Front End Support => Maximus Arcade => Topic started by: maxouge on March 07, 2017, 05:26:11 pm
Hello,
I managed to configure maximus arcarde for all my rom, and all the emulator recognize my ps4 controllers natively without any key mapper software.
I would like it to work with Maximus Arcade as well, I mean natively, I dont wwant to add a key mapper because I will mess with all the emulator configuration.
I just dont understand why nothing is being detected, is there is a solution to that ? I am quite surprise for a frontend gaming shareware that there is not a real support for controller? Even the most experimental emulator recognize my ps4 controller once there are plugged.
Am I messing something ?
Is someone had the same issue ? I cant find anything on the internet about that. So probably I am doing something wrong.
Basically once I choosed to activate joystick/gamepad input and that I want to set up keys, nothing is being detected. But the keyboard is being detected.
What can I do ?
Thanks in advance for your support,
Kind regards,
Maybe this?
https://www.maximus-arcade.com/pages/maximus-arcade-setup-documentation (https://www.maximus-arcade.com/pages/maximus-arcade-setup-documentation)
(6) Option to use either the RavWare or DirectControl input method. Try switching input options if you are encountering joystick related issues.
HELLO,
Thank you for your answer, howver it's still doesnt detect anything... It's sad because windows support well ps4 controller, even zsnes suport it...
I really wonder why the controller settings hasnt been well developped when you see that this software cost 25 dollars... Shame.
I guess I ll go for another frontend wich is maybe free and for sure more developped.
I am glad I still didnt purschase this software.
Thank you anyway.
Reup,
I can see that both of my ps4 controllers are well being detected by Maximus Arcade 2.0 in the "view" section in the "controller" section in Maximus Arcade preferences.
All my button works well on the graphical test manager from maximus arcade.
I used directinput option and i put capture joystick/gamepad option. But when i tried to hold the gamepad button or joystick to configure maximus arcade command nothing is being registered. Only when I press the keyboard key something is being recorded.
I am sure I am missing something because my controllers are well recognize and all the button are being detected and well mapped in gamepad test area.
So how can I fix that ? please someone help ...
