Main => Consoles => Topic started by: Howard_Casto on May 21, 2016, 05:49:30 pm
Mine finally bit the big one. I'm wondering if there are replacements. It'd have to be fairly cheap because I can just buy another dreamcast for 30 bucks. I just hate to toss this one as it's mint and even has the original box and stuff.
I looked at the disc-less solutions but they seem really expensive.
I did some poking around and came up with nothing. I can find them for the ps1 all day. the closest I came was a dreamcast motor for like 5 bucks. I would like one as well to keep in my console parts bin for future use.
ok so I just learned that there are two dreamcast drives. Yamaha and samsung. they are not interchangeable. so if you are up for a fun new project and have the correct drive I found a hack to use a pc cd rom laser.
http://dreamcast-talk.com/forum/viewtopic.php?t=1982 (http://dreamcast-talk.com/forum/viewtopic.php?t=1982)
Man that looks rough. I think dreamcasts are going for 30 bucks atm on amazon, probably less on eBay so I doubt it's worth it unfortunately. I'll probably buy another DC and save this one for when hdd/usb mods become affordable.
I'm not having much luck this weekend. I think I borked the scanline generator I was building as well. That one doesn't hurt as much since I'm only out 3 bucks in parts.
Don't know but this is what I found.
$5.33 with free shipping (http://www.aliexpress.com/item/High-Quality-SPU-3200-1PCS-LOT-16pin-Laser-Lens-SPU3200-Sega-Dreamcast-Optical-Pickup-Replacement-For/32612842521.html?spm=2114.01010208.3.1.UaQL5z&ws_ab_test=searchweb201556_8,searchweb201602_1_10037_10017_10021_507_10022_10032_10009_10020_10008_10018_10019_101,searchweb201603_2&btsid=ca0e22e0-07f3-47d3-8556-02a9dee2f929) High Quality SPU-3200 1PCS/LOT 16pin Laser Lens SPU3200 Sega Dreamcast Optical Pickup Replacement For DC Game Player
Here is a different one, many the other brand? (http://www.aliexpress.com/item/SPU3090-Laser-head-SPU3090-CD-Dreamcast-Optical-Pick-up/1405891604.html?spm=2114.01010208.3.156.UaQL5z&ws_ab_test=searchweb201556_8,searchweb201602_1_10037_10017_10021_507_10022_10032_10009_10020_10008_10018_10019_101,searchweb201603_2&btsid=ca0e22e0-07f3-47d3-8556-02a9dee2f929) SPU3090 Laser head SPU3090 CD Dreamcast Optical Pick-up
There are also the USB hack's but I think there are bottle neck issues. (http://www.aliexpress.com/item/Band-New-DIY-for-Dreamcast-Support-For-Sega-DC-SD-Card-Adapter-Converter-For-DC-game/32607251219.html?spm=2114.01010208.3.10.UaQL5z&ws_ab_test=searchweb201556_8,searchweb201602_1_10037_10017_10021_507_10022_10032_10009_10020_10008_10018_10019_101,searchweb201603_2&btsid=ca0e22e0-07f3-47d3-8556-02a9dee2f929)
Thanks a ton man. I should have thought of our eBay to the east. ;) I'll have to research which one is which. Hmm.... since I have to order from there anyway, I might as well get another multi-cart or some other goodie.
While we are on the subject, do any of you guys know a cdr format that works well on the dreamcast? The reason I ask is, when I first got my DC a made quick work of my remaining CDRs, circa 2000 vintage and they burned just fine. After I eventually ran out, I just picked up a pack of phillips CDRs at the store and I've yet to get a disc to run with them. I'm using discjuggler with all the usual settings.
Be careful with the replacement drive. I have read that some of them work but do not play retail games.
As for the cdr. I use these:
https://www.amazon.com/gp/aw/d/B000FTADXK/ref=mp_s_a_1_7?qid=1464278666&sr=8-7&pi=AC_SX236_SY340_FMwebp_QL65&keywords=verbatim+cdr&dpPl=1&dpID=41LXnhiQpkL&ref=plSrch (https://www.amazon.com/gp/aw/d/B000FTADXK/ref=mp_s_a_1_7?qid=1464278666&sr=8-7&pi=AC_SX236_SY340_FMwebp_QL65&keywords=verbatim+cdr&dpPl=1&dpID=41LXnhiQpkL&ref=plSrch)
BAH! I'll have to open it up again to confirm, but it looks like I have a Samsung drive and all the replacements are for a Yamaha drive. You can get a Yamaha replacement for around 5 bucks.... I only found one Samsung.... 60 bucks. I mean I could try that cdrom trick, but I'm not sure if I even have any non-cdrw drives left.
I found some Kodak CD-R 52X in my local supermarket a little while back. They work well. Not sure if you can still pick them up locally, but there's plenny in ebay land (",)
