Main => Software Forum => Topic started by: oldskoolcade on May 20, 2006, 08:11:07 am
I posted this over on Mameworld as well, but I thought I'd give it a shot over here too. I made the mistake of overwriting my current Catver with one for Mame105u3. Well I'm only running 104u6 (so as to use my wingun drivers still), and Mamewah has problems with generating custom lists unless you use the catver for the version you're running (otherwise you always get stray games added to whatever list).
If anyone has an earlier version, I'd appreciate a PM.
Thanks all!
Mike
Here is a catver.INI file for Mame-v103 ..... just change the file entension from TXT to INI ......
Fantastic stuff! Thanks so much!
Mike
