Arcade Collecting => Restorations & repair => Topic started by: Mark W on April 01, 2021, 01:24:00 pm
I found an old thread on this site which featured Ken Layton. He is a guru with these dart boards. So if he is listening or if anybody else knows about these vintage dart boards please chime in.
I recently bought a early 80’s century idea board. When plugged in nothing happens. Ken talks about these power supplies are crap. Can’t disagree with that! I have not found a wiring diagram. I did find on board which sits between the transformer and the capacitor has a burned up solder component called J1. I’m not sure what went there but it’s gone now. I will post pictures and would like to know about this Peter cheau power supply Ken talked about. Any help would be appreciated thanks
Definitely try googling the parts seperately. Like the power supply model number. Measuring voltages is step one.
On schematics and PCBs, J = Jack.
- Fixed part of a jack + plug connector pair.
- Typically a female socket, but could be male pins.
Just spitballing since I haven't seen a schematic or pics yet, but there's a good chance it was the power input jack for that PCB.
- It probably burned up because of the heat generated by a poor-quality, high-resistance connection.
I assume you're referring to this thread where Ken mentioned the possibility of using a Peter Chou power supply to replace the poor quality original power supply if someone can find a schematic of the original.
http://forum.arcadecontrols.com/index.php/topic,122218.0.html (http://forum.arcadecontrols.com/index.php/topic,122218.0.html)
The Peter Chou PSU is an arcade-style switching power supply.
(https://images-na.ssl-images-amazon.com/images/I/81qS9inqzPL._AC_SL1500_.jpg)
Thanks for the replies. I wanted to post some images to give more contacts to the issue. Now that I cleaned off all the dust from some Smokey tavern I can. I can read the voltages on the transformer but I’m not sure where to go from there. I spent over 100 bones on this thing which is way more than I should have for something that doesn’t turn on. So in the end I just can’t put too much money in it.
Here is some more images
As well as some from the under side.
Great news! After going over everything and clean and clean I started testing voltage. Right off the bat I found the switch was bad. I replaced it and the transformer starter to hum. I put a jumper wire around the J1 missing component and the whole dart board sprung to life.
The only thing left is to find a working target board. I will post a picture of the manufacturer. If anybody knows where to get one of these or how to fix it I would appreciate it.
Thanks again
Mark.
That's the tough part with these older dart games, and can be somewhat hard to find. What you need is a replacement matrix; that's what senses the darts as they hit the board. It's a network of membrane switches that is able to detect where the hit is without a large number of electrical connections to the ECU. I have a similar problem with my Arachnid 6000. Mine doesn't sense hits to the number one spot. At least I can play Cricket, so it's perfectly usable until I do find a replacement. When one does pop up, they typically go for around $100 though. I always seem to be broke when one does!
The company seems to still be in business, you might want to try and contact them: http://www.memtron.in (http://www.memtron.in)
You could also try creating an automated search on eBay to notify you if one becomes available. Good luck!
The company (I.D.E.A. ) that made Century Dartes has been bought and sold several times over the years. The company progression is this:
IDEA -> Valley (the pool table company) -> Shelti
Over 30 years ago, we had maybe 4 of the Century Darts machines on the route. I remember schematics did come with the machines. The power supply was definitely the weakest part of the machine.
