Software Support => GroovyMAME => Topic started by: jimmy2x2x on December 13, 2011, 05:01:57 pm
I am running groovymame32_0144u2.013d and have a problem with Galaga when run with HLSL enabled.
Deleted all .cfg and .ini files
generate new .ini with -cc option
edit mame.ini
video d3d
hlsl 1
monitor vga
groovymame32_0144u2.013d.exe galaga
Galaga boots, shows post screens then after the white grid blacks out the screen, I can get the tab menu to display but no graphics
All other games seem fine
any ideas?
Hi jimmy2x2x,
I've no clue of what can be happening, running galaga here with hlsl and your same settings does work normally.
Very strange!
Thanks for testing
I will try it out on a couple of other PC's see whats happening there..
Try and get a screenshot when there's no video, and check if it's black too.
Solved, thanks for the tip!
The screenshot showed the graphics
So I disabled the shadow mask texture and now its fine ;)
Must have been an alpha channel issue
Strange... I've tested it on xp32, ATI HD4350, Catalyst 11.??
Please test it with normal MAME too if possible. Also, try using the -monitor lcd option.
