Software Support => GroovyMAME => Topic started by: bodine1231 on March 17, 2019, 11:56:54 am
Have all the latest builds on windows 10,ati 5450. I'm trying to set up a vertical only cabinet on my Astro City. Every game that I try switchres changes it to 1248x496i instead of 320x240p and makes everything look blurry. I'm sure theres an easy setting but I searched all over and cant find.
You need to tell GM that your setup is vertical. You do that by means of the -orientation option. Use either -orientation rotate_r or -orientation rotate_l.
When I launch mame its already rotated,the orientation is set to vertical in the .ini.
Ok tried something different. In 'settings' on VMMaker I changed monitor rotation from "vertical fixed" to "rotating to the right". Games are launching in 240p but they are squished now
(testing on PVM until i move to cab)
https://imgur.com/ba5yoc0
https://imgur.com/IQggxoU
Fixed it! I unchecked (desktop rotates too) in the VMMaker settings.
