just to compare against the local prices
Post by: macattack on October 10, 2013, 02:39:09 pm
pre primed mdf.
1/2" is around $35 for a 4x8 sheet.
Post by: floriske.nl on October 10, 2013, 05:31:02 pm
$ 35,- for a 4x8 sheet of 1/2" laminated particle board?
Whish we had it at that price would be a lot better than pre primed MDF (Thanks!  :notworthy:) at $ 40 for s 8x4 sheet
Post by: Rick on October 10, 2013, 05:33:29 pm
$ 35,- for a 4x8 sheet of 1/2" laminated particle board? Whish we had it at that price would be a lot better than pre primed MDF (Thanks!  :notworthy:) at $ 40 for s 8x4 sheet
I'm with you. It's $52 at our Home Depot for 5/8" melamine sheets, vs. $33 for MDF here in Canada.
Post by: Rick on October 11, 2013, 07:56:06 pm
Well, since Haruman isn't here to blow his own horn, here's a link (http://www.reddit.com/r/cade/comments/1o8gr8/my_first_home_made_arcade_machine/) to some "positive press" he's received on Reddit. Well done, my friend.
Post by: HaRuMaN on October 11, 2013, 09:09:25 pm
Where did I go? O0
Thanks for the find & the link!
Post by: Rick on October 11, 2013, 09:11:47 pm
No problem. Some of us dabble in Reddit. Others of us live there.
Title: Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
Post by: HaRuMaN on October 11, 2013, 11:03:28 pm
Yeah, I'm pretty new to the whole reddit thing.
Post by: Rick on October 11, 2013, 11:07:02 pm
Don't worry about it. Next week, I'll show you how it works.
Post by: cdf12345 on October 11, 2013, 11:46:53 pm
If you made a cabinet out of bacon, they would probably throw money at their screens.
And I say they as in we. Myself included.
Post by: Rick on October 11, 2013, 11:48:35 pm
STOP GIVING HIM IDEAS!
Post by: cdf12345 on October 11, 2013, 11:49:47 pm
If by ideas, you mean making him hungry.
I will not sir!
Post by: HaRuMaN on October 12, 2013, 12:37:31 pm
I was thinking of making a bartop from bacon infused waffles...
Post by: cdf12345 on October 12, 2013, 01:04:41 pm
BreakfastTop
Post by: HaRuMaN on October 12, 2013, 01:36:52 pm
Oh, I've already got a few new ideas percolating...   >:D
Post by: yotsuya on October 12, 2013, 02:04:10 pm
Where's my skee ball at, bro?
Post by: HaRuMaN on October 12, 2013, 02:50:25 pm
Shhhh ;-)
Post by: Rick on October 12, 2013, 03:34:32 pm
Stealing mine doesn't count as "new ideas", brosef.
Post by: HaRuMaN on October 12, 2013, 03:36:42 pm
Oh, no, these aren't yours ;-)
Post by: Rick on October 12, 2013, 03:40:14 pm
No worries. I'll just hold on to the fact that I'm the reason you're coming up with these new ideas. Your Muse, if you will.
>:D
Post by: Rick on October 12, 2013, 03:44:05 pm
[singing]I'm the meaning in your life... I'm your inspiration![/singing]
Post by: Malenko on October 12, 2013, 04:13:56 pm
They are mine, and I gave them to you, so I guess technically, they are ours?
Post by: Rick on October 12, 2013, 04:31:29 pm
(http://i.imgur.com/ReAM9Sx.jpg)
Post by: yotsuya on October 12, 2013, 04:31:54 pm
Get a room, you three !
Post by: Malenko on October 12, 2013, 04:56:47 pm
I honestly have no idea what hes even talking about. I came up with the pockets instead of tabs idea (and Haruman found a way to make it work), and the idea to ship the kits with pool noodles (which he upgraded my idea to pipe insulators) . I suggested the Galaga style vert kit, and some other things. I cant keep up with everyone who hates me anymore, its easier to keep track of the few who do like me =)
Post by: macattack on October 12, 2013, 05:06:56 pm
Don't take it too bad, most of that lot I had been doing for years with pins and bezels. Pipe insulating is better since it reduced shipping dimensions ;) those noodles are way to big. Lol.
We want wood!!!
Post by: Rick on October 12, 2013, 05:14:15 pm
I honestly have no idea what hes even talking about. I came up with the pockets instead of tabs idea)
Nice to meet you, Mr. Mortice. Or was that Mr. Tenon? ;)
And who hates you? I love you, man.
Post by: Malenko on October 12, 2013, 05:46:10 pm
In no particular order:
Genesim
Tommy
KevSteele
Xooushe2
Ark Adder (sometimes)
404 (used to, I think)
MarkMVP (mostly because hes not good at comprehension in football threads)
and that's just on the forums!
As for the pockets, I'm not saying I invented the idea of the wood pocket, just that I was a factor in the pocket becoming implemented in Haruman's kits, same thing with the pool noodle. I suggested the pockets after receiving a version 1.0 kit (well 2 of them) and HATING the batons, and suggested the noodles when he told me he was having an issue with the melamine getting chipped in transit. I certainly didnt invent the Galaga cab, but I suggested to him to make a vert based on it. Snaaaaaaaaaaaaaake (is that the right amount of As?) suggested the widebody kit. Point is individually we are all pretty good, but as a community we are pretty great. Far too often on these boards there's an unhealthy competition or bickering over nothing. That doesnt apply to you completely, I mean you seem to be ok with sharing ideas with Lee but sometimes I dunno, its ---smurfing--- annoying to see all the jabs being taken by everyone on here, and yes, Im guilty of doing it too sometimes but Im working on it.
Kudos on the mortise and tenon joint reference that no ones gonna get :(
I digress. I come to these boards to have fun, see others creativity, get help, and show off my projects, not to argue over semantics.
Post by: Rick on October 12, 2013, 05:50:51 pm
I'm just gonna go on record and say that no idea is original, and any claim I ever make saying, "I invented this idea" is done 100% tongue in cheek.
If I've ever offended anyone who may have thought I was serious, I sincerely apologize.
Post by: HaRuMaN on October 12, 2013, 11:17:45 pm
I'm only offended by your lack of wood ;-)
Post by: Rick on October 12, 2013, 11:19:41 pm
That's not what you said last night!
Post by: cdf12345 on October 12, 2013, 11:25:45 pm
I invented the idea that nothing is original.
Post by: HaRuMaN on October 12, 2013, 11:30:50 pm
Haha C:-)
Post by: HaRuMaN on October 14, 2013, 01:16:11 pm
Paid customer commission, just sent off to the CNC this morning:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=298310;image)
Post by: Rick on October 14, 2013, 01:17:10 pm
Might this be a jukebox?
Post by: HaRuMaN on October 14, 2013, 01:20:41 pm
Wall mount vertical, there aren't any control holes because the customer wanted to do that himself (still deciding on mini-trackball / etc).
Post by: rablack97 on October 14, 2013, 02:27:31 pm
what in the heck your cramming into that, a gerbil?
With the speaker being right there in the front and PC at the base, he's not gonna have much room for jack.
How deep is it?
Post by: Rick on October 14, 2013, 02:36:24 pm
Well... he does have all those ...
:lol
Never mind. Too easy.
Post by: HaRuMaN on October 14, 2013, 02:49:46 pm
How deep is it?
He'll be using 60-in-1, tiny.  Plenty of room for that.
Internally at the base there is a cube of space available that is 5" x 14" x 9.5"
Post by: Rick on October 14, 2013, 03:01:26 pm
He'll be using 60-in-1, tiny.  Plenty of room for that.  Internally at the base there is a cube of space available that is 5" x 14" x 9.5"
Almost enough for the power supply and controls!!! Sweet!
Post by: rablack97 on October 14, 2013, 03:15:09 pm
wow....hope he has small hands to wire that thing up.
Post by: HaRuMaN on October 14, 2013, 03:45:43 pm
Oh ye of little faith.  Although, I do imagine you can fit infinite components in imaginary bartops... ;)
Post by: Rick on October 14, 2013, 03:47:31 pm
You know it. I'm the guy who won't sell them until he can see them, and proud of it! Et tu, purveyor of invisible Nintendo-cabs?
Post by: HaRuMaN on October 14, 2013, 03:48:55 pm
My plans are so good now I don't need prototypes to sell.  ;)
Also, my Nintendo bartop order is with my CNC guy now.  Care to take bets on whose is done first?   ;D
Post by: Rick on October 14, 2013, 03:51:54 pm
Oh, how I would love to make you eat that winkie. (Oh, that - so - did not come out right.)
:lol
Depending on the wager, sure.
Post by: macattack on October 14, 2013, 03:52:23 pm
Geez, we are lucky there is the width of an entire continent between you too!!
besides, the race is for who's second not first  :notworthy:
PM outbound this week per the NAAA   :applaud:
Post by: Rick on October 14, 2013, 03:55:40 pm
Geez, we are lucky there is the width of an entire continent between you too!! besides, the race is for who's second not first  :notworthy: PM outbound this week per the NAAA   :applaud:
LOL. S'all good, my friend. Haruman and I are just ribbing each other. He knows my designs far surpass his best efforts.
;) :) :D :lol
Post by: HaRuMaN on October 14, 2013, 04:04:00 pm
(http://www.tuition.io/blog/wp-content/uploads/2013/08/Better-Off-Dead-Wheres-My-Two-Dollars.gif)
Post by: Rick on October 14, 2013, 04:06:15 pm
Ok, as long as it's not...
(http://i.qkme.me/3sikal.jpg)
Post by: cdf12345 on October 14, 2013, 04:20:08 pm
(http://i.imgur.com/vdIy4.gif)
Dis gonna B Gud
Post by: HaRuMaN on October 14, 2013, 04:24:02 pm
(http://i.imgur.com/GZ5CD5r.gif)
Post by: yotsuya on October 14, 2013, 04:24:39 pm
Don't you mean "two dollah, cash-in-hand"?
Post by: Rick on October 14, 2013, 04:26:52 pm
What Haruman should have done...
(http://i1239.photobucket.com/albums/ff510/Cynder_Stallion/A%20New%20Album/simpsons-gifs-grandpa-leaves.gif)
Post by: mann0mann on October 15, 2013, 04:04:11 am
Hey Lee - Not to interupt the designers love fest here...but I'd like to throw this out there as a possible future design offering.
Not that your cabinets kits aren't incredibly affordable as it is.  But maybe an even more stripped down simple marquee-less cabinet along the lines of these as inspiration?
http://www.koenigs.dk/mame/eng/stepnanocade6.htm (http://www.koenigs.dk/mame/eng/stepnanocade6.htm)
or
http://forum.arcadecontrols.com/index.php/topic,134837.0/topicseen.html (http://forum.arcadecontrols.com/index.php/topic,134837.0/topicseen.html)
Like a simple, 17", 3-4 button cab made for like a 60-in-1 or ArcadeSD
Just a thought....please feel free to return usual shennanigans.  ;D
PS - Hey Rick - I grew up in Detroit, in-laws still live there...we're heading back for thanksgiving.  Any arcade-type places I should hit up while I'm there?
Post by: Rick on October 15, 2013, 08:02:36 am
I'm up in Ajax, Ontario myself. There's only one place locally that I know about, and that's The Playdium Store (https://www.theplaydiumstore.com/). It's pretty good - they've got about 20 pins and 10 multi-arcade machines... ...all on free play. (It's getting to the point that I'm thinking the U.S./Canada border is the official "arcade dead zone". I'm hoping to fix that.)
:D
Post by: macattack on October 15, 2013, 09:50:34 am
I assume your familiar with Marvins here in Farmington Hills?
right now they have around 10 machines, including:
WOZ
new Star Trek
Tron
Metallica
Adams (with color dmd)
Post by: HaRuMaN on October 15, 2013, 09:53:49 am
or
I could do something like that, sure.   :cheers:
Post by: TKW4rr10r on October 15, 2013, 12:05:26 pm
One of those mini, micro, whatever bar-tops would be a good candidate for a smaller wide screen LCD. And have a digital marquee that changes at the top of the vertical LCD depending on the game you play.
Just spitballin.
Post by: HaRuMaN on October 15, 2013, 03:56:36 pm
Looks like my Nintendo & Wall Mount bartop are getting cut tomorrow or Thursday.  Muahaha!  I want my 2 dollars!  8)
Post by: yotsuya on October 15, 2013, 03:58:40 pm
I read that as "Nintendo Wal-Mart bartop".
Post by: Rick on October 15, 2013, 04:13:07 pm
They're only getting cut tomorrow or Thursday? Mine was done on Friday.
:D
Post by: yotsuya on October 15, 2013, 04:14:06 pm
:D
Pics or it didn't happen.
Post by: HaRuMaN on October 15, 2013, 04:16:12 pm
:D
Beat me to it.
(http://narwhaler.com/original/dv/f/broken-image-no-pic-it-didnt-happen-DVfWa2.jpg)
Post by: yotsuya on October 15, 2013, 04:20:06 pm
"I told you, I couldn't post pics of it Friday because I was in Alaska with my uncle hunting wolverines!"
(http://4.bp.blogspot.com/-1pqPk-CF0Ps/Ts1lhP83j7I/AAAAAAAABD0/JjMCxN5D_Zk/s1600/napoleon-dynamite1.jpg)
Post by: Rick on October 15, 2013, 06:23:05 pm
Don't even try using that quote for me. I couldn't make 10 minutes into that insipid movie.
Post by: yotsuya on October 15, 2013, 06:25:21 pm
Best. Stupid. Movie. EVER!
Post by: Rick on October 15, 2013, 06:33:25 pm
Airplane. (...and any number of better films.)
Your argument is invalid.
Post by: cdf12345 on October 15, 2013, 06:41:19 pm
I feel obligated to post this, I just saw it a few days ago and it's a great description of the purpose of the movie http://www.reddit.com/r/AskReddit/comments/188xrl/which_films_are_much_darker_than_they_appear_to_be/c8cpyii (http://www.reddit.com/r/AskReddit/comments/188xrl/which_films_are_much_darker_than_they_appear_to_be/c8cpyii)
Post by: HaRuMaN on October 15, 2013, 06:47:14 pm
I'm with Rick on this one, I cannot watch that dumb movie.
Post by: yotsuya on October 15, 2013, 08:52:28 pm
Ok, Airplane>N.D., but N.D. is awesome.
Post by: mann0mann on October 16, 2013, 01:25:02 am
:D
oops. I got you and mac-attack mixed up!   :dizzy:
Post by: HaRuMaN on October 16, 2013, 06:04:14 pm
not only do I have wood, but it's pretty wood at that. This is dry fit, no glue.
Post by: macattack on October 16, 2013, 06:07:35 pm
Nice. Loving the art.
Post by: Rick on October 16, 2013, 06:12:58 pm
I got your two bucks, right here. Come get it.
Post by: HaRuMaN on October 16, 2013, 06:14:15 pm
WWW.xtremepinball.com (http://WWW.xtremepinball.com)
Post by: HaRuMaN on October 16, 2013, 06:17:51 pm
As a matter of fact, two Nintendo cabs (one baltic birch, the other white melamine) and the wall hanger were cut today, I'll be picking them up tomorrow.
This is one of my Midway verticals, this one will be going off to Malenko soon (after I get the art on it's Galaga twin and take pics of both together).
Thanks to Malenko for the art files, and SoulDraw for the printing!
Post by: Rick on October 16, 2013, 06:23:07 pm
As a matter of fact, two Nintendo cabs (one baltic birch, the other white melamine) and the wall hanger were cut today, I'll be picking them up tomorrow. This is one of my Midway verticals, this one will be going off to Malenko soon (after I get the art on it's Galaga twin and take pics of both together). Thanks to Malenko for the art files, and SoulDraw for the printing!
You're right. I was a bit cross-eyed looking at it, and didn't even notice it wasn't the Nintendo... ...too much staring at the screen at what I've named, "Haruman's Folly". Got one of these babies in your repertoire, anywhere?
(http://i.imgur.com/IvUuS0e.png)
(I'm thinking this may take more than 1/2 a sheet of MDF...)
Post by: HaRuMaN on October 16, 2013, 06:32:38 pm
Lol, I wish.
Post by: Rick on October 16, 2013, 06:35:10 pm
Lol, I wish.
I actually designed that a couple of years ago. I've got it 90% 'ready to assemble', but I just don't have any space to put it. Damn.
Post by: HaRuMaN on October 16, 2013, 06:40:25 pm
I have space for one, but after getting used to the precision of my cnc guy, I think I would be disappointed by a home build...
Post by: Rick on October 16, 2013, 06:44:08 pm
I've been following CNC forums and information for a while now, and from what I understand, precision isn't usually an issue. Like, at all. You may not get the speed of a professional machine, but I hear that there would be little-to-no loss between machines. If you have the room and the ability to assemble it, I'd seriously look into it.
If I had a building, or even the space inside my house, this is the first thing I would build. First. Thing.
Post by: HaRuMaN on October 16, 2013, 06:57:11 pm
One of the coolest things about my CNC guy's setup is the hold down vacuum.  No clamps for material, just a 20HP vacuum pump that pulls air THROUGH a sacrificial piece of MDF to hold down the material above it.   :o
Title: Re: Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
Post by: Rick on October 16, 2013, 07:02:50 pm
LOVE vacuum tables. Surprising thing? Easy to make! Also, removing 1/16" from each side of MDF makes it flow through.
Post by: macattack on October 16, 2013, 07:17:05 pm
Vac bed is on my too do list, really good for cutting stuff like acrylic. Also you can then make 100% use of the material.
But for now, what I have is good.
Post by: Rick on October 16, 2013, 07:20:16 pm
What's that, an hour of your time to cut a 4x8 piece of MDF with 4" square x 1/4" deep grooves and some holes for PVC piping? Get at 'er, man!
Post by: macattack on October 16, 2013, 07:24:50 pm
Not given it
Much thought, draw it up then and I'll poc it for you ;)
Post by: Rick on October 16, 2013, 07:40:55 pm
Not given it much thought, draw it up then and I'll poc it for you ;)
Watch this...
https://www.youtube.com/watch?v=sx8fAv5f8js&feature=youtube_gdata_player
...and build it yourself!
Post by: tron84 on October 16, 2013, 08:23:17 pm
That Ms. Pacman is the Shiot!!!!! :applaud: :cheers:  Great Job!!!!!!
That is one Sexy Cab. ;D ;D
(http://i.imgur.com/7Ik7JUF.jpg)
Post by: tron84 on October 16, 2013, 09:50:10 pm
Where in the hell did you find 1/2" pink Tmold??
Post by: HaRuMaN on October 16, 2013, 09:56:14 pm
I didn't. I trimmed 3/4" by hand.
Post by: tron84 on October 16, 2013, 10:03:53 pm
I had a feeling that was the case.  I looked high & low for 1/2" Tmold for the barstick. Something other than black or white or 500' of red. :hissy: ;D
I was hoping that you we're gonna say something goofy like, " Soul-t-Mold.com". :afro:  ;D hehehe  ;D
Post by: tron84 on October 16, 2013, 10:06:58 pm
Well nice trim job man :) looks great :cheers:
Post by: TKW4rr10r on October 17, 2013, 09:49:19 am
 :o :o :o
Need moar pics! That is amazing. Can't wait to see the galaga bar-top.
A co-worker was just saying how his girl wanted a galaga, but a bar-top would be much easier to get into his house.....
You provide options for the artwork too, or would one have to pester someone else to obtain?
Post by: HaRuMaN on October 17, 2013, 09:50:59 am
 :o :o :o
I haven't added it yet, but yes, I will be providing options for Ms. Pac, Galaga, and Reunion art sets (sides, control panel, and marquee).
Post by: Brian74 on October 17, 2013, 10:11:15 am
Where is my wall-mount juke?
Post by: HaRuMaN on October 17, 2013, 10:13:21 am
Seriously, though.  Give me some ideas if you want.  I can work something up for you.   :cheers:
Post by: macattack on October 17, 2013, 10:14:06 am
Watch this...
https://www.youtube.com/watch?v=sx8fAv5f8js&feature=youtube_gdata_player (https://www.youtube.com/watch?v=sx8fAv5f8js&feature=youtube_gdata_player)
I did, now i need to run the plumbing :)
(http://i913.photobucket.com/albums/ac340/gbconcepts/vacbed_zps64cc734a.jpg) (http://s913.photobucket.com/user/gbconcepts/media/vacbed_zps64cc734a.jpg.html)
Post by: HaRuMaN on October 17, 2013, 10:48:41 am
Lol...  I currently have 4 Nintendo bartops ordered from 4 different materials.  I pick 2 up today.
White melamine, black melamine, cherry melamine, and cabinet grade baltic birch plywood.   :dizzy:
Post by: Brian74 on October 17, 2013, 11:03:47 am
Post by: HaRuMaN on October 17, 2013, 11:05:45 am
Depending on what your budget looks like, my CNC guy can cut & laser etch acrylic, exactly like that bottom pic.
Post by: Brian74 on October 17, 2013, 11:18:04 am
Bartop touchscreen
Post by: Brian74 on October 17, 2013, 11:20:12 am
That would be cool, I like the first pic too. I would like to have one with 2 displays. Trying to find that skinny display has been tough.
Post by: Brian74 on October 17, 2013, 11:25:32 am
I have also have been toying with the idea of a video touchscreen slot/poker machine. Like this with a more flat cp.
Post by: HaRuMaN on October 17, 2013, 02:45:41 pm
Boom! Just picked up 2 Nintendo kits and the wall hanging kit!
Dry fit at the shop was good, no issues.
Post by: yotsuya on October 17, 2013, 02:54:55 pm
So when do you get your $2?
Post by: mann0mann on October 17, 2013, 05:42:04 pm
So Malenko...how much for me to intercept that Mrs. Pac-Man before it reached you? ;-)
Post by: HaRuMaN on October 18, 2013, 09:27:42 am
Someone just sent me 2 Canadian dollars... hmm...  ;D
Post by: Malenko on October 18, 2013, 09:48:28 am
Dawwwww, you cant haz mine, but you can order the exact same thing from Haruman,artwork, tmolding, the whole thing. And you can get reunion, mspac, or galaga art!
I did put together the artwork, and not tooting my own horn, I think it all turned out pretty good.
Post by: Rick on October 18, 2013, 09:54:57 am
"Someone", huh? Not even a credit to my namesake? I'll have you know I am a man of HONOUR, sir.
Post by: HaRuMaN on October 18, 2013, 09:55:09 am
It really did.  I took a look at the Galaga art I got from the printer, looks sweet!  I hope to get it on tonight.
Post by: HaRuMaN on October 18, 2013, 09:55:44 am
The PayPal said some guy named Genii  ;D
Post by: Rick on October 18, 2013, 10:02:02 am
For your information, "Genii" is the plural form of "genius". Thus, it should be pretty obvious.
:D
Post by: yotsuya on October 18, 2013, 10:34:33 am
What is that, like $0.32 American?
Post by: HaRuMaN on October 18, 2013, 10:45:45 am
It twas $1.89
Post by: Rick on October 18, 2013, 11:01:36 am
It twas $1.89
You got ripped. The proper conversion should have been $1.95. Source. (http://www.xe.com/currencyconverter/convert/?Amount=2&From=CAD&To=USD)
Post by: HaRuMaN on October 18, 2013, 11:07:39 am
It twas $1.89
Conversion from:
-$2.00 CAD
Conversion to:
$1.89 USD
Exchange rate:
1 Canadian Dollar = 0.9461 U.S. Dollars
Lol.
Post by: Rick on October 18, 2013, 11:11:26 am
Lol.
1 CAD = 0.972459 USD as per mid-market rates: 2013-10-18 15:08 UTC
I'm tellin' ya, man. You got hosed. Them Paypallers are sneaky bastages.
Post by: HaRuMaN on October 18, 2013, 11:34:19 am
Lol.
Oh I know, it's the most convenient way for me to take payments for the bartops, but man do the fees get old...
Post by: Malenko on October 18, 2013, 11:43:54 am
thats why I pay you as a gift from my checking account. Its free on my end, dunno about yours.
Post by: Rick on October 18, 2013, 11:48:29 am
As I understand, you pay for it when you do it as a "gift" and the receiver pays for it when you pay for it as a "item purchased". When I sent the $2, I chose "gift" and I got charged a small fee for the transfer.
Post by: rablack97 on October 18, 2013, 11:50:41 am
Yeah its free on his end until paypal catches on that he's actually using that option for sales, then the option gets shutdown.  You have to be doing decent volume though to get redflagged.
Also, Haruman....
Sourced you some elusive 5/8 mdf core melamine, 2 sided black, in case you want to play.....46.00 a sheet....
Talked to the guy today, and they carry it in stock....might have your guy give em a call they may offer discounted rates for shops.
http://brazosfp.com/board-products-mdf.html (http://brazosfp.com/board-products-mdf.html)
Post by: rablack97 on October 18, 2013, 11:53:33 am
There is a special trick to where, neither side gets charged.  I can't remember but i had a customer send to me as a gift, he had his bank account attached to his paypal, so it was free for him, and i got the full amount on my side......just depends on how you have it setup i guess.
Post by: HaRuMaN on October 18, 2013, 03:50:41 pm
Got some french fries at lunch with that $1.89.... man did they taste good.  The sweet taste of VICTORY!  :lol
Post by: Rick on October 18, 2013, 03:53:08 pm
Got some french fries at lunch with that $1.89.... man did they taste good.  The sweet taste of...
Wilford Brimley Raps You Can't Touch Diabetes (MC HAMMER) NEW (http://www.youtube.com/watch?v=p0oXPf0hMag#)
FTFY
Post by: yotsuya on October 18, 2013, 04:32:46 pm
Moral of the story- when you make a bet with Canadians, insist that they include 3% for fees.  >:D
Post by: Rick on October 18, 2013, 04:33:59 pm
It wasn't the fees, tyvm. *I* paid those. I bet him $2. Next time, be clear that you're betting $2 USD.
Post by: yotsuya on October 18, 2013, 04:34:45 pm
I would have insisted on physical loonies, myself.  :cheers:
Post by: Rick on October 18, 2013, 04:37:15 pm
Hey, I'd be more than happy mailing these two hundred Canadian pennies, if he wanted 'em!
Post by: yotsuya on October 18, 2013, 04:47:44 pm
I thought a loonie was like a silver dollar.
Post by: HaRuMaN on October 18, 2013, 06:03:13 pm
Baltic birch
Post by: HaRuMaN on October 18, 2013, 11:55:46 pm
Giggity!
Post by: HaRuMaN on October 19, 2013, 06:22:46 pm
Another look
Post by: Rick on October 19, 2013, 07:47:30 pm
Those look AMAZING!!! Too bad your camera still sucks.
Post by: HaRuMaN on October 19, 2013, 07:51:26 pm
Oh when I'm done with art I'm gonna do set with the good camera vs. My cell phone
Post by: Rick on October 19, 2013, 08:05:26 pm
Good. I look forward to those!
Post by: tron84 on October 19, 2013, 08:39:20 pm
Another look
Double Trouble  ;D :o :applaud:
Looking good!!!!
Post by: HaRuMaN on October 21, 2013, 01:14:04 pm
Just for Rick: and yes, my cell phone camera is a potato
Post by: Rick on October 21, 2013, 02:24:26 pm
a) It certainly shows.
b) Shhhh! I'm busy.
Post by: HaRuMaN on October 23, 2013, 05:42:46 pm
Customer commision, local...
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=298825;image)
Post by: TKW4rr10r on October 23, 2013, 05:51:11 pm
Looks like a Centipede upright.... ???
(http://happycampers.to/arcade/ataricabs2.gif)
Post by: Rick on October 23, 2013, 06:03:33 pm
Needs moar holes.
Post by: HaRuMaN on October 23, 2013, 06:17:09 pm
Needs moar holes.
I drew it with no holes or arcs so your cnc guy could cut it, too... ;-)
Post by: Rick on October 23, 2013, 06:24:10 pm
Here, I fixed it for you.
(http://i.imgur.com/XJTPtvo.png)
 >:D
Post by: yotsuya on October 23, 2013, 06:29:29 pm
Needs moar holes.
(http://img.photobucket.com/albums/v352/Dustbunny3/obama_oh-snap.jpg)
Post by: tron84 on October 23, 2013, 06:34:28 pm
Ohhh, Dig Dug  ;D Nice, looks good man.
(http://i.imgur.com/9kQfIex.jpg)
(http://i.imgur.com/CKO3Vpu.gif)
Post by: HaRuMaN on October 23, 2013, 11:05:17 pm
 >:D
Weak sauce... Plus I know they don't let you Canadians have guns... >:D
Post by: opt2not on October 24, 2013, 01:41:44 am
:lol  :applaud:
Post by: Rick on October 24, 2013, 08:08:43 pm
"America is not an elephant. For one thing, elephants never forget, whereas Americans don't really know much to begin with. Ninety per cent of them can't pick out their hometown on an unmarked map...We're bigger than they are and we're on top. If we were in prison, they'd be our ---smurfette---." - Rick Mercer
Post by: HaRuMaN on October 24, 2013, 08:38:11 pm
Canada's like a loft apartment over a great party... "Keep it down, eh?!"
-Robin Williams
Post by: HaRuMaN on October 25, 2013, 01:31:01 pm
Another order picked up!
1 black Nintendo
1 cherry Nintendo
1 black MVS
1 black Standard
1 black custom CP top
Post by: HaRuMaN on October 25, 2013, 04:00:24 pm
Another customer commission:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=299003;image)
Post by: macattack on October 25, 2013, 04:01:57 pm
sweet, seems like i have seen that somewhere recently :)
Post by: Rick on October 25, 2013, 04:02:57 pm
Do you manually nest all of your parts yourself?
Post by: HaRuMaN on October 25, 2013, 04:22:17 pm
Yeah... no way to get this one down to two sheets so I just threw the parts anywhere, really.  This is for the same local that wants the other full size.
Post by: Rick on October 25, 2013, 04:26:21 pm
I was going to say that it looks like you could squeeze it down to at most 2 1/2 sheets, if you oriented the rear pieces sideways, or modified their dimensions to fit... Just my two cents.
Post by: yotsuya on October 25, 2013, 04:32:37 pm
That's OK, his CNC guy makes him lawn decorations with the left over scraps. True story.
Title: CNC Cut Bartop Kits - Orders Open! New Models Available!
Post by: ctozzi on October 27, 2013, 12:59:51 am
pm sent o custom mk cab
Post by: JDFan on October 27, 2013, 11:16:35 am
Or could squeeze in a bartop or barstick design in the excess space  :dunno
Post by: HaRuMaN on October 27, 2013, 03:42:29 pm
Yeah, my cnc guy handles the nesting, and he'll cut extra kits from the leftovers of there is enough room. He'll cut one of the popular ones if there is space
Post by: HaRuMaN on October 28, 2013, 01:23:04 pm
Wall hanging kit, dry fit before shipping
Post by: HaRuMaN on October 28, 2013, 01:28:40 pm
Getting more orders ready to go...
Post by: HaRuMaN on October 28, 2013, 01:30:14 pm
Cherry Nintendo
Post by: Rick on October 30, 2013, 10:10:20 am
With all of these orders, you should be able to afford a better camera!
Post by: HaRuMaN on October 30, 2013, 11:36:11 am
Hush you, I'm busy...
Post by: Rick on October 30, 2013, 11:49:06 am
LOL. No way! It's my first day off since starting my new job. Gotta make the most of it!
:D
Post by: rablack97 on October 30, 2013, 09:39:26 pm
ok, you gotta tell me, i bought my first melamine board today, got it in 5/8 and 3/4 in mdf core....
This stuff is like handling glass, you cant set it down on a edge at all or it chips, do you have the same problem with the particle board core?
Post by: HaRuMaN on October 30, 2013, 10:30:17 pm
Haven't had any complaints, 50 some orders in. Of course, I also offer any material the customer wants. I just made a really nice Nintendo in a cabinet grade Baltic birch.
Customers seem to appreciate not having to paint. Or laminate.
Post by: Malenko on October 30, 2013, 10:39:16 pm
Hell yeah, and not needing to use batons either! lol
Post by: rablack97 on October 30, 2013, 11:00:19 pm
One thing i've learned is once you cut the piece, immediately iron on the edge banding, that keeps the edges from scraping the ground.
It's not very saw friendly, router or cnc cuts it nice though.
One time builds, i agree with the laminate approach, but when your doing a cabaret of builds the laminating gets old really quick.  What really pisses you off is laminating and then chipping that, after all that hard work.
Post by: pbj on November 01, 2013, 02:08:03 pm
What's the "friend price" for a wee-cade style kit?  You have to promise not to tell BYOAC that I bought one.
Post by: HaRuMaN on November 01, 2013, 02:11:44 pm
I don't think anyone would be believe me if I did tell.  Lol.
Post by: Rick on November 01, 2013, 03:51:57 pm
Dude, three words: Konkey. Dong. Bartop.
Post by: opt2not on November 01, 2013, 04:12:19 pm
Too many ---Deutsche Frankfurters---
Too many dongs
Too many schlongs
Now sing this song....
http://youtu.be/kIdIcZShWUo (http://youtu.be/kIdIcZShWUo)
Post by: DJMattB241 on November 02, 2013, 09:43:50 am
Hey Haruman!
Okay so, I'm still EXTREMELY green to this whole "building arcade cabinets" thing (aka this is going to be my first one), so I have a couple questions that may be incredibly dumb. I'm looking at the two player wide screen bartop.
Questions!
1) Does it matter what kind of monitor I put in? Or will basically any 23" widescreen LCD fit the bill?
2) You offer a "Clear 1/8" polycarbonate bezel & marquee with black plastic U-channel for the right & left sides of each." Unfortunately my dumb newbie brain doesn't know exactly what that means. What is that?
3) Is there any concern of, like, palm sweat wearing out the paint and such on the control panels?
4) You mention an "admin panel"... is that the buttons on the lower section facing straight out towards the player?
5) Speaking of buttons, I have (what seems to be standard-ish) 30mm buttons. Will those fit the button holes?
6) For the widescreen kit, what do you need as far as motherboard size? Will an ATX motherboard fit, or is it designed for something smaller?
I'm like half a second away from ordering a kit (well, maybe like a paycheck away), but I just wanted to make sure I was fully aware of what I was getting, etc.
Thank you SO MUCH! :)
Post by: HaRuMaN on November 02, 2013, 10:49:02 am
1) As long as the monitor's physical size is less than 22" wide, any 23" widescreen should work.
2) So, you get the plexiglass to cover the marquee area, and you get the plexiglass to cover the monitor area.  Black U-channel is just a decorative touch that goes on the left / right sides of both.
3) This is black melamine (a type of laminate).  It's not going to wear off under your hands.  :)
4) Yes
5) Yes. the widescreen kit comes with 30mm button holes.
6) I would go with MicroATX.
Let me know if you have any more questions!
Thanks!  :cheers:
Post by: SNAAKE on November 02, 2013, 04:55:57 pm
just opened the box now..yeah I am really.............really late
so no glue for the control panel wood piece? it just slides in?
Post by: yotsuya on November 02, 2013, 05:27:42 pm
You MFs who want a cocktail need to get on this ---steaming pile of meadow muffin--- NOW. HaRuMaN's kits are awesome abd give you the framework to do cool ---steaming pile of meadow muffin--- like this:
Post by: yotsuya on November 02, 2013, 05:29:15 pm
The kit is the foundation. The rest is up to you.
Post by: HaRuMaN on November 02, 2013, 08:22:05 pm
@snaaaake, the control panel rests on the batons that are glued in. How you attach the cp is up to you. Some people screw it down, some use Velcro, I'm gonna try magnets soon.
Post by: HaRuMaN on November 02, 2013, 08:59:34 pm
@yotsuya, that looks awesome!
Post by: SNAAKE on November 03, 2013, 01:25:27 pm
velcro it is
Post by: tron84 on November 03, 2013, 02:13:33 pm
I used carriage bolts on my cp for the barstick. I dont have the nut on it so I can twist it off to remove the cp as needed. I use needle nose to start to get it out or finish it down so it is flat.  Then use the fingers for the rest of the twisting. That mug dont go nowhere :D Stays on like a champ. :)
@yotsuya, killer job man.  Great looking cocktail  :cheers:
Post by: yotsuya on November 03, 2013, 02:26:51 pm
Thanks, my friend. Here's a shot of it in place, under my wall-mounted juke. I'll rotate it out for play.
Awesome kit, HaRuMaN. Wish I had a need to build another one!
Post by: tron84 on November 03, 2013, 02:32:39 pm
I have always had a sweet spot for cocktail tables :D  I day I will have one, Haruman always does a great job on his stuff. :cheers:
Where did you get the smoked glass top for it?
OHHHH that pic made my day between the tempest & the cocktail...... :D
Post by: yotsuya on November 03, 2013, 02:34:53 pm
Found a place that sells them for $79 shipped for real glass, which is $20 cheaper than anything else I've seen. They have super fast shipping, too.
https://www.xtremegameroom.com/ms-pacman-pac-man-galaga-tron-midway-bally-cocktail-table-glass.html (https://www.xtremegameroom.com/ms-pacman-pac-man-galaga-tron-midway-bally-cocktail-table-glass.html)
I made the CPs on this out of metal, the ones on the previous one were wood. Both were fine.
Post by: tron84 on November 03, 2013, 02:40:35 pm
damn that is a good price on the glass top  :o
The cocktail looks right at home in the pick, NICE!!!!! :cheers:  luv the Tempest also.
But IMHO the wood grain cocktails are the way to go, old skool style  :cheers: They look the best.
Post by: yotsuya on November 03, 2013, 02:50:15 pm
Yeah, what sold me on this kit is the woodgrain. The melamine HaRuMaN used is a beautiful cherry color. I did use a black top on this one, so that's why the glass looks smoked. I did put a smoked piece of plexi between the screen and glass, though. Looks better.
My daughter gave it a name, and I had a buddy print the vinyl stickers used for the graphics. It really adds a pop to the table.
Post by: tron84 on November 03, 2013, 02:58:08 pm
Ahh ok, well it turned out great :D  It looks really smoked good like Chong  ;D
(http://i.imgur.com/f18jzAL.jpg)
Thats cool also your daughter had a part in it, the next gen gamer  :cheers:
Post by: DJMattB241 on November 03, 2013, 03:18:24 pm
HaRuMaN, couple more questions I thought of:
1) I saw you mention that the control panel is removeable. Is that the only way into the innards of the case, to replace dead hardware and such?
2) Can you do modifications? I was thinking of maybe two small ports on the back side of the case for USB mounts, so you can plug a keyboard/mouse in for software troubleshooting and such.
Post by: Malenko on November 03, 2013, 03:23:15 pm
1) there's always the back door?
2) you can always drill holes to customize it.
Post by: HaRuMaN on November 03, 2013, 06:08:29 pm
Yeah, primary access will be through the back panel, which doesn't get glued. I can add any holes you like, just let me know the size.
Post by: HaRuMaN on November 03, 2013, 06:11:18 pm
Potato camera, just the way Rick likes it...
Post by: opt2not on November 03, 2013, 07:28:30 pm
Lookin' sharp!
Post by: Malenko on November 03, 2013, 07:40:53 pm
that looks tits, big FAT OPRAH TITS!  :applaud:
Post by: HaRuMaN on November 03, 2013, 09:30:30 pm
2 more Nintendo kits, rolling out the door...
Post by: tron84 on November 03, 2013, 09:35:11 pm
Wooo Haaaa  :applaud: Looking great as always  :cheers: That alien green tmold sets it off besides the art work Malenko did. Now that is a mini midway!!!!!! :burgerking:
I thought is was a cracker jack camera  ;D ::) hahahaha just giving ya shiot. :laugh: but w/o I could not get to see the toys  ;D
Post by: tron84 on November 03, 2013, 09:38:32 pm
You staged those boxes, so somebody else would feel bad for not showing the wood . ;D ;) ;D hahahaha
Post by: HaRuMaN on November 04, 2013, 09:26:34 am
Oh no, those are real orders, I wouldn't waste supplies for a joke, lol.
Post by: HaRuMaN on November 04, 2013, 09:29:39 am
Those big boxes are like $6 each... :'(
Post by: HaRuMaN on November 04, 2013, 02:17:49 pm
Woo
Post by: opt2not on November 04, 2013, 02:21:08 pm
So....not a dry-fit this time?  Glued?
Post by: Malenko on November 04, 2013, 02:22:37 pm
thats still a dry fit, cause he hasn't shipped that cab to me yet.
Post by: opt2not on November 04, 2013, 02:27:32 pm
How many bartops do you need?? :lol
Post by: HaRuMaN on November 04, 2013, 02:37:09 pm
Yup, dry fit, about to break it down to ship to Malenko.
Post by: Malenko on November 04, 2013, 04:48:28 pm
2 per Galaga?
Post by: HaRuMaN on November 05, 2013, 09:37:36 am
Here we go, non-potato camera:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=299619;image)
Post by: pbj on November 05, 2013, 09:55:12 am
How much for one of those?  I can't follow this chaotic thread or your website.
Post by: HaRuMaN on November 05, 2013, 09:59:06 am
http://www.harumancustoms.com/shop/catalog/browse?shop_param= (http://www.harumancustoms.com/shop/catalog/browse?shop_param=)
Bottom left.
And yeah, this thread has gotten messy.  I should probably start a separate thread for stuff in progress and a thread of kits that are available.
Post by: pbj on November 05, 2013, 10:20:49 am
Are you selling the artwork and t-molding, too?  All I see is a plain black one on the website.
Post by: Nephasth on November 05, 2013, 10:24:38 am
What the hell? Your website lists the price, then says "plus shipping and handling". Click on the "plus shipping and handling" and it opens a pop up window that says "all prices include shipping, no extra charges". :lol
Post by: HaRuMaN on November 05, 2013, 10:30:19 am
Yes, I will be adding those to the website soon...  A full set of Ms. Pac art (sides, CPO, marquee) and pink t-molding trimmed to 1/2" will run $80 for install yourself.  I've thought about offering pre-installed, but haven't decided on that price yet.
Post by: HaRuMaN on November 05, 2013, 10:31:57 am
I know...  I'm still trying to figure out how to fix that.  The price you see is the price SHIPPED.  I'm a newb when it comes to websites & espcially e-shops, I'm just glad I was able to get it hooked up to PayPal correctly.   :dizzy:
Post by: DJMattB241 on November 05, 2013, 12:37:45 pm
Alright, that's it. Placing my order. :D
Post by: pbj on November 05, 2013, 01:15:08 pm
That's cool that you were able to secure all the appropriate licensing.
Post by: HaRuMaN on November 05, 2013, 01:16:34 pm
Order received, thanks!
Post by: DJMattB241 on November 05, 2013, 03:07:42 pm
So, questions for the general populous:
What kind of speakers are you putting behind those fantastic grills? Are they computer speakers? Or like, stereo speakers that you've wired to a 1/8" headphone plug for plugging into your motherboard?
Is this the wrong thread for this question?  :-\
Post by: HaRuMaN on November 05, 2013, 03:11:51 pm
Nope, this is the right thread.  I have used small USB powered speakers in mine, but you could also use car type speakers and a small amp, like this:
http://www.amazon.com/LP-2020A-Lepai-Tripath-Class-T-Amplifier/dp/B0049P6OTI/ (http://www.amazon.com/LP-2020A-Lepai-Tripath-Class-T-Amplifier/dp/B0049P6OTI/)
My next build will probably go the speaker / amp route.
Post by: DJMattB241 on November 05, 2013, 03:13:06 pm
And so you just take the actual speakers out of their cases and screw them to the back of the speaker grill board?
Post by: HaRuMaN on November 05, 2013, 03:15:24 pm
My usb powered speakers I just left in the case and velcro'ed them to the space above the grates.
Post by: DJMattB241 on November 06, 2013, 09:39:40 am
Alright, to continue my "dumb questions post-purchase" thread:
I guess I don't know what the back panel looks like, because all my questions come from that:
How does power come into this box? Is there just a hole cut in the back where a single power cord can come out? And I guess that follows straight into a more general question: what's the ideal way to set these up to power on? You've got to at least be able to turn on/off the computer and monitor with one switch, right? Or am I missing something obvious?
Post by: Malenko on November 06, 2013, 09:48:12 am
Only 1 of my bartops runs a PC, Bonnie's Pink Box. It has a wireless KB and mouse, so we shutdown from that. However, most mobo's you can set to shut down PC with press of a button, so you could just wire a button into the back/top and use that to shut down.  Power comes in at the bottom of the door on all my cabs, drill a hole, put an arcade button in there without a plunger, and run the wire through. I unplug the cabs when not inuse and the monitors auto power on when I plug it in.
You might answer a lot fo the questions you come up with by looking at some bartop project threads  :cheers:
Post by: opt2not on November 06, 2013, 03:48:57 pm
Bonnie's Pink Box
 :lol  Still gets me every time.
Post by: FelixTheJeep on November 08, 2013, 02:00:26 pm
Haruman, these are amazing.  Do the cocktail cabs come with control panels?  Your site mentions they can be used with standard Midway metal CPs but I couldn't tell if they normally ship with wood panels.
Post by: HaRuMaN on November 08, 2013, 02:30:02 pm
I don't have them shown, but yes, these can ship with wood control panels, just make a note on the order.  (Metal control panels not included, though).   :cheers:
Post by: FelixTheJeep on November 08, 2013, 06:00:21 pm
Awesome, thanks!  I'm torn between a bartop or a cocktail.  Any chance you're going to start making bartop cocktails?    :laugh:
Post by: DudeRegular on November 09, 2013, 09:26:29 am
Hi Haruman, i have a couple of questions.
I am interested in setting one up with a vertical oriented monitor to play pacman, donkey kong, galaga, etc. My goal is to spend less time on the cab and more getting the guts and software done. I like the midway and the nintendo designs. What dimensions are recommended for monitors in these two cabs? The details may very well be in this thread, but its 28 pages! I am leaning towards using on old hp laptop I have sitting around. It is a 15" widescreen with a 1280x800 monitor.
Has anyone used a laptop and a laptop screen in one of these? With the polycarbonate bezel and vesa mount it looks like a desktop style monitor is probably the best bet, but just wondering if there are any other options.
Thanks in advance
Post by: HaRuMaN on November 09, 2013, 10:01:51 am
With the vertical, a 17" 4:3 is recommended. With the Nintendo, you could do a 19" vertically or a 20.1" horizontally. You could probably get a 15" looking good in the vertical kit if you got creative with some bezel art.
Post by: TKW4rr10r on November 09, 2013, 07:13:44 pm
(http://cdn.memegenerator.net/instances/400x/24974543.jpg)
Post by: HaRuMaN on November 09, 2013, 08:37:29 pm
Nope, I said that right.
Post by: TKW4rr10r on November 09, 2013, 08:46:45 pm
Just doesn't read right to me. Why couldn't you do 20" vertically or 19" horizontally then? I'm too tired  :dizzy:
Post by: HaRuMaN on November 09, 2013, 09:49:38 pm
Because I'm talking max. It's slightly wider than tall (the monitor space)
Post by: opt2not on November 09, 2013, 11:22:34 pm
You're slightly wider than tall.
Post by: Rick on November 10, 2013, 06:59:47 am
(http://kingtrumpsace.files.wordpress.com/2011/01/haters-gonna-hate.gif)
:lol
Post by: Mark1204 on November 11, 2013, 03:34:05 pm
Hello can you give me the dimensions on the barstick it is kinda confusing on the site, thanks
and is the price still $85.
Sorry strike that i found the info i was looking at the wrong item thanks
Post by: HaRuMaN on November 13, 2013, 01:18:58 pm
Let me know if you have any more questions.
Post by: HaRuMaN on November 13, 2013, 01:20:43 pm
Clearance!  I have a V1.5 Standard bartop just sitting around, it was a hybrid prototype.  Has the black melamine sides, but the rest is MDF.  I can take pictures if anyone is interested.  I was thinking $75 shipped.
Post by: pbj on November 13, 2013, 01:57:10 pm
Hm... do I need another dust collector?
Post by: opt2not on November 13, 2013, 01:58:40 pm
Let me know if you want any more "special" art. ;)
Post by: 05SRT4 on November 14, 2013, 08:15:05 am
Control holes drilled?
Post by: HaRuMaN on November 14, 2013, 08:49:57 am
Yes, has a 1 player  6 button control panel with extra 2 buttons (start / coin), and 3 admin panel holes.  Sale is pending, stay tuned.
Post by: HaRuMaN on November 14, 2013, 10:18:21 am
Available again if anyone is interested.   :cheers:
Post by: yotsuya on November 14, 2013, 10:20:08 am
Someone try to LOWBALL YOU, MAN!!!!!1111 ?
