Main => Monitor/Video Forum => Topic started by: Iflippedthecanoe on March 21, 2020, 10:04:01 am
Im looking for a good all around horizontal arcade monitor for a multicade MAME build. I really don't know the differences between monitors at all. Im looking for a good resolution to play 8bit to games up to 3D arcade games and decent scanlines and quality obviously would be nice!!! :notworthy:
So, first things first: what games are you going to play? Actual examples would be good, because you make it sound like you plan to play console games and that can make a really big difference if you want to play 5th gen or newer. You also need to understand that there's different resolutions of arcade games. Most will be low-res CGA, a few will be medium res, and a few will be higher res. If you just want to pick a good all-around tube, pick a CGA tube. If you have loads of cash, pick a tri-sync that can do all 3.
Oh damn ok that helps to know. I don't really plan on spending more than $400 but the games I want to play are 1st through 6 gen console games. Also want to play lots of arcade games from 2D to 3D. So basically everything. But If I had to choose I just want a clear monitor that works good with 16bit-ish games and good scanlines if possible.
A monitor that makes Mortal Kombat 3 look good would be good I think...
MK3 is a CGA/standard res tube. 16 bit games and most of your 80s and 90s arcade titles will also play well on a standard res tube with very few exceptions. N64 and Playstation will probably look like ass on a CGA tube, but you probably don't want to play the majority of those on an arcade stick in the first place, so I wouldn't worry about it.
Ok that helps. I do plan on playing 3D mame games but CGA might work for me, maybe idealy a tri sync would be the best all in one monitor?
Also are there higher end higher resolution CGA monitors out there? Also what would be a good make/model for CGA/tri sync or anytything else?
I also have a monitor called an Effinet EFG-1701M/F , but i have no idea what the quality of that model is...
If money is no object, Nanao brand is considered exceptional, they came in Japanese candy cabs and are some of the finest. They're available in CGA and tri-sync. As for the EFFinet thing, if it's reasonably new, probably not a big deal to use it. Contact the manufacturer for a data sheet if you need it.
https://effinet.en.ec21.com/CRT_Monitor--762751_762764.html
