Software Support => GroovyMAME => Topic started by: timply on December 13, 2015, 07:07:36 pm
Games like Tapper, Timber and Journey are running at around 200% and was wondering if anybody has encountered this problem before?
Windows 7
GM 0.168 w/ Super Resolutions
Kortek KT-2914F
Those games are working at 30 Hz so probably forced those to work at 60 Hz by using syncrefresh 1 and using progressive resolutions. Is Kortek KT-2914F a tri-sync monitor ?
In windows 7 every interlaced resolution in presented at half of actual refresh rate and if You are force syncrefresh and use interlaced resolution actual gameplay should be still 100%.
Setting the syncrefresh to 0 fixed it! Thanks!
Should I make syncrefresh 0 the default setting or just for those games?
By default should be 0. Groovymame will change this option if required.
