Main => Audio/Jukebox/MP3 Forum => Topic started by: Demigon on January 14, 2020, 07:56:45 am
Hello! I have a 1967 Rowe AMI mm1 jukebox. Always selects the right record but will only play the A side regardless of which side is selected. The manual indicates it is probably a problem with cam switch 4. That switch appears to be tracking properly. Does anyone know where I could get a replacement switch? I am in the US, Utah specifically. Thank you for your help!