Post by: HaRuMaN on November 14, 2013, 10:22:00 am
Hah, no.   :D
Post by: HaRuMaN on November 14, 2013, 02:55:22 pm
Pics:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=300279;image)
and:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=300281;image)
Not that the plexi is NOT included, but if you want it, let's call it an even $100 shipped to the US.
Post by: yotsuya on November 14, 2013, 04:51:55 pm
What a deal!!  :o
Post by: TKW4rr10r on November 14, 2013, 05:02:23 pm
What a deal!!  :o
http://youtu.be/Pa9AI8FdMdk (http://youtu.be/Pa9AI8FdMdk)
Post by: DudeRegular on November 14, 2013, 10:10:46 pm
I have been debating how to get after this project for a bit. Your clearance one has me thinking about just going that route. Does the clearance one you are selling have the center piece with the monitor mount? If so, you can put me down for that kit along with the plexi. If not, i would probably pass and opt for a full kit.
Post by: HaRuMaN on November 14, 2013, 10:54:04 pm
Yes, it includes the monitor mount piece with 100 x 100 and 75 x 75 VESA mount holes as well as the triangular brackets to hold the monitor mount to the sides.
Post by: DudeRegular on November 14, 2013, 11:02:26 pm
PM Sent. Thanks man.
Post by: jWin on November 15, 2013, 05:26:42 pm
Sorry not sure if you received my PM,
Was a pedestal ever created for the standard bartop? I think one that is easily detatched and doubles as a bookshelf from the front would be really great.  ill be ordering soon regardless!
thanks
Post by: HaRuMaN on November 15, 2013, 05:43:28 pm
thanks
Not for the standard bartop, but I can put one together.   :cheers:
Post by: jWin on November 16, 2013, 03:48:52 am
thanks
Sure, The one on page 21 of this thread was neat, I would prefer something open on the front that can be used for storage or bookshelf/game shelf ..... show me something and a price   :cheers:
Post by: HaRuMaN on November 16, 2013, 01:20:47 pm
Clearance kit sold! Thanks!
Post by: HaRuMaN on November 16, 2013, 08:55:33 pm
thanks
You want the pedestal big enough so you can stand at the bartop?
Also, how much spacing you want on the shelves? Big enough for day a 360 game standing up?
Post by: jWin on November 17, 2013, 07:14:40 pm
thanks
Yes sir, that sounds awesome!
Post by: HaRuMaN on November 19, 2013, 09:02:04 am
thanks
Hey, just wanted to double check that you meant a 360 game case (like a DVD case)...  or did you want big enough for an actual 360 console.   ;D  Figured I'd ask before I got too far into the plans.
Post by: jWin on November 19, 2013, 01:58:42 pm
DVD size case is fine for the spacing, I will not need to fit any gaming consoles onto it, it does not need any additional holes in it for connections either,  looking forward to the finished product  :cheers:
Post by: HaRuMaN on November 19, 2013, 02:00:37 pm
DVD size case is fine for the spacing, looking forward to the finished product  :cheers:
Ok cool, just wanted to make sure :)
Post by: HaRuMaN on November 20, 2013, 12:47:55 pm
Customer commission, custom MK bartop with MKIII layout, designed to house a MKIII pcb & 13" WG CRT.   :cheers:  Order is with the CNC shop.
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=300537;image)
Post by: HaRuMaN on November 20, 2013, 01:37:45 pm
Take a look, let me know what you think:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=300539;image)
Post by: jWin on November 20, 2013, 02:36:06 pm
Very nice! Could you include a piece of board to cover the very bottom opening?, I could possibly install a drawer into it.  Also for the edges, I would prefer to have it pre-cut for t-molding.   Let me know the pricing of everything, I want to get the standard bartop, pedestal, polycarbonate bezel & marquee and have everything pre-slotted for t-molding.
Post by: HaRuMaN on November 20, 2013, 02:42:13 pm
I could do that, sure.  Let me get the plans for the pedestal over to the shop so I can find out how much it would run.
Post by: HaRuMaN on November 20, 2013, 04:22:06 pm
Looks like I should have an estimate on the pedestal tomorrow.
Another customer commission, the widescreen 2 player Nintendo bartop!
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=300555;image)
Post by: jWin on November 22, 2013, 04:49:38 pm
Did you get my payment? not sure if my PM's are going thru.
Post by: HaRuMaN on November 22, 2013, 05:37:03 pm
Sure did. I placed the order with my cnc guy last night. :)
Post by: DJMattB241 on November 24, 2013, 09:56:56 am
HaRuMaN, I got the case and have been assembling it all weekend!
It's been going pretty well (considering my lack of woodworking/planning skills), but I have a few questions that may be dumb:
So I've got those little sticks, that it seems you're supposed to glue(?) into the not-as-deep slats, and then rest the back door and controls on them. I guess my questions are 1) do you glue the sticks into those slots and 2) how do you keep the controls from just lifting off when someone pulls up on a joystick, or the back door from just falling off?
Thanks! (Seriously, this case came out great, and my lack of woodworking skills are barely going to be able to do it justice!)
Post by: HaRuMaN on November 25, 2013, 04:08:07 pm
Not dumb at all.  The thin strips get glued into the sides. How to attach the cp and back is up to you. Some people use screws, some use industrial Velcro, I am going to try strong magnets soon. As far as the back goes, I usually hinge the bottom, and use a lock at the top.
Post by: HaRuMaN on November 26, 2013, 02:43:08 pm
I love it, from concept to reality in 6 days!
Post by: HaRuMaN on November 26, 2013, 02:43:48 pm
Another view
Post by: Malenko on November 26, 2013, 02:44:35 pm
www.harumancustoms.com (http://www.harumancustoms.com)
MORTAL KOMBAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAT
Post by: Morphx2 on November 26, 2013, 09:14:19 pm
Question for ya
I sent the plans to the CNC person here to see how much it would cost, but they are unsure of the dimensions.  Any idea of them so I can let him know?  It is based off of your rev_c design.
Post by: jWin on November 27, 2013, 07:43:00 am
Any updates?  ;D
Post by: HaRuMaN on November 27, 2013, 08:54:11 am
Question for ya
How exactly are they unsure of the dimensions?  It's an Autocad file, the dimensions are in the drawing.  Everything is in inches.
Post by: HaRuMaN on November 27, 2013, 08:55:21 am
Any updates?  ;D
With the holiday break, it sounds like the shop will have this ready on Monday.   :cheers:  At which point I will pick it up, do the slot cutting, and pack it.
Post by: DJMattB241 on November 27, 2013, 08:57:46 am
Hello sir!
This may be my final question (haha, who am I kidding), because the constructing part of this may be nearing the end!
So the marquee. You said grab some L-channel? How exactly is that installed? I can't figure out how that would hold plexiglass and a sign. Maybe I'm just not picturing it correctly...
Post by: HaRuMaN on November 27, 2013, 09:05:46 am
Hello sir!
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=289365;image)
So, if you take a close look you can see 2 screws around the bottom of the marquee area.  This is holding the L-channel on.  The 2nd piece of L-channel is on top.
Post by: Morphx2 on November 27, 2013, 09:23:29 am
I am not sure either why they couldn't tell. Oh well. I just wanted to get a price of how much it would cost.  I can't open the autocad file at work and see. They said they can't do square corners either, only rounded
Maybe I'll just order from you, we'll see!
Thanks a bunch sir
Question for ya
Post by: HaRuMaN on November 27, 2013, 09:47:57 am
Thanks a bunch sir
Yeah that sounds very weird.  The only corners I can't get square are inside corners, they will always have a small radius to them.  Outside corners, no problem.
Post by: HaRuMaN on November 27, 2013, 05:59:57 pm
Design improvement (thanks malenko!).
Eliminates the issue of having an LCD monitor in a vertical cabinet where the VESA mount holes aren't centered in the vertical direction (monitor oriented normally).
Post by: Rick on November 27, 2013, 06:54:44 pm
That is smart! Thanks, Malenko!
:D
Post by: Malenko on November 27, 2013, 07:15:02 pm
:D
Just tryin to help. I'm still lookin at way to improve the designs. I cant really figure stuff out unless I have the cab in front of me, which is how I thought of this. While putting together my MsPacman mini (project thread to be started later) I had issues getting the monitor centered, so I sent Haruman the idea, he made it a reality.
Now if only I could convince him to send me a Midway cocktail for free........
Post by: Morphx2 on November 27, 2013, 11:18:43 pm
I tried 3 non-autocad programs to open it and none of them show dimensions :\
Maybe I just need autocad to see them.  I tried getting the trial for it, but it wont install.  Oh well, ill try again after thanksgiving
Thanks a bunch sir
Post by: HaRuMaN on November 28, 2013, 08:58:34 am
Thanks a bunch sir
Download draftsight, it's free, that's what I use to draw. You will have to use the dimension tool to make the dimensions show up, but they're a part of the drawing.
Post by: Morphx2 on November 28, 2013, 10:26:46 am
An draft sight.  I had it but didn't know about the dimension tool.  Will try!
Kinda figured it out, using smart dimensions, it puts big dimensions and you can drag it around; correct?
Do you have the cnc file for the 2-player version?  I didnt see it on the first page and looked around a few pages
I would send you a PM with this, but it won't work for me
Post by: HaRuMaN on November 28, 2013, 12:45:58 pm
Send me an email at my username @gmail.com and I'll mail it to you.
I don't use the smart dimension tool, I just use dimension - linear and click the two points I want to know the length of
Post by: DJMattB241 on November 29, 2013, 10:53:48 pm
Alright came up with another question:
In this thread a few people showing finished products, the edges of the two side panels have this nice black plastic edging. I don't know how to find that. I tried "edging" at amazon, but all it has is gardening stuff. I don't even know if its called edging.
What's that stuff?! :)
EDIT: Edge Banding. Found it. Of course as soon as I ask. haha
EDIT2: Okay so... Do you just get it 1/2 inch wide and iron it on? I can't find it 1/2 inch wide in my basic google/amazon searches.
Post by: Slippyblade on November 29, 2013, 11:00:27 pm
It's called T-Molding.
http://www.t-molding.com/ (http://www.t-molding.com/) is a regular place to get it.
Groovy Game Gear (http://groovygamegear.com/webstore/index.php?main_page=index&cPath=75&zenid=opin93c91f46c3o5gdhidnaf17) has it too.
If you look at the bartop pic in the very first post of this thread you will see a groove cut into the wood.  The leg of the "T" molding gets pressed/tapped/beaten into that groove.
Post by: yotsuya on November 29, 2013, 11:03:09 pm
Get 20 ft of this stuff:
http://www.gamemolding.com/products/111-arcade_t-molding_black_5_8.aspx (http://www.gamemolding.com/products/111-arcade_t-molding_black_5_8.aspx)
Post by: opt2not on November 30, 2013, 01:58:42 am
Looks like someone needs to read the byoac bible (http://www.amazon.com/Project-Arcade-Build-Your-Machine/dp/047089153X/ref=pd_sim_sbs_b_1).
There you go Saint. ;)
Post by: DJMattB241 on November 30, 2013, 08:27:21 am
GASP.
Thanks you guys! A site to buy it from, and a book so I can stop asking so many questions! haha
Love it!
Post by: HaRuMaN on December 02, 2013, 02:05:27 pm
Just picked up 2 standard bartops, 1 standard pedestal, and this thing:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=300906;image)
Customer commission of a bartop designed to fit an X-arcade tankstick (tankstick not included).
 :afro:
Post by: yotsuya on December 02, 2013, 02:07:47 pm
That's a pretty tall front porch there.  :cheers:
Post by: jWin on December 02, 2013, 04:29:13 pm
Looking forward to putting everything together! :cheers:
Post by: opt2not on December 02, 2013, 10:39:43 pm
Lookie what I got this weekend:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=300910)
This came all the way from down there in Arizona, to up here in Vancouver BC Canada.
At first opening the box, I can see the packaging was well thought out, from the light-weight materials to the method of wrapping the panels.
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=300914)
Each set of panels are tightly packed together, with foam protecting the edges.
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=300918)
No damage! I was worried that the long travel distance and exchanging of hands/trucks/planes, etc... would yield some unwanted results, but it all came in unscathed!
All the contents:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=300916)
I asked Lee to route out the bottom of my control panel to be able to fit Japanese-type controls. My Seimitsu LS-58, and Sanwa buttons fit well!  Don't mind the snap-in Sanwa buttons, I'll be going with screw-in ones once they arrive.
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=300912)
Paradise Arcade Shop's aluminum balltop with shaft cover on the LS-58. I love that balltop, it has this dark, dull, matte look that is really sleek looking in RL. This is a 1P bartop...geared towards more non-kick harness games. (if you know how I feel about the LS-58's, and what I use them for, then it'll be pretty easy to figure out what type of games I'll be playing on this thing)
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=300908)
I gotta say, this kit is looking really sweet!
The quality of the cuts is clean, as expected, and the weight of the cabinet altogether isn't too heavy, but not too light. The laminate is going to save a lot of time painting and priming, and it just looks sexy.
I've got a few plans for having the CP accessible from the front.
I'll post more information on it once I start assembling, and probably put up a project thread. For now, I'm keeping my project intentions close-to-the-chest, but I will say that I'm stoked to get this assembled, all wired and art'd up!
Post by: Rick on December 03, 2013, 11:54:56 am
Wow, that looks amazing!!! The packing and shipping quality on Haruman's stuff is second-to-none. Kudos.
Post by: HaRuMaN on December 03, 2013, 12:21:51 pm
Thank you good sir!  :applaud:
Post by: jWin on December 03, 2013, 03:22:16 pm
Any idea how much tmolding I need to order for the bartop and pedestal combo?
Post by: HaRuMaN on December 03, 2013, 04:08:28 pm
Hmm.  I'm gonna guess 40 ft
Post by: HaRuMaN on December 04, 2013, 04:02:36 pm
Have a new slot cutter coming Friday, I just burned up my last one.  Will get your kits slotted over the weekend, and mailed out on Monday.   :cheers:
Title: Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
Post by: HaRuMaN on December 05, 2013, 12:35:09 pm
Any suggestions on what to make next?
Post by: yotsuya on December 05, 2013, 12:36:18 pm
(http://upload.wikimedia.org/wikipedia/commons/thumb/3/32/Signed_Pong_Cabinet.jpg/250px-Signed_Pong_Cabinet.jpg)
Post by: HaRuMaN on December 05, 2013, 12:38:32 pm
Bartop or original size?
Post by: yotsuya on December 05, 2013, 01:27:30 pm
Bartop. One I can stick my TV Pong console into.
Post by: HaRuMaN on December 05, 2013, 01:41:02 pm
To the drawing board!
Post by: opt2not on December 05, 2013, 04:08:16 pm
Vewlix bartop? Too plain perhaps?
Post by: pbj on December 05, 2013, 04:09:42 pm
A bartop version of a cabinet that looks like a computer desk?   I don't even....
:lol
Post by: opt2not on December 05, 2013, 07:32:21 pm
Yeah, I know. But the 20-year-olds would like it, and it's simple, so it has the possibility of being a decent profit margin.  ;)
Post by: gmurad on December 09, 2013, 05:43:45 pm
Hey, I built a cabinet from your cad design (I have access to a CNC machine) and it looks great. I just changed the control panel for a 2 player layout.
How are you guys mounting the joystick on the 1/2" CP? Just with a regular nut and bolt? Thanks.
Post by: yotsuya on December 09, 2013, 05:45:21 pm
Carriage bolts FTW.
Post by: jWin on December 09, 2013, 08:48:57 pm
Any tracking infos yet?  ;D
Post by: HaRuMaN on December 10, 2013, 08:51:48 am
In your PM.   :cheers:
Post by: HaRuMaN on December 10, 2013, 04:21:13 pm
Booked solid through the end of the year, any new orders will likely not get cut until early January.  All paid orders to date will be completed within the week.   :cheers:
Post by: yotsuya on December 10, 2013, 05:33:05 pm
Thanks for all you've done this year! I know I appreciate it.
Post by: Malenko on December 10, 2013, 09:44:53 pm
Guess you shouldnt reveal the custom Galaxian Art I finished today for the vert kits then.
Post by: PsychoAU on December 12, 2013, 01:01:00 pm
So I might just be a dummy, but how does this marquee plexi go on?  I have the plastic u-channel pieces and the piece of plexi for the marquee, but do I just glue the plastic pieces on?  I am very confused.
Can you give any detailed pictures of how this all works?
Post by: HaRuMaN on December 12, 2013, 01:25:03 pm
Ok... so you need 2 pieces of L channel, one for the top, one for the bottom.  I just screw it into the wood on the top and bottom...
I'll see if I can find a pic.
Post by: PsychoAU on December 12, 2013, 01:41:08 pm
L channels would make sense, but I ordered your 1-Player kit back in the summer and you sent me just U shaped pieces.  That's where I was getting confused.
Post by: HaRuMaN on December 12, 2013, 01:48:12 pm
Ahh, reading comprehension fail on my part.  U-channel is just decorative, really, goes on the left / right sides of the plexi.
Post by: PsychoAU on December 12, 2013, 01:50:29 pm
Ok, that solves the mystery of what the U pieces are for, but I still don't have a way to mount the plexi.  Were you sending out L-Channel pieces at one time?  Did I just not get any?
Can you send me a picture of all of these pieces installed?  Maybe have it as part of your installation pictures in the first post?
Post by: HaRuMaN on December 12, 2013, 01:57:12 pm
No, I was not sending out L - channel...  I did find a source of some nice matte black plastic L-channel, I could send you a couple of pieces if you like.  The place I get from has a minimum order.
As for pics, this what I could find at the moment...  see the two silver color screws?  They are holding the L-channel on.
Post by: PsychoAU on December 12, 2013, 05:09:04 pm
And one more question just because I am at work and planning on going by the hardware store on the way home...  what is the width of the marquee plexi on a 1-player cab?  I am gonna go by and look for L-brackets that could work and can't get home to measure the cab.
EDIT: Nevermind.  I see in the first post the width of the CP is 17.72" so I can assume the plexi is the same width.  Thanks, though.
Post by: HaRuMaN on December 13, 2013, 10:44:52 am
More progress...
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=301464;image)
Post by: Rick on December 13, 2013, 10:55:23 am
Mmm, that's a tasty spud.
:D
Post by: jmike on December 13, 2013, 12:08:32 pm
Love the artwork on that beauty.
Care to explain this...  ;D
Post by: HaRuMaN on December 13, 2013, 12:10:11 pm
Hahahaha...  good eye.  My daughter (3.5 years old) likes to come up into the gameroom while I work.  She gets half the table to play with Play-Doh, the other half is mine for bartop work.
Post by: tron84 on December 16, 2013, 12:43:25 pm
Man that Galaga is killer..... Looks really sweet man.  :cheers: she's a beauty!!!!! :applaud:
Post by: HaRuMaN on December 16, 2013, 12:49:39 pm
Thanks! :)
Post by: tron84 on December 16, 2013, 12:57:36 pm
Thanks! :)
dude you always do nice work :)
Is that one Malenko's Galaga?
Post by: HaRuMaN on December 16, 2013, 12:58:27 pm
Thanks! :)
Nope, that one is mine, Malenko got the Ms. Pac.
Post by: tron84 on December 16, 2013, 01:02:48 pm
Thanks! :)
NICE  :cheers: a early Xmas present to you from you.... ;D
Now, since you already know my address, you can send me a Xmas present.... ;) ;D I really luv Galaga... hint hint  ::)   hahahahahaha
Post by: HaRuMaN on December 16, 2013, 02:09:14 pm
Shurrrrrrrrrre.... for $1200 shipped....
Post by: Malenko on December 16, 2013, 04:57:00 pm
The MsPac is my moms retirement gift. I already have 2 full sized Galagas, so I dont need a bartop yet.  Galaxian art is done and Im working on regular pacman art next up I start tackling nintendo art
Post by: tron84 on December 17, 2013, 10:26:19 am
:o ;D  :laugh: Call me skip because I guess Santa is skipping the homestead for Galaga. lol.... You killed me w/ that font. I had to blow it up to 700% you know I have bad eyes brother.
That is going to look nice sitting along w/ your Neo-Geo mini :D
Ahhh, very nice gift. That was a sweet mini too. That is kool she is a gamer.... :cheers:
Post by: Malenko on December 17, 2013, 04:22:28 pm
Dont zoom in the font, just copy /paste it to the address bar
My mom isnt a gamer she just really loves MsPac, but she's still getting a 60 in 1 anyway :)
Post by: pbj on December 17, 2013, 04:29:22 pm
That's pretty how Harumen sends competitor threads to Post Hell.
Post by: HaRuMaN on December 17, 2013, 04:56:58 pm
No, I send posts to post hell that are selling 60-in-1 boards.
Post by: yotsuya on December 17, 2013, 04:59:58 pm
To be fair, I'm pretty sure it was because of what the guy was explicitly selling with the bartops. HaRuMaN's been more than generous with the other bartop vendors.
Post by: Malenko on December 17, 2013, 06:26:22 pm
To be fair, I'm pretty it was because of what the guy was explicitly selling with the bartops. HaRuMaN's been more than generous with the other bartop vendors.
You are pretty Yotsuya, and yeah homeskillet was selling 60 in 1s
Post by: yotsuya on December 17, 2013, 07:29:49 pm
Thanks, bro.
The OP was also selling 176 in 1 horizontals. I'm sure if he reposted without the bootleg mentions, it'd be ok. However, if you're reading this, familyfuntimeamusement or whatever your handle was, you may want to rethink your design.
Post by: pbj on December 17, 2013, 07:33:36 pm
Forum sponsors sell multiboards
Haruman deletes factual posts
Post by: yotsuya on December 17, 2013, 07:41:52 pm
You're making it sound like he's doing something sketchy for his own gain, but I know for a fact he's the one that gave sticky status to all the other bartop makers.
Post by: Rick on December 18, 2013, 08:00:33 am
Harumen
There's more than one of them now??!
 :dizzy:
Post by: HaRuMaN on December 18, 2013, 08:50:50 am
Harumen
 :dizzy:
We are many...
Post by: Rick on December 18, 2013, 10:10:44 am
We are many...
Funny. I always read it as "How'r you, mon?"... Like a drunk Trinidadian or such.
Post by: HaRuMaN on December 18, 2013, 10:21:57 am
We are many...
lol... it's pronounced like Saruman, just with an H
Post by: HaRuMaN on December 20, 2013, 10:55:14 am
Next up: 1943: a Tiny Pilot kit!
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=301723;image)
From the back:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=103207.0;attach=301725;image)
Thanks to Maximus for offering to allow me to make this as a kit, see his project here:
http://forum.arcadecontrols.com/index.php/topic,133872.msg1379284.html#msg1379284 (http://forum.arcadecontrols.com/index.php/topic,133872.msg1379284.html#msg1379284)
Sides are 3/4" MDF, all other pieces are 1/2" MDF.  Should have the estimate back from my CNC guy in a few days.   :cheers:
Post by: Rick on December 21, 2013, 12:27:09 am
Does your CNC guy give you the angled edges or are you doing these yourself?
Post by: gmurad on December 22, 2013, 07:58:32 pm
I adapted the standard bartop design for 2 players and built a cabinet, my first DIY project. My T-moldings are not trimmed, not sure how I can do it at this point. Also, I'm still missing the side graphics.
I have an AMD A10-6800K APU inside with 8GB DDR3 and SSD, Micro-ATX motherboard. It's running MAME right now.
(https://scontent-b-iad.xx.fbcdn.net/hphotos-ash3/1480558_10202196145718647_1920515076_n.jpg)
Post by: Malenko on December 22, 2013, 08:54:25 pm
flush trim bit on your router. You can also order 1/2" white or black molding. That's an interesting button layout you went with.
Post by: Malenko on December 22, 2013, 11:20:06 pm
Pacman art done and sent to Haruman. Includes a pacman CPO in the style of the mspac I made, and another one made in the style of the original pacman.
Post by: HaRuMaN on December 23, 2013, 08:46:18 am
Myself.  The control panel with a round over bit and the back vent panel with a 45 degree chamfer bit
Post by: HaRuMaN on January 02, 2014, 10:24:08 am
Vewlix-style cab complete (needs marquee)...  Potato cam goodness (I took a bunch of good pictures with my other camera, just need to download them).
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=302188;image)
Post by: Vylrath on January 02, 2014, 06:31:08 pm
Post deleted ... got in touch.
Post by: HaRuMaN on January 02, 2014, 08:47:48 pm
Just a note that my website & online store are currently down.  They didn't bother to mention that when I upgraded to the larger store it would nuke everything I had before.   :banghead:
In any case, if you need anything, just message me here.
Thanks.  :cheers:
Post by: HaRuMaN on January 03, 2014, 03:32:47 pm
Got some items coming back online... whee...  :applaud:
Post by: retrogamedude on January 05, 2014, 08:20:38 pm
Whats the easiest way to mount the monitor in the widescreen kit.  I have the monitor mounted to the VESA board, I read farther back to turn the cab on its side but how do I know the best spot to mount it?  Should I have the plexi on the monitor first to allow for that space?
Post by: HaRuMaN on January 05, 2014, 10:09:17 pm
I usually lay the bartop face down, rest the plexi in, set the monitor on top of the plexi, and mount it that way.
Post by: BAMBOO on January 07, 2014, 01:37:25 am
These kits are awesome!
Post by: Rick on January 07, 2014, 09:09:32 am
That's the way I do it. So, this makes the process ...
(http://www.quickmeme.com/img/70/70f4091d6ea34a1be65d424a990961c8866319a2287e57327665123d043c568e.jpg)
Post by: HaRuMaN on January 07, 2014, 09:52:37 am
Sneak preview of something in the works...   ;)
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=302442;image)
Post by: Ginsu Victim on January 07, 2014, 12:17:00 pm
Post by: HaRuMaN on January 09, 2014, 09:21:01 am
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=302594;image)
Post by: 05SRT4 on January 09, 2014, 10:44:05 am
Are those for the cocktails?
Post by: HaRuMaN on January 09, 2014, 10:44:26 am
You are correct sir!  Still a prototype, haven't done a final production run yet.  Need to test in an assembled cabinet, which will happen very soon.   :cheers:
Post by: dextercf on January 10, 2014, 07:01:29 am
This right here is gold!
Your ---steaming pile of meadow muffin--- is turning out really polished my good man HaRuMaN!
Post by: HaRuMaN on January 16, 2014, 11:25:49 am
Thanks! :)  Here's what's coming next:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=302957;image)
Just a simple fightstick, should be very affordable.  Has an additional button hole on the back, and a 24mm hole for a Neutrick USB pass-through.
Post by: tron84 on January 16, 2014, 11:33:55 am
ohhhh, I likie  ;D looks good man. :applaud:
Post by: HaRuMaN on January 16, 2014, 11:34:58 am
How many can I put you down for? ;)
Post by: tron84 on January 16, 2014, 11:45:56 am
Is there a 3for deal?  ;D  most likely 3.  I am running out of room for panels.  These will work great.
Post by: HaRuMaN on January 16, 2014, 11:49:44 am
For sure!  Any multiple deal would save on shipping, so yes.
Post by: tron84 on January 16, 2014, 11:56:40 am
:cheers: :cheers: you are all right in my book  :D  :D ;D
Post by: Rick on January 17, 2014, 08:25:12 am
Thanks! :)  Here's what's coming. Just a simple fightstick, should be very affordable.  Has an additional button hole on the back, and a 24mm hole for a Neutrick USB pass-through.
I'll be honest. While most of your designs look great, I'm not really loving the look of this one. (You know me. I consider you a friend, so it's certainly not sour grapes on my part.)
Post by: HaRuMaN on January 17, 2014, 08:44:30 am
Oh I know.  What about this one, specifically?
Post by: Malenko on January 17, 2014, 09:08:56 am
you gotta picture it with art I guess?
forgive the MS Paint , Im at work
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=303090;image)
Post by: Rick on January 17, 2014, 09:38:33 am
you gotta picture it with art I guess? forgive the MS Paint , Im at work.
It's not that. I think it's two things - the sides and the odd curves on the front of the control panel.
:D
Post by: HaRuMaN on January 17, 2014, 09:44:22 am
Customer request, with this as inspiration:
(http://i1106.photobucket.com/albums/h378/mann0mann/l_capcomstylestickfullsize.png)
Here's a better render, sketchup sometimes makes things look more angular than they really are...
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=303092;image)
Post by: Rick on January 17, 2014, 09:47:09 am
Now, that makes it look a lot better. I know what you mean in regards to the render. If you don't change one setting in Solidworks, everything looks like it was made in Sketchup. (Dig dig dig.) ;)
Post by: HaRuMaN on January 17, 2014, 09:51:39 am
I can't complain about the price... lol.
Post by: pbj on January 17, 2014, 10:11:45 am
(http://zapek.com/wp-content/uploads/2008/12/xarcade-solo-1.jpg)
Post by: Rick on January 17, 2014, 10:27:04 am
 :o
That's AMAZING!!! That's it, I can't compete. I'm so outta this hobby!!!
 :notworthy:
Post by: Malenko on January 17, 2014, 12:40:46 pm
 :o
 :notworthy:
yup, the taller side walls, joystick placement, button count and placement, all completely identical! I guess if you get a blank from Rick or Haruman you dont get the high quality buttons or stick or the top of the line encoder, so thats another reason to go Xarcade. /sarcasm
Post by: 05SRT4 on January 17, 2014, 12:58:19 pm
I hate owning a tank stick and being on this forum lol
Post by: HaRuMaN on January 17, 2014, 01:05:33 pm
Lol.  It can be rough, to be sure...   ;D
Post by: TKW4rr10r on January 17, 2014, 01:16:53 pm
[!!!Topic derailment incoming!!!]
 :soapbox:
Sorry, maybe I missed something in my absence (and by absence, i mean not being able to check the forum several times a day like a used to), but what is all the hate recently with anything being designed / built from a kit these days?
I mean, the kits I've seen come out of the community here lately have been top-notch quality, and using pretty much the same materials if they were built any other way. We are not all lucky enough to have access to the same tools or workshop space, so I consider these a godsend.
Sure, some of what I saw as recently as 5 years ago was not very impressive. And some products I've seen being sold elsewhere on-line still fall into that "questionable quality" category. But not internally here.
Is it the influx of more bar-top builds and less "true restoration" threads? People being considered lazy? The designs? I just don't see the cause for the venom. Not trying to stir a hornet's nest, genuinely curious and I'll start a separate thread if needed.
[resume topic]
Post by: Malenko on January 17, 2014, 01:19:56 pm
PBJ has always hated everything kit based. No one reads the restoration threads except people like me with active restoration projects
Post by: yotsuya on January 17, 2014, 01:51:16 pm
That's just PBJ being PBJ.
I love my HaRuMaNCustoms cocktail kit. He basically did the heavy lifting part for me with the main body kit, and I've been able to give it my own touches. My plan was always to build from scratch, but it ended up saving me time. In fact, I've bought 5 kits from HaRuMaN over the past year, and we're working on the 6th right now. That means I qualify for a free sawhorse.
Oh, and I LOVE restorations.
Post by: 404 on January 17, 2014, 02:22:27 pm
hate to hijack this thread but does anyone know if there is a vector of the button decals. I found a rendition of them online but the joystick part of the art is wrong.
Post by: tron84 on January 17, 2014, 02:32:35 pm
That is just the way the MAS Full Stick was made & that one had a 360 optical joy in it.
http://www.arcadeshock.com/items/mas-system-pro-arcade-sticks/capcom-style-fighting-stick-ps-ps2-full-size-perfect-360-convex-capfullstick-prosticks-detail.htm (http://www.arcadeshock.com/items/mas-system-pro-arcade-sticks/capcom-style-fighting-stick-ps-ps2-full-size-perfect-360-convex-capfullstick-prosticks-detail.htm)
EDIT:  sorry I read it wrong. Thought it was asking why it is like that...  dohhhh :(
Post by: Rick on January 17, 2014, 02:38:34 pm
Well, you could always go post your feelings in my thread to invite more conversation! I mean, geez. Does it always have to be Haruman's thread that gets the off-side convos?
Post by: HaRuMaN on January 17, 2014, 02:40:34 pm
(http://img.pandawhale.com/90170-you-really-love-me-gif-The-Mas-QXUR.gif)
Post by: JDFan on January 17, 2014, 02:44:59 pm
Best pic I could find - A bit small but might be a good start !
(http://img.photobucket.com/albums/v316/silbaughkj/Art/masTEcopy1.jpg)
Post by: pbj on January 17, 2014, 02:45:38 pm
Hello, Haruman's does look uglier and more uncomfortable to play.  A far superior design.
Post by: tron84 on January 17, 2014, 02:53:07 pm
Haruman's looks good... put down that pipe man, its effecting your judgement  ;D
Post by: Rick on January 17, 2014, 03:17:27 pm
I'm just going to say, "Haruman's looks to be of great quality, like his other projects and is definitely true to the source material." and leave it at that.
Post by: 404 on January 17, 2014, 03:26:16 pm
Thanks but i was actually just looking for the button and joystick surrounds. the joystick surround sticker everyone tends to use is wrong. That's the champion edition surround. A variation of it is also used in street fighter 1
from
http://segamadebaddecisions.wordpress.com/2012/06/19/street-fighter-2-art-resources/ (http://segamadebaddecisions.wordpress.com/2012/06/19/street-fighter-2-art-resources/)
The problem is the Super Street fighter surround has a two tone triangular design. like the one below (the image shows super street fighter II button surround overlays on a street fighter II world warriors cp art)
(http://i123.photobucket.com/albums/o310/kuanti45/RESTO%202/DSC02055.jpg)
Post by: Malenko on January 17, 2014, 03:36:51 pm
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=303110;image)
MSPAINT FTW!
Post by: JDFan on January 17, 2014, 10:30:12 pm
from
So you are looking for something similar to this then ? ( I added the joystick surround to the other art you linked - it isn't perfect but should work - would probably work better as a vector rather than in PS but it's been awhile since I tried any vector work.)
Post by: 404 on January 20, 2014, 11:47:58 am
from
Thanks. The weekend has been pretty busy so i took some time little by little to try to get the triangles symmetrical etc. my vector work is very rusty but so far i'm working on cleaning up the image and setting it to scale. So far, pretty decent. When I'm done, i'll upload what i have.
edit: Maybe a moderator can split these last few posts into the artwork section.
Post by: HaRuMaN on January 22, 2014, 09:38:34 am
Variant 2 of the simple fight stick with a slightly curved layout:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=303258;image)
Both are $65 shipped each and include T-molding slots already cut.
Post by: HaRuMaN on January 24, 2014, 04:47:12 pm
Redesign of the widescreen bartop.  Change the side profiles, made it slightly wider to hole a 24" widescreen monitor.  Added more space in the bottom, can hold a phat ps3 or 360.    :cheers:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=303368;image)
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=303370;image)
Post by: ark_ader on January 26, 2014, 09:36:49 pm
Oh crap there goes my pocket money for next month.... :drool
Post by: Donkey_Kong on January 26, 2014, 09:59:26 pm
Looks great man!
Post by: DJMattB241 on January 26, 2014, 11:42:32 pm
Hey, here's a thing I just finished!
FIRST CABINET!  :applaud:
(http://i.imgur.com/0D8wxQO.jpg)
Post by: Malenko on January 27, 2014, 07:53:53 am
that looks really good Matt! Love me some WindJammers too
Post by: HaRuMaN on January 27, 2014, 08:45:18 am
Awesome!!!  Digging the marquee, too.   :applaud:
Post by: HaRuMaN on January 27, 2014, 03:54:20 pm
Couple of panels for the new widescreen...  One with a hitbox layout for P1, Vewlix layout for the other player.  And a second panel with 2 Vewlix layouts.   :cheers:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=303560;image)
Bottoms routed out for Sanwa controls:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=303562;image)
Post by: yotsuya on January 27, 2014, 03:57:43 pm
You get the craziest ass requests I've ever seen, bro.
Post by: pbj on January 27, 2014, 04:03:01 pm
Can you CNC me some DDR squares?  They'd need to be 1/8" thick and I need 8 (dimensions are roughly 12x12).  Cheap.
Post by: HaRuMaN on January 27, 2014, 04:05:08 pm
What material?
Post by: HaRuMaN on January 27, 2014, 04:05:35 pm
Keeps things interesting.   ;D
Post by: yotsuya on January 27, 2014, 04:06:15 pm
I need a widescreen with a control panel to house my PONG controller. How much shipped to 85015?
Post by: pbj on January 27, 2014, 04:07:15 pm
What material?
Lexan, I guess.  Something that's going to withstand my godzilla sized ass stomping on it.
Post by: HaRuMaN on January 27, 2014, 04:10:56 pm
What material?
Ok, I will find out.  Quantity 8, roughly 1' squares of 1/8" lexan.
Post by: mann0mann on January 31, 2014, 02:28:16 pm
Any chance a single player variation could be made?
Post by: HaRuMaN on January 31, 2014, 02:29:50 pm
Absolutely!  You want it as wide (23" internal) or back to the typical 1 player size?  (17.75" internal)?
Post by: HaRuMaN on February 11, 2014, 10:02:39 am
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=304371;image)
Post by: Ginsu Victim on February 11, 2014, 10:15:13 am
I want that so bad.  :applaud:
Post by: Malenko on February 11, 2014, 10:50:37 am
You must pay your artist a ton of money for that kind of work.
Post by: HaRuMaN on February 11, 2014, 10:53:01 am
I pay him in Harubucks...
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=304373;image)
Bam!
Post by: yotsuya on February 11, 2014, 10:53:55 am
'Tis true. I have $40 HaRuBuCkS saved up. What's the interest rate?
Post by: HaRuMaN on February 11, 2014, 10:57:37 am
-1%
Post by: Malenko on February 11, 2014, 10:59:20 am
I get 1 Harubuck per complete art set, almost up to a tenner! Rick gave me a virtual high five then took my VESA mount idea :(
Post by: yotsuya on February 11, 2014, 11:07:43 am
Only one buck per set? I got my $40 for merchandise and services rendered. No JO, though. I got scruples, dude.  :cheers:
Post by: meyer980 on February 11, 2014, 11:38:58 am
Wow that's beautiful. Description on your site says it's meant for a 17" or 19" horizontal monitor, what's the biggest vertical it could fit? Are the artwork areas (marquee) the same size as a full Nintendo cab or shrunk down?
Post by: HaRuMaN on February 11, 2014, 11:51:00 am
I believe a 19" could fit vertically but I would need to double check.
Marquee is shrunk down to fit the cabinet.
Post by: Malenko on February 11, 2014, 11:54:02 am
How would you know?  >:D
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=304385;image)
great now I want one :(
Post by: TKW4rr10r on February 11, 2014, 04:06:18 pm
So is anyone offering the artwork for this? I need to get started on my H-Man special soon  ;)
Post by: HaRuMaN on February 11, 2014, 04:25:13 pm
Refresh my memory, did you buy a Nintendo bartop?
Post by: tron84 on February 12, 2014, 11:40:59 am
That mini DK cab is a Beauty. Really nice man  :cheers: :applaud:
Post by: HaRuMaN on February 12, 2014, 03:39:30 pm
And now for something completely different...
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=304431;image)
Post by: HaRuMaN on February 12, 2014, 04:39:02 pm
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=304433;image)
Post by: Rick on February 13, 2014, 06:31:08 am
So, hang on. Are you offering renders of full-on skinned graphics for everybody's kits now?
Post by: HaRuMaN on February 13, 2014, 08:54:27 am
Just the ones that use Malenko's sweet VESA mount idea...  oh wait
Post by: tron84 on February 13, 2014, 11:19:08 am
So are you making these now, I guess.  Very cool  :applaud:, everybody needs a Mario cube  :cheers:
How much :)
(http://i.imgur.com/3Kpb8e9.gif)
Post by: HaRuMaN on February 13, 2014, 11:22:56 am
How much :)
I'm tweaking the design a bit...  but, would you want just the cube?  Or a cube lamp?   ;D
Post by: tron84 on February 13, 2014, 11:30:31 am
A cube  ;D I already have a lamp it would get put on. :)
Post by: HaRuMaN on February 13, 2014, 12:58:49 pm
Better design:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=304459;image)
Post by: Rick on February 13, 2014, 11:15:36 pm
That's not bad. Maybe I should start selling cubes...
(http://fc09.deviantart.net/fs71/f/2012/100/1/8/toon_companion_cube_stock_by_xquatrox-d4vqwp6.png)
Post by: opt2not on February 13, 2014, 11:18:49 pm
Oh get a room you two!  :lol
Post by: Rick on February 13, 2014, 11:20:02 pm
I don't need him. I've got myself a Companion Cube.
Post by: mattgold on February 14, 2014, 12:54:12 am
I hope I'm not stepping on your thread HaRuMan - but have you seen these: 8bitlit.com
I backed it on Kickstarter and have had it hanging up for a while now.  You hit the bottom to turn it on / off and it makes the coin 'da-ding' noise - very cool.
Post by: HaRuMaN on February 14, 2014, 09:05:50 am
Yeah, I've seen those, and while the mechanics are pretty cool, I don't care for the way they did the shade, which is why I'm doing this one.   :)
Post by: TKW4rr10r on February 14, 2014, 10:57:43 am
Better design:
Get out of my head! I was just going to PM you that very same edge design idea. Will the top/bottom panels be interchangeable? I'll be in for one, but I'd like to hang it with a light in from above. I'd assume you could use the same whole sizes for that regardless if you were using it as a floor standing lamp or hanging profile.
Post by: HaRuMaN on February 14, 2014, 11:41:01 am
Nope, not interchangeable, however, my design will allow for bottom mounting (table, wall) and top mounting (hanging).  The mounts aren't shown in the picture here.  :)  I've got a good line on some lamp hardware that will work really well for these.
Post by: lordnacho on February 23, 2014, 09:12:22 pm
Did this happen?
Post by: HaRuMaN on February 24, 2014, 08:35:29 am
Did this happen?
Yes, I have the estimate, let me dig it up from my email...
Post by: HaRuMaN on February 25, 2014, 11:02:53 am
Bam!
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=305123;image)
Post by: HaRuMaN on February 25, 2014, 11:05:30 am
Did this happen?
Looks like I can get this done for around $275 + shipping...
Post by: HaRuMaN on February 27, 2014, 01:15:42 pm
Everyone else is doing it...
www.youtube.com/watch?feature=player_detailpage&v=q_W20PbsKSo (http://www.youtube.com/watch?v=q_W20PbsKSo#)
Post by: fantoboy on February 28, 2014, 02:34:51 pm
I have a two player Haruman I'm about to assemble.  Is there anything you guys recommend doing before I glue it together?  I was thinking mounting the speakers would be easier before I glue
Post by: HaRuMaN on February 28, 2014, 02:46:52 pm
Yes, that might make it a bit easier.
Post by: stoopid2001 on March 01, 2014, 08:54:18 pm
I had a little trouble mounting the marquee light after assembly too.
Post by: HaRuMaN on March 02, 2014, 01:55:25 pm
I used cold cathode lights with the included velcro for mine, worked pretty well (installed after assembly).
Post by: Rick on March 02, 2014, 02:34:29 pm
Pro tip, right here. ^^ Unless you're going with the retro "yellowed" look, there's no reason not to go with these little babies. Inexpensive, light, and oh so bright.
:D
Post by: Baezl on March 10, 2014, 04:27:54 pm
Hey guys or HaRuMaN, does anyone have the widescreen bartop (2 player) cnc plans or templates?  I want to attempt this.  I suck at cutting wood so was going to print the CNC plans to scale and use it.  I did download the sides that were posted at the beginging of the thread but was looking for inside measurments etc.  Any help is highly appreciated.  Damn HaRuMaN does great work!  Very creative!!!
Thank you
Luis
Post by: HaRuMaN on March 10, 2014, 04:43:21 pm
Thank you
Luis
The widescreen is simply the weecade (standard) bartop with the internal panels stretched to 22".  The sides are the same.
I can still host them somewhere if you need them.
Post by: Baezl on March 10, 2014, 05:02:16 pm
Thanks .  I emailed you on your site about buying 3-5 units.  Do you do a discount?  If you have the CNC plans yes, then I will take them if its not too much trouble.  Either way, if you send them, we still want to buy some units, I just want to build one with my son for fun.
Your the man!!
Thank you
Luis
Post by: InfraredMonkey on March 11, 2014, 12:01:49 pm
Hey guys!  Long time lurker on this post.  In fact, I went through page by page for the last day or so.  I gotta say HaRuMaN's designs and CNC production is amazing!  I really think you all collectively improve on the interest on bartop arcades.  It's incredible!  :applaud:  :notworthy:
Now that the gushfest is done.  I wanted to get down to some business.  Oh yes, I want one.  I wanted to know a few things.  I've scanned back in the last 2 pages of this post and I gotta say, I love that Nintendo design.  It's really awesome.  I am for sure interested in getting one that will fit a 19" vertically.  Has anyone tried this?  If so, do we have any real pictures of this?
HaRuMaN - If I intend to get the Nintendo version, I wanted to know how the plexiglass situation goes.  How does it mount?  Also were you able to experiment with Nintendo buttons?  Will they clear?  Forgive me on my ignorance here, I just didn't see much detail on this.  We could move this over to a PM if needed.
Thanks,
Spencer
Post by: HaRuMaN on March 11, 2014, 12:06:51 pm
I am pretty certain a 19" will mount vertically, I have one at home I can measure to double check.
The marquee is held on at the top with a piece of L-channel, and at the bottom with a piece of H-channel.  The top of the bezel fits into the bottom of the H-chanel, and I have a mounting slot at the bottom for the bezel.
Got a drawing or pictures of Nintendo buttons?  I don't see what would cause them not to clear, but I would need to see some to be sure.
-Lee :cheers:
Post by: InfraredMonkey on March 11, 2014, 01:10:11 pm
-Lee :cheers:
Right on, Lee.  I appreciate the response.  Here is what I can dig up (attached below).  I imagine it would be okay, I figured I would ask.
Is the h-channel and t-channel included in the price for the marquee and monitor plexi?  I saw a few folks were showing off cabarets.  Have you thoughts about getting these done through a CNC guy?  If so, do you have an idea of cost to do it (maybe a ball park on shipping?)?  It's not for me, but I have a friend whom I was telling him about all the work and success you had on these bartops.  Then I started showing him some of the testimonials.   ;D
-- Spencer
Post by: HaRuMaN on March 11, 2014, 01:13:34 pm
-- Spencer
Yeah, that button should fine.  H & L channel are available for an additional $15.  I custom cut them to size to fit each cab.
I have drawn plans up for a cabaret, I think I got an estimate from my CNC guy, let me take a look.
Post by: InfraredMonkey on March 11, 2014, 02:05:46 pm
Sounds good!  I've sent a PM.   :notworthy:  I should probably stop using that emote before Rick finds out.  :cheers:
-- Spencer
Post by: HaRuMaN on March 11, 2014, 02:11:39 pm
-- Spencer
Rick secretly does it, too... ;)
Post by: fantoboy on March 18, 2014, 09:48:15 am
I got the two player model and I'm planning on putting Sanwa sticks in it.  Will they feel ok just mounted underneath?  Or should I get the extended shafts?  The bottom of the CP isn't routed for them.
http://www.amazon.com/dp/B00BFL2SSA/ref=wl_it_dp_o_pd_S_ttl?_encoding=UTF8&colid=14ONEKU9MA8CE&coliid=I154EYNU6UDB1D (http://www.amazon.com/dp/B00BFL2SSA/ref=wl_it_dp_o_pd_S_ttl?_encoding=UTF8&colid=14ONEKU9MA8CE&coliid=I154EYNU6UDB1D)
Post by: HaRuMaN on March 19, 2014, 02:22:48 pm
The CP is 1/2" thick...  you may want to think about the extended shafts
Post by: Rick on March 19, 2014, 03:25:08 pm
The CP is 1/2" thick...  you may want to think about the extended shafts.
It's totally a judgment call, really. I ordered Jiffy Sticks (Sanwa clones) and with regular shafts and using 5/8" MDF, they fit well into my bartop.
(http://i.imgur.com/kAyrAWC.jpg)
I personally wouldn't install longer shafts, but to each his own.
Post by: FelixTheJeep on March 21, 2014, 10:11:16 am
HaRuMaN, are you still doing cocktail tables?  Thanks!
Post by: HaRuMaN on March 21, 2014, 10:29:25 am
yes :)
Post by: rablack97 on March 24, 2014, 07:17:00 pm
That dude is jamming, what video is that from, curious as to what he's dancing too...
Post by: HaRuMaN on March 24, 2014, 08:09:35 pm
TECHNOVIKING! (Captioned) (http://www.youtube.com/watch?v=FwsntHcWiy4#)
Post by: Rick on March 25, 2014, 07:54:08 pm
Dude, I'm 41, and even *I* know that's Technoviking.
