Arcade Collecting => Miscellaneous Arcade Talk => Topic started by: rtkiii on March 10, 2013, 01:43:45 pm
Hey guys,
Finally moved the cabinet into my house and I noticed an orange haze that I did not notice in the garage. It is more and likely from age but I weas hoping there was some sort of solution I could use to wipe away that orange without hurting the artwork underneath as it is an original Dig Dug artwork. I tried some minor chemicals to get the dirt off and it looks better but getting trid of that orange would make a world of difference.
orange haze? like smoke or discolored from age?
smoke can be removed with formula 409 or "LA's totally awesome cleaner" http://www.amazon.com/LAS-PURPOSE-CONCENTRATED-TOTALLY-AWESOME/dp/B0017KT3IM (http://www.amazon.com/LAS-PURPOSE-CONCENTRATED-TOTALLY-AWESOME/dp/B0017KT3IM)
age...not much you can do without messing stuff up.
Good to know...I did not think about it being smoke. i will give 409 a try first...but yeah if that does not do it then I think I am out of luck unless I want to repaint.
