Main => Raspberry Pi & Dev Board => Topic started by: Dense12 on July 19, 2021, 10:02:50 pm
Running on a RP4
I have 4 UltraStik 360s that are working in mame without a problem. But I'm having issues with them on RetroPie main menus and game select.
I did have player 1 and 2 joystick working in the main menu before, but then I reset all controllers and haven't been able to get back to that state. I feel like I'm missing something dumb :banghead:
Do you have a button hooked into the U360 that you can use to set up that stick in Retropie? It may mess up your MAME joystick set up though. I had to hook up a button temporarily to get it to see the joystick (you have to hold down a button when setting up a controller in Retropie and it does not recognize a direction as a button). :-\ if you can hook up a button, tell it you want to set up a new controller and then it should see it when you hold down the button you hooked into the U360.
J_K_M_A_N
I don't have one into the joystick unfortunately. My buttons are all connected into the Ultimate IO board.
I'll keep digging and see if I can find what's going on. PS4 controller is fine in the menus so that's my work around for now.
I think there is a way to alter the config file but I don't know which one or what needs to be added. The U360 should have 5-8 pins on it or something like that. One is ground and the rest are for buttons. If you just connect a couple wires to those, you can use it as a temp button. Good luck.
J_K_M_A_N
I think I found at least a log showing my problem. ES_LOG event after exiting the retroarch gui. Not sure what this looked like when it was actually working on the system. I'll work up the temp button for now..
Jul 21 03:20:56 lvl2: Added unconfigured joystick Ultimarc UltraStik Ultimarc Ultra-Stik Player 4 (GUID: 0300000009d200001405000011010000, instance ID: 20, device index: 0).
Jul 21 03:20:56 lvl2: Added unconfigured joystick Ultimarc UltraStik Ultimarc Ultra-Stik Player 1 (GUID: 0300000009d200001105000011010000, instance ID: 21, device index: 1).
Jul 21 03:20:56 lvl2: Added known joystick Sony Interactive Entertainment Wireless Controller (instance ID: 22, device index: 2)
Jul 21 03:20:56 lvl2: Added unconfigured joystick Ultimarc UltraStik Ultimarc Ultra-Stik Player 3 (GUID: 0300000009d200001305000011010000, instance ID: 23, device index: 3).
Jul 21 03:20:56 lvl2: Added unconfigured joystick Ultimarc UltraStik Ultimarc Ultra-Stik Player 2 (GUID: 0300000009d200001205000011010000, instance ID: 24, device index: 4).