Post by: rablack97 on March 25, 2014, 10:30:33 pm
For one i'm 40 too, for 2 i'm black, so how the heck is a brotha suppose to know anything about Technoviking :afro:
Just watched vid, dude is jamming......sorry Haruman, carry on with thread greatness  :applaud: :applaud:
Post by: yotsuya on March 26, 2014, 12:15:49 am
Wait, you're black?
Post by: rablack97 on March 26, 2014, 01:49:57 am
As the night itself, and yes black people know how build stuff to sir....
Please tell me your not just now putting 2+2 together.....Well I'll be damned.... :dunno
I think i'm gonna remix that vid with "It takes 2" by rob base......yall aint feelin the john travolta move at the beginning of the groove fest.
Post by: yotsuya on March 26, 2014, 02:08:10 am
Throw on some "Joy 'N Pain" afterwards.
Post by: HaRuMaN on March 27, 2014, 11:28:59 am
Result of a customer request, Defender:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=306700;image)
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=306702;image)
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=306704;image)
Post by: FelixTheJeep on March 27, 2014, 05:21:40 pm
yes :)
Excellent!  I wasn't sure because I didn't see them for sell on your site anymore, but now I see on the front page that the Midway cocktail is being redesigned.  Do you know when the redesign will be ready for shipping and the price?
Post by: HaRuMaN on March 27, 2014, 05:23:29 pm
yes :)
It's the next one on my plate.  Should be very soon, price for cherry woodgrain melamine would be ~$220 shipped.  Can also do a cabinet grade baltic birch for around $260 shipped (this one you would need to stain or something to finish).  Both are 1/2" materials.
Post by: FelixTheJeep on March 28, 2014, 11:45:13 am
yes :)
Great, looking forward to seeing them!
Post by: 404 on April 01, 2014, 09:38:33 am
I'm not white and I know who techno-viking is. That was funny stuff back in the day.
Post by: Malenko on April 01, 2014, 10:06:17 am
I'm black albino.
Post by: HaRuMaN on April 02, 2014, 11:54:04 am
Well, ZapCon is less than 2 weeks away.  I'll be there set up as a vendor.  I've been working feverishly to finish off some bartops for the show.  Looks like I'll have:
MDF Weecade V1 running a DC with VGA box and Mini-SLG
Melamine Weecade V2 running MAME with a prototype howler PCB (courtesy of Wolfware Technologies Inc.) and RGB controls (courtesy of Paradise Arcade)
Melamine vertical kit running a 60-in-1 with a Mini-SLG, with Galaga artwork
Melamine Neo Geo kit running a 1 slot Neo Geo Mobo, RGB to VGA converter, Mini-SLG
Brand new widescreen kit (V2) running Xbox 360 with hacked controllers & all Sanwa controls in a Vewlix - like layout
Cheers to yotsuya for bring his haruman cocktail kit for demo.   :cheers:
Anybody here plan on attending?
Post by: yotsuya on April 02, 2014, 12:34:55 pm
Oooooooo...oooooo.....me! Me!
Post by: opt2not on April 02, 2014, 01:47:38 pm
If you and yots split my plane ticket, I'll go!  >:D
Post by: pbj on April 02, 2014, 01:53:30 pm
I'm black, 450 lbs, and 5' tall.
 :dunno
Post by: Rick on April 02, 2014, 02:16:03 pm
Oh yeah, 'cause Arizona is ... wait, what? WHO THE HELL HOLDS A CON IN ARIZONA?
:lol
Post by: yotsuya on April 02, 2014, 02:19:37 pm
:lol
The City of Phoenix is, at last count, the sixth largest city in America. So there.
Conversely, your momma does.
Post by: opt2not on April 02, 2014, 03:14:06 pm
I love Arizona...it's the closest I'll ever be to walking on Mars. Such a bazaar and surreal landscape.
As for Phoenix, I caught a Suns game there and it was pretty awesome (a lot of Canadians loved the Suns when Nash played there).
But freeway drivers are absolutely insane. First and last time in my life that I actually felt like a timid driver...and I spent 4 years driving LA rush hour, so I'm no slouch to aggressive driving.
 :dizzy:
Post by: 404 on April 02, 2014, 03:28:14 pm
 :dunno
from your facebook page
(http://www.esquire.com/cm/esquire/images/LP/bowling-ball-0408-lg.jpg)
Post by: mann0mann on April 03, 2014, 05:14:41 am
Would really like to see that widescreen v2 in real life....any chance you could post some pictures of that?
I, unlike Rick...don't care if you use your crappy cell phone camera.  ;-)  LOL
I'm kicking around the idea to come.  I can't make CAX which is right in my backyard (I'll be in Lincoln, NE ugh that week) but I'd like to go to one of these cons, plus I'd love to see some of your stuff built up and in the flesh.  Add in the bonus of getting to meet Yotsuya....who wouldn't consider that tempting!  ;-)
Post by: yotsuya on April 03, 2014, 10:17:19 am
If you come, drinks are on HaRuMaN!  :cheers:
Post by: HaRuMaN on April 03, 2014, 10:37:11 am
Haha. no.
Post by: HaRuMaN on April 03, 2014, 10:47:51 am
Potato cam goodness!
Side profile:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=306882;image)
Front view, you can see the 360 sitting comfortably inside.  Also, plexi is resting on the plexi / control panel shelf.  Notice that little brass colored thing on the bottom left?
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=306884;image)
Zoomed in...  it's an invisible barrel hinge.  This kit will come with 2 of them.  As well as 2 16-pound-pull neodemium magnet latches that attach the the top of the control panel and control panel shelf...
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=306886;image)
And here it is, control panel wired, testing the monitor (not mounted yet, just sitting behind the cabinet).  It's a 24" LED gaming monitor, 2ms refresh...  and it looks awesome in person...
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=306888;image)
Post by: Malenko on April 03, 2014, 10:51:10 am
Plexi shelf?!?! BRILLIANT!
Post by: fantoboy on April 03, 2014, 02:50:22 pm
Speaking of which, anyone have any good solutions they have used on their kits to hold the plexi?
Post by: HaRuMaN on April 03, 2014, 03:09:17 pm
On my previous kits I have rested the plexi on the back of the speaker shelf and the back of the batons for the CP and mounted the monitor in such a way that it applies a slight pressure to hold the plexi in place.
Post by: Malenko on April 03, 2014, 03:27:18 pm
Yes, I invented the plexi shelf
Post by: Rick on April 04, 2014, 09:38:17 am
Some of us cut slots into the cabinet sides to fit our plexi. (Only in Canada you say? Pity!)
:D
Post by: HaRuMaN on April 04, 2014, 09:49:15 am
:D
What if your customer doesn't want plexi?  Then they're stuck with slots running down the sides... hmm...  My slot is hidden behind the control panel.
Post by: Rick on April 04, 2014, 09:53:17 am
Don't fret - it's an optional choice as to whether or not the channel is cut.
Post by: HaRuMaN on April 04, 2014, 09:56:41 am
Potato gif!
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=306916;image)
Post by: yotsuya on April 04, 2014, 10:52:28 am
:D
(http://cdn.memegenerator.net/instances/500x/48119700.jpg)
Post by: yotsuya on April 04, 2014, 10:53:33 am
Above post was a joke, BTW.  :gobama
Post by: HaRuMaN on April 04, 2014, 12:32:30 pm
Made for ZapCon:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=306918;image)
Post by: opt2not on April 04, 2014, 12:56:42 pm
Looks good, Lee!  Very cool design. :applaud:
Post by: pbj on April 04, 2014, 01:15:53 pm
That's going to cut into both player's wrists during a two player session.
Post by: Rick on April 04, 2014, 02:38:27 pm
Nah man. It's a short-sleeved t-shirt.
Post by: HaRuMaN on April 04, 2014, 02:44:25 pm
 :laugh2:
Post by: HaRuMaN on April 04, 2014, 03:44:31 pm
Power(ups) to the people!
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=306920;image)
Post by: DJMattB241 on April 04, 2014, 03:45:13 pm
Haruman,
What do you think about a podium style cabinet? Something like this: http://i.imgur.com/GZyOMwe.jpg (http://i.imgur.com/GZyOMwe.jpg) except four players and... you know.... wood.  :dunno
Post by: HaRuMaN on April 04, 2014, 03:45:57 pm
Haruman,
I'm making one right now for a customer :)
Post by: Rick on April 04, 2014, 03:46:10 pm
*BA-DING!*
Post by: DJMattB241 on April 04, 2014, 03:48:00 pm
Haruman,
Well hey, if that's a thing, I'd love to maybe get one too!
...I can't believe I'm addicted to making arcade cabinets. wtf life. :P
Post by: HaRuMaN on April 04, 2014, 04:02:50 pm
Haruman,
I'll get you some pictures of it soon.   :cheers:
Post by: rablack97 on April 07, 2014, 02:59:10 pm
Too Lazy to read through entire thread?
You designed a full size cab and shipped out yet?
Might have some work for you  :afro:
Post by: HaRuMaN on April 07, 2014, 03:46:52 pm
4 player pedestal just shipped this morning, actually...   :cheers:
Post by: rablack97 on April 07, 2014, 04:29:39 pm
ok cool, once i get some more info, i'll pm about so we can talk fees :cheers:
Post by: pbj on April 07, 2014, 04:42:54 pm
No pic = no pedestal
Post by: HaRuMaN on April 07, 2014, 04:48:57 pm
Some parts
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=307059;image)
Dry fit, no glue:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=307061;image)
Rear (again, dry fit)
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=307063;image)
Post by: yotsuya on April 07, 2014, 04:52:26 pm
How much for a Kaneda Special shipped to 85015?
Post by: HaRuMaN on April 07, 2014, 04:53:58 pm
Lol.  You can come pick one up.  This ended up being 3 boxes, 125 pounds combined.   :dizzy:
Post by: tron84 on April 07, 2014, 05:47:22 pm
My Package came today  :o ;D ;D
Thanks Haruman, turned out great!!!!!! :applaud:
edit: just dry fit here.
Post by: HaRuMaN on April 08, 2014, 10:47:11 am
Awesome!  Looks good!
Post by: HaRuMaN on April 08, 2014, 10:49:58 am
More progress on the new widescreen.  It's completely playable as is, I just have a few minor details to finish up before Zapcon.  This will be available to play at the convention.
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=307116;image)
And just for fun, the bartop that started me off on this whole adventure.  My V1 Weecade (PBJ's favorite) in MDF.  I've got it running a DC with a hacked controller.
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=307118;image)
Post by: Malenko on April 08, 2014, 10:57:45 am
get a mini SLG in there STAT!
Post by: HaRuMaN on April 08, 2014, 11:08:57 am
In the DC?  There is one.  Just hard to see in that pic.   :cheers:
Post by: Malenko on April 08, 2014, 11:11:31 am
POTATO CAM FTW!
Post by: yotsuya on April 08, 2014, 11:13:18 am
I have an "Inspected by PinballJim" sticker for the front of that Weecade ready to go for the show!  :cheers:
Post by: HaRuMaN on April 08, 2014, 12:18:38 pm
Bring it.  I'll take pics.
Post by: retrogamedude on April 08, 2014, 01:51:47 pm
How does the new widescreen differ from the old widescreen model?
Post by: HaRuMaN on April 08, 2014, 02:24:11 pm
The old widescreen is simply the weecade stratched out.
The new one is my own design.  It's an inch wider so it can hold a 24" widescreen monitor.  There is more depth available inside to accommodate a fat 360 easily.  The new one also incorporates a CP / plexi shelf to make mounting the plexi easier.  The CP shelf also holds neodemium magnets to keep the CP closed.  The CP opens using a pair of invisible barrel hinges.  Also, the CP is routed for Sanwa controls.
Post by: HaRuMaN on April 10, 2014, 03:01:56 pm
Potato cam goodness, ready for ZapCon:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=307261;image)
And
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=307263;image)
Post by: yotsuya on April 10, 2014, 03:05:02 pm
Do they all come with the Dorito bag attachment, or is that just if you buy the Galaga art?
Post by: HaRuMaN on April 10, 2014, 03:09:15 pm
Shaddap you.  Putting 5 bartops together is hungry work...   >:D
Post by: HaRuMaN on April 10, 2014, 03:10:40 pm
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=307265;image)
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=307267;image)
Hmm.  What could this be...
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=307269;image)
Post by: Rick on April 10, 2014, 03:12:51 pm
I don't know, but it's got FIVE BUTTS!!!
 :burgerking:
Post by: RetroGreg on April 10, 2014, 03:54:31 pm
I recently got the itch to get back into the hobby. I've read through some threads over the past couple weeks and came across this one. I'll be going to ZapCon on Saturday and I'll make sure to stop by your booth to chat about your bartops. I think one is going to have to be my next project.
That Neo Geo is amazing btw  :applaud:
Post by: HaRuMaN on April 10, 2014, 04:16:23 pm
Thanks man!  Make sure you stop by!
Post by: Rick on April 10, 2014, 04:56:34 pm
I found your next project. Fits with your theme, imho.
Realistic Mario: Brick Block (http://www.youtube.com/watch?v=7SXs3JZgZtk#ws)
 >:D
Post by: Ginsu Victim on April 10, 2014, 05:22:19 pm
...but Mario punches the blocks.......
Post by: yotsuya on April 10, 2014, 05:39:03 pm
Use the special ZapCon 2014 couponcode STFUPBJ to get a 90% discount AND a free t-shirt at the show!!!!*
*couponcode not valid anywhere
Post by: RetroGreg on April 10, 2014, 05:43:24 pm
lol will do  :D
Post by: yotsuya on April 11, 2014, 11:11:46 am
All the cool kids will be wearing these at ZapCon!
Post by: Rick on April 11, 2014, 11:22:21 am
If they were REALLY cool kids, they'd have the "Malenko monitor mod" on the mount. (---fudgesicle--- it, I'm making my own shirts!)
 >:D
Post by: Malenko on April 11, 2014, 11:43:00 am
hahahahahahahaha
Malenko Mount FTW!
Post by: rablack97 on April 11, 2014, 01:33:56 pm
 :burgerking:
Somebody bought a HOWLER, somebody bought a HOWLER....did you get from him or Paradise?   :applaud: :applaud: :applaud:
https://www.kickstarter.com/projects/2034467396/howler-arcade-controller (https://www.kickstarter.com/projects/2034467396/howler-arcade-controller)
Let me know how that thing works out for ya, Josh did and awesome job.
Post by: HaRuMaN on April 11, 2014, 05:40:25 pm
Setting up for Zapcon.  And don't worry, all you potato-cam haters can rest easy, I'm bringing the GOOD cameras tomorrow & Sunday.
Couple of unfinished bartops, the one on the left is running a howler pcb and RGB controls courtesy of Paradise Arcade.  The one on the right is running the DC.
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=307321;image)
Galaga, Neo Geo, New Widescreen with 360 and two hacked MadCatz controllers.
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=307323;image)
Another look.  I gotta thank opt2not again for his awesome work on my logo design!
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=307325;image)
And last, but not least...
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=307319;image)
 :laugh2:
Post by: yotsuya on April 11, 2014, 05:44:18 pm
No picture of my cocktail, bro? I hauled it half way across town for you!  >:D
I just overheard two guys talking about how awesome your setup is. Here's hoping to make a lot of sale!
Post by: HaRuMaN on April 11, 2014, 06:04:51 pm
No picture of my cocktail, bro? I hold it half way across town for you!  >:D
I know man, I forgot to snap a picture in all the excitement.  I'll get one tomorrow.
Sweeeeeet.  The few people we saw today seemed to like everything.   :cheers:  I'm not gonna sleep tonight, I can feel it.
Post by: Rick on April 11, 2014, 06:05:27 pm
GOOD LUCK, good sir! I've run in more than my fair share of shows, so make sure you've got enough info pamphlets, business cards, and more importantly FOOD AND WATER! You may not get the chance to leave when you're popular!
:D
Post by: yotsuya on April 11, 2014, 06:18:13 pm
Funny story-
HaRuMaN and I are there setting up his booth when this young adult kid wanders by. He starts talking to us, and he's especially taken with the Ultimate Widescreen Bartop. It's all going good, and then one of the organizers asked him who he's there with. We realized he was just some kid who wandered in off the street and walked into the venue. She kicked him out, but after he had gotten in some games of SF4. Did you hand him a business card?
I bet he was one of Rick's spies.
Post by: yotsuya on April 11, 2014, 06:19:48 pm
BTW, the Howler is pretty ---smurfing--- awesome.
Post by: Goz on April 11, 2014, 08:07:19 pm
Good luck brutha.... let us know how things go. I'm not driving still so no ZapCon for me this year.
Post by: Rick on April 11, 2014, 08:53:58 pm
You calling me a Fagin, son?
Post by: stoopid2001 on April 12, 2014, 10:18:28 am
Is there a project/build thread for the 360 bartop?
Post by: tron84 on April 12, 2014, 11:09:42 am
Funny story-
:lol Do you blame him, free arcade games to play. He made his own early bird pass to get in.  lol
Lookin good Haruman!!!! Your stuff should do really well there. :cheers:
Post by: jayfrost on April 13, 2014, 09:36:09 pm
Thought I would post a few pictures of my 99% complete Nintendo Cab.  The kit is great and really goes together quite well.  Took me about 8 total hours from start to finish.  This was built for my wife because she really wanted to play Donkey Kong!  This has a 60-1 Icade board with a 17in vertical vga monitor.  Be careful about the speaker that you buy for this machine.  I had a single speaker left from another project and needed to build a little workaround because a flush mount speaker is required!  Love the kit and getting ready to start on the new wide body 2 player cab for me!
Frost
Post by: HaRuMaN on April 14, 2014, 12:07:07 am
That looks pretty incredible! :)  Glad to see those pictures!  :cheers:
Post by: Rick on April 14, 2014, 09:14:24 am
It does look good! (Not to derail the awesome work, but when can we expect some pics from your show?)
Post by: HaRuMaN on April 14, 2014, 09:49:39 am
Later today :)
Post by: Rick on April 14, 2014, 09:55:31 am
Later today :)
sigh...
What I was hoping to see was some daily update posts throughout the day, yesterday. But no, you didn't think we were waiting to see any statuses, did you? I mean, come on man. We're chomping at the bit, here. That's certainly no way to treat your adoring fans!
:burgerking:
Post by: HaRuMaN on April 14, 2014, 09:58:55 am
Later today :)
sigh...
:burgerking:
Lol.  No wifi at the venue, otherwise I would have been posting non stop.  It was an exhausting weekend.  I don't think I've ever talked so much in 2 days.   :dizzy:
Post by: yotsuya on April 14, 2014, 10:19:20 am
I gotta give props to my man HaRuMaN- he was at the show hustling and schmoozing. He sold one bartop there and generated a lot of interest for future orders. The man was a machine!  ;D
Post by: Rick on April 14, 2014, 10:23:48 am
No cell phone signal either? I don't buy it. I call shenanigans.
:P
Seriously, I don't doubt it. I know how shows go, and I never expected anything but a full-on schmooze-fest from "the Man" in the U.S.
Post by: yotsuya on April 14, 2014, 10:25:40 am
I'd cover for him whenever he needed a bathroom break, but other than that, he was at the booth and always on. I give him credit- there were a lot of tire-kickers, but also a lot of genuine interest as well. He's already formluating plans for 2015!
Post by: HaRuMaN on April 14, 2014, 10:36:04 am
Yeah, I have to thank yots for all the help, he made it a lot easier (and brought me 5 Guys burger for dinner) to stay all weekend long.   :cheers:
Post by: HaRuMaN on April 14, 2014, 10:37:31 am
Lol.  I brought the good camera.  No potato cell phone cam!
Post by: yotsuya on April 14, 2014, 10:54:07 am
Yeah, we had a good time. The "Thong Alert" was my favorite!
Post by: HaRuMaN on April 14, 2014, 10:57:16 am
That was epic
Post by: Generic Eric on April 14, 2014, 11:04:36 am
:P
A live blog of Zapcon would have been cool.  Or even pictures.
I noticed on the website that a vendor could get free booth space if they brought 10 machines.  Are there 10 BYOAC members in driving distance for a booth next year?  (I'm not within driving distance)
Post by: Rick on April 14, 2014, 11:05:01 am
I hereby rescind by request for pics, if any of these include Haruman or Yotsuya in a thong.
Post by: HaRuMaN on April 14, 2014, 11:19:48 am
Twas not us.
Post by: yotsuya on April 14, 2014, 11:24:43 am
Trust me, it was a chick, and you should have see DAT ASS attached to it!
Post by: Rick on April 14, 2014, 11:27:22 am
Was it, perchance, a "Booth Babe"? Or, just some girl with a visible thong?
Post by: yotsuya on April 14, 2014, 11:32:50 am
Option B. I actually know a booth babe and tried to get HaRuMaN to hire her, but this year's budget didn't allow for it. Look for his Booth Babe Kickstarter next spring!
Post by: deadmoney5 on April 14, 2014, 12:05:42 pm
I wish I was closer...sound slike a blast.
by the way, that Galaga is so ---smurfing--- awesome!  I just HAD to order one..with the artwork..
That Donkey Kong is awesome, too.
So many talented people out there making this hobby great long after arcades have come and gone.  Good news for people like me with ZERO artistic and woodworking skills.  Being 44, I've spent countless quarters in actual arcades back in the day.  I like the new games as much as anyone, but there is still something special about firing up a game of Galaga or DOnkey Kong.
Post by: HaRuMaN on April 14, 2014, 12:08:50 pm
The Galaga was a crowd favorite, people really dug the artwork & the form factor.  I tried to keep as close to the original Midway profile as possible.   :cheers:
Post by: engg100 on April 14, 2014, 04:51:13 pm
Glad to hear that the show went well!
Just to let everyone know, the Howlers are NOW SHIPPING! Pick one up at: http://www.wolfwaretech.com/ (http://www.wolfwaretech.com/) or http://www.paradisearcadeshop.com/search?controller=search&orderby=position&orderway=desc&search_query=howler (http://www.paradisearcadeshop.com/search?controller=search&orderby=position&orderway=desc&search_query=howler)
I hope everyone is as excited as I am about them!
Josh
Post by: HaRuMaN on April 14, 2014, 04:53:43 pm
Josh
I have some pics & video of the howler in action, will get that up soon.
Post by: yotsuya on April 15, 2014, 12:33:26 pm
Hey man, where's my top secret project that we discussed at ZapCon at?  >:D
Post by: Rick on April 15, 2014, 12:35:41 pm
Haruman Customs Thong? CafePress is almost complete.
 >:D
Post by: yotsuya on April 15, 2014, 12:43:25 pm
 >:D
I have an awesome thong model HaRuMaN COULD use if he went that route, but this is something definitely different...
Post by: HaRuMaN on April 15, 2014, 12:52:19 pm
Shooon!
Post by: yotsuya on April 15, 2014, 01:42:59 pm
Shooon!
You got those measurements, right? I was as precise as I could be. Precision is going to be critical.
Post by: Rick on April 15, 2014, 01:56:24 pm
(http://media.tumblr.com/tumblr_lp5mjpa3t81qh2pxo.gif)
"Do you want a thong? Because that's how you get a thong!"
Post by: yotsuya on April 15, 2014, 02:09:38 pm
(http://i1.cpcache.com/product/195739830/canadian_beaver_classic_thong.jpg?color=White&height=460&width=460&qv=90)
Once you get it designed, HaRuMaN, let me know the dimensions so I can order the vinyl.
Post by: HaRuMaN on April 15, 2014, 02:30:21 pm
(http://cdn.niketalk.com/4/44/44ae2003_bth_threadderailedsu2.gif)
Post by: yotsuya on April 15, 2014, 03:14:23 pm
I am, it's Rick who's fascinated with thongs!
Hey, regarding retainers, plan one type as slot cut, the other as using original parts. Regarding power, on the one I built, I didn't cut a slot for a cord. I think a small cutout notch on the bottom back would suffice. It's better than using an IEC connector. Much smaller.
Any chance the tops could be black melamine and the sides raw MDF for painting/vinyl application? 1/2 or 3/4?
Post by: HaRuMaN on April 15, 2014, 03:17:17 pm
hmm... interesting ideas...
Post by: yotsuya on April 15, 2014, 03:27:18 pm
Yeah, see, that would be perfect for 95% of the projects out there.
Post by: Malenko on April 21, 2014, 10:30:58 am
mannnnnn raw sucks for paint and vynil. I have a V1 kit done  (Bonnie's Pink Box) and 1 in progress (still) Bobby's TMNT project, if the parts weren't held in with batons , the thing I'd hate most would be the sides. Took a lot of work to get the sides super smooth on both cabs. Ive now done a couple V2+ cabs and the vinyl goes on the sides perfectly with a nice smooth melamine surface.
Post by: yotsuya on April 21, 2014, 10:35:45 am
True, but I've used automotive primer with great results. This project we've discussed is going to be out of 3/4 MDF for best flexibility.  :cheers:
Title: Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
Post by: HaRuMaN on April 21, 2014, 10:39:18 am
Yup yup...
Post by: yotsuya on April 21, 2014, 10:43:36 am
Yup yup...
That reminds, me, where the hell is my top secret project?
Post by: Rick on April 21, 2014, 01:11:22 pm
... MDF for best flexibility.  :cheers:
I wonder where we've heard that thought before...
Post by: TKW4rr10r on April 22, 2014, 04:50:00 pm
Since we are off-topic....
I'm sick of your avatar.
(http://i.imgur.com/dClPNGc.gif)
I always catch myself watching the gif cycle at least a few times whenever I get updates on this thread. where the hell is that from?
 ;D ;D Keep up the awesome work  ;D ;D
( PS - I am fully aware of the opportunity to change said avatar and make this comment look potentially dangerous. I regret nothing. )
Post by: HaRuMaN on April 22, 2014, 04:58:51 pm
Hmm, what's that you say? ;)
Techno Viking, check youtube.   :afro:
Post by: Slippyblade on April 22, 2014, 05:24:26 pm
Google up techno-viking
Post by: yotsuya on April 22, 2014, 05:29:42 pm
Yeah, it sounds funny, but I enjoy watching that dude dance.  :laugh2:
Post by: Rick on April 23, 2014, 08:22:26 am
Since we are off-topic.... I'm sick of your avatar.
How can you hate it, when there are SO MANY OF THEM!!! IT'S HYPNOTIC!!!
(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)(http://i.imgur.com/dClPNGc.gif)
Post by: yotsuya on April 23, 2014, 02:44:16 pm
I imagine Rick was dancing like that when his first set of kits was finished.  >:D
So when can I pick up the prototype for Top Secret Project?
Post by: HaRuMaN on April 23, 2014, 02:45:53 pm
Just picked it up today... should be ready for you on Monday.   :cheers:
Post by: yotsuya on April 23, 2014, 02:53:56 pm
(http://clutch.mtv.com/wp-content/uploads/2011/01/beavis-and-butthead-dance.gif)
Damn, from casual conversation to working prototype in only a week and a half!
Post by: HaRuMaN on April 23, 2014, 02:55:09 pm
Yup!  I gotta tweak one for myself, should be pretty sweet.  Even have a place picked out for it.   :cheers:
Post by: yotsuya on April 23, 2014, 02:56:00 pm
Nice. Let me know if you need a SKU for the illumination.
Post by: yotsuya on April 23, 2014, 02:57:07 pm
Oh, yeah, forgot to tell you, I ordered the vinyl for the sides last night. I already have some for the top.
Post by: HaRuMaN on April 23, 2014, 02:57:35 pm
Yeah, let me get that...
Post by: yotsuya on April 23, 2014, 03:01:06 pm
Hmmm... can't find it online, but I'm stopping at the store after work today to pick one up anyway, so I'll get it for you then.
Post by: Rick on April 23, 2014, 03:02:39 pm
Get a room, you two. (I swear, it's like old people doin' it in here.)
Post by: yotsuya on April 23, 2014, 03:04:11 pm
We know you like to watch, Rick.  >:D
Post by: HaRuMaN on April 23, 2014, 03:11:21 pm
 :scared
Post by: Rick on April 23, 2014, 03:18:58 pm
(http://static6.businessinsider.com/image/50dc7d68ecad04342000000e/the-overly-attached-girlfriend-explains-what-its-like-being-a-wildly-popular-internet-meme.jpg)
Post by: HaRuMaN on April 23, 2014, 03:20:47 pm
Oh dear god
Post by: deadmoney5 on April 28, 2014, 12:35:47 pm
What's the usual turnaround on the bartops after ordering?
just wondering ;D
Post by: HaRuMaN on April 28, 2014, 01:23:43 pm
just wondering ;D
Yours is going out today.   :applaud:
Post by: Rick on April 28, 2014, 01:40:31 pm
(http://memecrunch.com/meme/IXYL/if-you-would-just-answer-the-question/image.png)
Post by: HaRuMaN on April 28, 2014, 01:46:42 pm
"Faster than it takes Rick to make a Galaga bartop"
Post by: yotsuya on April 28, 2014, 01:48:55 pm
(http://images.sodahead.com/polls/000934111/Misc_OhSnap_Bear_answer_2_xlarge.jpeg)
Post by: deadmoney5 on April 28, 2014, 02:08:59 pm
just wondering ;D
can't wait!  :cheers:
Post by: Rick on April 28, 2014, 02:32:54 pm
The words "proper looking" are strategically missing from your comment, I see.
:P
Post by: HaRuMaN on April 28, 2014, 03:18:07 pm
:P
I dunno, I think mine looks more like an original Galaga myself (minus the minty green T-molding).
Post by: pbj on April 28, 2014, 04:39:24 pm
Each of you can send me a kit and I'll be happy to share my professional opinion.
Post by: deadmoney5 on May 07, 2014, 10:21:49 am
So when applying the vinyl stickers to the bartop, do you guys just have a spray bottle with water and a couple drops of soap?  Then spray the wood and sticker?
DO you need a squeegee as well?
Post by: HaRuMaN on May 07, 2014, 10:44:03 am
I use a small spray bottle with water and a drop of dawn.  Spray the top of the wood till it's wet, apply the sticker on top, get it aligned, and then use something to squeeze the water out towards the edges.  I use a hard squeegee, one of the yellow ones from here:
http://www.tapplastics.com/product/window_films/tools_supplies/tap_squeegees/316 (http://www.tapplastics.com/product/window_films/tools_supplies/tap_squeegees/316)
Post by: deadmoney5 on May 12, 2014, 11:41:34 am
Do you cut the control panel so that there is extra hanging over edges, then once everything dries, cut that excess off?  I just don't want to have the edges lifting up once everything dries.
Sorry for the newb questions..I've never applied artwork to a control panel before, and I only have ONE shot :(
Post by: HaRuMaN on May 12, 2014, 11:43:27 am
Yes, the sticker has some excess to trim.  The excess in the front you can fold down and let the T-molding hold it in.
Post by: Malenko on May 12, 2014, 12:09:13 pm
"Faster than it takes a proper looking Rick to make a Galaga bartop"
:P
There, I fixed it.
Post by: deadmoney5 on May 15, 2014, 12:43:26 pm
in case others are wondering about the T-molding, it is VERY easy to trim the excess t molding on the 1/2" wood.  I actually ordered this http://www.amazon.com/Quad-Trimmer-Carbon-Steel-Blades/dp/B000WULWX2 (http://www.amazon.com/Quad-Trimmer-Carbon-Steel-Blades/dp/B000WULWX2)
and it was a waste of money for me.  I started using it and the cuts were not consistent at all, so i used a sharp exacto knife to fix...then I realized that the exacto knife worked better ::)
With a sharp exacto knife, trimming the excess T molding is very fast and clean.
Post by: jayfrost on May 17, 2014, 07:59:36 pm
What size tmolding did you trim.  I have used 1/2 black and white, but now i want to use a red color and cannot find 1/2 in red.
Post by: deadmoney5 on May 18, 2014, 12:07:07 pm
I think mine was 3/4".  So there was excess to trim on both sides of the bartop.
Post by: jayfrost on May 18, 2014, 02:26:19 pm
Does the 3/4 provide a smooth finish?  Any pictures.  Just curious before calling.
J
Post by: deadmoney5 on May 18, 2014, 05:31:23 pm
J
Yes..very smooth.  Just look at the galaga and ms pacman bartops that were made.  The t molding on those was trimmed to fit the 1/2" wood.  Looks fine.
Post by: HaRuMaN on May 20, 2014, 01:09:35 pm
Due to popular demand, redesigned the Defender bartop to be a little slimmer, I think this looks better as well:
(http://i.imgur.com/rMZDBqV.png)
(http://i.imgur.com/kR8hkzD.png)
Post by: jayfrost on May 20, 2014, 10:53:46 pm
Working on finishing my widebody bartop!  Its a beast and I love it, but having to do a few custom tweaks in order to ventilate it enough for the PC.  Got the art finished and will be sending to printer soon.  Based off the awesome Streetfighter Cab here http://forum.arcadecontrols.com/index.php/topic,84649.msg886549.html#msg886549 (http://forum.arcadecontrols.com/index.php/topic,84649.msg886549.html#msg886549).  Any feedback on the art?
Post by: yotsuya on May 21, 2014, 12:15:51 am
You got the Ultimate Xbox cabinet? Sweet.
Post by: Malenko on May 21, 2014, 08:30:20 am
is it sponsored by Hyperspin?
Post by: deadmoney5 on May 21, 2014, 10:59:09 am
What are you guys using for speakers?  The only ones I saw with detachable volume were ones with subs.
Post by: HaRuMaN on May 21, 2014, 11:04:38 am
I use little USB powered speakers mostly
Post by: deadmoney5 on May 21, 2014, 11:43:56 am
So you don't care about the volume?  DO you just adjust in MAME or whataver software you are using?
Post by: HaRuMaN on May 21, 2014, 12:17:28 pm
I open the back up and adjust the volume knob on the speaker if I have to
Post by: jayfrost on May 21, 2014, 07:38:56 pm
Actually, the hyperspin logo is just the sample I used for my buddy....I have a custom name on mine, "Frostcade"   Same look as the hyperspin logo, but my friend wants me to build one for him called "SheepCade"  Not sure about that, but to each their own!
Post by: deadmoney5 on May 22, 2014, 10:31:23 am
I just ordered these..real cheap plus a detachable volume control
http://www.adafruit.com/products/1363 (http://www.adafruit.com/products/1363)
Post by: HaRuMaN on May 22, 2014, 10:35:31 am
Nice, good price too.  I imagine you can crack that volume control piece in half and get a rod onto the volume pot
Post by: deadmoney5 on May 22, 2014, 11:22:50 am
you mean to hook up to a button?
Post by: HaRuMaN on May 22, 2014, 12:13:01 pm
to hook up to a knob
Post by: HaRuMaN on May 29, 2014, 05:40:35 pm
Finally got some artwork up on my new widescreen design (thanks to Malenko!):
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=309619;image)
Closeup of the marquee so it's not washed out by the camera:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=309621;image)
Another shot:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=309623;image)
Post by: jmike on May 29, 2014, 09:02:43 pm
Very cool. That artwork is sweet!!
Malenko you got some skill bro.
Post by: Rick on May 30, 2014, 10:09:55 am
How much for a "Hyper Fighting Haruman"?
Reminds me of this:
PSY - GENTLEMAN M/V (http://www.youtube.com/watch?v=ASO_zypdnsQ#ws)
 :laugh2:
Post by: HaRuMaN on May 30, 2014, 10:11:39 am
Reminds me of this:
 :laugh2:
You can't afford me  :-*
Post by: Malenko on May 30, 2014, 10:20:04 am
You do realize that normally the CAPCOM logo is there right?
(http://edeveaud.free.fr/tmp/Street%20Fighter%20II%20Champion%20Edition/Street%20Fighter%202%20Champion%20Edition%20Turbo%20Hyper%20FIghting%20Marquee.tif.jpg)
Post by: Rick on May 30, 2014, 10:31:20 am
Of course. I just thought it was ... amusing ... to place it there.
Post by: Malenko on May 30, 2014, 10:37:34 am
juuuuuuust checkin, like Tekken.
I thought I did a pretty good job recreating the marquee and CPO from scratch.  The CPO was such a pain in ze deitch!
Post by: deadmoney5 on June 02, 2014, 09:49:07 am
I finally was able to apply the Galaga artwork for the Midway Vertical bartop.  This made me nervous, considering it was my first time doing this.  As you can see, I was a hair off on aligning the button holes, but it looks kinda cool.
Post by: deadmoney5 on June 02, 2014, 09:51:52 am
 I used an old Ipac 2 I had from my previous build.
Props to Haruman for precision cuts!
Post by: Malenko on June 02, 2014, 09:52:19 am
get some red vinyl and punch out some red rings, put the red rings around the button holes.
Post by: deadmoney5 on June 02, 2014, 09:53:33 am
hmm...good idea :applaud:
Post by: HaRuMaN on June 02, 2014, 11:21:39 am
What stick is that again?
Post by: yotsuya on June 02, 2014, 11:22:34 am
Looks like GGG's Pac-Pro Leaf Stick, which is an awesome stick!
Post by: deadmoney5 on June 02, 2014, 11:33:15 am
bingo..great stick, indeed!
Post by: yotsuya on June 02, 2014, 12:30:09 pm
Yep - I need to get a second one for my cocktail cab. I have one on P1, and a Happ Reunion on P2.
Post by: HaRuMaN on June 02, 2014, 12:39:24 pm
I have some red vinyl on hand could cut you out some if you like.
Post by: deadmoney5 on June 02, 2014, 04:14:28 pm
wow..you don't have to do that..  that would be awesome though!
thanks!
Post by: HaRuMaN on June 02, 2014, 04:15:10 pm
thanks!
No problem, I'll get some cut out for you
Post by: suprastan on June 04, 2014, 08:55:02 pm
Im interested in picking one of these up but does anyone know if there is art already available for these? I dont have time to design just want to send the art to a printer and be done :)
Let me know
Post by: Malenko on June 04, 2014, 09:40:18 pm
Haruman has some art, anything specifically you need made?
Post by: deadmoney5 on June 05, 2014, 10:23:24 am
Let me know
When I bought the Midway bartop, I was able to buy Galaga artwork from him as well (I think the artwork is provided by Malenko?).  Top notch stuff.  Everything was scaled to fit the bartop perfectly.  I should be done with everything soon, and I will will post pics.
Post by: HaRuMaN on June 05, 2014, 10:33:40 am
Just let me know what you need...
Post by: yotsuya on June 05, 2014, 10:51:02 am
(I got China White, Mother of Pearl, Ivory Flake, What you need?)
(Well yeah, well let me check it out man, just let me get a freeze)
 (Go ahead man, stuff I got should kill ya!)
 (Yeah man th-that’s that’s raw, wuh)
 (Freeze! Haha ha ha! Rock! Freeze! Rock! Freeze! Rock!
 Freeze! Rock! Freeze! Rock! Freeze! Rock!)
Post by: HaRuMaN on June 08, 2014, 03:37:20 pm
I ended up cutting an extra standard bartop (weecade).  It's ready to go if someone wanted to order one.
Post by: deadmoney5 on June 08, 2014, 07:05:49 pm
What have some of you used to attach control panel?  Velcro didnt work too well for me..maybe a hinge from the inside?
Post by: Malenko on June 08, 2014, 07:26:32 pm
Ive always used industrial velcro without a problem.  You could use hinges, or magnets, or screws, or.....tons of options.
Post by: HaRuMaN on June 09, 2014, 02:49:14 pm
I use industrial velcro and it actually holds really well.
Post by: HaRuMaN on June 09, 2014, 02:50:18 pm
Any interest in an already assembled V1 weecade (MDF) or a V2 weecade (Black Melemine)?  I need to get some stuff out of my gameroom.  Let me know.
Post by: mann0mann on June 11, 2014, 09:48:42 pm
Haruman, could you send me an email with what you have and want to sell, I might be interested.
mike@htubayarea.com
Or if your into anything radio control, I own a hobby store.  Maybe we could trade?
Post by: HaRuMaN on June 12, 2014, 10:02:58 am
mike@htubayarea.com
Email sent!
Post by: Rick on June 12, 2014, 10:26:08 am
Email sent!
If I see a fleet of helicopter-delivered Haruman bartops flying while hearing Flight of the Valkyries play, Imma gonna lose my ---steaming pile of meadow muffin---.
Post by: HaRuMaN on June 12, 2014, 10:28:44 am
Email sent!
Get out of my head!
Post by: Rick on June 12, 2014, 10:36:50 am
Get out of my head!
I know what you really want.
David Hasselhoff - Jump In My Car (http://www.youtube.com/watch?v=dm7jEA3frY4#ws)]https://www.youtube.com/watch?v=dm7jEA3frY4
Post by: HaRuMaN on June 12, 2014, 10:41:46 am
I hate you for making me know that exists...  :banghead:
Post by: deadmoney5 on June 16, 2014, 02:41:16 pm
I actually used 3M Dual Lock instead of Velcro.  Worked much better for me.  Once everything "snaps" into place, the panel doesn't move at all.
Post by: HaRuMaN on June 17, 2014, 10:30:53 am
So I have an extra weecade (standard bartop) on hand due to ordering one to many. If someone purchases it today, I'll throw in a free T-shirt!   :burgerking:
Post by: yotsuya on June 17, 2014, 10:44:07 am
What size do you wear, James?
Post by: Rick on June 17, 2014, 10:49:26 am
Get one! Now, you too can look like Haruman!
(http://s3.amazonaws.com/rapgenius/wifebeater.jpg)
Post by: yotsuya on June 17, 2014, 10:52:03 am
I hear Rick's giving away free toques.  >:D
(http://media-cache-ak0.pinimg.com/736x/70/a3/4f/70a34ffb0de3af71fa56465c3f94a2cb.jpg)
Post by: HaRuMaN on June 17, 2014, 11:01:46 am
His toques supplier shut him down, he's currently looking for a new one.
Post by: yotsuya on June 17, 2014, 11:17:46 am
(http://3.bp.blogspot.com/-c0WFYe7yGEs/Um8p9w-RDhI/AAAAAAAAOaA/YaspI3zAruI/s640/Snap-92261843265.jpg)
Post by: Rick on June 17, 2014, 01:19:59 pm
Careful. It could happen to you!
(http://deadhomersociety.files.wordpress.com/2010/08/homerpalooza1.png)
Post by: Brian74 on June 17, 2014, 02:22:02 pm
So who is going to be the first one to make a funglo pedestal?
Post by: HaRuMaN on June 17, 2014, 02:27:45 pm
Already have.
Post by: HaRuMaN on June 17, 2014, 03:22:28 pm
For Rick's enjoyment:
(http://i.imgur.com/SgBEYox.jpg)
Post by: HaRuMaN on June 17, 2014, 03:34:34 pm
Also, when I order an odd number of kits, my CNC guy fills the remainder of the sheet with another kit.
So I do have a Nintendo and a Vertical ready to go with a quickness.
Post by: Rick on June 17, 2014, 04:11:10 pm
It's ... okay. (Sorry - it's certainly nothing against your professional work. I'm just not a fan of the original design it's fashioned after.)
Post by: DJMattB241 on June 18, 2014, 01:12:30 pm
Haruman,
I've got a killer (and probably already done elsewhere, haha) idea for a cabinet, but need someone to... you know... make it and then sell it to me for monies.
So... do I send you a PM? :)
Post by: HaRuMaN on June 18, 2014, 02:01:06 pm
Haruman,
Yes indeed!  PM me your email address and we can talk.
Post by: Brian74 on June 18, 2014, 08:18:13 pm
Already have.
I havent seen it, and I am looking to get one.
Post by: HaRuMaN on June 18, 2014, 09:23:48 pm
Already have.
I'll post some pics...
Post by: Brian74 on June 28, 2014, 02:26:00 pm
Already have.
Bump
Post by: HaRuMaN on June 30, 2014, 02:39:27 pm
Here are some I snapped, the customer is going to send me some pictures of it completed tonight.
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=311678;image)
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=311680;image)
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=311682;image)
Post by: HaRuMaN on July 03, 2014, 02:08:00 pm
Some CNC pron for you:
Cutting the Ultimate Widescreen Kit (http://www.youtube.com/watch?v=7R34nVo2Fhg#)
Second video is a little more interesting...
Cutting the Ultimate Widescreen Kit Part 2 (http://www.youtube.com/watch?v=bPZBcM4JWEM#)
Post by: fantoboy on July 08, 2014, 12:02:42 pm
I have one of the early 2 player wide kits.  I wanted to do Sanwa buttons, but they're too shallow.  Are the Seimitsu screw buttons a good alternative? and these should fit fine, right?
http://www.focusattack.com/seimitsu-ps-14-gn-screwbutton-white/ (http://www.focusattack.com/seimitsu-ps-14-gn-screwbutton-white/)
Post by: pbj on July 08, 2014, 12:12:55 pm
How much are the pedestals?  PBJ budget friendly or do you need to be in the Kaneda tier to afford one?
Post by: HaRuMaN on July 09, 2014, 09:11:00 am
Define PBJ budget friendly?   :D
They are definitely nowhere near Kanada price...
Post by: Rick on July 09, 2014, 10:04:43 am
(http://www.routinezero.co.uk/wp-content/uploads/2012/11/PIMP_BLING_BLING_by_DNL87.jpg)
Post by: pbj on July 09, 2014, 08:14:37 pm
Still waiting on a quote
Post by: bmfrosty on July 10, 2014, 12:01:39 pm
That pedestal is damn sexy.
Post by: mvsfan on July 14, 2014, 07:51:03 pm
I notice that a "barstick" is your least expensive option. what does that consist of?
Post by: deadmoney5 on July 14, 2014, 08:38:07 pm
My Galaga bartop ...
Post by: deadmoney5 on July 14, 2014, 08:58:12 pm
another
Post by: deadmoney5 on July 14, 2014, 08:59:02 pm
still more
Post by: HaRuMaN on July 14, 2014, 09:58:03 pm
Looks great man!!!  :cheers: That reminds me I've been slacking and need to get you those button rings.  I'll make em Friday and mail them to you.   :applaud:
Post by: deadmoney5 on July 15, 2014, 09:28:34 am
ha.  I forgot about that!  I was getting used to the off-center look!
Post by: HaRuMaN on July 15, 2014, 09:41:23 am
It's basically a stand alone controller with space for a marquee.
Post by: HaRuMaN on July 16, 2014, 09:55:34 am
Currently working on a Funglo - styled pedestal for a customer, this will get added to the lineup as well:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=312554;image)
Post by: HaRuMaN on July 16, 2014, 10:01:17 am
Previous pedestal kit concept:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=312556;image)
To reality:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=139979.0;attach=311738;image)
Post by: pbj on July 16, 2014, 11:14:38 am
You'd be better off hinging an opening on the front and adding shelves inside.  The areas underneath players 3 and 4 are excellent stool storage.
Post by: Rick on July 16, 2014, 11:17:18 am
Shh! Come post this stuff in my thread! Don't give him any more ideas!
Post by: HaRuMaN on July 16, 2014, 11:19:16 am
That's not a bad idea...
Those outer shelves just attached with dowels, so easy enough to delete them from the design.
Post by: pbj on July 16, 2014, 12:54:00 pm
It was an unintended bonus when I built my pedestal.  Where to put the stool?  Well... shoot... fits right under there.  Looks planned.
I can't afford anything the two of you make, but I can intercede in a bad design.
EDIT: which one of you will be the first to add an accompanying stool to your flat packs?   :lol
http://www.ikea.com/us/en/search/?query=stool (http://www.ikea.com/us/en/search/?query=stool)
Post by: hiljak on July 16, 2014, 08:33:30 pm
how much for the funglo style?  My dad and I were planning to build simple one based on some plans posted to over clockers forums but I like what I see in this thread.
Here's the plans for the simple two player unit you may consider doing as well:
http://forums.overclockers.com.au/showthread.php?t=1012016 (http://forums.overclockers.com.au/showthread.php?t=1012016)
Post by: yotsuya on July 16, 2014, 09:56:59 pm
The name Funglo turns me off.  :D
Post by: HaRuMaN on July 17, 2014, 09:44:53 am
I have to get the quote from my CNC (and figure out how much it weighs)... but I would guess in the $500-600 shipped range.
Post by: HaRuMaN on July 17, 2014, 10:06:48 am
Completed customer widescreen cabinet:
NINtendo Arcade Cabinet (nine inch nails themed) (http://www.youtube.com/watch?v=z47bV8Pd4Zo#ws)
Post by: pbj on July 17, 2014, 10:12:18 am
 :puke
Post by: Rick on July 17, 2014, 12:50:48 pm
:puke
To each his own. I'm a fan of Nine Inch Nails myself - although I wouldn't go so far as to model a cab after it.
Post by: Brian74 on July 18, 2014, 03:58:40 pm
:puke
+1
Post by: pbj on July 18, 2014, 04:06:19 pm
I liked Pretty Hate Machine, but the rest is lost on me.  This is coming from someone that's listened to industrial music for 20 years.
