Main => Project Announcements => Topic started by: Ond on November 07, 2012, 05:01:04 am
_
That looks amazing!, i look forward to reading your thread :)
Been waiting for this announcement since you posted the original design.
Will follow this build closely.
Well, I have to say that is one sexy concept you have there! I'm not normally a fan of bar-tops, but damn this one makes me reconsider!
Can't wait to see your progress as you get to work on Zenolix.
Looking good!
Sent from my iPhonophonoponononon.
make me one plz. will pay :hissy:
This won't divert attention away from the Astro cab will it?
6 button vertical games? ???
Great looking design. I also happen to like anything that ends in 'lix' and has sharp angles.
Maybe Ond is a big Daioh fan?
-Andrew
Very cool!! Hit me up if you want some bits of acrylic or some LASER cutting done. You're close enough that I can ship to you... ;D
:o who's got two thumbs and is all excited for this build??? THIS GUY!
You going to finish Retro-future first ???
_
Thanks mate; you did some very fine work on your version of this design. I may just take you up on that offer, maybe to cut the logo for the back and or the marquee logo also? Can you cut from a DXF or DWG file?
The LASER itself runs on DXF but I run everything through Corel X6 so I can convert just about any file format.
_
This is... relevant to my interests. :cheers:
_
Sweet! :cheers:
Nicely done on the template OND.
You are adding the marquee, right?
_
Hell! Time after time you just seem to create these awesome original concepts. I absolutely love this design.
I could even see some of my graphics being placed on a bastardized version of this ;D
I'll certainly be watching with gusto!
I'm trying to imagine how your going to be able to open it to maintain the internal components.
The only feasible option i could think is your going to create some form of a trap door on the underneath panel?
Haha even OND's method of creating cut templates makes me feel like an amateur. Can't wait to see how this build turns out!
(by the way, I feel a whole lot better about my some of my Ryobi tools knowing that OND uses them to create his arcades.)
_
I think your right on the money with having something bold and clean.
If it was me i'd try to do some stenciling. When i look at the concept model i just see an abundance of angles. Opposed to the rounded motif.
It may work better to bring that angular feel into the control panel?
I'd use the same blue your painting on the side and rear on the CP and bring the grey from the bezel down as well.
here's a raw idea...
_
Hey there OND,
Great design as usual :cheers:. When I first saw your mockup the first cabinet that popped to mind was STERN's BERZERK. I think if they had your cabinet desiging skill back in the day the BERZERK cabinet would have looked great as your xENOLIx cabinet. Sorry I took the liberty of lowercasing the Xs. Looks kinda cool. Some mentioned stencils and it clicked. I messed around on illustrator for about 15 minutes and this is what I came up with. Do what you wish with it, you'll probably come up with something infinately more awesome, but....
Jigenjuke
If you want to mess around with the illustrator file let me know.
_
_
I have no doubt that whatever you come up with will be super sneaky and awesome. However if you're not happy with the end result, maybe take a look at the Spark Optical Sensor here: http://godlikecontrols.com/ (http://godlikecontrols.com/)
It's a unit that you swap in place of the microswitches. Should be nice and quiet. ;)
in2amusements.com.au I'll have to try them out. I'm just about over supporting local suppliers when it takes a week longer to get something locally, not to mention the extra cost.
I'm still waiting for a spinner I ordered nearly two weeks ago from a local supplier. :banghead:
And then in a flash I had it! In the coming days I'll post up a mod for this stick to make it silent and super SHMUP responsive. Also the mod can be reverted back to standard JLF in about 30 seconds (not including wiring connections). For now its secret OND business >:D
(holds off on JLF optical mod until he see's what Ond's up to......)
Maybe there's still hope for the lonely JLF I have in storage after all. :cheers:
Pretty sure paradise arcade shop sells a silent JLF.... Not cheap though....
They do sell silent JLFs (http://www.paradisearcadeshop.com/en/sanwa-joysticks/696-paradise-silent-jlf-joystick.html).
