Arcade Collecting => Pinball => Topic started by: otsep on November 28, 2016, 12:03:02 am
I'm working on a Pinbot that is very dirty. Is there a way to safely clean coils or is it not worth it? Thanks.
Knock most of the black dust off with a paint brush and canned air or a vacuum cleaner. Then if you have grease or crud on the plastic bobbin, use lighter fluid or 99% isopropyl alcohol to clean it off. If the coil wrapper looks bad, you can download & print new one here:
http://www.pinballrebel.com/pinball/cards/ (http://www.pinballrebel.com/pinball/cards/)
Scroll the menu down to coil wrappers. When printing be sure to select "no scaling" in your print setup so it prints out the correct size.
I use double sided Scotch tape to secure the coil wrappers.
also, do not use any oil or lube on parts. all it does is attract dirt and cause gumming up.
A paint brush to dust off coil wrappers? Give me a break. Spray that sucker down with Formula 409.