Post by: Rick on July 18, 2014, 04:19:42 pm
I liked Pretty Hate Machine, but the rest is lost on me.  This is coming from someone that's listened to industrial music for 20 years. :cheers:
So, when can we expect your Ministry themed cab, amirite?
(F all y'all. I know I'm old.)
Post by: yotsuya on July 18, 2014, 04:31:46 pm
Very few people know that Rick has a Bryan Adams/Glass Tiger-themed bartop in the works...
Post by: Rick on July 18, 2014, 04:32:17 pm
Don't Stop Believin'! (..and it's a Gowan cab.)
Post by: g_block247 on July 19, 2014, 09:55:59 pm
Haruman, PM incoming. I have my ideal classic arcade stick in mind thanks to deadmoney5 posts on page 40. If you don't do what I'm proposing, I understand :)
Post by: deadmoney5 on July 24, 2014, 05:26:28 pm
hmmm. do share!
Post by: g_block247 on July 25, 2014, 01:14:23 pm
hmmm. do share!
since doing a cab is out of the question for me for the forseeable future, and I would like to play all the classics with a true 4-way setup w/ some classic art (via MAME), I'm getting a quote on a custom stick that's laid out basically like your Galaga panel on your bartop (complete with credit button on the front) . Except with a different art (I'm kind of partial to Pac-Man myself, but I threw some other potential ideas his way). If/when we close the deal and I receive it (or if he wants to post after finishing) pics will be posted :)
Post by: HaRuMaN on July 25, 2014, 01:19:04 pm
Post by: Malenko on July 25, 2014, 01:42:50 pm
welp he has full on pacman, mspacman, galaga, galaxian, defender, and mspac/galaxian reunion art already made ; I know because I made them  :afro:
Post by: Rick on July 25, 2014, 02:16:25 pm
But did you make them formatted for a Haruman Certified Game... ...stick? Is that what we're calling it?
Post by: Malenko on July 25, 2014, 02:18:42 pm
Im sure I will be.  You get your Galaxian built yet?
Post by: Rick on July 25, 2014, 02:21:31 pm
I've got a buttload of 'work work' to finish, but late last night, I got the sides assembled and glued up. Tonight, I hope to complete the case assembly and art installation.
:D
Post by: RetroGreg on July 25, 2014, 03:12:41 pm
Do you have any pics of the reunion art? I bet that's pretty cool.  ;D
Post by: HaRuMaN on July 25, 2014, 03:14:41 pm
Give me a few and I'll mock it up onto the vertical kit
Post by: HaRuMaN on July 25, 2014, 03:40:13 pm
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=313162;image)
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=313164;image)
Post by: HaRuMaN on July 25, 2014, 03:56:27 pm
And Galaxian:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=313168;image)
Post by: RetroGreg on July 25, 2014, 04:57:24 pm
Wow, those are both awesome! I really like the lines on that bartop design.
Thanks for posting that  :cheers:
Post by: deadmoney5 on July 28, 2014, 10:41:41 am
awesome work!
I am very happy with how mine turned out.
Now I may have to get a dedicated 8 way bartop to match!
I'm sure the gal won't mind ;D
Post by: g_block247 on July 28, 2014, 05:25:16 pm
I think I found my art for my 4 way MAME stick by HaRuMaN :D
Post by: HaRuMaN on July 28, 2014, 07:20:08 pm
Oh yeah?  :)
Post by: g_block247 on July 29, 2014, 06:14:57 am
Oh yeah?  :)
The Ms Pac Man/Galaga you just posted. It accompanies two of my favorite classics and they are both in the 4 way catagory. I could go with something cheesy like a multicade art, but that looks really good :)
Post by: xtconcepts on August 07, 2014, 12:34:30 pm
any updates on this funglo style cab?
Post by: HaRuMaN on August 07, 2014, 12:48:48 pm
I just need to send the design off to the CNC shop to get a price :)
Post by: xtconcepts on August 09, 2014, 02:03:15 am
That sounds great. shoot me a pm pls.   ;D
Post by: rablack97 on August 10, 2014, 10:20:11 pm
+1 :applaud:
Post by: HaRuMaN on August 15, 2014, 04:52:49 pm
Customer request:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=314467;image)
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=314469;image;image)
Cabinet is going to be cabinet grade baltic birch plywood, control panels will be MDF
Post by: HaRuMaN on August 15, 2014, 05:08:33 pm
Variation on the Funglo:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=314471;image)
Post by: Brian74 on August 16, 2014, 11:28:19 am
Post by: Rick on August 16, 2014, 05:30:15 pm
What's the idea behind the speakers? (Are those holes for speakers?) Aren't people meant to be playing this on their existing TV, which I'm assuming, already have some type of sound?
Post by: rablack97 on August 19, 2014, 08:46:51 pm
Its to make the sound more up close and personal and all in one portable.  I did the same thing for the VISION BOX. (http://forum.arcadecontrols.com/index.php/topic,133965.msg1380687.html#msg1380687)
It gives you the option of using your soundsystem or just the onboard speakers.
For instance say you wanna hook this up to a projector for an outdoors event...i'd rather not have to lug around speakers and a receiver.  Looks like theres space at the bottom for a subwoofer too, perfect 2.1 setup.  I like it....
I know i'm getting one, I have a small projector i'd like to put inside it and throw a 300" picture of some ms. pacman on a outdoor screen.....
Post by: yotsuya on August 19, 2014, 10:05:08 pm
So what is that called? A Funglo Plus?  :puke  >:D
Post by: rablack97 on August 19, 2014, 11:26:31 pm
(http://www.gagful.com/uploads/2011_11/1321051666_haters_gonna_hate_gag.jpg)
Get on DEEEZZZZZZZ nuuuuhhhhhuuutttzzzzz
(http://media1.giphy.com/media/QUOs7hGpn6PS/giphy.gif)
Post by: yotsuya on August 19, 2014, 11:29:50 pm
I can't stay mad when that dude PUMPS UP THE JAM!!!
I did some research - that guy doesn't have a "Peanuts" name. In honor of this thread, I'm naming him "Funglo".
Post by: yotsuya on August 19, 2014, 11:31:50 pm
Sometime in the future:
Saint got Tapatalk working!!!!
(http://awesomelyluvvie.com/wp-content/uploads/2013/01/CharlieBrownDance2.gif)
Post by: Brian74 on August 20, 2014, 06:27:32 am
I worked with HaRuMaN on that second version.  The original has the speakers inside the cp firing down. So I came up with the idea of mounting them like that. The opening in the center is for either a marquee or a second screen.
Post by: rablack97 on August 20, 2014, 10:13:55 am
+1 all in fun bro,  :cheers:
Post by: wp34 on August 21, 2014, 09:36:37 am
I missed the "sometime in the future" disclaimer and briefly starting doing that dance.  Sigh.
Post by: Malenko on August 21, 2014, 10:10:44 am
Do these come with instructions?
Post by: HaRuMaN on August 21, 2014, 10:16:45 am
Not for you... and just for you, I'll leave one piece out...   >:D
Post by: Rick on August 21, 2014, 10:18:52 am
I see a new signature in my future.
>:D
Post by: HaRuMaN on August 21, 2014, 10:19:54 am
>:D
I think it's about time I make you a custom title... hmm...   >:D
Post by: Rick on August 21, 2014, 10:28:23 am
Careful now. You don't want Saint making me your Boss. ;)
Post by: pbj on August 21, 2014, 10:37:00 am
If you want a piece left out, order from bartop arcades.
Post by: Malenko on August 21, 2014, 10:40:36 am
SHILL!
Post by: pbj on August 21, 2014, 10:44:43 am
Not particularly.  Only business I've done with Haruman that I can recall is buying a pair of Xbox controllers that didn't work.
Post by: Malenko on August 21, 2014, 10:46:00 am
Factual evidence has no bearing on the subject. Me calling you a shill literally has nothing to do with you.  :cheers:
Post by: yotsuya on August 21, 2014, 10:53:33 am
(http://static.gamespot.com/uploads/original/255/2550934/2366080-4111340865-oh_sn.png)
Post by: Rick on August 21, 2014, 10:57:41 am
I would just like to clarify that this is NOT ME he's talking about.
Post by: HaRuMaN on August 21, 2014, 10:58:47 am
Still not letting that go, eh?
Post by: lowgunn on August 21, 2014, 01:13:32 pm
so I finally got down to working on the kit from haruman and just wanted to share what I've done so far.  I used a multicolored led light strip to light up and change colors.
Post by: Rick on August 21, 2014, 01:16:45 pm
This looks great! Just as a thought, I too implemented an LED strip with exactly the same execution you did (i.e. wrapping it around the marquee hole) and found it was too bright, and the LED's 'showed through' the marquee itself too much. I opted to trim them down, and placed a single strip across the centre... I trimmed a piece of wood down to the width, so that it was around 3" tall, and wrapped it in tin-foil, with the LED strip glued horizontally across the centre. It created a more uniform glow overall, without the harshness of each little LED.
Just my two cents.
Post by: lowgunn on August 21, 2014, 01:22:21 pm
i'll post it with the marqee once I get it in.   This hobbies like crack, once you start with one you want another ....lol
Post by: HaRuMaN on August 21, 2014, 01:29:54 pm
 :drool
Man that is looking AWESOME.  Love what you did with the kit, the art, the LED's, very very nice!!!   :cheers:
Post by: HaRuMaN on August 21, 2014, 04:18:36 pm
Another customer commission.  Still gotta clean the side art up but you get the idea.   :cheers:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=314871;image)
And
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=314873;image)
Post by: xtconcepts on August 21, 2014, 05:53:50 pm
Orders Open! New Models Available!???
pm me please cuz I can't pm u.. I wanna place a custom order  ;D
Post by: HaRuMaN on August 21, 2014, 05:55:52 pm
PM sent  :cheers:
Post by: RetroGreg on August 22, 2014, 10:12:29 pm
PM sent. I'm finally starting a project this year.  ;D
Post by: lapeters11 on August 26, 2014, 10:01:36 am
Hello! First time poster on here, been lurking a lot, but I finally have a few questions.
I'll get the most annoying one out of the way first: I ordered a ultimate widescreen last week and wondering if there is an estimate on when it will be shipped out!
Now the real question! I want to make some art for it, I have some basic photoshop/illustrator background so I wanted to do it myself. Do you have any templates or something I could use to design since I don't have my kit yet to measure it? I assume you do since I see the cool custom art in this thread already. Also, where do you like to get your art printed? Is there a specific material you use for the control panel, should I do the sandwich style with plexiglass on top of the art?
Just wondering what you have found to work well with your kits. I read through this thread, but I haven't seen much about the ultimate widescreen. Any build logs of people who have used them? Can't wait to start mine!
Post by: HaRuMaN on August 26, 2014, 10:20:30 am
 Hey there, I should be picking up your kit from the CNC either today or tomorrow, and then the slot cutting & packing will take place over the weekend.  It will ship Tuesday, you'll get an email from FedEx with the tracking number.   :cheers:
I can send you some templates to make some art up.  I like to get my art printed at Soul Draw, but they have upped there minimum order, so it may not be economical for you.  I'm usually ordering multiple sets at a time so it works for me.
I just use self adhesive vinyl for the sides & control panel.  I don't cover the control panel with plexi, so far it's been fine.  If this was getting heavy use like in an arcade, then I would.
The ultimate widescreen has been a very good seller lately, but I haven't seen many threads on them.  I can tell you it is set up for Sanwa controls, 2 x JLF joysticks, 6 x 24mm OSBN buttons (screw in) and 16 x 30mm OSBN buttons (screw in).
Post by: lapeters11 on August 26, 2014, 10:45:41 am
Awesome thanks for the quick reply! I look forward to the template so I can get started, already have some ideas bouncing around. I have seen a lot of people using gameongrafix.com, do you think that would work for me?
And maybe I will make a build log for it, since there aren't any others yet. I have never done something like that before though so I will probably wait until I am finished to post it all at once.
Post by: HaRuMaN on August 26, 2014, 11:04:49 am
Gameongrafix should work just fine I would think.
I would like to see a build log.  I do enjoy seeing what people do with my kits.   :cheers:
Post by: HaRuMaN on August 26, 2014, 11:08:04 am
Update on the Berzerk bartop, sideart done, CPO done, control panel adjusted to match the original fire - joystick - fire spacing.  Bezel adjusted slightly for better fit.
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=315207;image)
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=315209;image)
Post by: lapeters11 on August 26, 2014, 11:34:48 am
Cool and thanks.
One last question for now: Do you think Micro ATX will fit ok or should I go mini ITX? I am thinking ITX
Post by: HaRuMaN on August 26, 2014, 11:40:34 am
There is a good amount of room, a fat 360 or PS3 will fit no problem, ATX would be fine.
Post by: IAmDotorg on August 27, 2014, 08:12:19 am
Customer request:
Damn those are cool. ;)
Post by: Malenko on August 27, 2014, 08:14:05 am
and big props to Haruman he did all that art for Berzerk on his own, and he did a pretty great job!  :cheers:
Post by: HaRuMaN on August 27, 2014, 09:35:02 am
I learned from da best!
Post by: lapeters11 on August 27, 2014, 11:00:29 am
It has been a long time since I used photoshop, but I found someone elses art a few pages back and copied it to make myself a template. I think I set the size right. I haven't actually played the new ones yet, but I always loved Soul Edge/Blade/Calibur when I was younger so I decided to use that as my theme. Not sure if I want to put words on my Marquee or not, if I do I will completely redo it. I wish I could've found good artwork from the older games, but the fourth game had the best selection to work with. I really like the sides and the marquee, but a little unsure on the control panel. Is it too random? The colors are the actual button colors I ordered (before I decided on a theme). Like I said I haven't played with any kind of design work in years. Looking for honest criticism.
(http://i.imgur.com/cxS8B70.jpg)
Post by: yotsuya on August 27, 2014, 11:02:47 am
Sides look great, go back to the drawing board on the Marquee and Control Panel.
Post by: HaRuMaN on August 27, 2014, 11:06:09 am
+1.  The collage stuff just is too busy for my eyes and it's distracting.
I have attached some templates to this post, just in case.
Post by: lapeters11 on August 27, 2014, 11:13:25 am
That's what I was afraid of. Back to work. Thanks!
Post by: yotsuya on August 27, 2014, 11:15:14 am
That logo by itself would make a great marquee, btw.
Post by: Rick on August 27, 2014, 11:31:04 am
Agreed, but I'd drop the registered "R".
Post by: lowgunn on August 27, 2014, 02:21:07 pm
I'm thinking of getting another kit ( the ultimate kit and 2 modded wired xbox360 controller).  I plan to put a xbox 360 slim in there and was curious on how you would get  the sync button extended so that I could get player 3 and 4 wireless controllers to be linked when I want to play a 4 player game.  What do you guys think would be the best solution.  I would not want to open the arcade box just to hit the sync button or have 2 dedicated wireless controller for this kit.  thanks in advance.
Post by: HaRuMaN on August 27, 2014, 02:27:02 pm
It's been a while since I looked at that button's guts on the 360...  it should just be a momentary pushbutton, which means it should be able to be wired to a normal arcade button.  I'll take a look & see, but it should be doable.
Post by: Malenko on August 27, 2014, 02:49:40 pm
drill a tiny hole and use a chopstick
Post by: deadmoney5 on August 28, 2014, 09:54:19 am
Did anybody make any bezels that fit your bartops?  Currently all I have for my Galaga is a thick piece of black paper.
Post by: Rick on August 28, 2014, 10:07:43 am
Whenever I build a bartop, I take my design over to Staples for printing. Caution: you need to give them strict dimensions when you have them print it - both for any outside and inside dimension - as their software can generally "shrink to fit" any printing. In Canada, they normally charge $14 for a poster-sized print.
Post by: HaRuMaN on August 28, 2014, 10:15:20 am
Not for the vertical ones yet.  I'm getting better at the photoshop, I can can give it a go and see how it turns out.  What size monitor are you using?  17"?
Post by: Malenko on August 28, 2014, 10:33:23 am
making a bezel can be tricky, since not all monitors have the same size bezel around the screen, and someone could use a 15 or 17 inch monitor instead of a 19 or 20. I can pretty easily design you a bezel for your cab if you give me dimensions
Post by: IAmDotorg on August 28, 2014, 02:00:47 pm
A simpler solution to consider -- I put two USB ports in my cab. For 4 player games, I can just plug in wired XB360 controllers. Easier than wireless, and the USB port is there for a keyboard or thumb drive, as well. The cocktail design he posted a bit ago is mine -- you can see the hole for one of the USB ports under the end control panel in one of them.  If I was doing a bartop, I'd just put one on each side, maybe back towards the rear, so they're out of the way. Its like $20 worth of parts.
Post by: HaRuMaN on August 28, 2014, 02:54:29 pm
The 2 usb ports are going to be taken up by 2 dedicated wired controller hacks for the main cabinet.  Can you plug more than 2 into a 360?
Post by: IAmDotorg on August 28, 2014, 03:20:28 pm
Yup, USB hubs work fine. You actually have four, anyway. There's two in the back and two in the front.
Post by: deadmoney5 on August 28, 2014, 05:02:28 pm
thanks guys..I'm using a 17" Dell monitor in the Vertical cab.
Post by: lowgunn on September 03, 2014, 11:57:22 am
Thanks,  I'll put that in mind.  I didn't know that USB hubs are supported on the xbox 360
Post by: The 414 on September 07, 2014, 07:14:06 pm
I have to say . i just got my cabinet from Haruman,  I have not started building it yet , just opening it for inspection. This guy is the King of shipping. Every piece so far has been packed and protected very well. (sometimes you have to worry when fed-ex has it for a few days) If this is a sign of things to come i am already impressed. Thanks again.
Post by: yotsuya on September 07, 2014, 10:07:59 pm
What did you get, bro?
Post by: samelak on September 10, 2014, 03:00:32 am
I'm really interested in the Nintendo kit. I was scanning through this thread and I only saw the Nintendo cab as a digital picture. Does anyone have a pic of their own completed Nintendo cab to post? Also, I read on the first page that these are supplied as black, but can you possibly supply in the traditional Nintendo colors? I'm thinking the orange or light blue found on Nintendo cabinets. Although I have been restoring cabinets for several years, I never picked up being able to make my own graphics. If anyone can recommend a site or member here, it would be appreciated.
Post by: Malenko on September 10, 2014, 07:42:43 am
Typically the black cab is wrapped in vinyl. It is quite common that , for example, the donkey kong side art piece gets printed with a DK Blue border around it big enough to cover the entire side of the cab.
Haruman offers some art packages, but if there is something you need, it cant hurt to ask. I (and others) have been known to help with art for free.
Post by: HaRuMaN on September 10, 2014, 09:08:37 am
Here is a customer completed cab with the art I printed for him.  I have since lightened the blue up to be more like a DK cab.
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=316096;image)
Post by: samelak on September 11, 2014, 07:01:52 am
[/quote]
That is exactly what I am looking for. Can you even help with the marquee and control panel? How do I contact you on pricing?
Post by: Malenko on September 11, 2014, 07:55:42 am
-1 on your quotefu
Post by: retrogamedude on September 11, 2014, 10:22:38 am
He only accepts short messages via postcards with cute kittens on them
Post by: HaRuMaN on September 11, 2014, 10:29:34 am
I sent you a PM with my email address.
Post by: HaRuMaN on September 11, 2014, 10:29:50 am
Lol.
Post by: HaRuMaN on September 11, 2014, 11:39:07 am
oo.  What could it be?
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=316146;image)
Hmmmmm...
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=316148;image)
 >:D
Post by: Rick on September 11, 2014, 12:29:07 pm
OMG, I know this!!! Is it "overpriced and way-to-slow technology??!" Spoiler: Yes. Yes it is.
The real question is, is it yours, or are you simply at a supplier or makerspace? Oh, and I guess the other question is, "what'cha makin'?"
Post by: Rick on September 11, 2014, 12:37:37 pm
I know what this is... This is an espresso machine. No, no wait. It's a snow cone maker. Is it a water heater?
>:D
Post by: HaRuMaN on September 11, 2014, 01:07:39 pm
Cleanup, Aisle 3@!
Post by: Malenko on September 11, 2014, 08:41:49 pm
sorry, ran out of filament. I'll load up the machine and try to print it again tomorrow.
Post by: Rick on September 12, 2014, 08:09:31 am
(https://d2npbuaakacvlz.cloudfront.net/images/uploaded/large-present/2011/12/20/whats-in-the-box-1324413231.png)
Post by: samelak on September 18, 2014, 02:34:57 am
What's the chance of seeing a Burger Time bar top down the line? I think that cab is one of the all-time classics in regard to the cabinet's visual appeal.
Post by: HaRuMaN on September 18, 2014, 09:51:06 am
I'll see what I can do :)
Post by: The 414 on September 19, 2014, 03:02:22 pm
haruman whats the size of the marquee that fits the standard bar-top . i got plexi cut from you but haven't unpacked it.  thanks
Post by: HaRuMaN on September 19, 2014, 03:04:17 pm
17.75" x 4.5"
Note that the top and bottom 0.5" should be a black bar (will be covered up by marquee retainer, so your effective marquee area is 17.75 x 3.5
Post by: samelak on September 22, 2014, 01:16:32 am
I sent you a message.
Post by: Generic Eric on September 25, 2014, 11:01:57 pm
I hope it's gears, thumb buttons & triggers.
Post by: Malenko on September 26, 2014, 07:29:23 am
sorry for being a tease with the 3D printer , we had some down time with it and when we change the heads we always print something goofy to test. Now we're rapid prototyping a new product and I cant finish my print for a couple weeks.   That being said, if I can get the files for what you need printed, I should be able to print some small things without too much issue.   Its not my printer so I definitely wont be offering any sort of full time service.
Post by: yotsuya on September 26, 2014, 03:58:03 pm
So a little birdie told me that HaRuMaN's Customs might have some exciting news coming down the pike? Care to refute or confirm the rumor?
(http://www.pe.com/pictures/2013__02__frog-380x245.jpg)
Post by: HaRuMaN on September 26, 2014, 04:01:13 pm
I can neither confirm nor deny those rumors...   ;)
Post by: Rick on September 26, 2014, 07:37:50 pm
Yes, it's true. Haruman's Customs is the first subsidiary of Gameroom Designs International.
(http://www.boredwrestlingfan.com/wp-content/uploads/2012/06/damien_sandow___you__re_welcome_by_heavymetalgear-d518o1g.png)
Post by: yotsuya on September 26, 2014, 08:10:00 pm
That wasn't the rumor I heard. If it were, I'm sure there would be issues with NAFTA.
Post by: DGP on September 30, 2014, 10:25:57 pm
Can you guys help me out a little here...
I am considering the Ultimate Widescreen bartop but not sure where the best deal is for all of the required joysticks/buttons/encoders?
I don't want to get ripped off and want decent parts, curious if the zippy sticks are ok or is the sanwa jlf the only solid option?
I would use Happ but I guess the Ultimate Widescreen comes routed for Sanwa JLF only.
* Haruman,
- What is estimated wait time for an Ultimate Widescreen bartop (order placed -> shipped out -> shipping time to west coast)?
- Is it currently best to PM you here or just order on the website?
Thanks,
Jason
Post by: yotsuya on September 30, 2014, 11:09:10 pm
* Haruman,
Thanks,
Jason
He lives in AZ, so West Coast turnaround shouldn't be too bad.  :cheers:
Post by: HaRuMaN on October 01, 2014, 10:04:09 am
* Haruman,
Thanks,
Jason
I can modify the control panel to use happ controls if you want, that's no problem at all.
I have a very large number of orders right now, so turnaround times are about 4 weeks.  Shipping to Cali would only take a couple days.
You can order on the website, just make a note to set it up for happ parts.  Did you want happ buttons as well?
Post by: smykes on October 01, 2014, 03:51:49 pm
Are the plans for the Barstick freely available anywhere?
Post by: HaRuMaN on October 01, 2014, 03:56:03 pm
http://kadevice.com/forum/viewtopic.php?f=51&t=325 (http://kadevice.com/forum/viewtopic.php?f=51&t=325)
Post by: rablack97 on October 01, 2014, 05:30:32 pm
check PM
Post by: smykes on October 01, 2014, 07:08:12 pm
Is current wait time 4 weeks on all products?
Post by: Shanefrom302 on October 01, 2014, 08:25:21 pm
pm sent!
Post by: HaRuMaN on October 02, 2014, 09:52:50 am
Yes pretty much.  Everything gets cut to order, I don't carry inventory.
Post by: Malenko on October 02, 2014, 09:55:12 am
Smart move, cause then you don't have to have a kickstarter to try and clear it.
Post by: Rick on October 02, 2014, 10:08:31 am
A Kickstarter to clear stock?
(http://resnarkable.com/wp-content/uploads/2013/02/inconceivable.jpg)
Post by: yotsuya on October 02, 2014, 10:19:48 am
Welcome to last week, Ricardo.
Post by: Malenko on October 02, 2014, 10:30:06 am
hi Debbie Downer!
Post by: Rick on October 02, 2014, 10:31:00 am
If you don't see my reply in a thread, there's a good chance I haven't read it. That being said, I just read the thread regarding this comment after being pointed to it by a fan. (Thanks, Haruman!) ;) I have no words.
Post by: pbj on October 02, 2014, 10:54:34 am
 :dunno
I kinda liked them but I have no need.  $500 and I'd probably buy one.
Post by: 05SRT4 on October 09, 2014, 08:59:35 pm
Order Submitted for an Ultimate Widescreen.
Post by: HaRuMaN on October 10, 2014, 09:55:00 am
Got it, thank you!
Post by: HaRuMaN on October 17, 2014, 10:45:34 am
Whew.  Almost caught up on all orders.  05SRT4, yours was the last order in, should be slot cut and mailed out on Monday.  :cheers:
Post by: jmike on October 17, 2014, 12:09:47 pm
PM sent.
Post by: mvolke1 on October 17, 2014, 03:20:11 pm
I'm having a fit issue with a mag stik plus on the 2 player-
With the stik "installed" it will hit the 2 buttons on the admin panel, not letting the control panel sit forward enough.
(http://i.imgur.com/3gjdiqfl.jpg)
(http://i.imgur.com/fi5FLA4l.jpg)
Hey Haruman,
Did you ever solve for this? I was actually worried about this happening with me, because I also have the Magstick Plus and I have the GGG Coin Drop Pushbutton: http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=73&products_id=295 (http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=73&products_id=295)
Post by: HaRuMaN on October 17, 2014, 03:36:40 pm
Which kit do you have?
Post by: mvolke1 on October 17, 2014, 04:11:45 pm
I ordered the widescreen bar top.
Post by: HaRuMaN on October 17, 2014, 04:36:14 pm
If you install it with the admin panel in the correct orientation (buttons in front of buttons) you won't have this issue.
Post by: mvolke1 on October 17, 2014, 04:37:22 pm
OK, cool! Can't wait to get it!
Post by: SNAAKE on October 18, 2014, 04:59:39 pm
my monitor has been sitting here forever. where do I get the screws to mount the monitor? talking about the "vesa" screws?? or bolts or whatever. local hardware stores should have them??
Post by: Malenko on October 18, 2014, 09:40:30 pm
yeah, so should any AV place. worst case, ebay.
Post by: PL1 on October 18, 2014, 10:23:59 pm
You probably need metric M4 (<200mm x 200mm patterns) or M6 (200mm x 200mm pattern) machine screws per this wiki page (http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface).    ;D
Just in case, take along a pencil rubbing of the threaded insert in case it is a non-standard size.
Post by: Rick on October 20, 2014, 12:09:47 pm
I couldn't find the "properly named" M4 screws for my implementations, however, Home Depot has them available as (I believe) 'cabinet hardware' screws. (They're the same size used for attaching knobs to the front of wood cabinets.) They're about 1 1/2" long, and 'sizable', meaning that in sections on the thread, there are 'blank spaces' so that you can cut them down using a pair of side cutters. It's certainly not my favourite solution, but it works.
Post by: HaRuMaN on October 20, 2014, 12:14:31 pm
I pick up 30mm M4 screws.  Works great for most bartop applications, in some cases have to toss a couple of washers on as a spacer.
Post by: HaRuMaN on November 13, 2014, 04:03:41 pm
Had some issues with my hosting, had to redo my store.
It's up and running again, the address is:
http://shop.harumancustoms.com/ (http://shop.harumancustoms.com/)
I'm running a coupon for $10 off for the rest of this year, code is BYOAC.
Post by: yotsuya on November 13, 2014, 05:20:55 pm
What does the code "FUPBJ" get you?
Post by: SNAAKE on November 13, 2014, 05:41:34 pm
50% discount  :burgerking:
my weeweecade looks great btw. might need another kit soon for my bro.
Post by: Malenko on November 13, 2014, 09:00:49 pm
$20 off if you pay cash in hand.
Post by: yotsuya on November 13, 2014, 09:39:05 pm
I forgot the code is actually "PBJSUX".
Post by: pbj on November 13, 2014, 10:16:18 pm
Post by: yotsuya on November 14, 2014, 12:20:05 am
(http://i114.photobucket.com/albums/n276/squirrelgrease/AnimatedGifs-5/CryingIndian.gif)
Post by: yotsuya on November 14, 2014, 09:23:08 am
hey, I noticed you haven't posted all that other stuff on your website that you've been working on. Not ready to unveil it yet?
Post by: HaRuMaN on November 14, 2014, 09:25:58 am
Getting close.   :cheers:
Post by: Malenko on November 14, 2014, 10:21:50 am
I like the new descriptions! You must be rich if you can afford a writer AND an artist.
Post by: HaRuMaN on November 14, 2014, 10:24:10 am
Glad you reminded me.  I just sent that file off to the CNC.   :applaud:
Post by: HaRuMaN on November 14, 2014, 10:24:57 am
I've got millions... of harubux...  >:D
Post by: yotsuya on November 14, 2014, 10:25:26 am
Dude, hurry up. I want to see that prototype in realspace!  :cheers:
Post by: HaRuMaN on November 14, 2014, 10:27:59 am
Should have it in hand Monday.
Post by: pbj on November 14, 2014, 10:29:33 am
Did I imagine it or did an entire series of posts just get purged from this thread?
 :dizzy:
Post by: yotsuya on November 14, 2014, 10:39:22 am
 :dizzy:
Hitting the mead early again, I see.
Post by: pbj on November 14, 2014, 10:41:44 am
Yeah, that must be it.  Could have sworn I saw some internet slap fight involving grown men arguing over who's idea it was to rip off the design of an old arcade cabinet.
 :dunno
Post by: Nephasth on November 14, 2014, 10:42:28 am
Mmm, mead... :drool
Post by: yotsuya on November 14, 2014, 10:44:47 am
 :dunno
Here? Never.
Post by: t-matt on November 14, 2014, 01:09:02 pm
Have you considered making an astro city style bartop?
Post by: yotsuya on November 14, 2014, 01:11:05 pm
I'm sure you're the first to ask, but asking is all it takes to light a spark...
Post by: fireslayer26 on November 14, 2014, 08:43:20 pm
If I were to order one of your 2 player widescreen kits, could I get a different drilled front panel? Instead of having 3 holes on either side. Have 2 on each side and 3 in the middle?
I would like to have 1P and Coin on the left and 2P and Coin on the right with 3 admin buttons in the middle.
Thanks,
William
Post by: HaRuMaN on November 14, 2014, 09:06:21 pm
Thanks,
William
Sure can :-)
Post by: HaRuMaN on November 14, 2014, 09:20:44 pm
Haven't before but I'm thinking about it now...  :cheers:
Post by: t-matt on November 15, 2014, 10:57:35 pm
I know you could come up with something rad. My ideal would be an astro city style bartop where I could replace the panel somehow and have a few like one with a track ball or spinner. I played Centipede on an astro city cab once that had a trackball and it has just stuck with me.
Post by: deadmoney5 on November 17, 2014, 12:32:43 pm
I'm thinking a Crazy Climber Bartop is in my future...Would look good next to the Galaga.  Plus I'm missing all the 8-way games now.  :banghead:
Post by: HaRuMaN on November 17, 2014, 12:34:27 pm
So just a standard Taito cab shape?  I could do that :)
Post by: raniel on November 19, 2014, 10:30:40 am
Can you ship to the Philippines?
Post by: HaRuMaN on November 19, 2014, 10:37:41 am
I could but it would likely be pretty expensive.  Let me know which kit you are interested and I could tell you how much shipping would be.
Post by: raniel on November 19, 2014, 01:49:34 pm
Widescreen bartop or the ultimate widescreen. Thanks!
EDIT: please also post the weight and dimensions of the box as I plan to use a freight forwarder if shipping directly to the Philippines would cost a lot
Post by: HaRuMaN on November 19, 2014, 02:33:12 pm
Ouch.
Ultimate: 39 lbs, 28" x 24" x 6", $280
Widescreem: 30 lbs, 24" x 18" x 6", $140
Not sure why the huge difference, I guess the more expensive one crosses some dimensional threshold...
Post by: pappascw on November 20, 2014, 12:51:14 pm
Do you have a cocktail table available?
Post by: sarcophagus on November 24, 2014, 12:07:26 am
Hey all, first time poster here. Now that I have read all 45 pages of this thread, I feel qualified to ask some questions. I'm interested in a widescreen kit.
1. Any pictures of a cabinet in white melamine? I'm interested in doing a "dry erase" bartop cabinet for my daughters to scribble on as they play.
2. Are there any videos of the hinges for the ultimate? I'd rather pay less for the non-ultimate, but it seems like having a removable CP would be pretty useful for changes. I'm having trouble visualizing how industrial velcro would attach.
3. What exactly is slot cutting? Is that the channel for the t-molding or for plexiglass?
4. How long is the wait right now?
5. How much is shipping to the Chicago area?
6. Do you sell buttons/sticks? Which work best with the widescreen kit?
7. Once the cab is glued, how do you access everything? Are people cutting a door in the back panel or attaching it with velcro or something?
Thanks, man. Hopefully I can fit this into the budget and get wifely approval.
Post by: raniel on November 24, 2014, 09:05:13 am
Ouch.
Geez. that's too expensive (shipping cost).
Can you post the plan for the widescreen and ultimate? I'll try it first and if it didn't go well I'll buy a kit from you. Better start saving a lot of money now hehe
Post by: Malenko on November 24, 2014, 09:20:12 am
heres the ones I can answer:
1)I can photoshop some or Haruman can prolly render one
2) the CP sits on 2 batons, so velcro goes on the far left and right sides of the CP and on the batons
3) thats exactly what it is
7) The door on the back is usually hinged/screwed/velcro'ed on , so you access it from the back.
Post by: HaRuMaN on November 24, 2014, 10:10:33 am
Ouch.
Here is the link to the standard (degenatron).  It's open source.  The only difference between it & the widescreen is the panels are 22" long vs ~17.75"
https://docs.google.com/file/d/0B7Rqi_4oIj-wbDVtaWlLQ1NTQk0/edit?usp=sharing
Post by: HaRuMaN on November 24, 2014, 01:03:24 pm
1) See Attached
2) Videos?  No.  It's just a barrel hinge.  See Attached.  Hidden until opened up.  All my other kits I use industrial velcro on the batons and on the front edge.
3) T-molding slot.  You'll need 1/2" to complete the kit.
4) Little less than 3 weeks.  Have 4 orders in queue at this moment.
5) $30
6) Not yet!  Something I'm looking into.  For the widescreen kit, standard Happ joys & buttons work well.
7) Velcro, or hinges for the back, velcro for the control panel.  That industrial velcro is really handy.
Thanks!  :cheers:
Post by: HaRuMaN on November 24, 2014, 01:09:46 pm
Kind of.  I'm not happy with the way the control panels mate with the cabinet.  Working on a better method.   :cheers:
Post by: yotsuya on November 24, 2014, 01:49:06 pm
What?!?!!??! Do I get an upgrade?  ;D
It's a good kit as is, folks! Order worry free!
Post by: HaRuMaN on November 24, 2014, 01:50:49 pm
Heh, thanks man!   :applaud:  I just, I dunno, want it to be even easier.
Post by: yotsuya on November 24, 2014, 01:51:38 pm
I get where you're coing from. Mine is still solid after a year, though. It's gonna get some play over Thanksgiving.
Post by: IAmDotorg on November 24, 2014, 02:24:52 pm
Which part of it? I think the assembly order needs to be slightly different so everything is glued in-place, but at least in my case they work well enough.
Post by: IAmDotorg on November 24, 2014, 02:28:29 pm
My (admittedly quite a bit customized) Haruman cocktail cab is pretty damn sexy, if I do say so myself! ;D
Title: Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
Post by: HaRuMaN on November 24, 2014, 02:32:56 pm
 :applaud:  :cheers:  :applaud:
Looks great!!!
Post by: sarcophagus on November 24, 2014, 05:01:56 pm
1) See Attached
5) $30
Thanks for the answers! Is slot cutting for T-molding included or is it extra?
I'll be budgeting and hope to put in an order in soon.
Post by: HaRuMaN on November 24, 2014, 05:48:25 pm
1) See Attached
5) $30
Slot cutting is included.
Post by: HaRuMaN on November 25, 2014, 09:19:59 am
Bam!
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=319856;image)
Gotta pick up some Kilz primer so I can start painting it.
Post by: yotsuya on November 25, 2014, 11:05:31 am
(http://upload.wikimedia.org/wikipedia/en/9/9f/Hall_Oates_Ooh_Yeah.jpg)
Looks great, bro!
Post by: RetroGreg on November 25, 2014, 11:45:43 am
That sign is pretty cool. Nice job! And lol at the Hall & Oates pic.
Post by: HaRuMaN on November 25, 2014, 11:49:26 am
Thanks.  There was a lot of back & forth with the CNC to get that one right...   :cheers:
Post by: pbj on November 25, 2014, 01:44:53 pm
An expensive, carved version of a cheap plastic sign.  This hobby is going full circle again.
Post by: yotsuya on November 25, 2014, 01:49:18 pm
You owe me $5, HaRuMaN.
Don't you have wine bottles you need to be stuffing Xmas lights into?
Post by: HaRuMaN on November 25, 2014, 02:12:16 pm
As you recall, I didn't take that bet.   ;)
Post by: pbj on November 25, 2014, 02:50:04 pm
That's sweet that you guys talk about me.  If you wanted a wine bottle, all you had to do was ask.  Enjoy the $5.
It'd be nice to see Haruman's efforts invested in something original.  But, hey, hope he sells thousands of these.
Post by: yotsuya on November 25, 2014, 02:54:08 pm
Actually, that was just a test project to see how his CNC guy's machine handled different levels of carving. But hey, if people want to buy them, they're available.  :cheers:
Post by: pbj on November 25, 2014, 03:02:06 pm
That would look pretty damn cool with black light reactive paint, I think.  $?
Post by: HaRuMaN on November 25, 2014, 04:01:16 pm
I gotta ask my CNC guy.  Destroyed a couple of pieces to get to this one.  Now it should be pretty easy.  24" x 12"
Post by: Rick on November 25, 2014, 04:07:21 pm
There doesn't seem to be a lot of complication with the design. I see maybe three different depths, and two or three different bit selections? Where did you run into challenges?
Post by: yotsuya on November 25, 2014, 04:14:28 pm
Hey, Rick, I found you a new CNC guy. He's Canadian, too!
(http://i84.photobucket.com/albums/k39/SericeousBurden/blog/canadian-beaver.jpg)
Post by: HaRuMaN on November 25, 2014, 04:18:17 pm
Well, at first I started off with an STL file to make this a true carving with smooth 3D gradients, etc.  The problem with that was the time it would have taken on the machine, which drove the cost WAAAAAYYYY up.  Like $400.
Second, I then created a 2D file instead to cut like I do my bartops.  Problem was each letter was made of 1000's of points and was taking forever to cut and in fact crashed the CNC.
Third, just getting the layers just right, extending higher layers into negative space.
Post by: pbj on November 25, 2014, 04:22:37 pm
Perhaps Rick could modify your files and sell a Canadian version?
"No Loitering, eh?"
Post by: HaRuMaN on November 26, 2014, 09:51:05 am
$55 + ship
(unpainted, of course)
Post by: Rick on November 26, 2014, 10:28:02 am
Perhaps Rick could modify your files and sell a Canadian version? "No Loitering, eh?"
"Trespassers will be asked to leave. Politely. Sorry."
(I've made signs like this in the past - once I have my shop working, it's definitely an option.)
Post by: pbj on November 26, 2014, 11:56:24 am
No pic = no sign
Post by: Rick on November 26, 2014, 12:20:34 pm
No pic = no sign
Come on, now. You know me better than that.
(http://i.imgur.com/xmi6Anu.jpg)
It's a couple of years old, and definitely needs some touch-up. I used a couple of different decorative bits to create it.
Post by: sarcophagus on November 28, 2014, 10:53:21 pm
Ordered 2 days ago. This is the first step of raising a new generation of arcade gamers!
Post by: yotsuya on December 08, 2014, 12:24:33 pm
Hey, are you done with that new thing we had been talking about? Xmas is right around the corner, and people might want one.  :cheers:
Post by: HaRuMaN on December 08, 2014, 12:27:18 pm
Shoooooooooon!
Post by: rablack97 on December 08, 2014, 04:52:56 pm
Wooorddd???!!!!
http://forum.arcadecontrols.com/index.php/topic,142718.msg1478922.html#msg1478922 (http://forum.arcadecontrols.com/index.php/topic,142718.msg1478922.html#msg1478922)
Post by: crawlingpeter on December 10, 2014, 10:54:15 pm
Hey HaRuMaN,
I was wondering if you could give me a run-down of the slimmest two-player standing pedestal you currently produce... Not gonna have a whole lot of space in the game room but I'd like to get a little something set up if possible!
Thanks.
EDIT:
I would assume it's something similar to this one? http://forum.arcadecontrols.com/index.php/topic,130522.msg1448205.html#msg1448205 (http://forum.arcadecontrols.com/index.php/topic,130522.msg1448205.html#msg1448205) Looks awesome!
Post by: HaRuMaN on December 11, 2014, 10:44:55 am
Don't really have anything currently set up, but I could work on a 2 player variant of that one.   :cheers:
Post by: Malenko on December 11, 2014, 10:48:39 am
measurements wouldnt hurt, how much room ya got?
Post by: crawlingpeter on December 11, 2014, 12:54:04 pm
It will be going into a house that we are currently fixing up. I'll stop by there tonite to grab some measurements and scope out how much space we've got but it should definitely be plenty accommodating for a 2-player cab.  The distance from the pedestal to the screen is the only real concern, but I can always just scoot them closer together and use a smaller screen. No biggie.
I know you don't have anything currently set up, but if we ended up going with a 2-player variation of the build I linked yesterday, would you be able to just throw out a ballpark price range for it? Thanks.
Post by: HaRuMaN on December 11, 2014, 01:00:58 pm
I'll dig up what that 4p cost and scale it back some, I'll let you know.   :cheers:
Post by: crawlingpeter on December 11, 2014, 08:00:02 pm
That sounds perfect!  ;D
Post by: sarcophagus on December 12, 2014, 07:26:44 am
Just got a shipping notification! :w00t
Post by: HaRuMaN on December 12, 2014, 09:17:32 am
Post by: skyzophrenyk on December 13, 2014, 12:33:26 pm
Your stuff looks excellent as usual.
Also, when did you change the name of the Nintendo-style to "Pretendo"? I like that, haha.
Post by: HaRuMaN on December 13, 2014, 01:02:15 pm
Names got changed when I redid the shop, Malenko helped me out with ideas.
Post by: SNAAKE on December 14, 2014, 04:51:21 pm
emailed about another possible weeweecade order
Post by: deadmoney5 on December 18, 2014, 05:16:41 pm
One of these days.....
Post by: sarcophagus on December 21, 2014, 12:49:35 am
Got my HaRuMaN Customs widescreen kit! It was packed very well and is quite gorgeous.
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=321151;image)
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=321154;image)
I started a thread to track build progress and ask questions:
http://forum.arcadecontrols.com/index.php/topic,142915.0.html (http://forum.arcadecontrols.com/index.php/topic,142915.0.html)
Post by: RetroGreg on January 08, 2015, 11:20:12 pm
I sent you a PM. thanks.
Post by: NinjaZero on January 10, 2015, 02:24:47 am
I'm really close to pulling the trigger on the Widescreen setup.  I have a couple of questions for you guys.
1. I'm thinking about using the ball top U360's, Octagon restrictor with the stiffer spring and not buying the i-pac but using the joystick encoder.  Each joystick only supports 8 buttons and the admin panel using 3 per player + 6 game buttons = total of 9.  So do I really need the extra button? I know I can map insert coin and start to 1 button.  Oh and I plan to use hyperspin as my front end.   I've been reading and it also sounds like I will need to also run something like joy2key for the Front end and I'm ok with that.  I'm more concerned about missing a button / functionality.
2. If this works, then my next question is about mounting the joystick, I like the clean aesthetics of not using the carriage bolts and I've seen joystick mount kits like http://www.ultimarc.com/controls.html#mountingkits (http://www.ultimarc.com/controls.html#mountingkits)  and I'm wondering if this works good on particle board?
3. If joystick mounting kits work which size should I get 3/4 or 5/8?
4. I also like the LED buttons on the ultimarc site but will they also fit in the admin panel? (the button size is 28-30mm)
5. Last joystick related question, the u360's have the same mounting plate as the Sanwa should i get the CP be routed for it?
I'm planning on using the a small amp to power car speakers but I was not sure if the coaxial speakers will work mounted in the marque as apposed to outside of it.  If not any car speakers that I should look into instead (i would hate to loose the tweeter of a 2-way speaker thou)
For the monitor I really like the Asus VS238H-P 23-Inch which clocks in at 21.7 inches so it sounds like I should be good (2ms IPS).
Post by: yotsuya on January 10, 2015, 02:14:23 pm
I'm pretty sure they kits are 1/2, so neither of the kits would work.
Either screw in to the wood from the bottom, or embrace the carriage bolts. I love the look of them. Screams authentic to me.
Post by: Malenko on January 10, 2015, 03:16:28 pm
I put screws in from the bottom for the hung donkey, I and the owner were always afraid they'd get ripped out during frantic play, so I ended up putting in carriage bolts.
If you want to hide the bolts, you can counter sink the holes then fill it in and put some art over the CP but the deeper you counter sink it, the less "meat" the control panel is going to have.
I love carriage bolts showing, but I used to hate them.
Post by: SNAAKE on January 11, 2015, 02:43:50 pm
2 more weeweecade on the way! :burgerking:
Post by: sarcophagus on January 12, 2015, 01:50:02 pm
What are the marquee dimensions for the standard widescreen?
Also, is there a template file with dimensions for sideart and CP art? I'd like to try my hand at photoshopping and then gameongrafixing.
Post by: braggtd on January 24, 2015, 11:18:50 pm
Are these cabinets still available?  I haven't seen much movement on the board.  I am very interested.
Post by: SNAAKE on January 24, 2015, 11:29:25 pm
I will post dimensions here if you want. I will probably be doing artworks for this again.
got 2 more weeweecade in the mail today :cheers:
Post by: sarcophagus on January 24, 2015, 11:42:05 pm
That would be awesome! I'm gonna try to whip something up and hope it doesn't look too amateurish. I made my widescreen weeweecade for my 3 daughters, so I was thinking of having three racing Ms. Pac-Mans (or Ms. Pac-Men) on the side like this
   ᗧ
      ᗧ
or something along those lines with a marquee labeled AAArcade (all my daughters have names starting with A)
Dimensions would be really help, particularly for the marquee (Sideboards are the same dimensions as the original degenatrons plans, right?).
Post by: jjasso21 on January 25, 2015, 01:08:18 am
Haruman,
After reading all the pages in this thread, I decided on ordering the Widescreen Bartop from you. Just a quick question through, any suggestions for the acrylic bezel. I am looking for something Neo Geo or Street Fighter themed. Any idea on where I can start looking for them?
Post by: Malenko on January 25, 2015, 08:16:08 pm
Haruman,
I can do art for a reasonable price, stpcore can print it for a reasonable price as well.
Post by: sarcophagus on January 25, 2015, 08:34:50 pm
It also helps that I'm in Chicago so I can do local pickup from stpcore. Is there a thread where I can see some of your art?
Post by: Malenko on January 26, 2015, 01:29:07 pm
pretty much all the art on any of harumans kits were done by me.
Post by: Eskapade on January 26, 2015, 07:09:48 pm
Hey guys!
