Software Support => GroovyMAME => Topic started by: timply on October 26, 2014, 03:17:43 pm
Win7 64
Core i7 960
HD4350
Betson-Kortek Monitor
Using 8BitMonk's custom presets:
crt_range1 15625-16240, 50-65, 3.000, 4.700, 7.700, 0.190, 0.191, 1.018, 0, 0, 192, 248, 0, 0
crt_range2 16029-17200, 50-65, 1.220, 4.728, 7.626, 0.190, 0.191, 1.018, 0, 0, 249, 256, 0, 0
crt_range3 18300-18800, 50-65, 8.300, 2.750, 9.000, 0.190, 0.191, 1.018, 0, 0, 257, 280, 0, 0
crt_range4 18448-31000, 50-65, 6.278, 2.058, 7.410, 0.799, 0.828, .876, 0, 0, 281, 360, 0, 0
crt_range5 24000-29000, 58-65, 1.163, 3.595, 1.798, 0.081, 0.162, 0.889, 0, 0, 376, 384, 0, 0
crt_range6 24000-29000, 57-65, 1.549, 2.820, 6.502, 0.225, 0.150, 2.021, 0, 0, 392, 400, 0, 0
crt_range7 30000-34000, 58-65, 0.636, 3.813, 1.906, 0.020, 0.106, 0.607, 0, 0, 432, 496, 0, 0
crt_range8 33001-38000, 58-65, 0.942, 3.062, 2.827, 0.471, 0.118, 0.972, 0, 0, 512, 588, 0, 0
Pac-man and Ms Pac-man are the only 2 that I have found that run really fast. I've provided the Ms Pac-man and Mame settings below. There is no telling what crazy settings that I have changed. Lol!
Either use ddraw or increase the value of frame_delay.
Using a value of "1" in frame_delay is ridiculously low and if combined with d3d causes this issue where the same vertical retrace is entered twice resulting in speed x2.
Ok sounds good.
Which one of these is the more ideal situation? Upping the frame delay or just switching to ddraw?
