Main => Artwork => Topic started by: RadiantAnsel on June 30, 2022, 10:35:59 pm
Hello! I'm trying to build a single player Mortal Kombat themed stick.
I would like to see if somebody here has files for template PSD or any editable format, since I would like them to look a bit closer to arcade artwork.
Thanks a lot for the help, cheers.
Do you have both CPO artwork in high resolution?
I might be able to help you out. What is the specs/dimensions of the single player control?
