Software Support => GroovyMAME => Topic started by: shredward on January 03, 2019, 02:31:55 am
I could use some help...
Trying to install CRT Emudriver for a HD6450, but when I run setup.exe no compatible devices are listed and thus the install driver button is greyed out.
"Have you tried turning it off and on again ?"
Joke aside that happened to me not too long ago, the card only appeared (listed as a generic VGA graphics card) after a power cycle or two.
The first time it simply was not detected, don't know why...
Yes, I tried the on/off switch! :)
W7 wouldn't recognize the HD6450 either and listed it as a standard VGA adapter, so i thought that was a possible reason CRT Emu wasn't recognizing it as a supported card. I finally got that resolved, but to no avail. I've tried DDU, changed cards (I have two 6450s), and a bunch of other stuff - no joy.
Any other ideas?
Make sure you're downloading the file ended as "_nieg"
Will do...I see that option now that Eiusdemmodi is back up!
Thanks for your help and for all of the work you put into this!
