Main => Project Announcements => Topic started by: arno on November 05, 2014, 10:11:54 am
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/header-project-page.jpg)
It is about for me to start a new (at this forum my first) project. I will start with a small version (bartop) of a Fix it Felix Jr. cabinet. ;D
I choose to use an old small television as a monitor, this is quite a challenge because of the small dimensions of the cabinet. To control the television i will make a "VGA to SCART" cable and let the video card output a 15Hz signal.
Specifications:
- Pc: AMD Dual-core, 4GB memory, 250GB drive, Ati Radeon HD4350
- Speakers: Mono speaker from TV
- Monitor: TV
- Software: Soft15hz, Windows XP
- Joystick: Upgraded Zippy long shaft joystick with zippy switches
- Pushbuttons: Concave classic pushbuttons
- More specs on next update
In order to determine the shape of the side panels I have printed a template to scale. The template will be used later on 18mm MDF.
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(1).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(2).jpg)
Long straights cutting with a circular saw. The angles are later completed with a jigsaw.
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(3).jpg)
I placed on the inside a 18x18mm wooden beam to get a solid compound at a later stage.
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(4).jpg)
The outside panels are done! :cheers:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(5).jpg)
The monitor
An LCD or TFT screen would obviously been the easiest option to process in a bartop. I will take the challenge to use a CRT screen (TV). It will be tight, the question is whether it's all working. We'll see ... :blah:
I can get the TV working by using the SVIDEO output on the Radeon HD4350 card, but this will not be giving us the image we are looking for. I will try to make a VGA to SCART cable so the TV will work in RGB. (Red, Green and Blue separately). The benefit is that we can start using the audio from the TV.
Get the diagram (great topic BTW!) and let's try it out:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(6).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(7).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(8).jpg)
It is working, but it needs to be calibrated. :applaud:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(9).jpg)
Discharged the monitor, scary...
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(10).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(11).jpg)
Tight fit...
It is very challenging to place the CRT.
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(12).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(13).jpg)
The computer has been disassembled
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(19).jpg)
Testing the artwork:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(14).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(15).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(16).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(17).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(18).jpg)
A grid for the speaker is routed out and holes for extra buttons are cut with a speed drill. Also, at the locations where it will later be inserted T-molding is a slot of 2mm ~ routed out.
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(20).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(23).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(24).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(25).jpg)
3 very little service buttons for START - PAUSE - STOP are placed under the monitor beazel. I know that it is not original, but I need them at reach... I think this is the best position.
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(26).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(27).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(28).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(29).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(30).jpg)
The back is covered with a low model arcade lock and fused power switch.
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(31).jpg)
For the monitor, cabinet sides and controlpanel the vinyl has arrived. The marquee is made of printed plexiglass so that it can pass through this light.
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(21).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(22).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-(32).jpg)
Hope you guys like it! More to come soon...
Greetz,
Arno
That is pretty awesome man!
Thanks ;D
Next step is to sand it and get the cab in primer.
Nice work! Do you need the (dutch) color numbers for the paint?
Thanks Sjaak! I just got the numbers from Superfrog last week. ;)
Looking really great so far! Can't wait to see it finished! :applaud:
Looking really good, i'm following - creative Monitor Discharge Tool, you should patent :lol
DaOld Man likes!
I have the same screwdriver.
Good to know it has another use.
This is like!!! :applaud: :applaud: :applaud: :cheers:
So you actually did fit a CRT inside there? Are you using the plans from http://www.379009.net/nintendo-bartop/ (http://www.379009.net/nintendo-bartop/) ? (that's my site btw ;) )
And did you resize the side panel plans (made them bigger)?
When I made made mine I tried to fit a CRT computer monitor inside but it was too deep, but then again, a TV may not be that deep. I ended up using a 15" LCD. Well, great job so far! :applaud: :applaud: :applaud:
I will follow your build closely. Maybe I'll install a CRT myself in the end.
Very nice! Are the plans custom or did you find them somewhere?
Nice to see the good reactions! Thanks guys!
I need to say that i used some files for the artwork from you, very, very nice work. I need to thank you a LOT for sharing :applaud:.