Recently ordered the Widescreen Bar Top kit and purchased some controls from Paradise Arcade! I have a question that I probably should have asked before I ordered the control layout:
* I ordered two of these sticks http://www.paradisearcadeshop.com/levers-paradise-arcade/672-black-top.html (http://www.paradisearcadeshop.com/levers-paradise-arcade/672-black-top.html) and these buttons http://www.paradisearcadeshop.com/paradise-led-30-c/234-white-translucent-led-pushbutton.html (http://www.paradisearcadeshop.com/paradise-led-30-c/234-white-translucent-led-pushbutton.html) Will they work with the kit and do I need anything in addition such as mounting hardware? I'd like for nothing to show on top of the control panel.
Post by: HaRuMaN on January 26, 2015, 08:33:59 pm
Those controls will work.
As far as the joysticks go, you can use just wood screws from underneath, and that should work. Just predrill, and don't pop through the other side of the panel.
Post by: HaRuMaN on January 27, 2015, 02:03:43 pm
QFT.  With the exception of my R-type II art (done by opt2not) and the Berzerk art (done by yours truly), everything else has been put together by Malenko.   :cheers:
Man, it's been a busy January.  12 orders since Jan 1, been working steadily at getting everything shipped out.
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=323086;image)
Post by: yotsuya on January 27, 2015, 02:11:38 pm
How many of those are going to the Great White North?
Post by: HaRuMaN on January 27, 2015, 02:47:06 pm
Just the one with the stickers on the side.  He's been a repeat customer for about a year now... and the Canadian post have proved to be a little brutal with the boxes.  Heh.  Changed the way I've been shipping to Canada, started using instapack quick RT as well as some more dense foam insulators for the edges.  So far so good with the new packing!
Post by: Rick on January 27, 2015, 02:52:29 pm
I haven't had any complaints, but maybe it's the transfer between USPS and Canada Post that's the issue. I've seen importers be more ... physical ... with some packages during the transition. Or, maybe the greater distance between the two is a factor - more touch points, and all that.
You shouldn't have to worry about it for much longer. ;)
Post by: yotsuya on January 27, 2015, 03:22:58 pm
You're right, I hear he's opening a Canadian branch of HaRuMaNCustoms in Ottawa...
Post by: HaRuMaN on January 27, 2015, 03:30:54 pm
Bwahahaha
Post by: Rick on January 27, 2015, 03:37:25 pm
Bwahahaha
It actually made me laugh as well.
:D
Post by: tkersting on January 27, 2015, 09:32:09 pm
Newbie here.  I'm one of the 12 orders since January. This will be my first build. Already have the software side setup, looking forward to the build portion.
Post by: Slippyblade on January 27, 2015, 09:45:24 pm
Very good call doing the software side first.  :cheers:
Post by: Eskapade on February 02, 2015, 01:44:43 pm
Got my kit this weekend and started my build :) Thanks again Haruman! (http://i.imgur.com/Xc6pUQW.jpg) Can't wait to do some cosmetic work.
Few questions:
1.) I notice a lot of people with the widescreen kits having the acrylic covering the monitor with no bezel blocking the slim bezel of the monitor. I would like to include a bezel under my acrylic even if it is thin. What could I use to do this?
2.) What type of paper is suggested to print Marquee art on. (for light to properly show through)
3.) Any suggestions for quality/inexpensive USB speakers, and perhaps a couple grills to cover the speaker holes?
That's it for now. I'm sure I'll have more
Post by: Malenko on February 02, 2015, 01:47:05 pm
Few questions:
1.) Bezel, What could I use to do this?
1) Construction Paper
2) email stpcore with your art, he'll print exactly what you need
3) really any stereo speaker will work, I used felt on the top of the speaker wood to block light. Costs like $1 at a craft store.
Post by: Rick on February 02, 2015, 02:13:33 pm
Thanks, Haruman Lite!
:lol
Post by: Malenko on February 02, 2015, 02:26:47 pm
:lol
No prob PBJ Lite!
As soon as you make one, I'll try to help people out with it.
Post by: yotsuya on February 02, 2015, 02:30:15 pm
:lol
No prob PBJ Lite!
(http://i.imgur.com/k0Xygbv.gif)
Post by: Rick on February 02, 2015, 02:40:26 pm
No prob PBJ Lite!
Worse things to be, I guess. Does this mean you'll be my ---smurfette--- (http://forum.arcadecontrols.com/index.php/topic,133968.msg1491402.html#msg1491402), too (http://forum.arcadecontrols.com/index.php/topic,133968.msg1491418.html#msg1491418)?
Post by: Malenko on February 02, 2015, 02:43:25 pm
if testing 2 games for PBJ, in an effort to help TK sell more computers makes me a ---smurfette--- sure. But then we're circling back around to helping someone sell something..........
Post by: yotsuya on February 02, 2015, 02:46:24 pm
Damn, Rick's chippy. Waiting on his CNC to get finished is giving him blue balls or something.
Post by: Rick on February 02, 2015, 02:56:21 pm
Nah. Hardly that. Add that I can't walk to the fact that I lost my job and can't claim UI and that could be the source of the snappy retorts. Meh, all the way around.
Post by: TKW4rr10r on February 06, 2015, 05:27:50 pm
Too funny. Forgot how entertaining this thread was. :lol
(http://replygif.net/i/1243.gif)
(http://replygif.net/i/266.gif)
Post by: HaRuMaN on February 10, 2015, 12:48:37 pm
3 more out the door this morning.  2 more on my work table, 2 on the dining room table, 3 in the garage, and one in the car.   :cheers:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=323855;image)
Been a busy February so far too.  Looking to be a good year if this keeps going at this pace.   :burgerking:
Post by: HaRuMaN on February 10, 2015, 12:53:11 pm
Made this one for a repeat customer.  It's a nintendo bartop shrunk by 25%.  Take a look at the original and reduced sides:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=323857;image)
Here it is dry fit (and still dusty):
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=323859;image)
Render I made before CNC:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=323861;image)
Post by: yotsuya on February 10, 2015, 01:04:09 pm
How much shipped to M4B 2W3?  :cheers:
Post by: jjasso21 on February 17, 2015, 11:29:54 am
Haruman,
I'm enjoying the kit so far, Just have to get a nice monitor to set it up with and do the wiring for the buttons.
Malenko, what kind of art do you have available? I was looking for something SF4 themed.I had gotten Haruman's Widescreen model, which measures at: L:18.6" W:23.0" H:21.45", if you need it.
Post by: jeremy0203 on February 17, 2015, 08:06:21 pm
Interested. Pmed you some questions.
Post by: HaRuMaN on February 18, 2015, 03:52:05 pm
Another 5 orders rolled out the door today.  Still have 6 more to get fully caught up.   :dizzy:  Lol.
Post by: SNAAKE on February 19, 2015, 10:38:31 am
this is you right :burgerking:
(http://reactiongifs.me/wp-content/uploads/2014/03/I-am-rich-floyd-mayweather-throwing-money.gif)
Post by: jeremy0203 on February 19, 2015, 12:00:13 pm
What is the depth of the shallow cuts?
Post by: HaRuMaN on February 19, 2015, 02:04:06 pm
So, with some constructive criticism from Malenko (who assembled a couple of the first versions for me), I have redesigned the basic fightstick.
Top no longer is encased by the sides:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=324405;image)
Top is also now 3/4" thick for more color choices with T-molding:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=324407;image)
Moved the button & Neutrik hole on the back to get them out of the way of the two rear buttons on the top panel.
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=324409;image)
Currently the plan is to make the sides & bottom out of 1/2", but may change that over to 3/4" to match the top...
Post by: HaRuMaN on February 19, 2015, 02:04:50 pm
Haha, yeah.   >:D
Post by: yotsuya on February 19, 2015, 02:09:15 pm
That's much nicer.  :cheers:
Post by: HaRuMaN on February 19, 2015, 02:11:18 pm
I agree.   :applaud:
Post by: SNAAKE on February 19, 2015, 11:19:08 pm
start and select button need to be on the side. preferably on the right side. and all around 3/4" would be better for single player stick. otherwise looks good.
Post by: pbj on February 19, 2015, 11:20:32 pm
Looks awfully familiar.
 :dunno
Post by: SNAAKE on February 19, 2015, 11:26:30 pm
of course it does. many many people build single sticks like that including myself. don't need to reinvent the wheel.
HOWEVER I don't like the fat/tall look. as short as possible makes it look better. you wanna go for something like this or sell this type of box too. Id buy some for sure :burgerking:
(http://gearmedia.ign.com/gear/image/article/909/909396/arcade-in-a-box-slim-arcade-custom-controller-review-20080911104706729-000.jpg)
Post by: Malenko on February 20, 2015, 01:36:38 pm
I like the fat/tall look, but I also like the slims. There is one issue with the slims though, and that is that sometimes they arent deep enough to compensate for US sticks. I think a slim version of this stick is a great idea  :cheers:
Post by: HaRuMaN on February 20, 2015, 01:39:07 pm
Yeah the customer will be using Happ stuff.  Hence the height.  Easy enough to make another, slimmer version.   :cheers:
Post by: ih8lag on February 21, 2015, 07:46:04 am
Shipping confirmation received... Thanks HaRuMaN...
I know i read in the thread somewhere there were blank templates available for creating the artwork. I can not seem to find them.
Post by: Malenko on February 21, 2015, 09:25:49 am
I PM'ed ya , I don keep designs "in stock" I kinda create on the fly. So get 3 more posts so you can PM me back :)
Post by: tron84 on February 21, 2015, 10:08:26 am
That looks way better then the 1st design of them. I really never did dig those high sides on the 1st gen ones :D Those look really good now.
Post by: Malenko on February 21, 2015, 01:08:34 pm
agreed. They werent terrible though:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=321515;image)
after I got the first gen fightsticks, I gave Haruman a lot of feedback on design. I'll be picking up a V2 and seeing if there are any other improvements I can think of. I suggest anyone who buys anything from a vendor here do the same. Feedback is how things get improved.
Post by: SNAAKE on February 22, 2015, 05:47:34 pm
a case for american parts can be little slimmer. Id make it as slim as possible. same one can be good for us and jap parts.
Post by: Malenko on February 22, 2015, 06:52:19 pm
so slim, phat, and extra amedium?
Post by: tarheel2344 on February 24, 2015, 07:02:01 pm
I know it's not a Bartop, but I would be interested in a pedestal similar to this one.  Have you done anything similar to this that you could quote me?
(http://www.xtremepinball.com/images/xped.jpg)
Post by: HaRuMaN on February 24, 2015, 07:12:14 pm
I haven't done anything quite that size, I would need to mock something up to get an estimate from my cnc guy
Post by: tarheel2344 on February 24, 2015, 07:16:38 pm
Roger that.  If you get a chance to quote it and want to shoot me a PM, that would be cool.
Post by: HaRuMaN on February 26, 2015, 03:44:24 pm
I'll try to work on that next week.
Post by: HaRuMaN on February 26, 2015, 03:45:36 pm
Just picked a batch of 8 of the new fight stick boxes.  6 are paid for, 2 left.  Will get some pictures when I get them slot cut and dry fit over the weekend.   :cheers:
Title: Missing Widescreen Order?
Post by: calpencil on March 01, 2015, 05:04:11 pm
Long time listener, first time buyer.  I purchased from your website the Ultimate Widescreen Kit.  Now, I know you're busy and have many orders, but what troubles me is that the order says "complete" and I haven't received not an email response nor a wait time from when it'll be completed.  Does the "complete" order status mean that you've sent it already?  Because this showed up immediately after purchasing and I haven't received a product.
I was thinking that if everything goes well with this order, I'll order more from you to complete them for the rest of my family.  Thank you for your understanding.  Not mad at all here, simple curious to what's happening on your end with these orders.
Post by: HaRuMaN on March 01, 2015, 06:33:51 pm
My cart software automatically assigns complete when an order is placed. Still trying to figure out how to change it.
All orders are cut to order, current turnaround time is 3-4 weeks.
If your order is the one I think it is (has all the accessories), it will be going out this week.
Post by: calpencil on March 03, 2015, 08:26:42 pm
Thank you. I'm pretty excited Haruman. I've heard you have a pretty good reputation when it comes to design. I suspect that everything will come together smoothly. All I have to figure out is the best type of monitor that'll fit inside, something that'll power on when I power the computer on, and then figure out the artwork.
Did you have any designers that can make the vinyls for the side and controller and marquee for this model? From what I understand, this is your newest one. I apologize in advance if this question was answered already the forums.
Post by: Malenko on March 03, 2015, 08:35:16 pm
Its not official, but Ive been known to make art packages for haruman's kits.  If your interested, shoot me a PM with what kinda art you want. I recently designed an Ultra SF4 theme and had it designed, printed, and shipped the art for $165
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=325286;image)
Post by: calpencil on March 03, 2015, 10:11:36 pm
That looks amazing!  Pretty high price, but I'm assuming you're using quality materials.  I bought the ultimate widescreen, and that one you're showing is just the widescreen.  Any mock designs for that one?  I wouldn't mind using this thread to showcase his designs.  Actually, it might inspire others to purchase his work.
Post by: jjasso21 on March 04, 2015, 01:29:06 am
Yes, it definitely looks amazing. I can't wait until I get it. On a side note, how is everyone attaching the control and back panel? Is it best to use Industrial Strength Velcro Strips? Or is it better to use a hinge for securing the back panel.
Post by: mann0mann on March 04, 2015, 02:06:30 am
Do you have pricing yet?  and when will be able to order?
I ended up going another route on my stick after getting the first design (I think I was the one to first hit you up about making them)...but after spending a year here and another year over at the other site, now collecting dedicated machines...I feel like I would prefer to build something around a Wico leaf or GGG new leaf stick instead of the JLW I have right now.  My current housing is not deep enough.  Do we know how much clearance you'll have for stick depth on this design?
Post by: HaRuMaN on March 04, 2015, 10:05:21 am
I use a hinge and velcro for the back, velcro for the control panel.
Post by: HaRuMaN on March 04, 2015, 10:10:37 am
Pricing I'm still working out.  I need to get my dry fit to check everything, then they will be ready for sale.
Top is sloped, but at the midpoint of the CP, the depth is about 2.8".  There is also a recess cut for the joystick (0.375" deep) , so that gives more room.
Post by: gbarnes27 on March 04, 2015, 12:44:43 pm
Just finished my first cab and I have to say it was so easy to complete and install everything.  It looks so nice I had to order two more because my sister and brother in law now wants one.  I can't say how impressed I have been with the craftsmanship, quality, and communication so far.  I will be a customer from now on.
Greg
Post by: Malenko on March 04, 2015, 02:25:35 pm
typically its 85 for design(well 85 if I make the design and you make it available to everyone, $100 if its "exclusive") and 80 to print and ship. Most designs take about 6 hours, so thats $14 an hour if it only takes 6 hours and I actually get paid. If you add up all the times I finished art and didnt get paid Im at about $3 an hour.
I dont believe I designed any full size side art for an ultimate wide screen, but I did do a marquee and CPO:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=309623;image)
Haruman made his own SF2CE side art stickers.
Post by: Rick on March 04, 2015, 04:06:59 pm
I dont believe I designed any full size side art for an ultimate wide screen...
Because if you did, the profile on the side would have to look like this:
(http://cdn.alltheragefaces.com/img/faces/large/surprised-reaction-guy-l.png)
:D
But yeah, I can't recommend the Mighty Malenko's art enough. (And if you received art from Malenko and didn't at least offer him a stipend, shame on you.)
Post by: yotsuya on March 04, 2015, 04:10:08 pm
"Picture of Rick"
I don't get it.
Agreed.
Post by: Jalkelly on March 08, 2015, 10:54:32 am
Haruman,
Have you thought about having a display at Zapcon this year with a few different options for people to see?  I have been in pinball the last 3 years but just starting to research building a cab for myself so am a total noob.  I would love to be able to try out some of your more popular cabs to see what feels best to me before I commit to one.
Post by: HaRuMaN on March 09, 2015, 01:12:30 pm
Haruman,
I did Zapcon last year, had four different completed kits out.
I plan on attending this year, just not as a vendor.  I need a break, it's been super busy here, my wife's been recovering from surgery since Jan 7th, and I've had no time to get ready.
Next year, tho...  I plan on having a really good booth set up, with some bartops and perhaps one of my full size cabs as well.   :cheers:
Post by: Jalkelly on March 09, 2015, 05:07:22 pm
[/quote]
DOH!  I wasn't interested in building my own cab then so didn't pay much attention...I just got bit by the bug and have made it about halfway through this thread so far.  Hopefully I can make a decision on which cab to go with after I finish it up.  The amount of support and customization you provide is top notch and the community is lucky to have you in it.  I may PM you if I have any questions so thanks in advance!
Post by: HaRuMaN on March 09, 2015, 05:31:09 pm
Yup, was over with the other vendors by the wall:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=325679;image)
Just let me know if you have any questions.   :cheers:
So far the best seller is the Ultimate Widescreen, followed by the regular Widescreen.  Nintendo is in 3rd, followed by the Vertical.
Post by: Malenko on March 09, 2015, 07:10:06 pm
sold my neogeo :(
Post by: SNAAKE on March 09, 2015, 07:46:46 pm
random weeweecade swaggg :cheers:
(http://i61.tinypic.com/10zyeq9.jpg)
Post by: HaRuMaN on March 09, 2015, 08:03:58 pm
Looking good, man!
Post by: yotsuya on March 09, 2015, 09:37:18 pm
sold my neogeo :(
Traded it, actually.  To this mofo!
Post by: HaRuMaN on March 09, 2015, 10:02:06 pm
sold my neogeo :(
For services rendered...  ;)
Post by: yotsuya on March 09, 2015, 10:06:44 pm
sold my neogeo :(
Dude, that sounds gay (not that there's anything wrong with that).
Post by: Malenko on March 10, 2015, 10:58:22 am
yahtzee, if I service you can I get it?  >:D
Post by: ih8lag on March 11, 2015, 12:43:47 pm
Working on finishing up my widescreen build... T-Molding is on a truck for delivery today. Have new wiring harness ordered for a rewire on the control panel.
I am just finishing up artwork... I found two side templates on the forum but could not find ones for the control and admin panels...
Are there templates available for them?
Post by: HaRuMaN on March 11, 2015, 12:53:03 pm
The sides have been updated and are a little larger than before.  Here are the templates for the widescreen:
Post by: calpencil on March 11, 2015, 11:43:44 pm
Kit received!!!
I'm interested in putting it all together.  Here's the question that's probably asked over and over again, please don't flame me for it.  But where is the best place to get the correct buttons for this ultimate widescreen bar kit?  I understand it uses standard HAPP buttons and it's dimensions are listed on the top page.  But does anyone have any favorite vendors that they like to use to provide the buttons?
Also...not sure if it's mentioned but the smaller 3 button holes that go across the top on this ultimate widescreen, what size buttons fit there nicely?  I'm thinking of making those a "Coin-in", "Start Button", and Exit Buttons.
Post by: SNAAKE on March 11, 2015, 11:58:18 pm
24mm buttons admin buttons
you can buy buttons from anywhere. check ebay or random threads on buy/sell/trade forums here.
Post by: Rick on March 12, 2015, 07:20:16 am
Not to Bogart Haruman's thread, so PM sent.
Post by: HaRuMaN on March 12, 2015, 12:37:36 pm
The ultimate widescreen needs Sanwa controls, 2 Sanwa JLF joysticks, 16 of the 30mm Sanwa screw in buttons, and 6 of the 24mm Sanwa screw in buttons.
Not Happ / IL.   :cheers:
Post by: calpencil on March 13, 2015, 06:13:29 am
Haruman is an awesome possum!  :applaud:
Post by: HaRuMaN on March 17, 2015, 05:28:43 pm
What I'm working on:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=326108;image)
Almost ready for prototyping.   :cheers:
Post by: SNAAKE on March 17, 2015, 08:24:18 pm
why is the speaker hole around the marquee? that looks weird. unless maybe covered with artwork or something.
Post by: HaRuMaN on March 17, 2015, 08:55:28 pm
Look up the mvs 4 slot, big red. Same deal. Top marquee is neo geo, bottom marquee is the four games.
Post by: unsobill on March 17, 2015, 10:59:09 pm
Can anyone please PLEASE!! help me with building this setup ?
http://i.imgur.com/GZyOMwe.jpg (http://i.imgur.com/GZyOMwe.jpg)
Thanks !
Post by: HaRuMaN on March 18, 2015, 12:06:31 am
Thanks !
I'd be willing to take a stab at it. Just a warning, that thickness of acrylic or plexi isn't exactly cheap...
Post by: Malenko on March 18, 2015, 07:29:32 am
Thanks !
Neither is that food processor!
Post by: unsobill on March 18, 2015, 05:14:52 pm
Thanks !
Hi, unsure on how to PM you directly.
 I may be able to get 1/8" or 1/4" of 4ft x 8ft sheet for good price. Was trying to build this on most minimal budget...
Can you please let me know what we can do ?
Thanks !
Post by: HaRuMaN on March 18, 2015, 05:19:35 pm
Thanks !
Thanks !
I'll PM you my email address.
Post by: HaRuMaN on March 22, 2015, 03:34:48 pm
Pushing a lot of orders out this weekend, will probably be shipping 8 boxes out on Monday.   :cheers:
In honor of the 3rd annual Zapcon convention, I'll be running a promotion until April 20th.  10% off your entire cart.  Coupon code is ZAPCON2015
Look for me at Zapcon, I won't be a vendor this year, but I'll be there wearing a BYOAC (or a HarumanCustoms) shirt.
Prototype Neo Geo big red will be in next week, look for pics in this thread.  Will be adding some new stuff to the store soon too.   :applaud:
Post by: ih8lag on March 22, 2015, 09:31:50 pm
I have been working on my artwork. It is Mortal Kombat 9 inspired. I think the CPO needs some work it may bee too busy.
Post by: HaRuMaN on March 22, 2015, 09:37:43 pm
Looks good! I do agree, maybe a little less on the cpo
Post by: HaRuMaN on March 22, 2015, 09:38:50 pm
Busy weekend...
Post by: Malenko on March 22, 2015, 10:14:28 pm
put MORTAL on the left , logo in the middle , and KOMBAT on the right so its not so tiny horizontally .  NOT KNOCKING IT, by why does everyone do Subbie vs Scorpion? Raiden vs Kahn , Sonya vs Kano, etc
Post by: Rick on March 22, 2015, 10:18:57 pm
Ken vs. Ryu... Err...
Post by: HaRuMaN on March 23, 2015, 04:30:15 pm
Here's a rare beast. Someone wanted a widescreen in white, just shipped it to Tasmania, Australia this morning.
Post by: yotsuya on March 23, 2015, 04:37:43 pm
Thanks for donating that fightstick to the BYOAC-ZAPCON project. You are gentleman, and your reputation as a seller is sound! Much obliged!
Post by: HaRuMaN on March 23, 2015, 04:40:47 pm
No problem, should be a good time.   :cheers:
Post by: ih8lag on March 23, 2015, 07:54:08 pm
Spent some time at work thinking about the CPO today and thought maybe stage concept art... I took it to the next level and wrapped the CPO and admin panel with the art. I thought what better then the dead pool an awesome level.
Post by: HaRuMaN on March 23, 2015, 07:57:29 pm
Ok that's hawt
Post by: RetroGreg on March 23, 2015, 09:08:24 pm
I didn't think you guys were serious! I thought this was a "sleep on Haruman's couch" joke.
Post by: mameshane on March 23, 2015, 09:16:59 pm
What is the estimate on shipping to Australia? Brisbane, Queensland.
Post by: HaRuMaN on March 23, 2015, 09:19:17 pm
About $165
Post by: yotsuya on March 23, 2015, 09:25:19 pm
It actually started out that way because he was the first one to pay, but props to the master, he said lets make it happen.
Post by: RetroGreg on March 23, 2015, 09:31:46 pm
Well thanks! Ill make good use of it  :applaud:
Post by: jdevane on March 25, 2015, 09:54:18 pm
Any chance you would add a kit like the Outrun or Pole Position cabinet that johnrt made?
http://forum.arcadecontrols.com/index.php/topic,142697.120.html (http://forum.arcadecontrols.com/index.php/topic,142697.120.html)
http://forum.arcadecontrols.com/index.php/topic,139895.80.html (http://forum.arcadecontrols.com/index.php/topic,139895.80.html)
I'm guessing the PP would be easier since it doesn't have the curved back...
Post by: HaRuMaN on March 25, 2015, 09:56:16 pm
Yes, I have to talk to johnrt to get his blessing, but it's what I want to tackle next.
Post by: SNAAKE on March 25, 2015, 10:32:49 pm
whats next..blue color beast like the capcom cabinets :o ??
anyway they need to stop messing with the balance :angry:
(http://i57.tinypic.com/2i14e9.png)
Post by: HaRuMaN on March 25, 2015, 10:41:46 pm
Hahaha nice!
Post by: jdevane on March 25, 2015, 11:24:55 pm
Cool...
Post by: bsong on March 26, 2015, 06:59:22 pm
nice really enjoying the art work ! haruman anyway you still make the ones out of white? would love to get my hands on one just as another pet project
Post by: HaRuMaN on March 26, 2015, 07:00:23 pm
Yes, I can do white anytime
Post by: bsong on March 26, 2015, 07:30:51 pm
awesome, and what would you say the average size monitor that will fit in there along with the other computer parts behind comfortably
Post by: HaRuMaN on March 26, 2015, 07:34:23 pm
The widescreen? You can fit a 23" widescreen LCD in there.  The case just needs to be 22" or less from left to right.
Post by: SNAAKE on April 02, 2015, 11:35:22 am
ridin dirtay 8)
(http://i59.tinypic.com/24v1uvl.jpg)
Post by: 05SRT4 on April 03, 2015, 10:08:04 am
Hey guys,
Just wanted to share the Ultimate Widescreen kit I just finished for a friend.
(http://s19.postimg.org/dd91rmcxf/0402151818.jpg)
Thanks again HaRuMaN, cant wait to order the next one. :cheers:
Post by: HaRuMaN on April 03, 2015, 10:11:42 am
Looks great! What are you running in there?
Post by: Malenko on April 03, 2015, 10:20:24 am
I really like the blue accents, they really pop on that cab!
Post by: SNAAKE on April 03, 2015, 10:23:29 am
I need to get one of those cab too..add some variety around here
where did you get that coin button?? link plz :police:
Post by: 05SRT4 on April 03, 2015, 06:12:11 pm
Micro ATX Mobo with a AMD A6 APU CPU. I haven't stepped into the world of Jamma yet.
I thought it was going to need micro everything because of the sleek profile, but its actually quite roomy in there.
So the only thing I was confused about were the magnets. You can see on the lower inside area of the back panel that's where I put them. I already put the magnet in the houses so it was, no go on getting them unscrewed unless i hacked at it. Those magnet are no joke. As having it so low I decided to not install the metal plate on the other side and left them there as a reminder.
(http://s19.postimg.org/juwjovcoj/0402151815a.jpg)
No problem SNAAKE
I got the coin buttons from GGG they are the  NovaGemCDR Coin Drop Replacement Push button (http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=89&products_id=295[/url). And the others are  Spectra Eclipse. (http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=73&products_id=408[/url)
(http://s19.postimg.org/mz2m7x437/0402151819b.jpg)
And one more of the inside CP. Yes those are Ultimarc Mag-Stik Plus joysticks. Had to change out the mounting plate for it to fit. All connected to a Ipac 4.
(http://s19.postimg.org/6520g2pkj/0403151541.jpg)
Post by: HaRuMaN on April 08, 2015, 10:31:33 pm
Yeah those magnets are no joke. I typically use them for the cp on that model, but the way you did it works too.
Post by: HaRuMaN on April 10, 2015, 08:15:43 pm
Repro tmnt panel from high density 3/4" mdf and matching plexi:
Post by: HaRuMaN on April 10, 2015, 08:17:38 pm
That's a lot of T-molding... Just received my first shipment of 1/2" colored.
Post by: davidgilmour on April 11, 2015, 01:42:47 pm
Hi HaRuMan, are you able to make a copy of the real original Verticade?
That is the mdf plates (no moulding) and special acrylics control panel?
http://koenigs.dk/mame/eng/drawverticade.htm (http://koenigs.dk/mame/eng/drawverticade.htm)
Post by: HaRuMaN on April 11, 2015, 01:44:39 pm
Yes, I can handle something like that.
Post by: jdevane on April 11, 2015, 08:12:43 pm
Hi, I was wondering, something like one of your widescreen bartops, what weight would you say they typically run once completed, with screen and mininum computer parts...
I'm looking at using something like a wall tv mount to hang on off the wall, of course, my next concern would be whether the weight of the player on it would pull it off too...
this one says the load capacity is about 110
http://www.ebay.com/itm/Tilt-TV-LCD-LED-Plasma-Universal-VESA-Wall-Mount-Bracket-17-20-21-23-27-30-32-37/310360613263?rt=nc&_soffid=5001328703&_soffType=OrderSubTotalOffer&_trksid=p5731.m3795 (http://www.ebay.com/itm/Tilt-TV-LCD-LED-Plasma-Universal-VESA-Wall-Mount-Bracket-17-20-21-23-27-30-32-37/310360613263?rt=nc&_soffid=5001328703&_soffType=OrderSubTotalOffer&_trksid=p5731.m3795)
Post by: Slippyblade on April 11, 2015, 08:21:53 pm
jdevane: Check out this thread.  All his cabs are wall mounts and he talks in that thread about his hanging methods.
http://forum.arcadecontrols.com/index.php/topic,141265.msg1461909.html#msg1461909 (http://forum.arcadecontrols.com/index.php/topic,141265.msg1461909.html#msg1461909)
Post by: jdevane on April 11, 2015, 08:22:49 pm
thanks.
Post by: HaRuMaN on April 12, 2015, 10:05:45 am
I would say 40 pounds or so, completed
Post by: SimonAmpleman on April 13, 2015, 10:08:50 pm
Hello,
Thank you for your awesome work. I'll have a lot of fun building it :)
Since there is 49 pages on this topic, I just wanted to make sure that your latest plan are the ones in the first page ?
And another question, you say "shallow" in the autocad plans, do you have a specific value that you used in your build ?
Thank you :)
Simon
Post by: HaRuMaN on April 14, 2015, 09:49:06 am
Hello,
Thank you :)
Simon
Yes, those are correct.  The shallow cuts (yellow in the DWG) are 0.1".  The normal pockets (red) are 0.25".
Post by: RetroGreg on April 14, 2015, 03:40:33 pm
Did you have to special order all that colored t molding? I thought 1/2" only came in black?!?
Post by: HaRuMaN on April 14, 2015, 03:42:17 pm
So I found a source (thanks to one of my customers) of 1/2" in colors.  Only hitch is you have to order 250 feet rolls, which is fine for me.  :)
Post by: RetroGreg on April 14, 2015, 03:53:45 pm
Cool. That's awesome for your bartops!
Post by: HaRuMaN on April 15, 2015, 11:09:01 am
Yeah it is.  I have 1/2" green coming in this week.   :cheers:
Post by: gbarnes27 on April 15, 2015, 12:25:47 pm
No problem SNAAKE
05SRT4
Anyway you could send me how you did your machine?  All I have ever done is the ICADE machines and those are pretty simple compared to all this.  I really like how you have everything setup in there and wired.
Thanks for your time
Greg
Post by: heykool69 on April 15, 2015, 03:18:54 pm
I really want to order myself this cabinet kit.  Where is this shipping from?
Post by: HaRuMaN on April 15, 2015, 03:34:53 pm
I'm in Arizona
Post by: heykool69 on April 15, 2015, 05:23:10 pm
Ok thanks. Cuz don't know why the ordering page won't give me a shipping quote to California.  And somehow now my order has gotten thru.  I'm new to this and some of the members has such a nice setup.  The software setup is what i need to do LOTS of searching on  :banghead:
Post by: HaRuMaN on April 15, 2015, 05:25:24 pm
I don't see an order from you?  I'll send you a PM.
Post by: HaRuMaN on April 15, 2015, 05:30:54 pm
I stand corrected, I see it now.  Thanks!   :cheers:
Post by: HaRuMaN on April 20, 2015, 09:37:19 pm
Got some green 1/2" T-molding in.
Post by: Rick on April 21, 2015, 07:10:04 am
Not "Galaxian Green", mind you. Was that intentional, or does the art behind it not mean anything?
Post by: Malenko on April 21, 2015, 07:33:37 am
Thats not Galaxian behind it :p
Post by: Rick on April 21, 2015, 07:38:28 am
Well, you're right. That's Galaga. Eep. (I still think the t-molding is too dark. In fact, I don't think I can recall a cabinet that has 'forest green' t-molding.)
Post by: HaRuMaN on April 21, 2015, 10:03:10 am
I intended to show that it wasn't Galaga (or galaxian) green by showing the art behind it.  Hopefully eliminate any confusion.  This was the only green half inch.  Oh well.   :cheers:
Post by: Rick on April 21, 2015, 10:21:54 am
Have you noticed any challenge in getting the colours you want lately? I've checked with a number of t-molding suppliers, because the colour choices are not congruent across all sizes... For example, for my 5/8" requirements, I can get almost everything except green right now.
Post by: HaRuMaN on April 21, 2015, 10:39:35 am
Other than a lighter green and an orange, I can find just about all I need in 1/2"
Post by: efp9teen78 on April 23, 2015, 11:32:40 pm
Did you ever work out the control panel issue on cocktail cabinet design?
Post by: Mocean on April 28, 2015, 03:45:49 pm
Any chance of a kit version of Maximus' Little Ms Pacman slim cocktail ?  http://forum.arcadecontrols.com/index.php?topic=128666.0 (http://forum.arcadecontrols.com/index.php?topic=128666.0)
I've got a Samsung 213T ready and waiting :)
Post by: HaRuMaN on April 28, 2015, 03:47:04 pm
Yes there is.  I've been eyeballing that one for a while now.   :cheers:  I should be able to have something drawn up very soon.
Post by: JimmyU on April 28, 2015, 03:53:10 pm
I sent you a PM a couple of days ago.
Post by: HaRuMaN on April 28, 2015, 03:54:59 pm
Oops, just replied.  Thanks!   :cheers:
Post by: RetroGreg on April 28, 2015, 09:20:57 pm
These would be great gift projects, but I think I'd want to make it smaller with a 17" monitor so it's easier to lift and store. I like it though.
Post by: heykool69 on April 29, 2015, 11:51:18 am
It's only been 2 weeks and it seems eternity waiting for this kit.  I can't wait to start this project with so many threads to read through.
Post by: HaRuMaN on April 30, 2015, 12:13:10 pm
Are orders are in & have been slot cut.  Now just packing & shipping!   :cheers:
Post by: superManny on May 05, 2015, 12:49:03 am
Whats shipping like to CA?
Post by: superManny on May 05, 2015, 12:50:25 am
Whats shipping like to CA? Sorry duplicated on accident.
Post by: HaRuMaN on May 05, 2015, 09:34:59 am
You asking about shipping to Canada or California? Canada gets pricey.
Everything depends on the kit, though. Different box sizes and weights.
Post by: efp9teen78 on May 05, 2015, 12:32:21 pm
I am Interested in a widescreen bartop and a full size cocktail (if the CP issue has been worked out) both in the white laminate covering. But need a few more posts before I can PM. Also Im in Michigan
Post by: HaRuMaN on May 05, 2015, 12:35:54 pm
Sent you an PM with my email address.   :cheers:
Post by: superManny on May 05, 2015, 11:32:35 pm
Sorry, California.
Also the WeeCade link goes back to the main forums. Are you still selling these kits?
Post by: HaRuMaN on May 05, 2015, 11:33:56 pm
Yes I am. shop.harumancustoms.com
Post by: superManny on May 05, 2015, 11:37:12 pm
No problem SNAAKE
Is this one of your kits? If so which one?
I love the carbon fiber on the sides and the button layouts. ---smurfing--- sick
Post by: HaRuMaN on May 05, 2015, 11:38:21 pm
Yes that is, that's the ultimate widescreen kit.
Post by: superManny on May 05, 2015, 11:41:05 pm
Whats shipping on something like that for California?
Do you also sell the Carbon Fiber decals?
Post by: HaRuMaN on May 05, 2015, 11:43:11 pm
Give me a zip code and I'll take a look. I don't sell the carbon fiber, not sure where the customer got it.
Post by: superManny on May 05, 2015, 11:43:46 pm
95112
Post by: HaRuMaN on May 06, 2015, 09:40:12 am
95112
Shipping would be $32
Post by: dluusional on May 06, 2015, 11:28:22 am
Is the The Degenatron CP customizable? I want to use sawna controls/joystick along with 7 buttons. Basically I want a ultimate widescreen cp setup but for 1 player, the degenatron seems like a good fit for this. Also, can you estimate shipping for either the ultimate widescreen or degenatron to 77007.
Thank you
Post by: HaRuMaN on May 06, 2015, 11:32:51 am
Thank you
Yes, I can customize the Degenatron to a Sanwa layout, no problem at all.  There is no charge for customizing the control panel.
Degenatron to 77007 would be $29 shipping, Ultimate would be $35 shipping.
Post by: HaRuMaN on May 06, 2015, 02:47:16 pm
Just ordered white & black 1/2" T-molding to add to the store, so now I have red, blue, forest green, black, and white to choose from.   :cheers:
Post by: heykool69 on May 06, 2015, 11:12:50 pm
Just received and opened up my Widescreen kit.......freaking AWESOME!!!!!   Well, i haven't assemble it yet.  Just looking at the many pieces gives me goosebumps :)
Now to decide if i should get HaRuMaN's acrylic panel kit. Didn't know it was available :(
Curious, with those 3 holes (each player) on the front panel, seems so closed together.  Will it fit this button http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=89&products_id=295 (http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=89&products_id=295)[/url ?  I'm barely reading thru this thread on page 9 trying to seek out ideas from other members on their final cabinet.
PS.    The kit was very nicely and securely packaged HaRuMaN!!!   And i didn't know it was pre-slotted for t-molding.  Thanks.
Post by: HaRuMaN on May 06, 2015, 11:20:31 pm
Thanks man!
People who have used that button typically get me to make a custom front panel.
Post by: 05SRT4 on May 06, 2015, 11:26:34 pm
Yeah the photo gallery on your website is kind of weak, need to get some more examples or finished products. Maybe a customer upload area.
Post by: HaRuMaN on May 06, 2015, 11:29:12 pm
Yeah I do. I've got some pics collected, more would be great
Post by: yotsuya on May 07, 2015, 01:16:21 am
HaRuMaN is a very modest guy. I know for a fact he has sent out over a hundred kits, all over the US and Canada. He's not a fly-by-night operation.
Post by: efp9teen78 on May 07, 2015, 02:11:50 am
Very helpful too He does all he can to make sure you get what you want when order from him. Glad I pulled the trigger today have a feeling wont be the last time I buy from him either.
Post by: 05SRT4 on May 07, 2015, 05:48:48 am
I agree, I don't think I would of ever been able to build any of the kits I did by myself from scratch. I just don't know what to get next.
Post by: HaRuMaN on May 07, 2015, 12:52:34 pm
Thanks everyone!  :droid  I really should sit down and do a count and figure out just how many I've shipped.  It's definitely over 100, most to the US, a few to Canada, 2 to Australia, 1 to Belgium.
I did have a guy offer to help me work on my website, but he disappeared on me.  So I will struggle on :)  Hopefully I can make it better.
Post by: Malenko on May 07, 2015, 03:53:14 pm
I didnt disappear on you!
Post by: HaRuMaN on May 07, 2015, 03:54:18 pm
Haha not you, it was a customer who really liked his kit & offered to help and then disappeared.
Post by: heykool69 on May 07, 2015, 04:44:24 pm
I don't know why, but the image of a member near the beginning of this thread stated "$140 for some woods?" somehow had burned that image in my head.....hahahaha      I think it's a reasonable price eventhough i have the carpentry tools.  One does not know the time you need to spend just from measuring & cutting to make it fit perfect......especially with someone like me whom has a family of two small kids.
Post by: boomerps2 on May 14, 2015, 03:32:40 pm
I just purchased an ultimate widescreen bartop along with a couple of accessories and got a invoice that is automatically generated. I had a few questions I emailed and haven't got a response or any kind of shipping ETA/ Tracking number for the purchase. Is this business still operational?
Post by: HaRuMaN on May 14, 2015, 03:34:45 pm
Absolutely.  I haven't seen an email from you, but I will check my spam folders.  Your order is in with the CNC, he is picking up more material today.  I'll send you a PM with my email address.
Post by: efp9teen78 on May 14, 2015, 11:50:45 pm
Waiting is the hardest part.
Post by: superManny on May 16, 2015, 04:11:34 pm
Thanks for getting me the shipping info. I cant wait to get one ordered.
Post by: superManny on May 16, 2015, 04:24:20 pm
Dumb question but once I buy the kit what is the next thing I need to do? Can you point me to the best post for me to look at.
Post by: HaRuMaN on May 16, 2015, 04:26:43 pm
I have build instructions for each kit. Let me did up the link.
Post by: HaRuMaN on May 16, 2015, 04:30:47 pm
Pretendo (https://drive.google.com/open?id=0B7Rqi_4oIj-wcEdiYkI2bTA0X0U&authuser=0)
Ultimate Widescreen (https://drive.google.com/open?id=0B7Rqi_4oIj-wNWd6RnZ0cFp0cGM&authuser=0)
Degenatron & Widescreen (https://drive.google.com/open?id=0B7Rqi_4oIj-wd1FPZGJOb3FtT28&authuser=0)
Vertical (https://drive.google.com/open?id=0B7Rqi_4oIj-wVkhfaFhmQWV6ZEU&authuser=0)
Post by: Seanm57 on May 16, 2015, 04:41:35 pm
Haruman,
     I had asked a few questions when I placed my order as well, but never heard back. I must be in the spam folder also. However, I was able to find out the answer to one of them. I have ordered a Degenatron kit from you and I am putting in white LED Happ buttons with chrome rings. I was looking for a place where I could get chrome 1/2" t-molding. That place is here;
http://www.arcadeworlduk.com/products/chrome-half-inch-t-molding.html (http://www.arcadeworlduk.com/products/chrome-half-inch-t-molding.html)
Sadly, after shipping it ends up being quite expensive. 20' ran me $42. Maybe I should have waited until the dollar was doing a little better against the British Pound. I will post some pictures once I get everything assembled. I think the all black with chrome should look pretty good. Well, I hope so anyway.
     I had also requested that the control panel and lower panel be blank because I wanted a different button layout. In reading through this thread, I see that you have a plan that uses the layout I wanted. Is it still early enough for me to get a button layout like the picture below?
(http://i61.tinypic.com/4iebn6.jpg)
Post by: HaRuMaN on May 16, 2015, 04:50:09 pm
Single player?
Post by: Seanm57 on May 16, 2015, 05:02:29 pm
Yes. Single player.
Post by: HaRuMaN on May 16, 2015, 05:06:58 pm
Can do. What about the admin panel?
Post by: Seanm57 on May 16, 2015, 05:14:00 pm
I think blank. Im not sure what I want to put there. Maybe just a 1 player start button and coin button with a volume control panel. Its not set in stone yet because I'm using an Ultrastick 360 and that only supports 8 buttons I think. Not totally sure how I'm allocating them yet, but I at least know I am going to use 6 of them on the control panel.
Post by: HaRuMaN on May 16, 2015, 06:02:31 pm
 Alrite sounds good
Post by: Seanm57 on May 16, 2015, 06:04:59 pm
Thank you. Can't wait to get started. If you get a chance, can you let me know when you think the next batch will go out? I think my username for your order page is the same as the one here.
Post by: HaRuMaN on May 16, 2015, 06:30:35 pm
I believe my cnc shop just picked up the material Friday. There are 6 orders in this batch, so probably looking at a couple of weeks depending where you are in the queue. I'll have to check.
Post by: boomerps2 on May 17, 2015, 12:43:49 am
Hello Haruman,
                               I would like to start off by expressing my gratitude for answering all my questions and requests with prompt emails of which is a great business model to go by that many lack.
                               My question to you is that I have noticed you had a few pedestals in the design phase and was inquiring the status for any of those. I am very interested and would love to purchase one in a hurry if possible. Don't care about the wait time, just want one secured. If you have any details or a prices you can you can PM or email me because I know you got that. Again, thank you for the great service and product.
Post by: mafiafan123 on May 19, 2015, 06:14:33 pm
Nice kits,  I wish I would have found you first, I would have bought a kit from you instead of my crappy eBay one lol.
Don't be surprised though if you see an order from me in the near future though  ;D
Post by: HaRuMaN on May 19, 2015, 06:59:28 pm
I saw your thread and though about saying something in there, but then decided to just leave it alone.   :P
I will say my kits are a lot easier to assemble, come slot-cut for T-molding, and have the correct size button holes to boot!  Oh, and you don't have to paint!   :cheers:
Post by: RetroGreg on May 23, 2015, 01:28:37 am
Hi Haruman. The dude that came and did my yearly service on our AC unit totally geeked out on my cocktail unit and thinks he might want to get his own kit. I gave him your website address and told him to just contact you since the cocktail kits aren't listed there. Who knows if he will really follow thru, but he seemed really into it for his man room and I wanted to give you a heads up.  :cheers:
Post by: Mocean on May 25, 2015, 12:22:03 pm
Still hoping for a cocktail or table top cocktail to appear... No pressure :)
Post by: HaRuMaN on May 25, 2015, 12:24:17 pm
So I just made some changes to the midway cocktail cabinet with the control panel assembly and I think it's ready for primetime now.
Post by: Mocean on May 25, 2015, 05:15:15 pm
Woohoo!
If not a slim table top cocktail, would other be interested in a model with a really narrow pedestal?  My RPi2 doesn't require a lot of storage space. :)
Post by: efp9teen78 on May 25, 2015, 05:34:48 pm
Sometimes we just need a push. Still can't wait to see the boxes at my door.
Post by: HaRuMaN on May 25, 2015, 05:37:15 pm
I'm out in the garage making tons of sawdust right now ;-)
Post by: 05SRT4 on May 25, 2015, 05:57:51 pm
Speaking of Cocktail kits, I am just about done with mine. Just need to clean up some things on the coin door (got from Yots thats again bruh :cheers:) and configure all the games. First time using RGB buttons so it was a pain wiring everything. Still need some glass clips, not sure if I want to try some small suction cups or just make some custom clips.
Potato shot
(http://s19.postimg.org/eyur2o8ab/0507150358.jpg)
Might be ordering another widescreen soon  :cheers:
Post by: yotsuya on May 25, 2015, 07:35:50 pm
Potato shot
That looks super tight, brother!
Post by: heykool69 on May 26, 2015, 11:26:01 am
Potato shot
That looks clean & sweet!!!
Post by: xisorshadow on June 13, 2015, 02:34:03 am
Hey Haruman, i had a few questions before deciding whether to buy a kit from you. 1. is it possible to make your kit compatible with sanwa sticks/buttons rather than happ/il? 2. do you do custom layouts. and 3. how do i work with you for these customisations?
Title: Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
Post by: HaRuMaN on June 13, 2015, 03:58:47 pm
1) yes 2) yes 3) just let me know what kit you want, and what layout you want, I can mock up a layout for you to approve before cutting
Sent from my LGLS740 using Tapatalk
Post by: xisorshadow on June 14, 2015, 01:18:41 am
the ultimate widescreen, what size LCD will fit in that? and can i fit an ITX pc in there as well?.
anyways, ultimate widescreen, japanese 8 button layout for sanwa/seimetsu buttons and jlf stick. 3 24mm utility buttons on the main panel, maybe upper right corner?, 1 player, centered controls. 3 extra 24mm utility buttons, and a hole for one of those USB port things  on the admin panel.  That should be fairly simple/doable yes?. please reply with info about LCD size, and whether an ITX motherboard and ATX power supply will fit down inside. Also, do i use sanwa/seimestu screwbuttons instead of snaps for this?
as for artwork, know anyone i can get ahold of to do art for your kits?
Post by: HaRuMaN on June 14, 2015, 02:19:21 am
I can do that layout no problem. A 24" widescreen LCD will fit. The internal width is 23". Your pc components will fit too.
You'll want the screw in type buttons.
Malenko here on the forum is familiar with my kits and has made art for quite a few of my customers. I would contact him via pm.
Post by: xisorshadow on June 14, 2015, 02:32:50 am
sweet, thanks for the info, definitely gonna buy a kit from you now :D.  i noticed on your site you sell plexi sheets for the marquee and screen sections, are those easy to install or do additional modifications need to be made for all that? also, do you have smoked plexi? i'd love smoked plexi for the main screen cover area. Will be purchasing on the first, :D i havent decided whether to build an itx pc or just toss an alienware alpha in there yet, but it will def be something. any idea what cpu/gpu would be needed for good performance? would an i3 with intel graphics do it?
Post by: HaRuMaN on June 14, 2015, 09:05:56 am
They are easy to install. The marquee installs with marquee retainers (also sold in shop). The bezel fits into a slot in the control panel shelf at the rear of the control panel.
