Main => Main Forum => Topic started by: liche on November 11, 2002, 07:40:10 am
Without spending $200 for an expensive punch, what is the best way to make those square holes on my control panel (1/16" steel) to hold the carriage bolts????
Any help appreciated.
predrill a whole. then put the bold in and tighten. It will make it for you. At least that is what I did.
Lil Wolf, that worked for a steel control panel???
I would drill a hole, and then use a square file.
Use a triangular file. You can get them for under $3 at the hardware store. You can usually get a carton of 10 different files, rasps, etc. (square, round, triangular, flat) for $10 or so too.
Do you know what size pilot hole (prior to filing) is optimal for standard 3/16" carriage bolts. I say standard as I think this is the size most often used in control panels.
Thanks again
Make it exactly the width of the bolt, under the square... 3/16", then square out the corners. If you must go smaller wouldn't make it smaller than 1/8", as it would take too long to square out/more apt to mess up.
They actually make bits for cutting square holes...I know they exist for wood, but not sure about metal...
A mortise bit used for square holes in wood isn't going to help you with metal. I'd suggest the file route. If you have a lot of holes to do you could always bring it in somewhere.
Sorry, my example was for a wood control panel.
It would probably strip the bolts on a metal CP
1/16" steel sounds awfully thin for a control panel but if thats what your using then just drill a 3/16" hole, tighten it and let the bolt do the work for you. 1/16" steel is barely thicker than sheet metal so the carriage bolts should have no problem pulling themselves through. If all your using is 1/16" steel then I would cover it with at least 3/16" or 1/14" lexan to give the panel some strenth or just use thicker steel. I used 3/16" steel for my cp and I was still able to just tighten the carriage bolts without having to square out the holes.
