Main => Monitor/Video Forum => Topic started by: Ken Layton on May 29, 2008, 11:19:41 pm
For those that want to have a supply of the most commonly used electrolytic capacitors that cover a good percentage of most monitors, here is a list of the quantities and values to order:
100 1 uf @ 50 volt
50 1 uf @ 250 volt
10 1 uf @ 450 volt
100 2.2 uf @ 50 volt
20 2.2 uf @ 250 volt
20 3.3 uf @ 250 volt
100 4.7 uf @ 50 volt
20 4.7 uf @ 250 volt
100 10 uf @ 50 volt
30 10 uf @ 160 volt
30 10 uf @ 250 volt
20 22 uf @ 50 volt
20 22 uf @ 250 volt
100 47 uf @ 50 volt
20 47 uf @ 250 volt
100 100 uf @ 50 volt
20 100 uf @ 160 volt
50 220 uf @ 35 volt
30 470 uf @ 35 volt
20 1000 uf @ 25 volt
20 1000 uf @ 35 volt
20 2200 uf @ 35 volt
Special Bi-polar types:
20 1 uf @ 50 volt B.P.
20 4.7 uf @ 50 volt B.P.
20 10 uf @ 50 volt B.P.
Remember those listed above are "radial" style leads. I generally buy the Xicon brand cause they are the cheapest.
GREAT info.
Someone ought to make up an order on digikey or mouser and give us an estimated cost of the whole order. And a bonus would be to make a spreadsheet with the part number of the vendor for the correct item.
I would do it, but I am lazy. :dunno
A person could also order most of those capacitors in the 105 degree temperature rating (better, but cost a few pennies more) instead of the usual 85 degree for longer capacitor life in monitors.
i always order 105 degree due to the enclosed conditions of monitors
Well done Ken. Thanks for the list.
Could someone make this a sticky? This is fantastic info that people are probably looking for a lot... I know I just reproduced it myself from kits the other day and this could have saved me a couple hours of work.
I added a link to this post in The FAQ.
Bumping this topic.
Here is the mouser project. I used these criteria: 1. cheapest 2. In stock 3. Not at end of life. As of 5/14/2010 anyway.
http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=6f98bacb86 (http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=6f98bacb86)
Jeff
3.3uf @ 50V should be added to this list...G07s have two of them.
I added 100 3.3uf @ 50V to the project
Jef
D'oh...that should be 3.3uf @ 50V BP. Sorry about that.
I just looked at that Mouser project more in-depth. I'd just scanned it before. Here's my take:
1) I'd go with hi-temp only caps. They last longer than standard 85ºC caps.
2) Lelon brand capacitors haven't been getting good reviews. @ BadCaps.Net (http://ww.badcaps.net) forums they're listed on the bad caps list. I'd do nothing but Nichicon brand. More expensive
Then again, Xicon got bad reviews too, and I never had an issue with them. Time will tell on Lelon.
Everybody is probably going to want something a little different. That's why I went with: 1. Cheapest 2. In-Stock 3. Not End of Life. You can't get 105 degree caps for all of them and you can't get all the same brand. I guess if you wanted out of stock you could, but what's the point if delivery is some time in October.
Jeff
I updated it. I added an End of Life cap, but they had over 1000 in stock. If I added one that met the criteria, it was over $1 per cap. These are only 10 cents.
Jeff
If i get time, I'll make another project with the following criteria: 1. 105 degree 2. Not EOL 3. In stock. Do you have a brand recommendation?
Jeff
Nichicon is my choice.
Here's a 3.3uf, 50V BP for a quarter. (http://mouser.com/ProductDetail/Nichicon/UEP1H3R3MDD/?qs=sGAEpiMZZMtZ1n0r9vR22fwnQlnu%2fcHclpw5AXxWgyA%3d)
I didn't add that one because there were only 64 in stock and the delivery date for more was 11/1/2010.
Jeff
this seems quite useful...
http://www.multigame.com/CapKitCrossReference.pdf (http://www.multigame.com/CapKitCrossReference.pdf)
Bob Roberts started selling these for $40.
http://therealbobroberts.net/bulkcap.html (http://therealbobroberts.net/bulkcap.html)
5 Each Of These Values - 150 Total
1uf50v 4.7uf50v 22uf25v 47uf50v 100uf160v 470uf25v
1uf250v 4.7uf250v 22uf50v 47uf250v 220uf25v 470uf50v
2.2uf50v 10uf50v 22uf250v 100uf16v 220uf50v 1000uf16v
3.3uf50v 10uf160v 33uf25v 100uf25v 330uf25v 1000uf50v
3.3uf160v 10uf250v 47uf25v 100uf50v 330uf50v 2200uf35v
Jeff
A few of these are OOS.
Would you like me to create an up-to-date list with replacements?
A lot of those are either out of stock (endless back order) or have been discontinued. Yes, it's probably time for an updated list. :)
Updated list here: http://forum.arcadecontrols.com/index.php/topic,139622.0.html (http://forum.arcadecontrols.com/index.php/topic,139622.0.html)
