Main => Buy/Sell/Trade - non-retail => Topic started by: Raven.. on September 30, 2006, 11:48:02 pm
I'm pretty sure someone had asked me if I had a Frontline spinner, but I can't find the message.
To whomever it was: I actually found one in my stuff last weekend. Unfortunately, I forgot to bring it home to take pics. Next time I go out there, I'll try to snag it.
I was lookin' for one but changed my mind since the custom wiring job needed for MAME would be a beating for me. :(
PM Sent
Custom wiring job? I think it's exactly the same as wiring a joystick and fire button- or am I missing something?
I recall something about a switch to cut the ground or something similar when you go to enter it as a control in MAME. That's on the boards somewhere. . . :dunno
Yep. The frontline spinner is effectively an 8-way joystick (4 switches), but 1 or 2 of the switches are always activated depending on position. The easiest way to "disable" the control (so that it doesn't always signal a switch closed) is to disconnect the ground as needed. I have mounted a simple on/off switch on the ground wire which leads to the control under the control panel. When I want to play frontline/wild western/tin star, I simply turn the switch on, otherwise it is left off for general pupose mame games.
Actually, doesn't sound as bad as I remembered!