They also have a mod kit with Zippyy switches (http://www.paradisearcadeshop.com/en/microswitches/531-silent-jlf-modification-zippy.html) and a .187" QD to JLF-style adapter harness or a kit with Cherry switches (http://www.paradisearcadeshop.com/en/microswitches/532-silent-jlf-modification-cherry.html) and a .187" QD to JLF-style adapter harness.
Stop posting solutions, you'll stop the innovation! :cheers:
I tried the zippy switches in the JLF and they don't work that well with the round and octagon restrictors.
The restrictor being smaller and sitting closer to the joystick body causes the ledge on the actuator to catch occasionally.
Silent omron switches work, but for what they cost, you could almost buy the basic optical setup.
The plan for my new cab was to use the SparkCE sensor and replace the adjustment pot with some type of command line controlled variable resistor. So for shmups, it could be super sensitive and for 4-way games, the sensetivity would be low enough only one switch would be tripped at a time. I'm not done looking, but the best idea I've come up with so far for a computer controlled resistor is an LED and a photosensor.
Sigh, the more I talk about this idea, the more I want to do it, so I guess I'll go ahead and order the SparkCEs. ::)
Hope I'm not :banghead: when I see Ond's solution.
emphatic - Sorry bout that. I'll try not to do that in the future. ;D
Ond - You know you want to join them in saying. . . .
-These aren't the droids we're looking for....-- - YouTube2.wmv (http://www.youtube.com/watch?v=Z9XFCtktkhY#)
(Couldn't find a video clip of the "You didn't see anything (http://www.dailywav.com/program.php?Program=Madagascar)" line from Madagascar.)
(Couldn't find a video clip of the "You didn't see anything" line from Madagascar.)
You didn't see anything... (http://www.youtube.com/watch?v=7qXXWHfJha4#)
_
Holy carp, it's happening! :cheers:
What he said! :applaud:
_
Didn't you build this already? Or was that someone else?
_
I was thinking that too, Deja vooooo'd me. Nice to see a wooden version of it. :applaud:
Looking good Ond.
Can't wait for the marquee construction.
Nope, this is the real thing complete with glowing marquee and rear logo and glowing front edge ;D. selfie did a plastic version of my design last year.
a nice subtle dig at me taking the easy way out without the marquee :P ;D ;D Looking good so far. The offer to LASER cut anything still stands too.
_
_
Man, those are sharp. Gives me some ideas. Im loving where this is headed.
Always enjoy watching an Ond build! Looking great! :applaud:
It's amazing how much those MDF pieces enhance the look of your cabinet. :cheers:
_
_
:applaud: :applaud:
Looking sweet!!
How are we normal humans suppose to recreate that marquee. :banghead:
Have you tried steam bending MDF? I did it with hardboard and had great results. On small bends like that the jig would be fairly manageable as well. Just a thought for next time so you don't have to kerf if you don't want to.
Looking stellar btw :cheers:
_
This is so great. Can hardly wait for the paint job pics. :cheers:
:applaud: :applaud:
Looking sweet!!
have me do it in photoshop... :lol
but yeah whoa amazing work here
_
Being able to say I contributed is thanks enough :cheers:
On the masking material, there is a signwriters vinyl specifically for masking that can be run through a vinyl cutter like a normal cut sticker. Also Application tape, the low tack masking tape, that is used to hold cut vinyl stickers together works well as a mask provided you use a very sharp knife to cut it.
_
OND, The quality of your work / projects are just amazing - I'm def putting in a lot of hours here reading your posts :D
_
It's great seeing quite a few new people rolling into the forum lately!. Playing games on your own hand-built MAME cabinet is sure enough great fun, but many find the actual build process the real buzz in the hobby. ;D
As a total newbie on this board I have to say that your builds are nothing short of inspiring. I have to also say that yes, building can be much more fun than playing.
Inspiring would be understated for me, his work is truly astonishing! If only I had OND's tools and even a small fraction of his skill set I would follow.
Between OND and Maximus my jaw is literally sore from the perma-grin, damn fun stuff here guys and please know that sharing it with the rest of us is greatly appreciated.
Jason
apologies for the no content bump - needed to . . .
subscribe.
^same. Subscribe. Looks really cool so far.
