Main => Monitor/Video Forum => Topic started by: dodathp113 on October 15, 2019, 03:53:03 pm
Hi everyone, I'm a newbie to this
I'm going to buy a MVS motherboard to build a custom cabinet. Then I realized that it output video in RGB-thing that I don't know. So is there any (cheap) way to connect the board to a consumer tv or monitor (CRT component is prefered, since I'm going to re-use one as a monitor)
Thank you very much
(https://ibb.co/Yc0Cqsb)
How are your soldering skills? (https://shmups.system11.org/viewtopic.php?f=6&t=56155)
I RGB-modded a TV and hooked up my one slot. Looks amazing.
A supergun is probably the easiest and cheapest method.
If you are good at soldering you could consoleise it.
For component video, you'll either need a supergun with component video out, a regular supergun plus a scart to component transcoder, or a jamma harness wired to a Jpak.
There is the cbox you could try.
https://m.aliexpress.com/item/32850852119.html