I will measure the side panels, the inside width of the cabinet is about 38CM. I think it is about the same size as your cab Johnrt.
The plans are from Johnrt, see the link above :D
Worlds biggest thumbs up for a CRT bartop. Proper job :D
Fix It Felix? Psh. Who does that? ;D
Very cool. Does Fix-It-Felix run in MAME? I've been out of the loop for a couple of years due to life but I've got the itch again so I'm trying to catch up...
Nope. Fix it Felix is a standalone executable (.exe) you run from Windows (>=XP I presume).
I am not sure how to fit the monitor plexi plates. On the top behind a alu profile, but how can i secure it at the bottom?
Any idea? ???
Any idea? ???
I used an aluminium profile:
http://www.379009.net/nintendo-bartop/pics/2013-12-16%2020.21.01.jpg (http://www.379009.net/nintendo-bartop/pics/2013-12-16%2020.21.01.jpg)
http://www.379009.net/nintendo-bartop/pics/2013-12-16%2020.24.06.jpg (http://www.379009.net/nintendo-bartop/pics/2013-12-16%2020.24.06.jpg)
http://www.379009.net/nintendo-bartop/pics/2013-12-16%2020.24.27.jpg (http://www.379009.net/nintendo-bartop/pics/2013-12-16%2020.24.27.jpg)
Any idea? ???
Looks good, behind the small plate. Did you get a square out of both sides from the plexi?
I'm not sure what you mean. I'm just using one piece of Lexan for the bezel. The bezel artwork is adhesive and just sticked to the Lexan.
You have your lexan behind that small wooden bar on top of the control panel. But there are 2 blocks behind it to fix it on to.
Did you have to cut this out on both sides of the lexan to get in the strip?
Yes, of course.
Yes, of course.
I get it, thanks!
I have a dumb question what program do you use to print the plans to scale?
I am using a 30day free trail of Photoshop CC
Where did you send your artwork to get printed arno?
I send it to Pixartprinting.com
The quality is very good. 😃
Awesome! I might want to check them out. I got my marquee done through them. They produce high quality work.
Good! Make sure that you pick the HD vinyl type.
Mine was printed right on the plexi. ;D
(https://farm4.staticflickr.com/3879/15260350741_85d75410ce_z.jpg)
Still think that looks awesome. :cheers:
I have to cut it to size over the weekend. I am not looking forward to it. :'(
Just squeeze between two pieces of mdf and use a router with a flush trim bit.
Gorgeous project.
Good to see you building again Arno!
Looking very promising so far :applaud:
Thanks again guys!
I will post a new update tomorrow!
Because someone is too good to post on the forum... >:D
(https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-xpf1/v/t1.0-9/10275931_525825854221706_8938718803382826804_n.jpg?oh=5181ebc336aab5b5112bbb3dacf33503&oe=54FFDC7C&__gda__=1427146006_14a92fdbac7a4a843bb2b7c8ab59a219)
Haha :) give me an hour :laugh:
(http://media.tumblr.com/e1c22ebdf11c9f778479fbb002bf9c1c/tumblr_inline_mqj7pzAAUc1qz4rgp.gif)
BUT I WANT IT NOW!!!! ;D
*** UPDATE 2 ***
Finally i had some time to update here :cheers:
The bartop is fully painted and coming together.
First a base coating:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(1).jpg)
The monitor had a metal band around it. I sprayed primer around it.
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(2).jpg)
The marquee area is sealed. Next step is to place a LED in here:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(3).jpg)
Cutting a slot for the t-molding.... at the wrong side :banghead:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(4).jpg)
2nd layer of primer:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(5).jpg)
I see black in here :laugh:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(6).jpg)
First layer of black paint:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(7).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(8).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(9).jpg)
I found a new smaller CPU fan, installed here:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(10).jpg)
One layer of paint is not good enough, again and again... ;D
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(11).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(12).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(13).jpg)
There it is! Blue paint:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(14).jpg)
First layer:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(15).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(16).jpg)
Monitor is painted:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(17).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(18).jpg)
I will use a long shaft zippyy 2/4/8 way stick. I installed genuine Zippy switches (200gr) for a small improvement.