I can get smoked plexi for the bezel.
As far as your pc question, I'm not the one to ask, but there are many here who could help. I tend to use old old pc's with old versions of MAME myself.
Post by: DGP on June 17, 2015, 02:47:25 am
HaRuMaN,
Best kit for a 21.3" 4:3 lcd that also has enough room in the back for a standard atx de-cased pc?
- The lcd is 18.7" (W) x 15.0" (H) and would be used Horizontal/Landscape.
Oh and is there a 1 player 8 button + trackball option with any of the cabs (would it require a smaller trackball, like a 2" model, or still too deep)?
- http://www.hollandcomputers.com/store/pc/catalog/ra-track-ball-2-in_02lg.jpg (http://www.hollandcomputers.com/store/pc/catalog/ra-track-ball-2-in_02lg.jpg)
I find the trackball (as mouse) to be a great addition when using a pc.
Thank you!  :cheers:
-Jason
Post by: dsync on June 17, 2015, 07:04:59 am
Hello there Haruman, I just sent an email to you to discuss the possibility for custom made bartop arcade from your store. Hope you could get back to me whenever you got it ;)
Post by: HaRuMaN on June 17, 2015, 12:06:09 pm
HaRuMaN,
Thank you!  :cheers:
-Jason
So.  The best bet for that monitor would probably be my new Big Red kit (not yet in store).  It could handle your monitor, 1 player 8 button setup, and that 2" trackball.
Render:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=330337;image)
Build (I've installed a Dell 2001FP in there.  20.1" 4:3):
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=330339;image)
Post by: HaRuMaN on June 17, 2015, 12:06:53 pm
Reading it now.   :cheers:
Post by: DGP on June 17, 2015, 12:45:49 pm
HaRuMaN,
Thank you!  :cheers:
-Jason
 :o
Looks excellent and has a good bit of room for a bartop, when will that cab be available/price?
Also curious... what is approximate cost with full art/plexi/t-molding (just like your render) if available?
Thank You, your time is very much appreciated.
- Jason
Post by: yotsuya on June 17, 2015, 01:08:37 pm
Two dollah.
Post by: DGP on June 17, 2015, 02:09:42 pm
Two dollah.
SOLD !
Post by: HaRuMaN on June 17, 2015, 05:25:35 pm
HaRuMaN,
Thank you!  :cheers:
-Jason
 :o
- Jason
So, kit should come in around ~$160 based on the size.
Plexi: $40
Art printed: ~$80 (sides, laminated CPO, marquee)
Marquee retainers: $15
T-molding: $10
VESA Screws: $3
Shipping: ~$45 (fully insured FedEx Home)
I'm still futzing with mine, but I think it's ready.  Just need to write up the installation instructions.
Post by: xisorshadow on June 17, 2015, 10:41:16 pm
hey haruman, i thought of another question, can you print and apply art to my cab if i supply the art, so i don't have to deal with it during assembly? or is that a bad idea? i would of course pay for it :P
Post by: HaRuMaN on June 17, 2015, 10:47:26 pm
I've actually done this before for another customer, there wasn't any issues.
Post by: xisorshadow on June 17, 2015, 11:09:09 pm
awesome, thanks!.... and i keep thinking of more questions >.<.... i can't find a good source of information about trying to do LED lighting on a JLF stick and on sanwa/seimetsu screwbuttons, you wouldnt happen to know a place to shop and what parts i should be getting to make this happen would you? or anyone else, information would be greatly appreciated here. Trying to get all my ducks in a row so i can buy the right things to make this cab a reality, and theres just so much crap out there, and not nearly so much information to match it lol.
Post by: gbarnes27 on June 18, 2015, 02:24:31 pm
Just a few pictures of complete cabinets that Haruman has provided for me.  They are the Pretendo cabinets.
(http://tulsavinyl.com/Arcade/20150305_210002.jpg)
(http://tulsavinyl.com/Arcade/20150305_210022.jpg)
(http://tulsavinyl.com/Arcade/Boston2_Pretendo.jpg)
(http://tulsavinyl.com/Arcade/Boston_Pretendo.jpg)
(http://tulsavinyl.com/Arcade/OSU_Pretendo.jpg)
(http://tulsavinyl.com/Arcade/OSU2_Pretendo.jpg)
(http://tulsavinyl.com/Arcade/OSU3_Pretendo.jpg)
Post by: DGP on June 18, 2015, 08:15:03 pm
HaRuMaN,
Thank you!  :cheers:
-Jason
 :o
- Jason
Plexi: $40
T-molding: $10
VESA Screws: $3
Thanks, will talk with my wife and see if she wants to do it.
Would be for our autistic son's b-day on 8/23, would that be doable or not enough time?
Thanks again!
Post by: HaRuMaN on June 18, 2015, 10:06:12 pm
HaRuMaN,
Thank you!  :cheers:
-Jason
 :o
- Jason
Plexi: $40
T-molding: $10
VESA Screws: $3
Thanks again!
Oh, that's perfectly doable.
Post by: HaRuMaN on June 21, 2015, 07:12:02 pm
Good weekend. 8 orders packed up and ready to go. One ultimate widescreen, three regular widescreen, one cocktail cabinet in white melamine, one Nintendo bartop kit in Baltic birch plywood, one assembled fight stick with art and T-molding applied, and one order of just T-molding and marquee retainers. Whew.
Post by: sealcouch on June 21, 2015, 09:04:01 pm
I'll use my first post to say that I've been looking through this thread obsessively. There's no way I'm not going to order one of these in a week or so.
Keep up the good work!
Post by: gbarnes27 on June 23, 2015, 03:44:54 pm
Don't forget my orders  :)  I have friends eagerly awaiting for me to build theirs now.
Greg
Post by: HaRuMaN on June 23, 2015, 03:45:55 pm
Greg
Of course not!  Tentatively these will be cut at the CNC on Friday.   :cheers:
Post by: HaRuMaN on June 23, 2015, 03:46:29 pm
Excellent, looking forward to it.   :applaud:
Post by: yotsuya on June 23, 2015, 04:07:04 pm
Let me know when you're done prototyping that thing. I've got some people that want to look at it.
Post by: HaRuMaN on June 23, 2015, 04:07:58 pm
Fo sho.  Should be soon.   :afro:
Post by: yotsuya on June 23, 2015, 04:09:02 pm
Sweet. Two guys keep asking me about it in particular, & I tell them you have to fulfill all your. Orders first.
Post by: HaRuMaN on June 23, 2015, 04:12:43 pm
Right on.
In other news, been making updates to the midway cocktail design. Much better control box mounting now, with translucent plexi included for lighting the control area.
Dry fit, no glue:
Post by: yotsuya on June 23, 2015, 05:17:45 pm
Yeah, that's a super tight modification. Looks great.
Post by: sealcouch on June 23, 2015, 05:46:23 pm
Aaaaaaand purchased. I have big plans for that minitendo.
Post by: HaRuMaN on June 23, 2015, 07:00:52 pm
And another view, dry fit, no glue. The mdf cp is just resting there. When installed the top will be parallel with the floor.
Post by: HaRuMaN on June 23, 2015, 07:01:47 pm
Excellent, can't wait to see
Post by: efp9teen78 on June 24, 2015, 11:05:16 am
Man that cocktail cab looks amazing. Cant wait to put the finishing touches on it  ;D
Post by: sealcouch on June 28, 2015, 01:33:56 am
Amazon Prime has completely spoiled me. I can't remember the last time I waited longer than a week for something I ordered. I know You're going to be sending an awesome product and the wait will be totally worth it. 7 days down!
Post by: HaRuMaN on June 28, 2015, 06:55:45 pm
Lol. Yeah if I had my own cnc it would be faster... Unfortunately I don't have the 80 grand needed for the machine my guy uses... And you can't beat the precision. It's in the thousandths of an inch...
Post by: yotsuya on June 28, 2015, 07:54:28 pm
That's why it pays to live in the same city as HaRuMaNCustoms... :cheers:
Post by: 05SRT4 on June 28, 2015, 08:02:26 pm
Uhmm no thanks!
(http://s19.postimg.org/hjieqll2n/temp.jpg) (http://postimg.org/image/hjieqll2n/)
I am freaking out over low 90's right now.
Post by: yotsuya on June 28, 2015, 08:10:17 pm
You just stay inside and play your video games all day. Duh!
Post by: HaRuMaN on June 28, 2015, 08:42:27 pm
Or get in the pool and drink beer, and try not to drink so much that you drown by accident... Lol
Post by: jdevane on June 30, 2015, 12:50:00 pm
I'm still interested in seeing one (maybe more... just think 8 bartops linked for Daytona USA.. cause that's what I'm thinking..) of these with a steering wheel...   I actually purchased a Happ wheel the other day with the UGCI board in case I can get something happening...
planning on getting a Galaga bartop in the meantime soon...
Post by: HaRuMaN on June 30, 2015, 06:19:42 pm
Yeah, I really need to get cracking on a driver bartop...
In another news, another day, another harubuck... 3 Nintendos, 1 baby Nintendo, and a slightly redesigned Defender (no more sharp corners, marquee retainers easier to install). Just have to pack up, now.
Post by: sealcouch on June 30, 2015, 10:46:44 pm
My hype knows no bounds.
Sent from my Nexus 6 using Tapatalk
Post by: HaRuMaN on July 03, 2015, 01:28:57 am
So I went to the Amazing Arizona Comic Con earlier this year and had a couple comic books signed by Greg Capullo. I want to hang them up in the gameroom to display them, but I really didn't find much in the way of comic book frames. Solution? CNC some! First prototype, unpainted mdf and plexiglass:
Post by: wp34 on July 03, 2015, 11:23:09 am
Nice!  You are correct there isn't much out there for comic book frames.  You could probably add these to your product offering.
Post by: sealcouch on July 03, 2015, 12:07:07 pm
This is pretty great. If you could find a way to produce them at a relatively low cost there would be a huge market for these.
Post by: HaRuMaN on July 03, 2015, 01:34:29 pm
I gotta work out the numbers, but I think these should be fairly reasonable.
Post by: HaRuMaN on July 06, 2015, 10:48:52 pm
Ready to go!
Post by: HaRuMaN on July 10, 2015, 03:42:45 pm
So, if you have purchased a kit from me, could you do me a favor and hop over to my website and add a review?  I would appreciate it.  You have to be logged into your customer account to post.
Thanks!   :cheers:
http://shop.harumancustoms.com/index.php?route=product/category&path=59 (http://shop.harumancustoms.com/index.php?route=product/category&path=59)
Post by: sealcouch on July 11, 2015, 09:02:48 pm
So here's a thing I'm working on:
(https://scontent-iad3-1.xx.fbcdn.net/hphotos-xfp1/v/t1.0-9/11011528_10207137257928822_5846971861030225935_n.jpg?oh=d3261cdf295511cffd51b86c24944dac&oe=5654A877)
I'm loving the kit. As soon as I finish the build I will add a review.
For some reason the back was just a few millimeters too large to fit. I was able to sand it down and get it in, but I thought you should know.
Post by: HaRuMaN on July 13, 2015, 09:40:03 am
Looks great!!!  Noted on the back.  Sometimes when I'm drawing I make pieces the exact size to cover a gap, which doesn't work in the real world.  I'll trim it down a hair in the drawing.
Post by: Ginsu Victim on July 13, 2015, 04:27:36 pm
Current promotion, use coupon code BYOAC for $10 off your order (good through 12/31/2014)
From the original post in this thread....maybe time for an edit.
Post by: HaRuMaN on July 13, 2015, 04:29:37 pm
Whoops.  Fixed.  At least I remembered to put an end date on the promotion.   :cheers:
Post by: Ginsu Victim on July 13, 2015, 04:35:11 pm
One of these days I'm going to place an order, but dammit, this many years later, that time still hasn't arrived. It will happen....
Vertical bartop or cocktail cab....hmmmm......
Post by: HaRuMaN on July 13, 2015, 04:40:17 pm
Do I need to make a new coupon to tempt you?   >:D
Post by: Ginsu Victim on July 13, 2015, 04:40:41 pm
No, you need to make a deposit in my bank account.
Post by: HaRuMaN on July 13, 2015, 04:41:32 pm
 :lol
Post by: Ginsu Victim on July 13, 2015, 04:42:49 pm
:lol
He laughs at my financial suffering....
Post by: HaRuMaN on July 13, 2015, 04:45:14 pm
:lol
Not even, I've been there, believe me.
I make the bartops so I can afford this hobby.   ;)
Post by: Ginsu Victim on July 13, 2015, 04:48:39 pm
Currently having to rebuild a privacy fence after Tropical Storm Bill kicked its ass, plus I had to replace the central air system (inside and out!), so the money is tight, but I pop in this thread occasionally to dream of a new project that's actually fun.
Post by: HaRuMaN on July 13, 2015, 04:51:01 pm
Yeah, we just replaced our upstairs AC / furnace about a month ago.  That hurt...   :dizzy:
Post by: yotsuya on July 13, 2015, 05:00:07 pm
I'll donate my $50 in HaRuBuCks to Ginsu Victim if it helps the cause.
Oh, and try the coupon code "RICK" to see what you get!
Post by: Ginsu Victim on July 13, 2015, 10:13:39 pm
Heh.
Post by: Malenko on July 14, 2015, 07:10:44 am
I'll toss some Harubux Ginsu's way  :applaud:
Post by: Ginsu Victim on July 14, 2015, 11:50:41 am
Do I have to strip? Make it rain!
Post by: HaRuMaN on July 14, 2015, 09:11:13 pm
Please no
Post by: sporbillis on July 16, 2015, 02:34:47 pm
Hey, don't want to be greedy or anything but is there any way any of you can supply cnc plans for a 2 player bartop with those nice curves? :/ Can't find anywhere
Post by: HaRuMaN on July 16, 2015, 02:38:07 pm
Well, my widescreen is based on the degenatrons open source bartop, so I will share that one with you.  PM incoming.
Post by: sporbillis on July 16, 2015, 02:45:20 pm
Well that was fast, i am not allowed to reply back to personal messages dunno why. Some questions, the file you send me will open with any cnc software?  I ll take it to a guy so i don't know his programs. Also which type of monitor that build takes? Thanks
Post by: sporbillis on July 16, 2015, 02:47:54 pm
Ah , just read on your website it takes a 23 inch monitor.. Mine is 17inch, best case scenario i can find a 19inch :/
Post by: HaRuMaN on July 16, 2015, 02:48:31 pm
You need to have 5 posts to reply to PM's.
It's a DWG (autocad) file.  Drawing is in inches.  Your CNC guy should be able to import it into whatever software he is using to cut.
This one can take up to a 23" widescreen monitor (there is 22" of space available horizontally)
Post by: HaRuMaN on July 16, 2015, 02:50:21 pm
23" is just the max size.
Alternately, you could take my single player plans (1st post in this thread) and modify it with a 2 player panel.  The single player works well with 17" monitor.
Post by: sporbillis on July 16, 2015, 02:52:16 pm
 Yea, basically i wanted to make 17-19inch bartop with 2 player controls, but i know nothing about drawing it up for a cnc or stuff like that. Anw, thanks for trying to help out!! Good kits
Post by: HaRuMaN on July 16, 2015, 10:18:41 pm
Making progress on the new Big Red bartop:
Post by: HaRuMaN on July 22, 2015, 10:01:13 pm
Even more progress
Post by: HaRuMaN on July 23, 2015, 02:36:38 pm
0.7" cast acrylic
Post by: fireslayer26 on July 30, 2015, 08:56:02 pm
I would be tempted! :)
Post by: Baezl on July 31, 2015, 09:15:38 am
Hey guys,
Where did you buy the joysticks?  Love this setup .Also how about the vinyl ?  Links?  Great colors.
Luis
Post by: 05SRT4 on August 03, 2015, 01:24:38 am
Hey guys,
Luis
Joysticks - Mag-Stik Plus (http://www.ultimarc.com/controls.html)
Vinyl - This Stuff (http://www.amazon.com/gp/product/B00CPN0BB8?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00)
Post by: wooftangclan on August 05, 2015, 10:47:57 pm
Just purchased my widescreen kit last night.
This will be my first build ever. Gonna do a RetroPie build since i'm already comfortable working with Raspberry Pi.
I just joined the forum and if someone could have Malenko PM me, that would be great. I'd love to commission him to do the art for my kit.
Post by: monkeybomb on August 06, 2015, 12:43:25 am
What happened with the begging for a coupon?  Did that pan out?   ;D
Post by: HaRuMaN on August 06, 2015, 11:29:47 am
Heh, twist my arm whydontcha?   ;D
From now (8/6/2015) till the end of August (8/31/2015), coupon code PBJ gets you $10 off a purchase of $100 or more.   :cheers:
Post by: HaRuMaN on August 06, 2015, 02:57:49 pm
Thanks for the purchase!  I have pointed Malenko in your direction.   :cheers:
Post by: Malenko on August 06, 2015, 03:08:46 pm
and I PM'ed you my email address
Post by: gbarnes27 on August 07, 2015, 05:43:45 pm
How close are the cocktail cabinets???
Greg
Post by: HaRuMaN on August 07, 2015, 05:53:15 pm
I'd say the midway cocktail is done. I learned enough with the last one, it's good. And I have some prototype 3/4" clips that need testing, too
Post by: 05SRT4 on August 07, 2015, 05:59:47 pm
I need some clips...
Post by: HaRuMaN on August 07, 2015, 06:51:24 pm
Shoot me your address in a PM, I'll get them in the mail.
Post by: 05SRT4 on August 07, 2015, 08:15:33 pm
Done, I will let you know how they work out.
Post by: HaRuMaN on August 09, 2015, 07:08:02 pm
6 kits slot cut and getting ready for shipping, 4 kits and one plexi order boxed upand ready to go, 2 orders still at the cnc. Whew. I need to get my truck back up and running.
Post by: gbarnes27 on August 10, 2015, 11:01:14 am
Let me know when the cocktail cabinet is ready for shipping.
Greg
Post by: Phreakwars on August 16, 2015, 05:38:15 am
OK, so I just ordered the Degentron, T-molding, Marquee, Bezel, retaining clips, etc. I have a couple of questions before this all arrives and I start on a new project.
First off, I see that you're saying a 17" is recommended, but that a 19" would work.. have any specific model of 19" that will go in this? I want to maximize viewing.
Second, what are the dimensions of the marquee and bezel, and where can I find someone to do a custom one for me. This one is actually gonna be for a friend of mine from work and will be going into his mancave/bar. I'm thinking Hyperspin this time around instead of AtomicFE like I used in my sons.
Post by: HaRuMaN on August 16, 2015, 08:16:53 am
Typically a Dell 19" 4:3.  As long as the width of the monitor is less than or equal to 17.7", you should be fine.
Malenko here can help you out.  I'll let him know you're looking for art.  The marquee is 17.75" x 4.5", top & bottom half inch should be black bars, leaving 3.5" view-able.  The bezel is 17.75" x 14.25".
Post by: Baezl on August 16, 2015, 09:27:41 am
Is the widescreen marquee basically is 22" x 4.5" (3.5" view-able) and 22" x 14.25" for bezel?  I am finally putting the widescreen I purchased from you together.
Luis
Post by: Malenko on August 16, 2015, 09:30:14 am
I PM'ed ya phreak
Post by: Phreakwars on August 16, 2015, 09:46:48 am
Yes!! Those dimensions show that I can put a 19.1" ASUS in it
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236115 (http://www.newegg.com/Product/Product.aspx?Item=N82E16824236115)
Post by: HaRuMaN on August 16, 2015, 09:53:10 am
Luis
Yes
Post by: HaRuMaN on August 16, 2015, 09:56:10 am
Yes, that one will work.   :cheers:
Post by: taxidriver6 on August 28, 2015, 11:22:52 am
Hello everyone. Long-time lurker, first-time poster. Finally ready to buy one of Haruman's ultimate widescreen kits to build with my son, but have a few questions:
1) Thinking a 6 button each 2 player setup will be fine. Am I missing something by not going with the extra two buttons? I know some games will benefit from it, but do I really need for games that I may not play?
2) Why do people add admin buttons? Thinking after I set this puppy up right, they won't be used enough to warrant them being added. If anything, I could add usb to the case and connect a keyboard and mouse for any "administrative" tasks. Or I could use "shift" function that Ipac has.
3) Maybe this is a question specifically for Haruman: I see the area where the speakers go, but it looks like your choice is to connect both speakers inside the the marquee with all sound going through the holes. I plan on a specific color scheme and would like to paint my speaker grills and have them exposed. Anyway I could have the speaker holes recessed, so the grills are seen, but flush with the body? I've seen a few cabs with this look and I quite like it.
That's it for now I believe. I'm sure there will be more, but I'm hoping I can get answers from other places.
Thanks in advance...
Post by: Phreakwars on August 30, 2015, 08:15:26 am
No, you do not have to install admin buttons if you don't want to. On my very first build years ago, I installed them because the iPac back then wasn't capable of the shift function that it is capable of now. With my son's cabinet, I left the admin buttons out and use the shift function. The iPac will program on the fly now, so setting buttons to do different things is really easy. My son's is a cocktail type cabinet and his is setup like this:
Left side button is PAUSE>shift 2nd player start
Fire button 1 shift=TAB
Fire button 3 shift=F3 (reset)
Fire button 4 shift=Vol down
Fire button 6 shift=Vol up
Right side button is ENTER>shift ESC
These are the most common admin buttons you would use and they all come together in a neat little package, works perfect with the AtomicFE frontends default settings. I was originally going to install admin buttons as well on the side of the cabinet.. that was before I found out the new generation iPac's use the shift function.
Now on the one I bought from HaRuMaN however (The Degenatron)... I WILL be installing admin buttons in the front because the holes are already there. On the Widescreen Bartop, if you look at the image, you will also have those buttons pre drilled.. of course you don't HAVE TO use them as admin buttons, you could use them as extra buttons or even fill it in with some LED's or something.
Post by: taxidriver6 on September 01, 2015, 06:53:28 pm
Thank you, Phreakwars.
Post by: Suilenrocc on September 02, 2015, 10:07:28 pm
Received my Bartop kit sometime last year.  It was very easy and quick to put together... would recommend!
Post by: taxidriver6 on September 03, 2015, 03:24:44 pm
Another question as I'm about to partake on this journey it seems many people have been taking recently - that of building my first Mame cabinet using Haruman's Ultimate Widescreen kit...
What are the benefits of running a PS3 or XBOX 360 as the main system instead of custom built PC? Obvious thoughts are having the ability to play those system games as I believe emulation for these systems is still undeveloped. Am I missing anything? For those that have went this route, are you able to run Hyperspin; as well as emulators for other systems? Please explain pro and cons of going console in cabinet route.
Thanks in advance.
Post by: HaRuMaN on September 03, 2015, 03:27:26 pm
Thanks in advance.
I have an Xbox 360 in mine, I swap discs for various fighting games and shmups.  Mine isn't modded, but you could theoretically put a modded one in there to avoid swapping discs.  I'm not sure of what else is out there for a modded 360.
Post by: Ginsu Victim on September 04, 2015, 03:32:21 pm
Or purchase Games on Demand versions.
Post by: Phreakwars on September 13, 2015, 03:08:22 am
Just a quick link to show what I have done so far with the help of one of HaRuMaN's kit's, Malenko's talents, Paradise Arcade's warez, and my guesswork/nerdiness:
 http://forum.arcadecontrols.com/index.php/topic,146895.0.html (http://forum.arcadecontrols.com/index.php/topic,146895.0.html)
Post by: The 414 on September 16, 2015, 01:31:09 pm
i have to say i have tried many monitors for this kit and i am happy to say you can fit A 20 inch in it . i found a Samsung syncmaster 204b and it fit. it is very tight but looks great.
http://www.cnet.com/products/samsung-syncmaster-204b/specs/ (http://www.cnet.com/products/samsung-syncmaster-204b/specs/)
Post by: HaRuMaN on September 16, 2015, 01:32:43 pm
Looks great!!
Post by: HaRuMaN on September 16, 2015, 01:33:06 pm
Which kit?
Post by: The 414 on September 16, 2015, 01:37:58 pm
sorry the one you have posted a picture of on page 1 . the single player bartop.
Post by: taxidriver6 on September 25, 2015, 04:02:46 pm
Previous pedestal kit concept:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=312556;image)
To reality:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=139979.0;attach=311738;image)
Hi Haruman,
Is that just a glossy silver? Where did you get the buttons, sticks and t-molding for this?  Thanks
Post by: HaRuMaN on September 25, 2015, 04:05:35 pm
Hi Haruman,
So it's a chrome T-molding if that's what you are asking.
I got the T-molding at T-molding.com:
http://www.t-molding.com/3-4in-chrome-t-molding.html (http://www.t-molding.com/3-4in-chrome-t-molding.html)
The sticks and buttons were all the customer, I'll have to see if I can find what he used.
Post by: taxidriver6 on September 25, 2015, 04:57:04 pm
Yes, that's what I meant. My bad. If you do find out, please let me know. Thanks.
Post by: HaRuMaN on October 05, 2015, 10:01:38 pm
Recently upgraded to a new car. Wouldn't have been to able to fit this many of my largest boxes in the old car...
Sent from my SPH-L710T using Tapatalk
Post by: yotsuya on October 05, 2015, 10:18:00 pm
New car? What did you get, brah?
Post by: HaRuMaN on October 05, 2015, 11:42:42 pm
HRV. Bigger than my old Fit, much nicer
Post by: Phreakwars on October 11, 2015, 09:09:13 pm
Left a review of "The Degenatron" on your website for ya HaRuMaN. And to repeat (more or less) what I had said for others on this forum to read:
Very easy to put together, but there are some considerations to be had before you just "GO FOR IT". First of all, you'll probably want to pre-mount the speakers/amp before gluing everything together. Otherwise, that's a pretty tight space to try working with. Also, note the bottom button ADMIN CP layout depth. If using something like HAPP buttons, you are probably going to have them banging into each other and will more than likely need to use spacers. PLAN AHEAD for this!! My personal recommendation and what I will be doing when I build another one, is to buy one WITHOUT the 3 extra holes drilled at the bottom and just use the "SHIFT" function of an iPac 2 and just program your admin buttons into the regular buttons. This will enable you to put the CP on using HAPP type buttons and joystick without bumping into anything up front. I was able to squeeze a 19.1" monitor in this cabinet with no problem at all. I used an ASUS VW199T-P. It is also noted that this kit it totally worth getting the extra T-molding and plexi glass bezel/marquee to go with it. I went a step further with the bezel plexi and tinted the glass using a 20% darkening tint (Wal-Mart®™). Using black duct tape around the monitor's bezel, then installing the tinted Plexiglas bezel gives this cabinet a sweet looking appearance and hides the monitor buttons, lights and branding.
(http://i16.photobucket.com/albums/b9/MrSnifflesfan/12004941_10206613145080318_7825126422209456983_n.jpg)
Post by: yotsuya on October 11, 2015, 09:48:41 pm
Fair review.
On the front buttons, I use Ultimarc GoldLeaf buttons. They fit the Happ hole, they look like Happs from the top, but under the CP is where they shine.
Post by: monkeybomb on October 12, 2015, 01:34:10 pm
First off, add me to the group that loves these kits.
The front panel buttons caused an issue for me as well.  I eventually realized that I had some shallow buttons from a used CP and it changed the situation quite a bit.  Using a shift key is a nice solution as well.
Guys, how did you secure the control panel?  I went with one of the velcro suggestions from somewhere in this thread and I would like to improve it.  Also curious to see some of the solutions for getting a power cable into the unit.  I ended up just drilling a hole in the bottom.
Post by: Phreakwars on October 12, 2015, 01:52:18 pm
I drilled 2 holes in the back. One for power, and the second one for a USB port.
http://www.amazon.com/gp/product/B00XJDP12W (http://www.amazon.com/gp/product/B00XJDP12W)
As small as the cabinet is, with a little tweaking to the design, you could actually fit a PC and a second console in it. I'm pretty tempted to attempt this next time around. I'm thinking I can do something else with those admin button cut out as well... like for instance, stick the USB port there instead.
What would also be nice to see, are included hinges with starter holes pre drilled, and perhaps a magnetic latch for the door.
And yeah, I also went with velcro on the CP. I debated drilling holes and screwing it down, maybe some hinges, even nailing it into the batons... said to hell with it and went velcro instead. That doesn't make it very secure IMO, but it will do for now.
Post by: HaRuMaN on October 12, 2015, 01:57:43 pm
So, I've been slowly compiling design changes, and have been testing out some new hardware to make these kits better...  :)
Some changes are in the works!   :cheers:
Post by: monkeybomb on October 12, 2015, 03:39:19 pm
I definitely don't want the suggestions to take away from what the cabinet offers.  If no changes are made at all, I still plan on getting another one.  The obstacles are space in the living room and time.  At some point my children will need to understand that making room for my toys is just as important as making room for theirs.   ;D
If you are looking to improve design, the CP mounting is probably the place, but adding to the instructions would go a lot further than design changes for me. FWIW I have the Golden Age Vertical and the kit didn't really cause the hurdles as much as I did.  Idiot proof instructions are the solution for that.
Pick what you think is the best way to mount the CP and put the recommendation in the instructions.  If people want to do something else, they will.  You can add the early speaker mounting and goldleaf type button recommendations if you agree with those.  In the end, I liked the option of putting the hole for the cable where I wanted, but it's another spot where officially giving your opinion would be nice,  The way to keep the back on is another.  I used the same velcro as the cp and it works well.
Post by: raidersan on October 18, 2015, 07:35:39 pm
Hi HaRuMaN,
Do you share the plans for your other variants as well? I am interested in getting the 2 player wider cabinet CNC cut here in the UK as shipping from the US is not an option. Do you have a shared repository of all your models?
Here is my current revision of the CNC plans:
https://docs.google.com/file/d/0B7Rqi_4oIj-wbDVtaWlLQ1NTQk0/edit?usp=sharing (https://docs.google.com/file/d/0B7Rqi_4oIj-wbDVtaWlLQ1NTQk0/edit?usp=sharing)
Post by: raidersan on October 19, 2015, 05:35:20 am
Hi, could you tell me what primer & paint (how many layers) you used to get that white finish?
Many thanks!
To reality:
Post by: JDFan on October 19, 2015, 10:26:00 am
Many thanks!
Don't think it is painted - they cut white Melamine panels that already had the white surface and covered the exposed areas with the t-molding.
Post by: HaRuMaN on October 19, 2015, 10:33:29 am
Many thanks!
Correct.  That is 3/4" white melamine coated particle board.
Post by: HaRuMaN on October 19, 2015, 10:34:28 am
Hi HaRuMaN,
I think you emailed me, too?  If so, just sent you an email back.   :cheers:
Post by: raidersan on October 20, 2015, 07:26:44 pm
Apologies if I am being thick but you replied without any text?
The link in the initial quote from your message back in Feb only points to 1 design, I was wondering if you also shared the designs of the wider kits?
Post by: HaRuMaN on October 21, 2015, 11:13:19 am
Messed up my reply using tapatalk, lol.
I have updated the first post with the wide plans, here is the link:
https://drive.google.com/open?id=0B7Rqi_4oIj-weFlwQ05NekFlRkE
Post by: SNAAKE on October 21, 2015, 03:20:22 pm
these holders on side should be optional. not everybody want those lol..
Post by: HaRuMaN on October 21, 2015, 03:21:29 pm
Huh?
Post by: heykool69 on October 21, 2015, 05:35:37 pm
Yeah. But i think it'll be great for extra tipping support.  You know how crazy some folks are after losing a challenge :)
Post by: HaRuMaN on October 22, 2015, 04:34:24 pm
New coupon, good through Nov 22, 2015.  Coupon code BYOAC saves you $10 off a purchase of $100 or more!
On a side note, 5 people used the PBJ coupon for $10 off.  Lol.   :cheers:
Post by: yotsuya on October 22, 2015, 05:01:46 pm
What does the PBJSUX code give you?
Post by: HaRuMaN on October 22, 2015, 05:12:33 pm
Absolutely nuffin
Post by: yotsuya on October 22, 2015, 05:15:42 pm
Absolutely nuffin
Not even a free "Inspected by PBJ" Sticker?
Post by: HaRuMaN on October 22, 2015, 05:16:34 pm
Absolutely nuffin
Ha!  I wonder if I can make a coupon code that gives you a free item...
Post by: yotsuya on October 22, 2015, 05:18:10 pm
Absolutely nuffin
Dooooooo eeeeeet!
Post by: HaRuMaN on October 23, 2015, 01:31:55 pm
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=337805;image)
Post by: rablack97 on October 23, 2015, 03:37:26 pm
I see ya sir.........the sketchup skill gettin solid... :applaud:
Post by: HaRuMaN on October 23, 2015, 03:40:29 pm
Yessir!  :cheers:
Post by: raidersan on October 24, 2015, 06:15:32 am
[quote author=HaRuMaN link=topic=130522.msg1539970#msg1539970 date=1445440399
[/quote]
Many thanks!
Post by: KuddlKat on October 27, 2015, 10:00:28 am
I have a question regarding the Widescreen version.  It might sound a bit stupid, but I'll be ordering one shortly and was trying to plan it out.
(Ref:  http://shop.harumancustoms.com/index.php?route=product/product&path=59&product_id=51 (http://shop.harumancustoms.com/index.php?route=product/product&path=59&product_id=51))
On the "admin" panel (vertical, front) there's holes for 6 buttons, 3 under each player.  What would be recommended for these, probably for a Pandora's Box (most likely) or a Mini-ITX MAME setup (later)?
I can see having Player 1/2 and Coin 1/2, but what would some of you recommend for the 3rd button on each side?  I did a CP a few years ago and have pause, menu (tab), and enter, but the grouping would look strange like that.  I have no problems drilling extra holes as necessary and prefer to keep the non-standard controls separate from the rest, but blanks always looked odd (not to mention they seem to cost more than actual buttons  ;D).
Post by: HaRuMaN on October 27, 2015, 10:02:53 am
Was kind of designed with MAME in mind, so a Pause and Exit button as well.
That being said, if you only want 2 on each side, let me know when you order, and I can change it.  No charge for modifications like that.   :cheers:
Post by: TheGuy on October 31, 2015, 03:26:57 am
Hello everyone,
I just ordered my first kit from HaRuMaN, and i'm very excited to get started. My brother has been wanting to buy an old arcade for quite a while, so i'm hoping to surprise him with a much nicer/more modern alternative.
Problem is, I have almost no experience with any of this with the exception of using RetroPie. Based on what i've read through the tons of pages on this thread, i'm thinking of going with the ipac-2 controller, but i'm at a loss for what buttons and other accessories I should go with. I'd like to emulate 05SRT4's build as much as possible.
Any advice you guys could give me would be greatly appreciated.
Post by: Phreakwars on October 31, 2015, 07:37:14 am
Hello everyone,
Start by reading my review of it:
http://forum.arcadecontrols.com/index.php/topic,147711.0.html (http://forum.arcadecontrols.com/index.php/topic,147711.0.html)
That should help you choose the right buttons for you.
The Goldleaf buttons that yotsuya talks about can be found here: http://www.ultimarc.com/goldleaf.html (http://www.ultimarc.com/goldleaf.html)
Speaking of which, Haruman, you should put an option on your website so that the buyer can choose with or without admin CP button holes. Would save you time on the drilling, and people wouldn't have to contact you to request it. I'd have at least 1 button for the admin CP on the right side though. There is nothing that it will get in the way of over there. Then a person could go coin and start on top, and pause on the admin CP, everything else, into the iPac shift function.
Post by: TheGuy on November 02, 2015, 09:44:23 pm
Awesome. That's actually very helpful. I've ordered a couple more things for the build, and was able to sneakily get some info on what kind of art to add to the cabinet.
Post by: HaRuMaN on November 05, 2015, 04:11:02 pm
I have 2 extra kits sitting here due to me getting a little slap happy with my ordering.  Both are Minitendo variety, one is black melamine, one is baltic birch.
http://shop.harumancustoms.com/index.php?route=product/product&product_id=61&tag=1+player (http://shop.harumancustoms.com/index.php?route=product/product&product_id=61&tag=1+player)
Post by: HaRuMaN on November 05, 2015, 04:12:45 pm
Yes.  I'm working on having more customization available from the main order page to make it smoother.  Have incorporated materials already, control panel layouts should be next.
Post by: yotsuya on November 05, 2015, 05:25:55 pm
Bro price to 85015?
Post by: HaRuMaN on November 05, 2015, 05:45:46 pm
Bro price to 85015?
For which one?  Baltic Birch one is a little more
Post by: yotsuya on November 05, 2015, 05:47:33 pm
Someone else buy these bar tops before I'm tempted.
Post by: yotsuya on November 05, 2015, 05:48:03 pm
Save them and sell them at the knock off 2.
Post by: HaRuMaN on November 05, 2015, 05:51:30 pm
Lolol
Post by: jackfrost2015 on November 10, 2015, 09:45:57 am
Hello All,
I'm think of buying my first kit from haruman.  I was leaning towards the Ultimate Widescreen kit.  Does anyone know if the OMNI2 joysticks and the Spectra Eclipse push buttons will fit with default control panel or would I have get it custom routed and cut.
Thanks in advanced
Post by: HaRuMaN on November 10, 2015, 06:22:11 pm
Hello All,
Thanks in advanced
I would need to change the control panel for those, but that's easy enough, and no extra charge.   :cheers:
Post by: HaRuMaN on November 11, 2015, 10:50:01 am
Ugh.  Something's wrong with the SQL on my shop, it's kinda working again now, but still pretty buggy.  If you need anything, let me know.  Until then I'm working with my host to sort it out.   :banghead:
Post by: HaRuMaN on November 11, 2015, 11:44:00 am
Back up!
Post by: jackfrost2015 on November 11, 2015, 12:03:03 pm
Great thank you.   ;D Just placed the order.  i also asked if 4 holes could be added to the admin panel 2 on each side 1 for usb extention and 1 for the NovaGemCDR™ Coin Drop Replacement Pushbutton.  Thanks again,  Can't wait to get started,   ;D
Post by: HaRuMaN on November 11, 2015, 12:29:02 pm
Order received, and no problem!  :cheers:
Post by: spedinfargo on November 20, 2015, 02:33:11 pm
Has anyone ripped the buttons and joysticks out of an Xarcade and put them in one of Haruman's kits?  I'm tired of stumbling over my half-completed bartop every time I walk in my work room and not actually playing any games... esp. since it's winter here now and I know I won't work on it anymore until next Spring/Summer...  So I think a Haruman kit would be a good christmas present to the family (er... myself)
Post by: HaRuMaN on November 20, 2015, 02:34:29 pm
No reason that couldn't be done, Xarcade joysticks and buttons are basically Happ clones.
Post by: spedinfargo on November 20, 2015, 02:44:35 pm
Cool - thanks for the quick response!  Another quick question:  since the last time I looked at these you added material options.  Do most people get one of the melamine options over the MDF?  Would the MDF be if I wanted to prime and paint myself?
Post by: HaRuMaN on November 20, 2015, 02:45:41 pm
I'd say 80% get the black melamine.  However, if you do want to prime & paint yourself, MDF is definitely the way to go.
Post by: Slippyblade on November 20, 2015, 04:05:16 pm
The X-Arcade parts are HAPP clones.  No reason not to do what you suggest.
Post by: HaRuMaN on November 20, 2015, 04:12:18 pm
Did you even read my post?  lol...
Post by: Slippyblade on November 20, 2015, 05:34:12 pm
Nope, didn't see it.  I apparently clicked an older link in my e-mail.  Sorry.
Post by: twitami on November 27, 2015, 11:15:06 pm
Sent you a message, but thought I might post here too. I am trying to come up with a MAME/Emulation controller that I will also use for video pinball games. This is mainly for CONSOLE pinball--ie, Sega Genesis, SNES, etc. There are some cool ones. So, I have a few ideas, and one was a Kade project or something you did, I will link the picture. I want pinball buttons on the sides of whatever it is, and a button on the front right to launch the ball. The regular buttons and joystick for other games. I was thinking of an Ikea hack as well, or a combo of an Ikea hack and a controller.
The control panel you made in this picture might work, or something like it. Put some legs on the bottom from Ikea, so it stands alone, and then put a TV stand of some kind (ikea hack or something) right up to it. I probably want several of these, so can't go too nuts on price--but your prices seem very good. I would want a Sega one, a Nintendo one, etc.
Thoughts anyone?
Post by: jdevane on November 29, 2015, 10:28:08 pm
Free bump for Haruman
I made my first purchase tonight, can't wait to build a Golden Age Vertical...
Post by: heykool69 on December 15, 2015, 09:53:21 pm
I'm trying to get the side layout to do the side art for my 2 player Widescreen Bartop.  Does HuMaRaN has it? Cuz i'd tried taking a picture of the side and masked it in Photoshop.  It didn't come out right. I just wasted $$ printing the vinyl art.
Post by: heykool69 on December 15, 2015, 09:59:15 pm
Never mind. Found it on the first page.
Post by: Birdman042 on December 16, 2015, 02:52:33 pm
Well, just pulled the trigger on an Ultimate Widescreen Kit (this build will be for myself). Having it sent to work (going to love the look on the receptionist's face when a 40 pound flat box shows up.... This will be for my 3rd build. I need to finish up the mini cocktail based on the Little Ms. Pacman design for a friend of my son's first...........
Jason
Post by: HaRuMaN on December 16, 2015, 02:58:29 pm
Jason
Saw it, and saw your note.  Will do standard Happ buttons for all.  There is room.
Thanks!  :cheers:
Post by: Birdman042 on December 16, 2015, 03:47:09 pm
Thanks!  :cheers:
Great! Look forward to receiving it next year  ;D!
Post by: HaRuMaN on December 17, 2015, 07:44:31 am
Thanks!  :cheers:
Hey, forgot to ask.  What joysticks are you using?
Post by: Birdman042 on December 17, 2015, 08:54:39 am
Thanks!  :cheers:
Sanwa JLF-TP-8YT
Post by: HaRuMaN on December 17, 2015, 08:55:59 am
Thanks!  :cheers:
Sanwa JLF-TP-8YT
ok perfect
Post by: Birdman042 on December 17, 2015, 09:05:47 am
Sent from my SM-G900V using Tapatalk
Post by: jdevane on December 18, 2015, 08:03:05 pm
got my kit today Haruman....   will begin assembly tomorrow...
Post by: Shanefrom302 on December 23, 2015, 01:38:19 am
Will you be making(or already have) stands for your bartops?
Post by: HaRuMaN on December 23, 2015, 08:58:31 am
So I have made stands for some kits:
Widescreen:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=341133;image)
Nintendo:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=341135;image)
The Nintendo one just got cut and is going out to a customer soon.
Post by: HaRuMaN on December 23, 2015, 09:00:03 am
Awesome!  Post some pics when you're done, I like to see what people do with these.   :cheers:
Post by: deadmoney5 on December 23, 2015, 04:49:20 pm
have you made any stands for the Midway vertical?
Post by: Slippyblade on December 23, 2015, 04:58:50 pm
Love the stands.  I want to build a pedestal that has shelves like this, I think it'll fit the decor much better than a closed up box.
Post by: yotsuya on December 23, 2015, 07:38:57 pm
That's probably the ONLY way I see a stand making sense for a bartop.
Post by: HaRuMaN on December 23, 2015, 07:40:45 pm
Not yet, but wouldn't be very difficult to do so.
Post by: vectorsigmasix on December 24, 2015, 11:24:09 pm
I was planning on buying either the widescreen or ultimate widescreen kits, and wanted to know what the difference in size was between them.
Would a standard ATX motherboard fit in either, or will I need a micro atx?
Post by: sealcouch on December 25, 2015, 02:16:08 am
Widescreen:
Nintendo:
These are so rad. I'd love to get one for my Crazy Kong mini pretendo I built. Its currently sitting on an old busted speaker. :(
Post by: teamkory on December 29, 2015, 09:56:30 am
Just ordered The Degenatron. Anyone have a good idea where to start to get the artwork done on this?
Some free (previously) designed options would be nice. Or something custom. Not wanting to spend more thank 150$ on art.
Post by: Malenko on January 01, 2016, 05:18:59 pm
PM me details of what you want, Ive made a bunch of art kits for Haruman cabs.
Post by: Phreakwars on January 02, 2016, 12:16:19 pm
+1 to Malenko
He's done a couple projects for me and I have a couple more coming up in the spring that I'll be needing his assistance on. Quality work indeed.
Here's some samples of his work for the Degenetron Bartop.
(http://i18.photobucket.com/albums/b149/phreakwars/3_zpskpetniaj.jpg)
This one had some air bubbles I needed to take out, but still a decent picture.
(http://i18.photobucket.com/albums/b149/phreakwars/2_zpsy276qitk.jpg)
(http://i18.photobucket.com/albums/b149/phreakwars/4_zpshjbr1fhn.jpg)
Post by: fudgeyall on January 05, 2016, 11:25:09 pm
Widescreen:
Nintendo:
I'm interested in getting a widescreen (eventually).  What would you charge to have a stand like this one built?
Post by: HaRuMaN on January 06, 2016, 09:09:09 am
I believe that was $150 + shipping.
Post by: fudgeyall on January 06, 2016, 09:27:13 am
Thanks, I'll be in touch.
Post by: Phreakwars on January 06, 2016, 03:50:42 pm
Haruman, you have any designs for a Juke-Box cabinet? Might be a good idea to try. I know I've been kinda looking into doing my very own jukebox, and well, my woodworks sucks. But a kit would be awesome.... pair it up with the pedestal, and I could have one setup in my entertainment room in the basement. Same dimensions as a double wide would be great. I'm thinking of sticking a Sony 5.1 surround sound system using Optical input for a super clean signal. I have no problem with a bare MB, just don't want to destroy a receiver that much to make it fit somewhere smaller.  ;D.
Post by: HaRuMaN on January 06, 2016, 03:52:58 pm
I've toyed around with the idea...  never actually put anything to paper though.
Give me some ideas of monitors, speakers, etc and I'll see what I can come up with.   :cheers:
Post by: Phreakwars on January 06, 2016, 05:53:02 pm
That would take someone else's input who is familiar with touch screens. I wouldn't know where to begin. They come in so many sizes too. I'm thinking a minimum of 20" monitor with 6.5" speaker ports on the side or up front. Don't know what others envision, but I'd like to use the the jukebox as the center channel and right left speakers, and hook up surround sound and sub to the back of it with a rack for my receiver (SONY DAV-DZ170 BRAVIA 5.1 Surround Theater System). I suppose I could use the stock speakers too. Either way. I'm thinking of 2 different type designs... one where the speakers mount in the front, and another where they blast out the sides. I imagine the one with speakers up front would be made for smaller monitor sizes.
Post by: 05SRT4 on January 06, 2016, 06:09:34 pm
I too would love to see a Juke Box kit.
Post by: yotsuya on January 06, 2016, 06:39:38 pm
My juke uses a 15 inch 4:3 touchscreen and it works just fine.
Post by: Wordgirl on January 06, 2016, 06:40:52 pm
Been lurking for a while, finally took the leap and joined up.
Love your work, Haruman! I saw the kit Peabo bought from you back in October and the Mr. Do BARTOP project and pretty much swooned. I have been wanting to get my husband a Mr. Do arcade setup and his birthday is coming up next month.
You all are inspiring me to maayyyybe try to build it.
I feel confident I could put a kit like yours together. Have seen some great artwork in the forums here that I can see myself using for the build, too, and I am pretty creative.
Now only the 'wiring up scary electronics part' has me scared stiff!   :dunno  LOL
Post by: 05SRT4 on January 06, 2016, 06:44:24 pm
I was thinking of something around the same size.
Post by: yotsuya on January 06, 2016, 06:57:35 pm
Plus, you can find them pretty cheap on eBay.
Post by: Phreakwars on January 06, 2016, 07:08:45 pm
For me, that's the easy part. I can do the programming, I can do the wiring, I can do the assembly (Hey, I put together and paint high dollar motorcycles for a living). Just never give me a saw. I'll hurt myself.
Post by: HaRuMaN on January 07, 2016, 10:50:04 am
You can do it! :)  :cheers:
The electronics aren't do hard, especially if you break it up by function and just do a piece at a time.   :)
Post by: anthony691 on January 08, 2016, 10:00:54 am
Got the widescreen bartop. Great kit.
Thanks Haruman, from an old BYOAC'er---I think my last login was literally a decade ago.
Post by: HaRuMaN on January 08, 2016, 10:02:55 am
Awesome!  Thank you!  Glad to see some old faces again!   :cheers:
Post by: anthony691 on January 29, 2016, 02:23:15 pm
I'll leave this here.
Thanks again. Great fun!
Post by: Todesengel on February 16, 2016, 04:18:51 pm
Hey,
Is there any chance you can do a white melamine on one of your kits? Special order maybe?