Jason
I agree with the sentiments re amazing quality of work - also agree with OND re it turning out the build process is just as enjoyable (maybe more so) than playing on the finished article with your mates (or seeing a commissioned cab being just for the first time by the customer) - thanks for the amazing inspiration and creative ways you guys share with us on how to approach different challenges in this hobby of ours :applaud:
This is awesome!
*Dreams of one day having a Garage full of OND designed cabinets
I saw the green version of this a while back and really liked the design. I don't have much experience, but I took a stab at it. I've really enjoyed building and playing it.
http://imgur.com/a/uPjld (http://imgur.com/a/uPjld)
(http://i581.photobucket.com/albums/ss251/Ond_photos/DSC_0223a_zps4ec56913.jpg)
Test fit CP and bezel to cab just with tape to make sure everything is nice and square and flush along joins.
This might be a dumb question, but did you cut that bezel using a 45 degree chamfer bit?
That is what I use to do mine, but I swear yours seems sharper and less rounded at the corners. It could also be that my eye are bad ;D
any chance of a pdf on the plans or some measurements please ... I love the design
I don't want plans or whatever... I want pictures an stories about the progress :cheers:
Hope it Will Come very soon :angel:
_
Ond,
This looks like another fantastic project! The design is amazing and I hope that you some day find the inspiration and time to complete it.
_
_
I've made really good progress on this in the last few day's. Pics SOOON.
Like normal person soon or Ond soon? Does the additional "O" denote more time or less? ::)
_
_
This looks insane. It in no way looks like wood. Beautiful bartop you got goin' on here.
Wow! This looks insane! Can't wait for the painted pics.
Ond are you going to connect the side moldings from the inside?
What are the small holes on the right side for?
_
Ready for paint later today.
(http://i581.photobucket.com/albums/ss251/Ond_photos/Xeno-1_zpskywzfbk2.jpg)
You mentioned this coating is Bondo (unless I misunderstood what you were talking about). If so what kind of Bondo is that? I've heard of people using Plastic Bondo, and figured that is what you used here but I cannot find any myself.
_
Thanks I'll check that out.
Now this is an interesting bartop!
Now that I see that blue, you only need to integrate white and you'll have R2-D2 colors.
Cool, cool, cool. :cheers:
Please come to England and paint my next cab.
I'll buy you a beer. :cheers:
Can someone point me to onds paint tutorial, can't find it from the main forum..
_
_
WOW
Just WOW!!!
_
What are the two circuit boards next to the speaker? Also I see your monitor cable is plugged into something?
_
Great thanks for the info
what games is this gonna run? Are you putting in an SSD?
_
awesome! gets my vote!
_
Stunning.
One of a kind... i love all the details on this masterpiece :notworthy:
_
See my videos in the How to videos thread on the Main Board for lots of details.
I may be a bit thick but I can't seem to find where the Iw to thread is :dunno :dunno
Mera Peak
That's the you tube channel I watched onds paint tutorials on.
Part 1 was missing though
I think that's where his videos linked to , but I've just checked and all contents gone
Ond's videos are in this (http://forum.arcadecontrols.com/index.php/topic,80229.msg1334817.html#msg1334817) post of the "Are there "How to Videos" on arcade building? (http://forum.arcadecontrols.com/index.php/topic,80229.0.html)" thread.
EDIT: Parts 2, 3, and 4 play embedded, but part 1 forces you to play it on YouTube because, "This video contains content from UMG."
The videos don't show when you view the "Mera Peak" account, but they are still available.
Yeah there the ones...
Part 1 not available though
Click on the "Watch on Youtube" text or the YouTube icon in the lower right corner to watch it on the YouTube site.
Yeah I know..and part 1 isn't available
_
It plays fine here in the U.S., but it might be restricted in your country due to the "This video contains content from UMG." restriction. :dunno
Where are you located?
I'll link to a dropbox download in that thread (and here) so you can view part 1 as soon as I've uploaded it to my Dropbox.
Thanks for going above and beyond. :cheers:
I'm in the UK.. vid 1 has never worked but the rest are great. Thanks for the Dropbox link
RIP
What's happened all ond's posts have gone??
He took his ball and went home.
Ah well...we all move up one rank!!!
Get back in line, n00b.