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(19).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(20).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(21).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(22).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(23).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(24).jpg)
The neckboard doen't fit, so I made a small adjustment:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(25).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(26).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(27).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(28).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(29).jpg)
I ordered 2 and 3mm plexi for the CP. I will go for 2mm ;)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(30).jpg)
Sandwich it between the CP and a piece of MDF and start drilling!
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(31).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(32).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(33).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(34).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(35).jpg)
Also the marquee is made to the correct size. I used a dremel tool for this. My router bit was missing...
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(36).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(37).jpg)
Control panel: (with black washer a.t.m.)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(38).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(39).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(40).jpg)
The cab:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(41).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd2-(42).jpg)
That was it for now. Hope you like it guys!
Grtz
Arno
(http://www.reactiongifs.com/r/2013/06/fart-in-elevator.gif)
Love the CP. The black border really makes the whole thing pop.
:applaud: Nice work so far, it is coming together well!
Everything is awesome. :cheers:
This is really awesome! The artwork on the control panel looks fantastic!
Thanks guys!
At this moment I am working on the electronics and the bezel. ;D
New update ;D ;D
Begun applying the t-molding. I made a small cut in the corners so that it has some space to form.
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(1).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(2).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(3).jpg)
Looks much better :-)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(4).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(5).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(6).jpg)
Aluminum profiles made to size (38cm). This will fix the plexiglass.
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(7).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(8).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(9).jpg)
Shortend the LED:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(10).jpg)
In order to secure the upper aluminum section, i will use threaded bushes.
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(11).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(12).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(13).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(14).jpg)
Done, but still need a paint job...
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(15).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(16).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(17).jpg)
2 plexiglass sheets are also made to size:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(18).jpg)
These fall both in a profile on the inside of the cabinet:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(19).jpg)
Cut the vinyl for the monitor bezel:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(20).jpg)
TV speaker used again and fitted:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(21).jpg)
Convex classic mini buttons placed for insert coin, button 3 en button 4.
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(22).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(23).jpg)
There is the light:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(24).jpg)
Service button placed to start the computer:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(25).jpg)
Finally, the PC can be placed! The ATX power supply is slightly adjusted so that the cables leaves the side of the housing.
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(26).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(27).jpg)
Thight fit!
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(28).jpg)
Harddisc placed.
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(29).jpg)
The PCB of the TV was in a nice plastic bracket. This is re-used.
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(30).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(31).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(32).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(33).jpg)
The interface (IPAC) is next! This is provided with PCB feets.
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(34).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(35).jpg)
The LED strip needs a 12 volt power supply. This is connected to a molex connector.
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(36).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(37).jpg)
230volt in:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(38).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(39).jpg)
PC connected start button, this plug is connected to the motherboard of the PC and is also standard in a computer case.
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(40).jpg)
The bezel / plexiglass will soon come against these blocks, the aluminum profile ensures that this is being held thight.
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(41).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(42).jpg)
Ground cable made because of the various sizes connectors.
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(43).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(44).jpg)
Controlpanel wiring:
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(45).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(46).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(47).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(48).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(49).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(50).jpg)
In this picture you can see that the neck board of the TV only just inside. This is challenge ...
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(51).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(52).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(53).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(54).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(55).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(56).jpg)
The loose cables will soon go to START, PAUSE and STOP buttons.
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(57).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(58).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(59).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(60).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(61).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2014/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd3-(62).jpg)
AND: after plugging in the powercord, it runs. So next update will be BIG
Very nice and clean work. This Bartop will be heavy, I think I would have used an LCD for it. And I always find it a pity to use marquee retainers which cover so much of the marquee. Half of that length would have been enough too.
Contrary to EMDB, I like that it'll be heavy. It'll be sturdier, less likely to slide or topple if you have players who are heavy-handed.
Plus bonus points for using a proper CRT. ;)
(mind you, due to the extra work getting a CRT into a bartop, I will be opting for an LCD myself, 'cause I'm a lazy arse. But I will live vicariously through you!)
You're in the final stretch! It's so close to being done!
This is definitely shaping up to be one of my favourite bartop projects on this forum. :cheers:
Believe me: It's heavy enough even with an LCD! But the CRT approach is way cooler of course!