Thanks,
JP
Post by: HaRuMaN on February 16, 2016, 04:25:14 pm
Hey,
Thanks,
JP
I offer white melamine as a regular option.  Just select that as the material when buying a kit.   :cheers:
Post by: scottstan on February 20, 2016, 02:09:10 am
Hey all.  I just recently a Degenatron kit from Haruman and was wondering if anyone had a template for the artwork.  I've read through this entire thread and it sounds like Malenko has been doing creating some art for some Haruman's kits.  Does anyone have any example files I can use as a starting point?  Illustrator or Photoshop would be preferred.  Haruman sent me some PNGs showing the height/width of the sideart, but I am having trouble recreating the dimensions in my editing software.  Thanks!
EDIT: I found templates posted by JDFAN at post #407 in this thread.  Thanks!
Post by: raniel on February 23, 2016, 12:54:53 am
Id like to order the ultimate widescreen kit. How long it would take for you to ship it to CA? (94066). Thanks. I hope you have one available as Im going back to the Philippines on March 4th.
Post by: raniel on February 23, 2016, 01:10:52 am
I sent you my email. please contact me. thanks!
Post by: HaRuMaN on February 23, 2016, 10:26:14 am
Email sent!  :cheers:
Post by: efp9teen78 on February 24, 2016, 09:44:46 pm
Ok I know there hasn't been many people who have the cocktail cabinet done with the Haruman touch. But I for the life of me can not figure out how to mount my monitor to the top. Any helpful tips would be greatly appreciated.
Post by: yotsuya on February 24, 2016, 09:58:47 pm
I mounted the monitor to a board, then used wood blocks between the backside of the top and the board. Worked fine.
Post by: HaRuMaN on February 25, 2016, 08:25:21 am
That's what's included in the kit these days.
Post by: 05SRT4 on February 25, 2016, 01:02:17 pm
Hey Dude,
I got the same kit and love it. As you can see I fudged up a couple of times trying to figure it out as well. I am still not sure if I installed it the intended way but it works and I am very happy with it. I dont think you would even need the 90 degree brackets I used, I kind of went screw happy on it. Haruman did a great job with these kits. The cocktail is usually the most played when I have people over.
(http://s19.postimg.org/nj0zafm5v/0225161050.jpg) (http://postimage.org/)
Post by: efp9teen78 on February 25, 2016, 11:06:25 pm
Hey Dude,
[/quote]
Hey this is a major help and explains a lot I dont have any pieces of wood that look like that. I may stop buy my local menards and buy a cheap shelve board and see if they will cut it down to size I need. I have no access to a saw and live in an apartment and we just got a good foot of snow in West Michigan last nite
One more question is that the dell 2007fp monitor uncased?
Post by: 05SRT4 on February 26, 2016, 02:40:44 am
I think I ended up using a Dell 2001FP which is still the same size I think. Picture is great even at odd angles.
Post by: RetroGreg on February 26, 2016, 07:19:48 pm
Hey Dude,
This is how I mounted mine as well. Also a Dell 20".
Post by: raniel on February 28, 2016, 02:12:47 am
Guys can you give me the link where can I buy the sticks, buttons and encoders that will fit? I just ordered the widescreen bartop from Haruman and I dont know what to order. I prefer ball type sanwa's. Thanks!
(Links or exact model number if possible)
Post by: HaRuMaN on February 28, 2016, 12:58:16 pm
Problem is I don't know if you'll be able to get anything shipped to you before you leave.
Sanwa JLF for joysticsks
http://www.paradisearcadeshop.com/levers-sanwa/695-sanwa-jlf-tp-8yt.html (http://www.paradisearcadeshop.com/levers-sanwa/695-sanwa-jlf-tp-8yt.html)
Don't forget to add a balltop.
I would get IL buttons (you'll need 12):
http://www.paradisearcadeshop.com/298-buttons-il-industrias-lorenzo (http://www.paradisearcadeshop.com/298-buttons-il-industrias-lorenzo)
Get the cherry microswitches with them (75 gram)
Post by: raniel on February 28, 2016, 02:45:46 pm
Yes youre right.
amazon is the only choice for me right now as I have Prime
Do you think below would work/fit my bartop kit?
Joysticks
http://www.amazon.com/gp/product/B00VZOWIYQ?keywords=sanwa%20jlf-tp-8yt&qid=1456686191&ref_=sr_1_2&sr=8-2 (http://www.amazon.com/gp/product/B00VZOWIYQ?keywords=sanwa%20jlf-tp-8yt&qid=1456686191&ref_=sr_1_2&sr=8-2)
BUttons
http://www.amazon.com/Sanwa-OBSF-30-Tournament-Joystick-Compatible/dp/B005BZ421M/ref=pd_bxgy_21_2?ie=UTF8&refRID=09G4VXE3FFQG6SH1Y3WN (http://www.amazon.com/Sanwa-OBSF-30-Tournament-Joystick-Compatible/dp/B005BZ421M/ref=pd_bxgy_21_2?ie=UTF8&refRID=09G4VXE3FFQG6SH1Y3WN)
Post by: raniel on February 28, 2016, 02:47:33 pm
But it doesnt come with microswitches.
Post by: Phreakwars on February 28, 2016, 04:08:10 pm
That's because the microswitch for them is built in. And yes, they will work.
Post by: HaRuMaN on February 28, 2016, 05:27:26 pm
Those buttons are 30mm and are too big.
Post by: HaRuMaN on March 01, 2016, 09:42:40 am
Overstock? So I had one too many Minitendo kits made in Baltic birch plywood.
Any interest in a "deluxe" kit ready to ship? Has tinted plexi for the bezel, also includes plexi marquee, marquee retainers, VESA screws, and your choice of black, white, blue, or red T-molding.
To purchase this kit from the shop would be $243 + shipping, will let it go for $200 + shipping.
LMK!
Post by: heykool69 on March 01, 2016, 05:49:36 pm
Now i wanna get me a cocktail kit.  Don't see the kit at HuRaMaN website.
Post by: HaRuMaN on March 01, 2016, 09:07:24 pm
Hey, PM incoming :)
Post by: HaRuMaN on March 02, 2016, 05:52:18 pm
LMK!
Sold!  :cheers:
Post by: efp9teen78 on March 05, 2016, 11:57:39 am
Turns out I was wrong I did have those pieces of wood. They had gotten mixed in with the widescreen bartop I haven't started assembling yet. Just have to get the right length of vesa screws now and work out the artwork. Slowly coming along maybe soon I can start working on the bartop
Post by: pauleku on March 16, 2016, 03:08:33 pm
So the widescreen CNC file looks like this on an online viewer: Is the cabinet part (file) complete or does it really not have the line(s) that look like they are missing (top middle)
(http://i.imgur.com/C91cfDs.jpg)
Post by: HaRuMaN on March 16, 2016, 03:39:50 pm
Don't use an online viewer, go and grab DraftSight (free).  It's what I use to draw these, and you will see all lines are there.
Post by: pauleku on March 16, 2016, 08:12:08 pm
Ah okay thanks!
A few other questions:
What are people doing about covering the edges of the tv (like an overlay to go over the fron on all parts but the display)?
What are people using regarding glass to go on top of that (if anything?)
Post by: Phreakwars on March 17, 2016, 04:43:59 am
Ah okay thanks!
Black tape/Black duct tape around the edges of the monitor combined with a light window tint film on the glass/plastic overlay.
Will give you this:
Post by: Hanzie on March 17, 2016, 12:31:38 pm
ive been thinking about picking one of these up , they look pretty cool
Post by: raniel on March 19, 2016, 09:24:41 am
Guys any tips on mounting the joysticks? I bought the widescreen and trying to mount sanawa jlf. How do I make sure it is centered? Thanks
Post by: HaRuMaN on March 19, 2016, 10:06:46 am
Place the joystick underneath the panel.  Look down at it from the top.  You should be able to line up the joystick hole with the joystick.
Hold it tightly once you have it lined up, flip everything over, and use a pencil to mark where the mounting plate holes go.  Pre-drill some holes, and attach your JLF.
Post by: acjgoblu on March 19, 2016, 02:28:01 pm
To follow up on this (and sorry if this is a noob question), what type of screw do you recommend using with your models (and a sanwa jlf joystick) to attach to the control panel? Since the top of the screws will be visible on top of the CP, do people tend to use a flatter head bolt or more of a carriage bolt? I didn't get any screws with my jlf's, so it's off to home depot with me, and I was hoping for some clarification... thanks!
Post by: HaRuMaN on March 19, 2016, 02:31:34 pm
I would just use a 1/2" wood screw and do it from the bottom, nothing visible from the top.
Post by: fablog on March 19, 2016, 04:58:21 pm
You should use threaded inserts, you won't regret it!
Post by: Hanzie on March 19, 2016, 09:32:57 pm
pm sent  Thanks!
Post by: Hanzie on March 20, 2016, 04:58:05 pm
heres a picture from my phone of the WIP in photoshop.  Galaga art is done, Reunion art is almost done.
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=130522.0;attach=297455;image)
id love to get my hands of some of this artwork or the files to get them printed, does anyone have a lead on this? :burgerking:
Post by: HaRuMaN on March 20, 2016, 05:28:37 pm
That would be me, you've got PM
Post by: Hanzie on March 20, 2016, 06:17:06 pm
payment sent on that, thanks!
Post by: yotsuya on March 20, 2016, 07:24:15 pm
You better be hooking brother Hanzie up, HaRuMaN.
Title: Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
Post by: HaRuMaN on March 20, 2016, 07:30:37 pm
Sure am, bringing his goods to ZapCon!  :cheers:
Post by: ts on March 21, 2016, 01:39:46 pm
Hi guys,
Getting back into a new cabinet build after about 12 years since my last.  Went smaller this time with one of Harumans cool widescreen bartop kits.
What is the best direction to go as far as finding someone to help me with some custom art design?  I know a few in this thread appear to have in the past helped out but wasnt sure who was still doing that.
Willing to pay of course for the time and talent.   Photoshop and I hate each other.   ;D
Post by: Hanzie on March 21, 2016, 09:32:15 pm
Thanks again for doing that for me, I'm letting my wife drive us down so hopefully it fits in her trunk  :applaud:
Post by: HaRuMaN on March 21, 2016, 09:44:09 pm
The box is 28" x 24" x 6"  :cheers:
Post by: Hanzie on March 21, 2016, 10:32:19 pm
Cool, should be fine. Thanks
Post by: raniel on March 24, 2016, 07:49:54 am
Any other alternatives on mounting control panel aside from velcro? I cant find velcro vendors in the place I live. Thanks
Post by: dmckean on March 24, 2016, 12:15:36 pm
Clamps or magnets.
Post by: RetroGreg on April 01, 2016, 01:04:54 pm
PM sent  :cheers:
Post by: HaRuMaN on April 01, 2016, 01:29:40 pm
PM sent  :cheers:
Hey got your PM's. We'll talk at ZapCon.  I'm swamped in orders & trying to get ready for the show...   :cheers:
Post by: RetroGreg on April 01, 2016, 04:01:20 pm
PM sent  :cheers:
Cool. Thanks  ;D
Post by: yotsuya on April 01, 2016, 04:04:45 pm
PM sent  :cheers:
Hey got your PM's. We'll talk at ZapCon.  My soaps are on & trying to figure out how to make a grilled cheese sandwich...   :cheers:
FTFY.
Post by: HaRuMaN on April 01, 2016, 04:44:09 pm
PM sent  :cheers:
FTFY.
You do know I worked as a cook for years, right?  Before I decided that sucked too much and decided to go back and get my degree.
lol
Post by: yotsuya on April 01, 2016, 04:45:14 pm
PM sent  :cheers:
FTFY.
lol
Dinner party at HaRuMaN's house after ZapCon. Dibs on the couch!
Post by: HaRuMaN on April 01, 2016, 05:45:54 pm
PM sent  :cheers:
FTFY.
lol
Lol.  No.
I am making the wife ribeye and lobster for her birthday dinner, tho
Post by: Rick on April 01, 2016, 06:42:00 pm
He said "cook" not "chef".
Post by: corysnyder28 on April 13, 2016, 08:50:48 pm
Hey all - Is everything alright w Lee? I sent him a few emails and even placed an order but haven't heard anything back from him in a short while.
Just hoping everything's OK!
Post by: yotsuya on April 13, 2016, 09:22:51 pm
You do realize that ZapCon is this weekend and Lee is a vendor, correct? Because I know for a fact he's been super busy getting ready for the show.
Post by: HaRuMaN on April 13, 2016, 09:28:32 pm
Hey sorry about that, yes I did get your email. Will shoot you a response in the morning.
Post by: corysnyder28 on April 13, 2016, 09:59:17 pm
No worries -- was just checking. Wasn't aware of Zapcon. No doubt you've got your hands full!
Post by: HaRuMaN on April 13, 2016, 10:21:37 pm
Yeah it's been crazy. Taking a cabaret and 4 (maybe 5) bartops. Plus an unbuilt kit for demo. Whew
Post by: dmckean on April 13, 2016, 10:59:29 pm
Can't wait to see it all.
Post by: yotsuya on April 14, 2016, 02:55:24 am
Remember, you can earn a badge by taking a photo in front of the HaRuMaN's Customs booth and post it in the official thread.
Post by: Slippyblade on April 14, 2016, 04:53:52 pm
Wait, cabaret?  You do cabarets now?
Post by: yotsuya on April 14, 2016, 04:57:28 pm
Yeah bro, you should see it. Oh wait, you will at ZapCon!
Post by: HaRuMaN on April 14, 2016, 04:59:51 pm
Yes indeedy
Post by: Slippyblade on April 14, 2016, 05:09:48 pm
It's not on your website.  Will it be a one-off or a regular item?
Post by: dmckean on April 14, 2016, 06:59:01 pm
He made mine over here:
http://forum.arcadecontrols.com/index.php/topic,146596.0.html (http://forum.arcadecontrols.com/index.php/topic,146596.0.html)
Still not finished assembling yet.
Post by: Hanzie on April 18, 2016, 07:55:14 pm
Lee, thanks for the kit, i got it put together yesterday and it looks very cool. the artwork really sets it off too!
Post by: RetroGreg on April 19, 2016, 10:55:39 am
PM sent for 3 kits  :o
Post by: HaRuMaN on April 19, 2016, 10:57:27 am
Post by: HaRuMaN on April 19, 2016, 11:00:09 am
Awesome, thanks!  Post pics if you get a chance!
Post by: Ginsu Victim on April 19, 2016, 05:44:42 pm
Update maybe?
Post by: yotsuya on April 19, 2016, 06:32:29 pm
Actually, try "haruscouch" and see what happens...
Post by: RetroGreg on April 19, 2016, 07:07:37 pm
I think you have to provide artwork and work the ZapCon booth to be eligible  ;D
Post by: yotsuya on April 19, 2016, 07:08:14 pm
He was supposed to put that up as a code.
Post by: Malenko on April 20, 2016, 10:15:37 am
I get paid handsomely........
in harubux
Post by: CobraX83 on May 17, 2016, 11:53:52 am
I came across the template's for Haruman's single player Degenatron on page 11 of this thread and was curious if someone can confirm that these will be the correct one I need before I start working on it!
If someone can post the marquee png and bottom control panel png that would be MUCH appreciated!
Thank you for any help!
Post by: spedinfargo on May 21, 2016, 11:52:00 am
Just got my kit in the mail and a couple questions before I actually start gluing.
1.  There is a slot for each of the two control panel batons.  However, the baton itself isn't long enough to fill the whole slot.  Do you slide the baton closer to the front of the cabinet or the back of the cabinet before gluing it or does it not really matter?  See attached picture for what I mean...
2.  I understand that the back panel is held either by a hinge or velcroing.  But what is that back slot for?  It's not as deep as the other five so I'm not sure what it's for.  See the other picture for what I'm talking about.
Post by: HaRuMaN on May 21, 2016, 12:02:09 pm
Just center the batons in the slot, doesn't need to be super precise on those.
The long batons go in the shallow slots on the back, they just prevent the back door from getting pushed in.
Post by: spedinfargo on May 21, 2016, 02:09:05 pm
Wow!  Thanks for the quick, response.   I may have been overthinking the batons because I'm still a bit unsure how the plexi fit works (thought I saw one post talking about wedging the plexi between the back of the speaker board and the control panel.
Mystery slot solved.
Thanks again...
Post by: Charlie97L on May 21, 2016, 03:33:05 pm
Ordered my kit!  Very excited.
I also scored a 19" dell on CL for 10.00.  I don't know what got me more excited.  :)
Post by: HaRuMaN on May 21, 2016, 03:39:13 pm
The bartop of course! ;)  :cheers:
Post by: Charlie97L on May 21, 2016, 04:15:37 pm
Indeed.
I'm stoked because the money I saved on the monitor will allow me to get a SLG now.  :)
But yeah, man I did a lock/cam kit for my ex a few years back and the quality on yours seems so much better.  I'm honestly excited.
And once I get everyone in the house hooked it'll be cocktail time.  :)
Post by: Charlie97L on May 23, 2016, 11:54:32 am
As I'm assembling my parts list...
Are these too thin on the CP to use flush-mount joystick kits with the T nuts?
No problem either way, just curious!
Post by: HaRuMaN on May 23, 2016, 01:36:04 pm
So I do have some threaded inserts I've been playing with, they mount from the bottom and you just screw into them.  I press them into the control panels with an arbor press.
I'm considering making them a standard feature (or maybe an optional one), it would add a little cost due to the hardware.
Post by: Charlie97L on May 23, 2016, 07:58:52 pm
I would definitely be down to add that on.
Post by: gonzo90017 on May 24, 2016, 09:04:15 pm
Do you have any plans to sell Jukebox kits?
Post by: SNAAKE on May 26, 2016, 02:42:01 pm
random weeweecade sighting :burgerking:
Post by: HaRuMaN on May 26, 2016, 03:23:15 pm
That's always a possibility.  Next up for new designs though is a mini virtual pin kit.
Post by: HaRuMaN on May 26, 2016, 03:37:17 pm
lol nice!   :cheers:
Post by: Charlie97L on May 26, 2016, 09:47:17 pm
Oh no.  Well, the future!
Post by: deadmoney5 on May 27, 2016, 11:48:38 am
I still want to do a Q*BERT soon..
anybody done one yet?
Post by: HaRuMaN on May 27, 2016, 12:37:07 pm
That would make a good looking bartop...
Post by: Charlie97L on May 29, 2016, 02:53:41 pm
I'm so excited. :)
Post by: HaRuMaN on June 07, 2016, 01:14:57 pm
New kit added to the store:
http://shop.harumancustoms.com/index.php?route=product%2Fproduct&path=59&product_id=71 (http://shop.harumancustoms.com/index.php?route=product%2Fproduct&path=59&product_id=71)
(and yes, floriske's permission was obtained first)
Post by: wildbil52 on June 17, 2016, 11:33:58 am
My kit showed up a few weeks ago.  Looks awesome.  Artwork printed and applied, will finish wiring the cp tonight.  Mobo, cpu, memory, and PSU should be here on Saturday.  I'll post pics once its mostly together.
I was thinking about attaching the back panel using only 4 magnets, no hinge.  Basically I would attach two vertical wooden handles (you'll understand when you see the theme) to the back of the door so I can just pull the door off the back and set it aside  if I need to get into the machine.  The magnets need to be strong enough to hold the door on by themselves, though.
Considering these:  https://www.amazon.com/Extra-Strong-High-Magnetic-Catch/dp/B009ZTQUPQ/ref=sr_1_8?ie=UTF8&qid=1466177553&sr=8-8&keywords=cabinet+magnets (https://www.amazon.com/Extra-Strong-High-Magnetic-Catch/dp/B009ZTQUPQ/ref=sr_1_8?ie=UTF8&qid=1466177553&sr=8-8&keywords=cabinet+magnets)
Post by: HaRuMaN on June 17, 2016, 11:40:37 am
That should work, although it seems like a little overkill, you could probably get away with smaller latches.
Post by: wildbil52 on June 17, 2016, 11:54:44 am
Yeah, thats why i haven't pulled the trigger yet.  The magnetic latches I saw at the local hardware places all seemed very weak so I wanted to find something slightly heavier duty than the standard ones.
Post by: BDS on July 06, 2016, 07:46:20 am
Hi I'm new here. I had a couple of questions and I'm not sure it's in the forum and has been answered already, sorry in advanced if it is.
My questions:
What button size would I have to purchase for Haruman's Ultimate widesreen Bartop? Does Sanwa sell Led joysticks and Led buttons that could be used in it?
Thanks.
Post by: HaRuMaN on July 06, 2016, 12:14:38 pm
It's designed for Sanwa JLF (x2) and 30mm Sanwa OSBN (screw type, x 16) and 24mm Sanwa OSBN (screw type, x 6).
Don't know if there are LED versions of those available or not.  If not, I can always change the button / joystick holes to what you need.
Post by: BDS on July 06, 2016, 02:52:20 pm
Thank you for the information. No need to modify the bartop in my case ,those dimensions are perfect.
Post by: rincewind on July 09, 2016, 07:56:35 pm
My first post here. I was much more active on a Pinball cabinet sites but then decided to go ahead and build my own arcade bartop cab. I was a longtime arcadecontrols.com lurker - never registered on forum but always found my answers here through a google search :)
Anyhow, I want to thank HaRuMan for the CNC widescreen plans which I intend to cut on my own. Frankly, I'd go straight ahead and buy a pre-cut cab from you, but I live on the other side (Europe) and the shipping would cost me a fortune and money is tight now eh. :) So I decided to find a local cnc guy and try my luck. :)
Since I haven't bought a cab directly from you, I still hope I'm eligible for some forum help if I come across any "gotchas"
Thanks again
Post by: HaRuMaN on July 09, 2016, 08:49:04 pm
Sure thing.  Just let me know if you have any questions! :cheers:
Post by: rincewind on July 10, 2016, 02:28:24 pm
OK quick question, would I have to alter the plans for a 18mm thickness of MDF sheet? I think the only change should be the thickness of routed holes (for the horisontal plates) on the inside panels?
Post by: mR_CaESaR on August 26, 2016, 10:08:05 am
Managed to find this thread through the wonders if google and I would like to thank you for openly distributing the cad file.
I've recently gotten access to a CNC machine and I am hoping to get one of these built up.
I'm hoping to extend the width by 10 cm or so, so I can fit 2 players and a 19" dell monitor. Not too worried about being "cramped" as the target audience are my kids :)
Post by: HaRuMaN on August 26, 2016, 10:09:56 am
Hey there.  Good luck!  I also have the widescreen version posted on the first page, it's already wider and 2 players.  Don't know if you saw that one or not.   :cheers:
Post pics!
Post by: mR_CaESaR on August 26, 2016, 10:18:22 am
Post pics!
I did see that, but it's too wide for me. I want to put a 5:4 screen in and I feel the WS version will look too odd with excess bezel on the sides
I'll definitely post pics once it's all done (it'll be a while, I need to try and learn how to modify this in solidworks or something equivalent). Configuring the retropie atm to make sure it's perfect once it goes in to the bartop.
I think I'm also going to want to modify the panel a bit so it's Sanwa OBSF30/OBSN30 and JLF compatible with the correct 25mm height.
Post by: mR_CaESaR on August 28, 2016, 12:58:20 am
Finally managed to through the whole thread, and I found this...
Here's a rare beast. Someone wanted a widescreen in white, just shipped it to Tasmania, Australia this morning.
Out of curiosity, how much did this cost to ship down under?
Post by: HaRuMaN on August 28, 2016, 03:01:11 am
That was $155 (ouch)
Post by: mR_CaESaR on August 28, 2016, 03:44:07 am
Yes. Ouch is a great way to explain it.
After spending a few hours yesterday trying to muck around in solidworks, I realised even though I have access to a CNC, I have no way of being able to edit the file :)
The thought crossed my mind about getting one shipped over here to Sydney. After all the mods, I'd want, it'll end up costing a pretty penny :)
How customisable are the control panel options?
Post by: HaRuMaN on August 28, 2016, 10:28:11 am
Can customize to anything you want.   :cheers:
Post by: HaRuMaN on September 04, 2016, 03:56:46 pm
New coupon now through end of September.  $10 off a purchase of $100 or more.  Code is:
BYOACSEP
Post by: yotsuya on September 04, 2016, 06:30:58 pm
I heard a rumor if you type in the word COUCH as your code, you get to stay at HaRuMaN's house for free during ZapCon .
All kidding aside, that's a good deal. You should jump on it, people.
Post by: HaRuMaN on September 04, 2016, 06:48:40 pm
That only works for a select few...
Post by: Malenko on September 04, 2016, 06:52:46 pm
SHOW US YOUR COUCH!
Post by: Slippyblade on September 05, 2016, 01:26:44 pm
Pics or there is no couch.
Post by: yotsuya on September 05, 2016, 08:25:23 pm
I thought I had a picture of Malenko humping HaRuMaN's couch, but sadly it seems to have disappeared from my text messages.
Post by: Malenko on September 05, 2016, 10:14:39 pm
Ironically I dont think I ever even sat on his couch.
Post by: yotsuya on September 05, 2016, 10:15:25 pm
I know I had a couch photo somewhere...
Post by: yotsuya on September 05, 2016, 10:19:57 pm
(http://uploads.tapatalk-cdn.com/20160906/8335389d997f1b7c01ed83edf233b9ee.gif)
Post by: yotsuya on September 05, 2016, 10:20:19 pm
Oh, buy with confidence, folks!!!!
Post by: thomas_surles on September 05, 2016, 10:30:58 pm
How much for the couch shipped?
Post by: HaRuMaN on September 05, 2016, 10:32:22 pm
About tree fiddy
Post by: thomas_surles on September 05, 2016, 11:09:37 pm
About tree fiddy
It was about that time I realized that HaRuMaN was about 8 stories tall...
Post by: yotsuya on September 05, 2016, 11:25:20 pm
I could have sworn Malenko had more red hair...
Post by: raniel on October 05, 2016, 02:59:09 pm
Hey Haruman. I got the widescreen bartop kit from you. Im planning to use a PC, what do you recommend with regards to the size of the motherboard? I'm planning to use itx or matx due to small form factor. If I use the standard size would that give me problems? thanks!
Post by: RetroGreg on October 07, 2016, 09:49:55 pm
I finished this several weeks ago, but haven't posted pics yet. First time posting pics so if it goes horribly wrong I may need help lol.
Special thanks to Haruman and Malenko for the kit and the sweet ass artwork  :cheers:
Currently running a 412 in 1 which I don't recommend. I think it's worse than a 60 in 1. I'm going to replace it soon with either a PC or an ArcadeSD within the next couple of months.
Edit: More details - I used goldleaf buttons on the panel and a Sanwa JLW. The panel is kind of tight on the minitendo kit so I'd definitely recommend the goldleafs. They feel great in gameplay too. The JLW was a hard fit. I had to bend some of the switch pins to get it to work ok, but it's fine. I used a 15" Dell and that's really the best size to use in this kit. You can see everything ok even with the bezel art. It would be hard to see everything with a 17".
Thanks again guys  ;D. Now I want to see someone do a Donkey Kong 3. That would be rad. Now onto the widescreen kit I got at the same time. I want to finish all my projects before ZapCon!
Post by: HaRuMaN on October 07, 2016, 10:09:33 pm
Looks great!
Post by: Malenko on October 07, 2016, 10:33:01 pm
smexy.
Glad the art turned out well for you.
Post by: monkeybomb on October 15, 2016, 08:36:31 pm
Did a pedestal ever make it into the mix here?
Post by: HaRuMaN on October 17, 2016, 10:54:58 am
So there's been a few pedestals for the bartops... and then there have been a couple of actual pedestals.  I'm also currently working on a 4P player pedestal for a customer.
Post by: pti on October 23, 2016, 11:17:51 am
I've ordered all of the pieces for a Haruman Minitendo-based Pac-Man themed kit. I went with Ultimarc MagStick and Goldleafs, a 15" Dell E157FP, and an ArcadeSD board.
I am stuck on what to do for a speaker, though. It looks like I'll only have ~3.25" to work with. What did you use?
Post by: RetroGreg on October 24, 2016, 12:51:25 am
I used a basic 2 inch speaker I got on amazon. You don't need anything great for the old games.
https://www.amazon.com/Mini-Hobby-Speaker-inch-Ohms/dp/B007P44Y4W/ref=sr_1_1?ie=UTF8&qid=1477284273&sr=8-1&keywords=2+inch+hobby+speaker (https://www.amazon.com/Mini-Hobby-Speaker-inch-Ohms/dp/B007P44Y4W/ref=sr_1_1?ie=UTF8&qid=1477284273&sr=8-1&keywords=2+inch+hobby+speaker)
It fit pretty good. Drill holes to attach one side before you glue up the kit to make it easy to secure the speaker later. It's offset to one side of the grill but you can't see it from the outside.
Post by: booty900 on October 29, 2016, 08:52:00 pm
I'll be buying The Degenatron soon. I just have some questions. What buttons would work best for the control panel and the admin? Also if I got a switchable joy stick would I have enough room to reach under the control panel to switch it from 4 to 8 way? If not Id just get a happ joystick that is 8 way
Post by: yotsuya on October 29, 2016, 09:55:07 pm
I got nothing to add, I just wanted to state I love the username booty900.
Post by: HaRuMaN on October 30, 2016, 05:59:01 pm
Happ or IL style buttons.  For the admin, short buttons are best, like Ultimarc Gold Leafs.
You'd have to pull the panel up or go through the back to switch.  Going through the back would be difficult I would think.
Post by: booty900 on October 31, 2016, 12:05:10 pm
Now I have a different question. I just looked at The Offender bartop. I don't know much about control panels. But it looks like it is for 2 joysticks. So could I have a 4 way on the left and an 8 way on the right? And would a 17" monitor fit in the offender? And are happ controls for that one too?
Post by: HaRuMaN on October 31, 2016, 01:09:47 pm
It's for a multi-williams setup but you could do that with the joysticks for sure.  And yes, 17" monitor will fit and it is made for Happ / IL buttons.
Post by: Jarozi on January 03, 2017, 03:22:32 pm
I ordered a Haruman Ultimate Widescreen kit and have started to build.  Can someone let me know what buttons and joysticks will fit?  I ordered the stock kit. Thanks!
Post by: HaRuMaN on January 03, 2017, 03:24:22 pm
Hey there.  So you need 2 Sanwa JLF joysticks, 16 x Sanwa OBSN 30mm, and 6 x Sanwa OBSN 24mm.  (OBSN are the screw in type)
Post by: Jarozi on January 03, 2017, 10:05:34 pm
Thanks! Are there any alternatives to the OBSN's?  I can't find a source for white 24mm's or black 30mm's.
Post by: HaRuMaN on January 03, 2017, 10:06:20 pm
Seimitsu makes an equivalent button
Post by: wildbil52 on January 24, 2017, 10:36:48 pm
It's about time I posted some pics of my (nearly) completed Haruman Bartop.  I went with an NHL 94 theme.
(http://i.imgur.com/YWmdgPD.jpg)
(http://i.imgur.com/vS988cU.jpg)
(http://i.imgur.com/KaeFh7R.jpg)
(http://i.imgur.com/zVXeCDD.jpg)
(http://i.imgur.com/3lVqKvj.jpg)
(http://i.imgur.com/W0VRev6.jpg)
Post by: HaRuMaN on January 25, 2017, 09:14:40 am
That looks GREAT!  Nice work, and thanks for sharing the pics!   :cheers: :cheers:
Post by: jdevane on January 25, 2017, 05:37:39 pm
Love the NHL 94 theme... beautiful...
Post by: alomar123 on January 26, 2017, 10:33:02 am
Has anyone tried putting in a 20" Dell 2007FP (vertical of course) in the Pretendo with Nintendo bezel artwork? It looks like it should fit per the dimensions but I am just not too sure.
Post by: HaRuMaN on January 26, 2017, 10:36:15 am
It would be close but I think it would work.
Post by: gonzo90017 on January 28, 2017, 02:39:29 pm
Nice theme. Can you provide some info on the artwork and how it was printed?
Post by: wildbil52 on January 31, 2017, 11:20:50 am
Sure.  The designs are all mine but I did get a little photoshop/InDesign assistance from a few friends.  The logos on the bezel were pulled from the NHL 94 matchup screen and the images on the front and CP were screenshots pulled from a game of NHL 94 running on Fusion.  The art was printed by Bowman signs in Milford, CT (Lucian045 here on byoac).  Brad is awesome and does lots of arcade and pin printing.  The CP has a polycarbonate coat on it for protection.  Looks and feels amazing.  We reverse printed the bezel and marquee so we get that nice shiny look of the plexi.  Fits with the theme, reminds me of the glass above the boards in a hockey rink.
Post by: Jarozi on February 05, 2017, 04:02:25 pm
Thanks again for all the help, getting nearly done with my Neo Geo themed Haruman Ultimate Widescreen can.
Can someone advise on a hinge solution for the back door?  I bought some little hinges but they aren't working.  I have the stock kit with the hinge tabs and door stops.
Post by: HaRuMaN on February 05, 2017, 04:07:25 pm
I did mine like this with some fat hinges:
Post by: Jarozi on February 05, 2017, 09:30:04 pm
What did you use on the latch mounts to keep the door closed?  Thanks!
Post by: HaRuMaN on February 05, 2017, 09:32:26 pm
I used the same magnets as the control panel but they are way strong, I would probably use industrial Velcro next time.
Post by: Jarozi on February 05, 2017, 09:51:07 pm
Ok, I picked up a pair of these that I'll try.
http://m.acehardware.com/product/index.jsp?productId=35265766 (http://m.acehardware.com/product/index.jsp?productId=35265766)
Post by: HaRuMaN on February 11, 2017, 11:58:46 am
That should work
Post by: soonerdoc on February 14, 2017, 01:28:52 pm
Hey all.
Been emailing Lee about some different things and don't want to keep bothering him.
Anyone have a place they recommend for joysticks and buttons and USB board to run them?  Was thinking about the package of sanwa joysticks with buttons to fit 28 mm diameter button holes from another site.  It comes with 20 buttons, two sticks and the USB encoder as well as an image to flash for RaspPi setup for the button assignments.
Anyone have any other suggestions?  THANKS!!
Post by: soonerdoc on February 24, 2017, 12:10:04 am
So, I found a couple places for buttons and sticks.  Pretty much ready to order.
Do the Sanwa push buttons or screw in buttons work better with Haruman's kits, or is it just personal preference.
Also if you want to customize a couple of things do you place the order than contact Haruman's or do they need to be notified first?
Post by: HaRuMaN on February 24, 2017, 08:38:44 am
Screw in works better.  The snap ins require a thinner (metal) panel.
You can leave a note when you checkout, that works fine.   :cheers:
Post by: Desperado on February 25, 2017, 10:51:41 am
I ordered my button set from eBay. The cheapest I found was $61 for 16 Happ buttons and 2 Happ Joysticks.
Hey all.
Post by: Wraithalchemist on February 26, 2017, 08:48:00 am
I am about to start a bartop for myself at a local shop I've found and was wondering if there was any way I could get the CNC plans for you ultimate wide-screen bartop. Also have you ever tried doing this with with plastics? Ive found a place nearby that will sell 4x8 sheets of industrial grade cutting boards at 1/2 and 3/4 inch thickness. Ive watched you videos and would love to have it in the format that you put into the machine if possible and not the way it is laid out in the plans I've seen on page one. I appreciate your time and thanks. What is your turnaround time right now if my friend orders Monday. He's not as brave lol.
Post by: equlizer on February 26, 2017, 05:09:11 pm
Almost done building another bartop and i will be using sanwa push buttons.  Using a cnc machine we made the holes slightly smaller than 30mm so they are very snug and work/look great.  You could also wrap some black electrical tape around the button then push it in.  also if you change your mind, the regular happ buttons work 100% in the 30mm holes.
Post by: Wraithalchemist on February 27, 2017, 11:25:05 am
Does anyone have the plans for this?
Post by: HaRuMaN on February 27, 2017, 11:28:21 am
I don't share the plans for the ultimate widescreen, sorry.
Also, the plans I just do up in autocad (like the ones on the front page) and they are imported into VCARVE PRO by my CNC guy...
Industrial grade cutting board would be interesting.  I have thought about cutting one in ABS or acrylic before, just have never done it.
Current turnaround times are 4-5 weeks.   :cheers:
Post by: boomerps2 on March 15, 2017, 03:59:44 pm
Is there any templates for the Ultimate Widescreen that can be used in Adobe AI or CS6 so we can come up with our own art. I noticed the CNC plans for the entire bartop but nothing with individual pieces to put art on. Thanks.
Post by: smass on March 15, 2017, 07:16:24 pm
Question for Haruman:
I am looking into ordering a cocktail kit for a friend.  I will be doing the build but I don't have any experience with cocktail cabs.  I notice yours is designed for a 4:3 monitor.  Another vendor makes one for a 16:9 monitor.  I played around with cocktail mode a bit on one of my mame cabs (which uses a 4:3 monitor) and it seems to work well for head to head games.  Is there any reason to consider a 16:9 for a cocktail?  Seems to me that you would either have black bars for most games and you would need to futz around with scaling for head to head.  The only advantage to 16:9 that I can think of would be for pinball emulation.  Am I missing anything?
Post by: HaRuMaN on March 15, 2017, 08:37:54 pm
What's your order number?  I'll email you what I have.
Post by: HaRuMaN on March 15, 2017, 08:39:11 pm
16:9 is more available, that would be the only reason I would think.
However, the 4:3 Dell 2001 or 2007 FP are still easy to find, and are 20.1" 4:3 with excellent viewing angles.
Post by: yotsuya on March 15, 2017, 10:42:48 pm
Amen. These monitors all day...
Post by: JDFan on March 16, 2017, 12:26:37 am
Agreed - Also the Samsung syncmasters (213T and 214T) which are 21.3" 4:3 monitors as well  :cheers:
Post by: Firepro4Life on March 17, 2017, 10:21:36 am
Speaking of the cocktail kits, would these be able to accommodate a 19 in CRT monitor if I was to rig up some kind of mounting system?
Sent from my iPhone using Tapatalk Pro
Post by: smass on March 17, 2017, 10:51:02 am
I found a 2005fp dell 4:3 on CL.  I have been googling to find out if its also IPS panel.  No luck - does anyone know?
Post by: HaRuMaN on March 17, 2017, 12:29:00 pm
They should work fine with the system I already have.
Post by: HaRuMaN on March 17, 2017, 12:29:48 pm
Well the dell 2005FPW (widescreen) has the good viewing angles 88/88 all around, so the 2005FP should too
Post by: JDFan on March 17, 2017, 12:41:45 pm
Are you sure ?? I don't recall there being a 2005fp - only the widescreen fpw which was 1680x1050 resolution so a 16:10 aspect - could be they listed it wrong.
Post by: smass on March 17, 2017, 01:33:07 pm
Here is the CL listing https://albany.craigslist.org/sys/6036537846.html
From the picture it looks like a 2001fp - but the front controls are different...the 2001fp has a power button and four additional menu buttons - this one has a power button and 3...  Seller hasnt got back to me to be sure...
EDIT - so I did some more searching on ebay and looking at pictures of monitors.  Also went to wikipedia.  Dell did not make a2005fp as you stated.  The 2001fp - interestingly - seems to have come with one of two different front control layouts.  So this one must be a 2001fp afterall....so if the seller ever gets back to me I am going to try and snag this one.  :)
Post by: JDFan on March 17, 2017, 02:07:23 pm
Yep that looks like a 2001FP - If you do get it be sure to get the Power brick (those have the power supply externally like a laptop power supply not inside the monitor case ! ) You can buy them but they run about $15 - $25 by themselves - so can add to the cost )   :cheers:
(http://i.ebayimg.com/images/g/qfsAAOSwPhdVCjYT/s-l1600.jpg)
Post by: soonerdoc on March 19, 2017, 04:34:24 pm
Hopefully my Ultimate Widescreen from Haruman's will be arriving in the next couple weeks.
Anyone have any tips on art for the cabinet?  Anyone know a place or somebody that has pre-designed art for these cabinets that can be printed onto vinyl and applied?  Don't necessarily want to design my own (not artistic at all).  Would love to find some that has been pre made.
thanks,
Vincent
Post by: HaRuMaN on March 27, 2017, 12:38:48 pm
Have an extra widescreen in Baltic birch, cut somewhat custom. Control panel is set up for Sanwa JLF joysticks and 16 30mm Sanwa screw in type buttons.
Admin panel has 2 30mm Sanwas on either side, and cutouts in the middle for 2 NovaGem (by Groovy Game Gear).
Back door has a single cutout for a 120mm fan, and speaker panel has 2 3" round cutouts for speakers.
Any one interested? Can do it kit only, or can do a "deluxe" kit with monitor / bezel plexi, retainers, T-molding, & VESA screws.
Let me know!  :cheers:
Post by: HaRuMaN on March 30, 2017, 11:28:10 am
Newly redone website has launched!
https://www.harumancustoms.com/ (https://www.harumancustoms.com/)
Take a look.  Also have a 5% coupon off your entire order from now to April 15th, coupon code RELAUNCH
Post by: NIVO on April 03, 2017, 04:45:48 pm
the site is amazing. Love it alot more than the previous version. Very easy to navigate.  :cheers:
Post by: HaRuMaN on April 03, 2017, 04:52:04 pm
Thanks!  Yes, it's a lot better now.   :cheers:
Post by: efp9teen78 on April 04, 2017, 02:31:23 am
Widescreen:
[/quote]
So I am interested in one of these for my widescreen  just have a few questions
1) Do you know how tall this makes the cabinet stand ? like from floor to approx where control panel would be
2) Can it be modified so the  stand is wider then the Cabinet instead of narrower?
3) About how much would it cost and what is expected lead time on it?
Thanks in advance
Post by: DeLuSioNal29 on May 04, 2017, 12:19:34 pm
It will be even better once you post this vid to it.  :-)
http://youtu.be/fwI6hNlFn4w (http://youtu.be/fwI6hNlFn4w)
DeL
Post by: NIVO on May 07, 2017, 09:30:10 pm
lol shameless. I'll be over on tuesday to play Del.
Post by: DeLuSioNal29 on May 08, 2017, 12:39:17 pm
Ha ha!  At least it belongs here and is related (I collaborated with Haruman and created it just for his website).
DeL
Post by: Erzak on May 12, 2017, 01:19:26 am
What ever happened with the Vewlix design? I  found one photo in another thread. Am curious what size monitor it would hold, cost, and dimensions of CP (for possible customization). Am wanting to build a stand-up cabinet and that looks like a cool design, plus am in AZ so no shipping needed.
Thanks, Eric
Post by: Erzak on May 12, 2017, 09:25:16 am
Hmm, after doing some more Google research, the Vewlix is aimed at being a sit-down cabinet, is that right?  If so, that's not what I'm looking for.  Unless it can be "stretched" upward to a more traditional stand-up height...
Post by: HaRuMaN on May 12, 2017, 09:56:45 am
It is a sit down, correct.  To make it a stand up, the base would just need some added height...
Post by: Erzak on May 12, 2017, 12:26:39 pm
So what size monitor does the Vewlix take?  From the picture I saw, looks to be fairly good sized, definitely not a 23" or 24".  Guessing it might be a ~30" TV in there?
Have you done any stand-up cabinets in the past that take a 23"/24" LCD and have a control panel about the width of that Vewlix?  The CP looks to be about the size I'd want, since I'd like a 2-player setup but also have a trackball in the middle and a spinner up towards the top and centered more or less.
Post by: imJGott on June 26, 2017, 04:26:24 am
after watching videos on youtube and finding this gem (from google search) im sold on getting the ultimate widescreen by haruman. before i place my order, and ill make a note in the order if im able to provide it, i would like to add an addition button on each side for pinball play if possible. im still doing some research on running hyperspin because i do intend on placing a pc inside this unit so i can play retro and current games. hopefully i should be able to place my order before july 4th so i can have in time to assemble this beast while im on vacation. also, im going to with a 24in monitor since it fits this unit nicely!
Post by: HaRuMaN on June 30, 2017, 06:16:11 pm
Seeing as I'm back from vacation and ready to go, how about a coupon?
From now until July 15, use coupon code VACATION to receive 10% off your entire order.
Post by: imJGott on July 01, 2017, 03:10:37 pm
welcome back! with this discount it looks like ill be placing an order next week. quick question about the ultimate widescreen unit. can add pinball buttons on to the side of the cabinet with my order when its made? not sure if i can add this information when i place my order.
Post by: HaRuMaN on July 01, 2017, 03:12:53 pm
Yes you can, just leave a note when you checkout and I will add the pinball buttons.
Post by: rave0035 on July 05, 2017, 01:15:37 pm
Ordered an Ultimate Widescreen a few months back and couldn't be happier with build quality, packing & shipping, and communication with Haruman,  If you're on the fence about ordering one, do it!  (I have yet to assemble it, but...)
I'm a little overwhelmed by artwork choices.  Is anyone churning out side out or marquees for these 'a la carte'?  I would imagine there's a market given the popularity of these kits.
I've got some ideas and themes but am looking for a place to start.
Mike
Post by: HaRuMaN on July 05, 2017, 01:18:29 pm
Thanks!!   :cheers:
I'll PM you Malenko's email, he does a lot of art for my customers.
Post by: imJGott on July 06, 2017, 10:16:58 pm
going to place my order tomorrow but i have one more question. is it possible to cut out a 230mm hole in the back to accept a 230mm fan for exhaust us in the back? i would like to go into some detail to the position of the fan due the reason i want to install a motherboard on the back door. once i make the order we can go into some details there unless this forum is ok. (i do have a smaller 140mm fan i could use if the 230mm is considered to be to large.)
Post by: HaRuMaN on July 06, 2017, 10:36:10 pm
230mm is probably too big if you're going to have a motherboard on there as well...
Sent from my SPH-L710T using Tapatalk
Post by: imJGott on July 07, 2017, 08:51:41 pm
thanks for the reply. ill use the 140mm fan instead and list that in the notes while im placing my order.
Post by: honkbahh on July 22, 2017, 04:18:48 am
Finished! Big thanks to everyone on the forum, as well as other forums on the web, and haruman of course! Ran through metal slug 2 (literally) cause I finally had a few minutes to give the arcade a somewhat lengthy test run. 32 continues, but it was for science! By far the biggest challenge was rocket launcher and hyper spin. Thanks all!
(https://sites.google.com/site/arcadepicshonkbahh/home/IMG_2833%20copy.JPG)
(https://sites.google.com/site/arcadepicshonkbahh/home/IMG_2835%20copy.JPG)
(https://sites.google.com/site/arcadepicshonkbahh/home/IMG_2837%20copy.JPG)
(https://sites.google.com/site/arcadepicshonkbahh/home/IMG_2839%20copy.JPG)
(https://sites.google.com/site/arcadepicshonkbahh/home/IMG_2841%20copy.JPG)
Post by: 05SRT4 on July 22, 2017, 08:13:48 pm
That collection though.
Bartop came out really nice, well done.
Post by: imJGott on July 24, 2017, 10:21:43 pm
HaRuMaN:
do you have a file where i can add vinyl to the cabinet?
Post by: HaRuMaN on July 24, 2017, 10:29:07 pm
HaRuMaN:
Are you asking for templates?
Post by: imJGott on July 25, 2017, 01:29:13 am
HaRuMaN:
yes sir
Post by: imJGott on July 26, 2017, 11:53:55 am
HaRuMaN:
yes sir
can i have that file so i can add a vinyl image? not sure where it is located on your site. unless you have a vendor that does the vinyl prints i can work with
Post by: HaRuMaN on July 26, 2017, 11:56:06 am
HaRuMaN:
yes sir
Hey sorry about that, I'll send them when I get home today (they're on my home PC).   :cheers:
Post by: imJGott on July 27, 2017, 06:48:52 pm
thanks for the file, i got in my email. what buttons do you recommend to use with your cabinets? i havent decided if im going with sanwa or another in terms of joysticks but i assume ill need a screw type of push button. suggestions?
Post by: HaRuMaN on July 28, 2017, 11:26:15 am
Personally, can't go wrong with the Sanwa OSBN (screw type).  Keep in mind your kit has been cut for 30mm buttons X 16, and 24mm buttons X 6, all screw type.  Joystick hole mounting pattern is the typical Sanwa JLF (another great all around stick, IMO).
Post by: imJGott on July 28, 2017, 04:44:58 pm
thanks for the advice! i was looking into the IL push buttons since they have a wider color selection that i have seen. but from my 8bitdo fightstick experience im a little hesitate on sanwa parts. i believe my fight stick doesnt have real sanwa parts but if they are legit then im just disappointed on how they have been performing for me.
oh yeah, package has been delivered! still ironing out on which cpu to go with for my build on this cabinet.
