Main => Audio/Jukebox/MP3 Forum => Topic started by: Surreyjukeboxuser on January 19, 2018, 04:25:20 pm
I purchased an Ami-Rowe R90 when I lived in the USA and used it successfully on USA power. I have now bought the machine back to the UK with me. Looking at a manual I have found and also looking at the power supply it would appear that the power supply is automatically dual voltage. On this basis, I am presuming that I do not need a step down transformer to use it in the UK and the records will also play at the correct speed. Am I correct in my assumptions?
Hello surrerjukeboxuser,
I spoke with you yesterday regarding your jukebox and said that you would require a stepdown transformer or a replacement power supply (junction box) and a 50 hz turntable belt pulley.
I await your motor plate arriving and we will supply you with a 240 volt power supply.
Regards
Alan
Alan Hood
ami-man
UK
Alan,
The plate was sent to you today
Hello Nigel,
Have you recieved the parts? and have these now rectified your problems?
Regards
Alan
Alan Hood
ami-man
UK
