Software Support => SK Jukebox => Topic started by: ediblegod on July 04, 2008, 08:22:41 pm
Hello,
I'm trying sk for the first time and have run into a problem.
Whenever I use the "Jump" feature it scrolls through everything and then switches back and forth between the first and last page rapidly. Then when I try to exit the program SK starts again???
Has anyone had the same problem?
Thanks!!!
Try deleting SKJukebox.ini to reset everything. Then try again. What version are you using?
Worked, thanks!
I'm using 4.1