Great, thanks guys! Very nice to read :)
@EMDB the marquee retainers are 18mm, exactly the width of the panels and does not cover the artwork:-).
The weight of the cab, yeah it is heavy! :laugh:
I understand you took the height of the retainers into account but still 2 x 18mm is huge compared to the total height of the marquee. It seems your initial artwork had a better ratio:
You could have used 15mm or even 12mm for the top panels. I did for my full cabinet:
(https://dl.dropboxusercontent.com/u/82432150/Retrocade/retainer_marquee_front.jpg)
Excellent build, and I'm totally jealous. But, why is it a horizontal monitor for a vertical game??!? :dizzy:
I see EMDB. I will have a look at it later on.
@matsadona, i know, you are right, but horizontally mounted fits much better in this small cabinet. Most of the time i will play horizontal games. ;)
Aha, I assumed it was a FIFJR dedicated cabinet, and that's why it didn't make any sense to me...
Tisk Tisk, missing the rubber boots on the QD's connecting to the button switches. ...Sloppy.
:P. I kidd, I kidd!
I just realized I haven't mentioned how much I love this build. :applaud: seriously, well done so far!
:P. I kidd, I kidd!
I am sorry, i guess i need to make another cab with protection covers? ::)
Looking sweet. kudos to the nice and neat wiring!
FINAL UPDATE! :applaud:
Excited to see if everything works when the power switch is switched, luckily everything was connected properly and we have a solid picture!
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(1).jpg)
The marquee LED strip gives a very bright, wide beam angle
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(2).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(3).jpg)
Artwork, printed the artwork on vinyl. The results are great!
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(4).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(5).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(6).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(7).jpg)
Painted the aluminum profiles matt black.
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(8).jpg)
The three service buttons for start, pause and stop are placed
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(9).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(10).jpg)
... and attached the aluminum strip behind this bar for securing the plexiglass.
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(11).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(12).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(13).jpg)
Placed. The control panel is now fixed right away.
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(14).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(15).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(16).jpg)
The screws also have a black layer of lacquer
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(17).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(18).jpg)
Black caps placed on the screws that hold the monitor in place
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(19).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(20).jpg)
Insert coin sticker has found its place
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(21).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(22).jpg)
The nameplate:
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(23).jpg)
The bezel for the monitor.
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(24).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(25).jpg)
Fixing the marquee in place
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(26).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(27).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(28).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(29).jpg)
The lighting looks very nice!
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(30).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(31).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(32).jpg)
Unfortunately i can not play at this moment, the computer was over 80 degrees making it dropped out after a minute or 5. By placing 2 large 12cm fans on the back plate with the necessary slots where the hot air can escape, i hope to tackle this problem.
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(33).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(34).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(35).jpg)
Top left i made a small opening for the ATX power supply so that the heat can be lost directly to the outside.
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(36).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(37).jpg)
The power supply that was made in the cabinet made a huge noise. I have received a new Antec power supply for this project. This psu had a lot of connections and power exactly on the wrong side. So i made a modification again:
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(38).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(39).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(40).jpg)
Testing it out:
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(41).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(42).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(43).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(44).jpg)
The new PSU:
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(45).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(46).jpg)
Ready for paint!
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(47).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(48).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(49).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(50).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(51).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(52).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(53).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(54).jpg)
With 2 fans on the back of the cabinet the PC remains at an acceptable temperature. See the end result here:
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(55).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(56).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(57).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(58).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(59).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(60).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(61).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(62).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(63).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(64).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(65).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(66).jpg)
(http://www.arcadewinkel.nl/image/data/blog/builds/2015/arcadewinkel-crt-fix-it-felix-jr-bartop/arno-fixit-felix-bartop-crt-upd4-(67).jpg)
Short movie:
https://youtu.be/_qszQGSpFqs (https://youtu.be/_qszQGSpFqs)
Very nice machine. :cheers:
This looks really good. Great execution.
Great work! But I see that this happened to yours also:
(http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=328109)
I had to redo the paintjob on mine because of this. We have probably used the wrong filler.
Thanks Johncrt. This problem is indeed caused by the wrong filler :hissy:
