Arcade Collecting => Merit/JVL Touchscreen => Topic started by: JoshCRT on January 21, 2019, 08:50:16 pm
I purchased an old JVL Conquest that was reporting disc read errors. The CD drive wasn't spinning, I swapped the drive but the machine still won't boot. It looks like the original operator was using a burned disc with the "MY_DISC" as the ID label - so I assume they didn't create a proper image when doing so.
Does anyone have a disc image of the iTouch 4 software? Thanks!
(https://i.imgur.com/GzSk5dq.jpg)
(https://i.imgur.com/HwULpoQ.jpg)
(https://i.imgur.com/eMFU7AO.jpg)
(https://i.imgur.com/1iRdlfp.jpg)
(https://i.imgur.com/UCdLB4g.jpg)
Is the cd spinning after replacing the drive? Getting power?
Lowest I can find is v5. If you're interested, I can see if I have a key to go along with it
The replacement drive is indeed working, I tested it with an IDE to USB adapter and was able to read the disc fine on another PC.
I can hear it spin up and start being read, it shows the disc ID at the bottom of the screen (MY_DISC) so I know it sees the disc. Before replacing the drive it never saw the disc ID.
Hi,
still in need of this software.
I have iTouch4PLUS V2.0X TW
Just let me know if you still want it.
And let me know to which place I could upload it.
It is 360MB
Best Regards