Post by: HaRuMaN on July 28, 2017, 04:54:32 pm
Personally I love the real Sanwa stuff, but for sure, the knock offs can really not feel right.
Post by: imJGott on August 06, 2017, 11:29:15 pm
i finally started to assemble this cabinet but i havent ordered my buttons, joystick or control board. will these buttons work?
https://www.focusattack.com/pushbuttons/popular-brands/industrias-lorenzo/ (https://www.focusattack.com/pushbuttons/popular-brands/industrias-lorenzo/)
Post by: Phreakwars on August 09, 2017, 01:58:45 am
They will work as long as you use shortened buttons for the admin CP. Otherwise, they will bang into each other.
Post by: HaRuMaN on August 09, 2017, 10:15:48 am
He has the Ultimate Widescreen.  No buttons on the admin.
Post by: HaRuMaN on August 09, 2017, 10:16:53 am
While those buttons will fit, they are a little small (~28mm) for the holes (30mm).
Post by: imJGott on August 10, 2017, 11:28:07 pm
the drawing on the right shows the width of the outer most ring at 33mm unless im reading it incorrectly.
(https://cdn2.bigcommerce.com/server500/d90a4/products/1193/images/5322/il_PSLCV_A0212_spec__59073.1421974556.1280.1280.png?c=2)
as for the admin buttons, wouldnt the 3 buttons above the 1st and 2nd player be considered admin buttons if i set them that way?
Post by: JDFan on August 11, 2017, 12:52:51 am
Yes - what they were talking about is on some models the admin buttons are on the front panel under the Control panel and are put in place sideways from the front of the system - and the longer buttons wind up hitting the Joystick/other buttons - so for those you need to use shorter length buttons.
for example the 6 buttons on the normal widescreen model
(https://www.harumancustoms.com/sites/default/files/styles/product_detail_main_image/public/widescreen-bartop.jpg?itok=A9UKRLqh)
Post by: Quattro on August 12, 2017, 03:58:07 pm
Hey Haruman, I can't PM you as my account is new. I have quite a few questions about the Ultimate Widescreen kit. What would be the best way to contact you? I tried your phone number but no luck.
Post by: PL1 on August 12, 2017, 06:21:56 pm
Welcome aboard, Quattro.   ;D
Your PMs should work now.   :cheers:
Post by: HaRuMaN on August 12, 2017, 06:23:53 pm
Sorry we've been cleaning house today with the radio turned wayyyyy up.  Email works best, haruman@gmail.com
Post by: dluusional on August 13, 2017, 01:52:05 pm
honkbahh, where did you get the artwork from?
Post by: SNAAKE on August 15, 2017, 01:25:55 pm
and which monitor did you use? look like a super exact fit lol
Post by: rflores2323 on September 04, 2017, 09:24:44 pm
I was wondering if the bartops can be mounted to the wall?  I wanted to buy a 2 player bar top box and then put a  jamma pandora 4s fighter stickbox..  can this be done as I see you have cut outs already but I rather get one of these bozlxes that already come with all the hardware and games.
Sent from my SM-G950U using Tapatalk
Post by: HaRuMaN on September 05, 2017, 10:06:23 am
You could probably mount to the wall.  I wouldn't do that with the melamine / mdf version though, I would only do that with the birch plywood one.
Post by: HaRuMaN on October 31, 2017, 09:47:02 am
I'm back! Thumb has healed up enough for me to start working kits again and to celebrate I've set up a coupon for 10% off all orders.
Use coupon code ALLTHUMBS to receive your discount!
I also want to take this opportunity to thank my customers for their patience while I heal up. I'll be working hard over the next few weeks to get caught back up.
Thanks again!
Post by: Mike A on October 31, 2017, 09:51:28 am
Shouldn't it be "NOTHUMBS"? ;)
Glad you healed up okay.
Post by: HaRuMaN on October 31, 2017, 09:53:11 am
Or maybe ONEGOODTHUMB, lol.
And me too, scariest accident I've had with a power tool for sure.
Post by: NIVO on November 03, 2017, 02:18:56 am
thumbs up to a great seller and friend. you cant go wrong folks. I shall have mine done very very soon!
Post by: SNAAKE on November 06, 2017, 03:09:03 pm
too soon for "thumbs up"  :police:
Post by: HaRuMaN on November 06, 2017, 03:16:01 pm
Haha!   :cheers:  Maybe 0.5 thumbs up :P
Post by: busbeepbeep on November 28, 2017, 10:45:43 pm
Decided to try to tackle one of the Haruman bartop kits.   Trying to decide between the Ultimate Widescreen or the WIDESCREEN EVO XR 2.  Hoping for something that can accommodate 2 adults playing Street Fighter 2 comfortably.  Plan on using a 24" 16:9 monitor or a 23" 16:10.
Think I've decided to go with IL Eurostick and iL concave buttons.
Post by: TheGreatRedDragon on November 30, 2017, 08:32:30 am
There's a widescreen Evo XR?
Post by: busbeepbeep on November 30, 2017, 08:43:59 am
Yeah, looks to just been added in the last week.
https://www.harumancustoms.com/products/bartop-kits/widescreen-evo-xr-2 (https://www.harumancustoms.com/products/bartop-kits/widescreen-evo-xr-2)
Ultimate Widescreen: 26.25" H, 21.5" D, 24" W
Regular Widescreen: 21.45" H, 18.6" D, 23.0"  W
Evo XR2 Widescreen: 27.5" H,  21" D, Width (Main Cabinet - 24") (Control Panel - 27.65")
Regular EVO XR2: 27.5" H x 21" D,  Width (Main Cabinet - 20.85") (Control Panel - 24.5")
Post by: HaRuMaN on November 30, 2017, 09:03:12 am
Yes, I just have to get the render pic done and posted.
Here is what it looks like, dry fit before I shipped it out:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=149895.0;attach=363894;image)
Post by: TheGreatRedDragon on November 30, 2017, 09:40:39 am
She's a beaut.
After almost two years of deliberation I finally settled on the Evo XR as my kit of choice and I'm 90% done with the art package but now I might have to bump up to the widescreen version. That extra wide CP looks super comfy.
Post by: HaRuMaN on November 30, 2017, 09:43:19 am
Thanks!  It's even wide enough to do 2 player 6 buttons each & a 3" trackball (Utrak).
Post by: TheGreatRedDragon on December 01, 2017, 03:36:53 am
Is the internal roomy enough for an ATX motherboard or is that too big?
Post by: HaRuMaN on December 01, 2017, 07:34:46 am
Should be.  Have dimensions?
Post by: TheGreatRedDragon on December 01, 2017, 07:52:00 am
Of the motherboard? 12 x 9.6".
Post by: busbeepbeep on December 05, 2017, 09:11:29 pm
She's a beaut.
I decided to go with the widescreen XR, and Haruman's post convinced to go with a trackball also.
Planning for iL Eurostick joysticks and iL or Happ 28mm buttons and a 3" Utrak.
I think I'll use an ipac-2 for the controls unless someone has a better suggestion.  Initially using a Pi3, maybe eventually a PC.
Got a 24" Benq RL2455 gaming monitor on Black Friday
Post by: steved61 on December 06, 2017, 01:47:04 pm
I have been trying to contact Haruman about a custom Trackball/Spinner control. After 4 emails no answer ?
Steve61
Post by: HaRuMaN on December 06, 2017, 01:53:04 pm
Steve61
Hey I saw your emails, sorry, been trying to catch up on communications today.   :cheers:  Will send you an email in a bit.
Post by: steved61 on December 06, 2017, 03:12:15 pm
Take your time, with the Holidays and such. Just wanted to make sure I was was loseing your emails in spam.
Thanks.
Post by: Ginsu Victim on December 13, 2017, 12:18:16 pm
Saw this post on Reddit thanking HaRuMaN
https://www.reddit.com/r/cade/comments/7iirio/neo_geo_barcade_finished_thanks_to_haruman/ (https://www.reddit.com/r/cade/comments/7iirio/neo_geo_barcade_finished_thanks_to_haruman/)
Post by: ivwshane on December 25, 2017, 10:57:00 am
The control panel is 1/2" thick correct? I'm guessing that means it won't take Sanwa obsn type buttons, especially if plexiglass is used?
For un drilled cp's what's the best way to cut the button holes? I have a 24mm forstner bit but I'm not sure how well that would work with melamine.
What size speaker does this take, 3"? And does anyone have a recommendation on a particular one and a corresponding amp?
How thick is the plexi bezel and how is it installed/held in place?
And lastly: how do you handle lighting the marquee?
Post by: HaRuMaN on December 25, 2017, 03:18:43 pm
without plexiglass you can use the screw in types as I route away .25" from the wood.  Which kit are you looking at?
Forstner bit works great if you take it slow and have sacrificial wood underneath.
Post by: ivwshane on December 25, 2017, 07:44:04 pm
The widescreen bartop.
Post by: busbeepbeep on December 26, 2017, 04:33:25 pm
Excited about my bartop kit.
Santa brought me the IPAC-2 board, already got a bunch of iL buttons and  2 iL eurostick joysticks, plus an ultitrak trackball.
Got an RPI3 all geared up with a 128gb card running Hyperpie.
Post by: SNAAKE on December 26, 2017, 06:48:21 pm
you dont even need ipac tho lol
those xin mo encoders work just fine with PI..2 player version too :applaud:
Post by: busbeepbeep on December 27, 2017, 01:29:00 am
Got the iPac since I'm using the trackball. If had to get the USB interface cable for the ultitrak with a xin mo or zero delay, then I'd just be a few dollars less than the ipac2 anyway.  And I plan on eventually going with a PC instead of rpi3 if that matters.
Post by: hgaudini on December 29, 2017, 12:17:17 pm
Hey HaRuMaN,
Are you releasing the plans or cnc files for your 2 Nintendo barcade cabinets?
I would like to build each one.
Post by: HaRuMaN on December 29, 2017, 05:43:19 pm
Hey HaRuMaN,
No I am not.  However, if you get the files from here:
https://www.classicarcadecabinets.com/donkey-kong.html (https://www.classicarcadecabinets.com/donkey-kong.html)
And basically chop off the bottom and scale it down, that's basically what I did.   :cheers:
Post by: Cilrider on January 08, 2018, 11:12:01 am
Huge thanks to Haruman (Lee)! Even after he got injured, he still took the time to reply back to my emails about my bartop order.  If you're in the market for a bartop or a bartop the you can customize, reach out to Lee.  He produces an incredible product and he takes the time to answer any questions you might have!
Here's my Haruman customs evo xr2 bartop.
Thanks again Lee!
Post by: SNAAKE on January 08, 2018, 11:53:27 am
^ looks good. which monitor are you using? looks like a 4/3" ratio ???
Post by: Cilrider on January 08, 2018, 12:32:23 pm
Yeah! I decided to get with a HP LP2065 (4x3) 20" monitor. Most of the retro gaming I'll be enjoying is 4x3. However, I'm still lusting over more modern widescreen games like Tekken 7. I'll just deal with the "letterboxing."
Post by: HaRuMaN on January 08, 2018, 03:29:01 pm
Looks great!!!!
Yeah the EVO is set up with 4:3 in mind.
However the EVO widescreen can do up to a 24" widescreen.
Post by: busbeepbeep on January 09, 2018, 02:00:30 pm
How many of those EVO Wides are out in the wild?   My kit set to arrive Thursday.  Hopefully I can successfully build a bartop and post a finished pic on here.   Though I won't have any artwork.
Post by: HaRuMaN on January 09, 2018, 02:01:13 pm
This will be about the 4th or 5th wide I think?
Post by: jdevane on January 10, 2018, 09:53:09 am
I'm so glad you take extra care when packaging your products for shipment.  FedEx doesn't apparently feel the same way, but at least nothing inside the box was damaged!
Have one side glued together and I am going to try and get the other side done tonight before I have to leave for a work trip tonight.
Post by: HaRuMaN on January 10, 2018, 09:57:27 am
They seem be to extra brutal as of late.  I recently assembled a bartop and shipped it to the customer...  luckily the customer had security cameras on the driveway, he provided me with video of the driver slamming the package to the concrete...  after dropping it on another box in the truck and crushing that box.
Amazingly, FedEx didn't fight me on that claim.   ::)
Post by: jdevane on January 10, 2018, 10:50:30 am
Our normal delivery guys around here are great, I deal with them a lot with work, so I know them, but yeah, lately, with the seasonal help, they could care less.  We have a seasonal guy servicing our office right now, and we had received a wooden office bookcase that was broken in the package.  We have a return label on it and it sits up front for the delivery guy.  When he came by every time before Christmas, his truck was slammed, wall to wall, I told him wait until it slows down and he can get it then, because it is a big box.  So finally, last week, he stops in to drop off a package for me (which is leaves at the very first open door he comes to mind you, not my office, 30 feet further down the hall) grabs the bookcase box and heads outside...  10 minutes later a lady tells me there is a big box sitting in our parking lot, I go outside and low and behold its the stupid bookcase.  Apparently, when the guy took it, he just set it down at the back of the truck, forgot it, and drove off.  So it's once again sitting at the door, waiting on him.  I have two deliveries coming this week, so we are going to try again.  If he fails this time I'm reporting him.  Our normal guy would have never treated us like this.
Post by: busbeepbeep on January 13, 2018, 06:52:32 pm
OK.   Got my Widescreen EVO XR kit from Haruman.  Took inventory of everything and tried to line everything up using the Ultimate Widescreen instructions.   Think I got the dry fit right.
Ordered some EZ-Lok press-fit inserts to undermount my iL Eurosticks and will have to figure out how to install the threaded inserts that came with the Ultimarc U-trak.
Just bought a 2'x2'x 1/2" scrap piece of MDF from Home Depot to practice on.
Post by: busbeepbeep on February 01, 2018, 08:49:36 pm
OK Lee, and others.  I need help.
Finally got some time to work on this.   I got everything glued together.  Here it is standing up, and I have the Control Panel sitting on there as a dry fit with the weight holding it in place.
Except I discover there's interference for what is planned to be the Start and Coin buttons on both sides.
What's my best remedy?
Also, the kit came with 2 magnetic latches.  ARe they both for the control panel or is one for the back cover?   The back doesn't have a latch piece like the Ultimate Widescreen instructions show.
Post by: JDFan on February 01, 2018, 09:16:14 pm
Looks like you should be able to just cut that portion of the lower board off - pretty much any type of saw would be able to be used - If you don't have one Harbor freight has a flush cut pull saw for about $8 that would work
(https://shop.harborfreight.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/i/m/image_14973.jpg)
Just cut enough of it off to have room for the button nuts to fit in place and it should not show once the CP is placed on ( think that panel was designed for a different button layout ( like the pic below ) and in moving them he probably forgot to check the clearance )
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=130522.0;attach=364633;image)
Post by: HaRuMaN on February 01, 2018, 09:44:32 pm
Yes, sorry about that, new kit, non-standard layout, I missed the interference.
Like JDFan said any saw will do there really.
The magnets are for the CP (both of them).
Thanks.  :cheers:
Post by: busbeepbeep on February 01, 2018, 10:22:18 pm
Ok, so looks like I'll have to find some tools.  I only have an 18v drill, screwdrivers, and wrenches.   Think my friend has a Rotozip that could probably work.
So what's the best or intended way to latch the rear door?   It just sits in there?
Post by: busbeepbeep on February 05, 2018, 03:20:57 pm
Getting there.   All hardware undermounted with threaded inserts.   Successfully drilled and hacked away some of the material interfering on the CP support.
Time to wire up the CP and learn how to program an Ipac2.
Thanks for all the tips and support so far.
(https://i.imgur.com/ZuPV1L8.jpg?2)
(https://i.imgur.com/EYCcuJI.jpg)
(https://i.imgur.com/7bQg0X0.jpg)
Post by: steved61 on February 06, 2018, 07:36:24 am
Kit looks great. I hope to get one soon.
SteveD
Post by: TheGreatRedDragon on February 09, 2018, 03:27:53 pm
Really loving the look of that widescreen.
Post by: busbeepbeep on February 20, 2018, 02:49:03 pm
Just about done.   Though I'm sure I'll be tweaking software and config files and game lists forever.
Just need a proper printed marquee and I should be good to go.  Looks like the marquee area is 23"x5", whereas most prints sold online seem to be design for 23x8" or 23x9".  Also plan to add speakers and an amp, but the LCD has built-in speakers that are getting the job done for now.
Used a black posterboard to make a bezel to hide the LCD as someone else had suggested somewhere in this thread.  It was a bit of an arts and crafts project going back and forth with masking tape on the plexi and measuring.
I need to start a proper project build thread.  Maybe I'll wait til I get a marquee.
(https://lh3.googleusercontent.com/nyFMPU_CFxOtXCvbKh85A_dfX8fMD7UrJAiQwOXd9yLCwhopABobJc0dAdV_tiaQYKg5YeFqsypH__-ca7GZ8KH7tlqcGPeaAl5rpKexSXP_cZBHiXQivIxdDRnJwvfaYydnLEk4aHwVqjMkzDAyMyJP-weOnUVosMJrYsvgS3nRzNjnHunOlk7M-TF14lewkeeIhlruiHnXS9jbAUMbxD-EJECBpv7XzAOLGYbj2fqkqfkae6MsnJCDr0z99zj1zr8Oa5Qal0coC8QHOXRW0nps5MY4dkCObA3fd81Gm26TXWkUkzPF2usgxhgzuMbfjm6D7bsgyNs7Ws_s5PJTS2b1-cFII9MaicBlPEBWCng4FfFjGKXla8qimn91O24rLTB5Wz6QY7fj7HXy0Z4ywjhCIxcS5DH7d-PfJxWaPfCuHzoGO5NfYdj_KGMosiBOOfQJp3CoODIuB4lLSpoQbIY4wyDq6hu60xw3XX6Ja28H_hW8FLVrPQr7r-1no8l47a55h_NDq5u-WaPQ0Pc35Ymxzou9sYmh52M3-ZkgkQv917fXsdDyr64aS1K60uuLF-79Kyu4c1xxdRSONSZIfa-Dl_kKEC-pcmBoNYTv=w769-h1079-no)
Post by: JDFan on February 20, 2018, 03:21:17 pm
Might try contacting stpcore ( he was selling some backlit vinyl printed marquees at decent pricing and could make it to your size needed a while back and might still be ) - Post linkie - http://forum.arcadecontrols.com/index.php/topic,143964.msg1495168.html#msg1495168 (http://forum.arcadecontrols.com/index.php/topic,143964.msg1495168.html#msg1495168)
Post by: busbeepbeep on February 21, 2018, 08:33:08 am
Thanks.  That thread doesn't look active since 2015.  I sent stpcore a PM.
Post by: HaRuMaN on February 21, 2018, 08:35:13 am
stpcore does all my printing
Post by: Inphonet on February 24, 2018, 08:31:07 pm
Hi there - long time lurker and fan of your work---
How much would you charge for a floor standing base to sit the bartop on? Along with a customized bartop...
I would like to have a control panel layout very similar to the recent pics on this page (centered trackball plus two player)
I would however like to use a 20.1" 4:3 monitor (possibly vertically?? With a taller style/classic/galaga like design -  but now I'm probably just getting crazy - sorry)
(Also - I would like pinball flipper buttons on the side)
Can you provide plexiglass (control panel, monitor bezel, marquee) how about tmolding? Can you provide vinyl graphics?
Would this all be possible? How much?
Thank you !
Sorry if this isn't the correct place or method to ask.
*updated/edited-   actually hmm... can i fit a 20.1" 4x3 into your EVO XR2 [widescreen]  ??   oh wow  - upon closer inspection it seems that to my surprise - a 24" monitor is actually taller than a 20.1 4x3!  wow-  sorry I'm a bit all over the place -- maybe I should just go with your widescreen model and use one of my Apple Cinema Displays [older 23" models]
what are the monitor dimensions in the EVO XR2 wide? [I want to know maximum height and depth -you list the width as 23" on your site] -  [I'm concerned about depth too because my display apparently needs what seems to be a deep adapter to work with a mount/vesa - maybe I should just buy a nice new 24" monitor ;-)  ]
so - the wide model also has a bigger control panel - seems no problem to add that centered trackball --- what about adding a spinner centered up top too?? too crazy??
Post by: busbeepbeep on February 25, 2018, 12:54:26 am
Here are the dimensions I gathered in my research.
I’m using a Benq RL2455 on the eco wide and there’s about 1/2” clearance on each side.
I don’t know what the backside of a spinner looks like but I’m pretty sure you can find room for one. That control panels is roomy.
Post by: Inphonet on February 25, 2018, 11:04:33 pm
Here are the dimensions I gathered in my research....
Thanks - I appreciate the input... Have you had a chance to play with your's yet?? It looks awesome! Do you find the trackball cramped with the nearby joystick at all? Did you succeed in lining up a vendor for art? I'm wondering what the cost is if you don't mind sharing that info
I'm anxious to order and start building - I'm really hoping to hear back from Haruman soon (I did send him an email etc)
Post by: busbeepbeep on February 26, 2018, 09:28:28 am
Yes I've been playing it.  There's no problems with room.  I suppose if I had to do it again, I wouldn't put the admin buttons right above the trackball.  I don't have any problems with it, but one of my guests kept hitting the button as we were playing Golden Tee 2K.
Nothing so far on art.  Just need a marquee.  May order something generic from ebay like this until I come up with a better design. https://www.ebay.com/itm/162917620352?ViewItem=&item=162917620352 (https://www.ebay.com/itm/162917620352?ViewItem=&item=162917620352)Wasn't planning on any side art.   I don't have a dedicated room, so the black blends in better with my apartment living room.
Post by: DBrown77 on March 12, 2018, 10:06:06 pm
Any word on the possibility of a virtual pinball cab?
Post by: HaRuMaN on March 13, 2018, 09:44:12 pm
It's coming...
Post by: DBrown77 on March 14, 2018, 01:59:24 am
Decided on Sizes? Mini or full Size? Extremely interested.
Title: Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
Post by: 05SRT4 on March 14, 2018, 03:14:43 am
+1
Post by: Galahad on March 26, 2018, 04:20:30 pm
Can you please give the files in cdr format? Coral draw format?
Post by: Malenko on March 26, 2018, 04:54:27 pm
Gingerballs sized.
Post by: TheGreatRedDragon on June 24, 2018, 03:20:43 am
Quick question: Can anyone tell me what the marquee dimensions on the Mintendo bartop are, as well as the live area that's not covered by brackets?
Post by: HaRuMaN on June 24, 2018, 12:07:10 pm
Who are you making art for?
Post by: TheGreatRedDragon on June 24, 2018, 04:49:10 pm
Me. Well, future me. A couple weeks ago I had an idea for a project (something absurd enough that it might get me excommunicated from this forum lol) and I've been plugging away at the art ever since, just to see if it's something I'd want to do, but the marquee has been a blindspot and I've kinda been working in the dark on it.
Post by: CobraX83 on July 02, 2018, 07:30:50 pm
Hey everyone....beautiful looking cabs in here !!!
I ordered a single player Degenatron quite some time ago and lost my psd files. The whole package was actually sitting safely stored away until I just recently began to build it and it is coming out nice ( =
Is there any chance someone could point me to where to obtain the correct PSD's so I can make some art for my machine? I did find some templates posted from a long time ago but was wondering if they were actually good as the poster was unsure as well.
I am also looking into purchasing a Ultimate Widescreen sometime in the near future.....looks sweet!!!
I would just like to finish the cab I have first and cannot do much art wise without the files....looking for a PSD with the sideart , cpo, admin panel below cpo and even marquee.....if one exists for the back door that would be awesome too.
THANK YOU to anyone that can help me !!!
Post by: SNAAKE on July 03, 2018, 01:25:55 pm
so what other monitors are good for the cocktail kit? trying to see who else bought that kit and used another (preferbly new) monitor
Post by: HaRuMaN on July 03, 2018, 07:27:26 pm
13.25 x 3.3
13.25 x 2.3 is the "live" area
Post by: TheGreatRedDragon on July 05, 2018, 04:29:00 am
13.25 x 3.3
Fantastic, the design I've been working on fits perfectly! Thanks a lot.
Post by: edhara on July 10, 2018, 08:33:17 pm
I’ve been searching for either a bartop or controller kit (or two) for some time, but my problem is that I haven’t been able to find the button layout I want. I don’t need a ton of buttons as I don’t play fighting games. I’d like to have a control panel laid out sort of like Moon Patrol. My intent is to have a four way ball joystick in the middle, two buttons on either side, and 1 and 2 player buttons, and maybe a credit button. Do you have something that can accommodate this? Thanks much in advance!
Eddie
Post by: HaRuMaN on July 10, 2018, 09:21:02 pm
Eddie
Any number of kits could.  Maybe Offender or Berzerker?
Post by: jdbailey1206 on July 27, 2018, 01:35:31 pm
Haruman since you wont answer emails or messages and I'm a lazy and I don't wont to read can you cut a full size cab?
Post by: HaRuMaN on July 27, 2018, 01:39:18 pm
Dude you just emailed me and messaged me this morning.  Lol.
Yes, I can do full cabs.
Post by: jdbailey1206 on July 27, 2018, 01:49:59 pm
(https://vignette.wikia.nocookie.net/dickfiguresfanon/images/5/5e/Tumblr_mkzlhvE9pd1rgjkhbo2_250.gif/revision/latest?cb=20150531054659)
HOW MUCH!?!?  Cutting, shipping to Michigan, etc.  Its a Star Wars upright...
Post by: HaRuMaN on July 27, 2018, 01:57:24 pm
What kind of material?
Also shipping isn't going to be cheap...
Post by: jdbailey1206 on July 27, 2018, 02:08:52 pm
I need black melamine comparable to what you make your cabs out of except in 3/4" and a nice finished plywood.  I've listed both below.  I know there are not Menards in AZ but I'm sure you know of a supply chain close by.
https://www.menards.com/main/building-materials/panel-products/prefinished-panels/dakota-trade-3-4-x-49-x-97-melamine-panel/mel3449black/p-1444428255688-c-13335.htm?tid=-6506712026121959898&ipos=9 (https://www.menards.com/main/building-materials/panel-products/prefinished-panels/dakota-trade-3-4-x-49-x-97-melamine-panel/mel3449black/p-1444428255688-c-13335.htm?tid=-6506712026121959898&ipos=9)
https://www.menards.com/main/building-materials/panel-products/underlayment-panels/4-x-8-acx-plywood/1251420/p-1444425371729-c-5704.htm (https://www.menards.com/main/building-materials/panel-products/underlayment-panels/4-x-8-acx-plywood/1251420/p-1444425371729-c-5704.htm)
Post by: nitrogen_widget on August 15, 2018, 01:29:13 pm
Was wondering if a 20" CRT TV would fit in this after decasing.
would also probably need some extra vertical bracing for the weight of the TV if i go with the 1/2 non Baltic birch option.
Post by: Charles Kline on August 17, 2018, 02:55:43 pm
hey, I noticed you haven't posted all that other stuff on your website that you've been working on. Not ready to unveil it yet?
Getting close.   :cheers:
Glad you reminded me.  I just sent that file off to the CNC.   :applaud:
Dude, hurry up. I want to see that prototype in realspace!  :cheers:
Should have it in hand Monday.
Bam!
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=319856;image)
Gotta pick up some Kilz primer so I can start painting it.
Cool!  Its the Time Out/ Time out Tunnel House Rules.
Post by: Charles Kline on August 20, 2018, 12:39:21 pm
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=337805;image)
Seriously considering getting one of your cocktail kits.
Does one of the wood grain melamine you have match the original Pacman cocktail wood grain?
It looks like the back in this model is split for the hinging side&top, is that correct?
Do you carry the glass as well?
Thanks,
-Charles
Post by: HaRuMaN on August 20, 2018, 01:13:08 pm
So I have to check if I can still get that cherry melamine. I've switched CNC slips need to see if that's still an option. In any case, it doesn't match the original Midway cabinets, but it was as close as I could find.
And yes the back is designed to be hinged.
I do not carry the glass but it is easily found, it's the replacement glass with the 3.5" radius corners.
Thanks,
-Charles
Sent from my Moto E (4) Plus using Tapatalk
Post by: Zq8 Blazer on August 31, 2018, 11:30:57 am
Hi, I am planning to cut your widescreen bartop version out on my cnc.  I have one question though, in the file it says "white lines are cut, yellow lines are shallow, redlines are pockets 1/4" deep.  I was wondering how deep the yellow lines need to be?  Thanks.
Post by: HaRuMaN on August 31, 2018, 04:49:42 pm
I do those 0.1" deep.
Post by: mrdizle on September 19, 2018, 10:39:23 am
how much for a full size melamine cab .5 inch thick?
Post by: yotsuya on September 19, 2018, 02:29:14 pm
Tree fiddy and you arrange shipping.
Post by: mrdizle on September 19, 2018, 02:56:30 pm
How the heck do I arrange shipping? Isn't it easier if he just bills me?
What other option do I have if I want a full size? I guess I could build a frame but that would take time.
Post by: Mike A on September 19, 2018, 03:06:33 pm
Wow. You are freaking lazy.
Post by: mrdizle on September 19, 2018, 03:16:59 pm
Bro I'm a physician and I work nights and weekends up to 70 hours per week. I have a toddler and another one on the way.
If I want to take a shortcut with ordering parts, let me do it.
Post by: HaRuMaN on September 19, 2018, 03:17:31 pm
Ignore the peanut gallery, I saw your email and will get back to you.
Post by: JDFan on September 19, 2018, 03:23:24 pm
Best option is to find someone local to do the cutting - the problem with full size cabs is most shippers will charge a lot extra for packages over 4' in any dimension since it takes up so much room on their truck - so it costs more than most people are willing to pay just for the shipping (often more than the cab itself ) -- CHeck your local area for a makers space that you could sign up to for a month or so and use their CNC machine ( or go there and see if they would be willing to cut it for you for a small fee ) or a business that has a CNC machine that would cut it for you for a fee (ie. a cabinet maker, etc. that has a CNC machine)- check your local Craigslist and see if any CNC shops offer services - etc.
The reason you will not find many cheap places that sell them is because the shipping can run several hundred dollars - since they are oversize/overweight for most carriers and if/when it gets damaged in shipping replacing a damaged piece means paying again for shipping making it a losing proposition to sell them in most cases. ( unless you are charging $1000 + )
Post by: Mike A on September 19, 2018, 03:28:13 pm
Feel free to ignore me. I work 14 to 16 hours a day. I need something to entertain me during the down times.
Haruman does good work and he stands by it. You are in good hands if you go with him.
Post by: mrdizle on September 19, 2018, 03:32:57 pm
Thanks for your reply. Maybe the bartop and the base can be sent as two units and assembled together, rather than one large unit. I'll check. Thanks.
Post by: piensken1 on October 09, 2018, 02:06:39 pm
hi,
I am trying to use the cnc plans for my own..
But my woodman told me the plas are scaled and now are 6mm :p
Does annybody knows the scale?
also, is it possible to use 18mm mdf? instead of 12mm
Kind Regards
Post by: HaRuMaN on October 10, 2018, 10:13:28 am
hi,
Kind Regards
So the plans are not scaled, they are full sized, and in inches.  Also it is designed for 1/2" material.
Post by: piensken1 on October 10, 2018, 02:44:06 pm
aah ok,
I will tell this to my woodguy.. If he can't fix it.. I will need your expertise. :D
thx for the info
Post by: thatpurplestuff on October 14, 2018, 01:13:23 am
hey Haruman, I just ordered a widescreen bartop from your site (very excited!) and was hoping to get some templates for the control panel/sides/marquee so I could get started on my artwork.  Do you have any official templates to work from, or should I look to create some based on the DWG file?  Thanks in advance!
Post by: HaRuMaN on October 14, 2018, 02:28:07 pm
I'll send you the templates today.   :cheers:
Post by: piensken1 on October 18, 2018, 09:00:12 am
can you also send them to me?
If you want ill pay for it :)
Also, what ae the small pices on the image? do we need them for installing?
Post by: HaRuMaN on October 18, 2018, 09:24:58 am
PM me your email.
Those are the batons for the control panel and back door, and yes, they are needed.
Post by: stephenp1983 on October 26, 2018, 05:55:00 pm
Curious if you have any pictures of the EVO Mini other than the render.  Also is there any type of monitor mount or did you just keep the stand on the 11 inch monitor and use it?
Post by: HaRuMaN on October 26, 2018, 06:12:51 pm
(https://i.imgur.com/rJJWz1x.jpg)
(https://i.imgur.com/pmjut3v.jpg)
There is a mount in the kit that works with the EYOYO monitor it is designed for.
Post by: Malenko on October 26, 2018, 06:34:34 pm
Not to tute my own horn, but I do good work
Post by: stephenp1983 on October 27, 2018, 01:50:23 pm
Thanks for posting the images.  I agree very nice work!
Post by: stephenp1983 on November 21, 2018, 09:18:33 am
Just placed an order for the mini evo.  Would you happen to have any AI or PS type templates for the pieces that I could use for artwork?  Order number is 534 if you need it.
Post by: HaRuMaN on November 21, 2018, 09:23:50 am
I will send you what I have later today.   :cheers:  Thanks!
Post by: stephenp1983 on November 21, 2018, 01:35:26 pm
Thanks I appreciate it!
Post by: dluusional on November 25, 2018, 12:42:44 pm
Hi Haruman,
I sent you an email via your web store on Thursday regarding the Evo XR 2, I was wondering if you had a change to read it yet.
Edit - sorry, seems your email fell into the spam folder. thanks for your response
Post by: stephenp1983 on December 01, 2018, 01:32:22 pm
Just wanted to see if you had a chance to get the templates for the mini yet. No rush just checking :)
Post by: HaRuMaN on December 01, 2018, 01:39:21 pm
Sorry.  Email me and I'll reply with the templates.
Post by: stephenp1983 on December 01, 2018, 08:07:29 pm
NP at all just sent you an email, thanks again.
Post by: negative1 on December 26, 2018, 04:47:14 pm
I don't see a post for the Cocktail cabinet kits. I guess I'll post it here.
Sent a PM with message, and emailed site also.
Post by: Kirmus on December 29, 2018, 07:02:20 pm
Hey All,
In the process (finally!) of figuring out my first bartop arcade machine.  From reading through the thread I answered a lot of my questions with using the plans on the first page though what I'm not sure on how to setup my tool paths to run.  I understand the part about cutting pockets for the yellow/red in the file but for the outside edges, I assume the bit follows the line directly as opposed to an inside/outside offset.  If that's the case, what size bit should be used?  I don't either eat away to much material with a bigger bit or leave extra by using a smaller bit.  And looking at the file, I guess I would ask the same of the button holes.  Should they be cut following the line directly?  It wouldn't make sense to cut these as pockets but wanted to verify first.
If anyone is interested, using a Shapeoko XXL and Carbide Create.
Post by: negative1 on January 02, 2019, 08:46:10 pm
Happy New Year,
Lee, get back to me about the cocktail unit.
I'm still interested in ordering it.
later
-1
Post by: stephenp1983 on January 13, 2019, 02:06:36 pm
Got my order for the EVO mini right before Christmas and the kit looks great. Just now having time to start working on it and was curious if you had assembly instructions for it like you do some of the other kits on your site.   Thanks!
Post by: HaRuMaN on January 13, 2019, 02:14:50 pm
Not yet.  A few tips though and it will be super easy:
1) Dry fit everything before gluing to make sure you know where it goes
2) Mount your monitor to the monitor mount board before gluing (the monitor mount gets glued in this kit)
3) Mount your speakers (if any, I just used the monitor speakers for my build of this kit) before gluing.
On this kit, the bottom is detachable, it will will connect to small batons on the bottom of the sides, I usually use industrial velcro to hold the bottom on.
Post by: negative1 on January 16, 2019, 10:05:33 pm
Can you use nails, and screws for added support, instead of just glue.
This is referring to the cocktail cabinet kit.
later
-1
Post by: HaRuMaN on January 16, 2019, 10:09:13 pm
later
-1
Not needed, but yes, you could add blocks internally and screw them in.
Post by: negative1 on January 18, 2019, 01:39:10 pm
later
-1
Good, I'm not a fan of glue.
Do you still have any cocktail kits.
I guess I'll worry about the controls later. Maybe you can send my blank panel,
and I'll drill the holes myself. Also, maybe I can extend the panels to be longer,
so the controls I wanted can fit properly.
later
-1
Post by: Mike A on January 18, 2019, 01:51:11 pm
A wood glue joint is stronger than nails and screws.
Post by: negative1 on January 19, 2019, 04:21:22 pm
True, but it's not easy to disassemble or take apart later on.
later
-1
Post by: Mike A on January 19, 2019, 05:24:49 pm
That is absolutely true, but the question didn't mention disassembly.
Post by: negative1 on January 19, 2019, 11:42:53 pm
I've owned 2 original cocktail tables before, and they were a pain in the neck to move,
and to do anything with.
I just gave them away when I finally moved.
even though I'm in a house now, and have plenty of room, if I ever do have to move,
I'd rather be able to take things apart when the time comes.
later
-1
Post by: MBaran on January 29, 2019, 03:59:01 pm
for those with an Evo XR 2, is there sufficient ability to cool using a few PC case fans mounted along the rear holes of the back panel?
Post by: Erzak on March 14, 2019, 06:06:21 pm
What the (assembled) dimensions of the Evo Mini cabinet?  Guessing it's ~8-9 inches wide based on the monitor width?
Post by: HaRuMaN on March 14, 2019, 06:08:03 pm
Approximately 19.3" Tall, 16.5" Deep, and 13.4" Wide
The control panel adds width. Internal width is 10.5" off the top of my head.
Post by: Doublegrg on April 04, 2019, 12:45:20 pm
did you end up selling this? sent you a msg on the 94 forum
Post by: rtkiii on April 15, 2019, 04:17:25 pm
Any plans to do a pedestal setup?
Post by: DeLuSioNal29 on April 20, 2019, 12:44:12 am
Here's a video of my completed Ms. Pac-Man themed Golden Age Bartop.
https://youtu.be/rYRM_JBst6Q
DeL
Sent from my moto z3 using Tapatalk
Post by: dustinf36 on August 24, 2019, 12:03:19 am
Hey HaRuMaN, I am wanting to talk to you about a custom panel but cant send a PM. Do you have another way I can contact you?
Post by: PL1 on August 24, 2019, 12:27:17 am
You can now.   :cheers:
Post by: HaRuMaN on August 24, 2019, 10:44:35 am
You can email me at:
haruman@gmail.com
Post by: wackocrash5150 on October 11, 2019, 09:43:12 am
Hi HaRuMaN.
Just wanted to pass on a thanks for sharing your drawings. I was able to cut one out on my cnc after a few modifications.  Mainly because the plan was for 0.5" melamine, whereas at Home Depot here in Canada, it's actually 13mm melamine.  Doesn't sound like much but it causes the pockets to be too small. First time cutting melamine on it too so I learned about how to avoid chip-out. After a few adjustments, I think it turned out pretty well. Attached is a pic of it just dry fit together.
Thanks again.
Post by: HaRuMaN on October 12, 2019, 06:49:27 pm
Excellent work!  Looks great!!!   :applaud:
Post by: bombfirst885 on December 06, 2019, 03:11:11 pm
I'm curious if you sell plans for your builds? I have a project for school coming up and I want to build a bartop cabinet. I need to build it myself but can get away with using dimensions from someone else. I'm interested in the Degenatron or the ultimate widescreen. I'm confused how to take the links in the OP and transfer those into plans to cut the material. Any help would be greatly appreciated!
Btw I'm new so forgive me if this question has been asked multiple times.
Post by: Mystrandir on April 20, 2020, 03:29:34 pm
Just wanted to drop a couple pictures of the build I completed using the Minitendo.
(https://i.imgur.com/LFPeL4S.png)
(https://i.imgur.com/aBrNf5i.png)
Post by: HaRuMaN on April 20, 2020, 08:34:42 pm
Looks great!!!
Post by: Mystrandir on April 22, 2020, 02:47:01 pm
Thanks, the kit made it easy  :) . I expect I'll be in the market for a widescreen in the near future.
Post by: Gilrock on April 23, 2020, 08:51:40 am
I was browsing that Minitendo on the website.  So its not clear to me those options for the marquee, bezel, and control panel plastics are you getting just the clear plastic or does it already have the artwork on the plastic?
Post by: HaRuMaN on April 23, 2020, 09:28:45 am
Just the clear plastic. The art I invoice separately for.
Marquee goes behind the Plexi, bezel is laminated vinyl that you apply to the Plexi, and control panel overlay is laminated vinyl that applies directly to the control panel.
Post by: Gilrock on April 23, 2020, 09:52:39 am
Thanks...I'm thinking about it cause my son wanted a project to work on.  But every time I hint at another bartop my wife freaks out....lol.
Post by: Mike A on April 23, 2020, 10:34:55 am
Put a strap on it. Tell her it is a purse.
Post by: bsilverop on July 29, 2020, 08:46:57 pm
What’s the difference between this company and GameroomSolutions?
Post by: HaRuMaN on July 29, 2020, 08:50:15 pm
This may help.  :)
https://www.reddit.com/r/cade/comments/hw225q/vendor_review_gameroomsolutionscom/
Post by: bsilverop on July 29, 2020, 08:52:53 pm
It helps me understand why I should have read that before ever ordering anything from GRS.. but what I’m not clear on is if these companies are owned by the same guy??
Post by: HaRuMaN on July 29, 2020, 08:56:50 pm
No they most definitely are not.  Haruman's Customs is owned by me (Lee) based out of Arizona.  GRS is Ryan?  Not sure where he is based.
Post by: bsilverop on July 29, 2020, 08:57:59 pm
Ugh, thanks. I meant to order from you but ordered from them instead and ended up with a $500 paper weight.
Post by: HaRuMaN on July 29, 2020, 09:01:27 pm
Oh man.  Sorry to hear that :(
Post by: bsilverop on July 29, 2020, 09:04:14 pm
Live and learn.. I had someone else waiting to see how mine came out before ordering, so I’ll send them your way instead!
Post by: Slippyblade on September 13, 2020, 05:34:10 pm
You'll not go wrong. Haruman is a stand up guy with great product. I just wish he had a cabaret kit!
Post by: HaRuMaN on September 13, 2020, 05:41:03 pm
I have cabaret kits.
Post by: Slippyblade on September 13, 2020, 05:47:53 pm
I didn't see em on the website. I'll go look, again.
Post by: ZoNiE on December 25, 2020, 07:56:01 pm
Hi, do you do full size models? I'm in AZ and can pickup if shipping is the issue with larger units.
Interested in an Asteroids or Full Berzerker...
Post by: HaRuMaN on December 27, 2020, 09:39:24 pm
Yes I can do that.  :)  Being in AZ makes it much easier.
Post by: PatentGeek on January 02, 2021, 08:47:47 pm
Nearly done with my widescreen bartop build and just have a few questions:
- The kit came with plastic marquee retainers (top and bottom). What should I use to secure them to the cabinet?
- There are vertical batons for the back panel – presumably to make it readily removable. What should I use to fasten the panel to the batons?
- What should I use to secure the control panel to the horizontal (slightly tilted) batons?
Post by: HaRuMaN on January 03, 2021, 10:56:30 am
Wood screws for the marquee retainers.
I usually attach the top of the back door with hinges and use a small piece of velcro to adhere the back door to the batons
Control panel on that kit I usually attach with industrial velcro on the batons and the top of the admin panel.  ("paint" the top of the admin panel with a thin layer of glue and wait to dry, then apply velcro.  Will stick better that way since it's raw MDF there).
Post by: PatentGeek on January 03, 2021, 12:44:50 pm
Thanks, Lee! I think I might go with just velcro for the back panel, so it can be removed completely... any reason not to do that if the velcro is strong enough? (I have some velcro rated up to 15 pounds...)
Post by: HaRuMaN on January 03, 2021, 03:59:01 pm
You could do that too.
Post by: cofh on May 07, 2021, 11:50:51 pm
Hi Haruman,
So sorry to bother you on here.
My 11 year old autistic son is absolutely determined that we build our own Minitendo Donkey Kong bartop, exactly as shown on your website Bartop Kits graphic.  I sent you a message via the Contact link on your website, but have not heard back in almost 3 weeks.
Can you give me an idea of the approximate cost to buy the finished cabinet it with all of the DK graphics?  I am also wondering if there is enough room to modify the control panel to have six buttons for some Street Fighter fun?  I live in Toronto, Canada so I'm also wondering what the shipping/duty costs would be (approximately).
Any help you can offer would be greatly appreciated.  I love your stuff and how easy it looks to assemble.
Thank you.
Post by: HaRuMaN on May 08, 2021, 04:15:45 pm
Hi Haruman,
Thank you.
I will check my email for your message, I must have missed it.
Post by: bollwerk on August 09, 2021, 06:11:04 pm
Haruman,
I don't suppose you have any sit down non-cocktail style cabinets, like either a Japanese style "candy cab", or something like what's in these pictures from Rec Room Masters (which they discontinued, sadly)?
I can't find any company that makes something like this at a reasonable price (under $1000 before shipping).
Ideally, I'd like a cabinet that does NOT house the monitor, but rather has a backmount, so I can install a rotating VESA mount, allowing me to rotate the TV and change between horizontal and vertical games.
I would be happy to pay you to design the files, if I can't get the CNC files from Rec Room Masters.
Post by: HaRuMaN on August 10, 2021, 12:16:25 pm
I could do something like that.
Send me an email.  My username here @gmail.com
Post by: 96p993 on February 14, 2022, 05:37:38 pm
Email sent this morning...Thanks
Post by: fvargasfrank on March 21, 2022, 11:38:39 pm
Are the plans for the bars-stick available? I went to the site but it's no longer active.
Post by: PL1 on March 22, 2022, 06:32:12 am
The Internet Wayback Machine has a backup.
KADE forum thread:
https://web.archive.org/web/20160826064217/http://kadevice.com/forum/viewtopic.php?f=51&t=325&sid=974d29dde242837119d3b7e021bf551d (https://web.archive.org/web/20160826064217/http://kadevice.com/forum/viewtopic.php?f=51&t=325&sid=974d29dde242837119d3b7e021bf551d)
Direct download link for plans:
https://web.archive.org/web/20201016110043/https://d126d645-a-62cb3a1a-s-sites.googlegroups.com/site/kadevice/cnc-templates/barstick_prototype_plans_by_degenatrons.dwg?attachauth=ANoY7coxoqZJJ9H95JksV28RalTPsqmU3tsgP2QEQ_2lEcPHwk81remiaxtoZHS5WDGYZklqpTcg9UBtRqEfMgzJXXJDuSUjbX1yMvayUpVrrfI0mOYWz7iaY239RjlipQNy4Rf4_bxvPSKsPiLzkVXfMlNJkoXXmkKaTGDriDkRtZK75zc7E0UgcaJyL3O65dsRBr-vaHGopHTzHMw5gID3he_oCHUWAzbw_dunKL0isXihI4BKgVwBdEsPyzRqdw8ejNohB6F4Iis3LF_9XK49xjJSEKIHLA%3D%3D&attredirects=0 (https://web.archive.org/web/20201016110043/https://d126d645-a-62cb3a1a-s-sites.googlegroups.com/site/kadevice/cnc-templates/barstick_prototype_plans_by_degenatrons.dwg?attachauth=ANoY7coxoqZJJ9H95JksV28RalTPsqmU3tsgP2QEQ_2lEcPHwk81remiaxtoZHS5WDGYZklqpTcg9UBtRqEfMgzJXXJDuSUjbX1yMvayUpVrrfI0mOYWz7iaY239RjlipQNy4Rf4_bxvPSKsPiLzkVXfMlNJkoXXmkKaTGDriDkRtZK75zc7E0UgcaJyL3O65dsRBr-vaHGopHTzHMw5gID3he_oCHUWAzbw_dunKL0isXihI4BKgVwBdEsPyzRqdw8ejNohB6F4Iis3LF_9XK49xjJSEKIHLA%3D%3D&attredirects=0)
Post by: fvargasfrank on March 22, 2022, 08:27:07 am
KADE forum thread:
Thank you very much, did not know of suck sorcery as internet wayback lol.
Post by: busbeepbeep on January 05, 2024, 12:03:12 am
@haruman, I built a Widescreen EVO XR2 a few years back.  Have an issue with the control panel and the barrel hinges.   When playing fighting games with lesser experienced players who are rough with the joystick, the control panel starts to pull away from the bartop.  The magnets aren't strong enough and I guess the holes for the barrel hinges have loosened.
Any suggestions on ways to secure the control panel?  Even if I lose ability to quickly access the internals, that would be ok with me if find a way to way secure the CP and enjoy playing more.
Post by: HaRuMaN on January 08, 2024, 09:08:11 am
You could always put a couple of bolts through the admin panel and the panel behind it...
