Main => Project Announcements => Topic started by: rbarr110 on January 13, 2022, 01:52:18 pm
I built my first mame cabinet over 15+ years ago. Ever since I saw the O.G. 1-Up rotating panel cab (named pacmamia if I remember correctly), I wanted to make my own. Since I wanted to build one I decided I needed a CNC machine. Well I completed the CNC in 2012....but never made another arcade machine (yet). However, I spent countless hours sketching layouts and ways to build the rotating panel over the last 15 years, never giving up on the idea.
Since COVID gave me some extra time at home teh last 2 years, I got back into the cabinet design and piecing it together using Fusion 360 which has given me the confidence that I have the design right. That being said, I plan on building a mock-up because the support for and mechanism for stabilizing the rotating panel and mounting of the panel is conceptual and I am 90% confident it will work, so a MDF mock-up will give me the opportunity to fine tune or change as needed before I build it from the more expensive birch plywood I want to stain to match the other wood of my bar, saltwater tank stand, and trim etc. in the family room.
The new cabinet will be wall mounted so it is not a "full" height free standing cabinet, but is pretty close. I also designed it to be wide enough to house a 32" monitor and give a little extra width on the control panels. However, I think I will stick with a 27" monitor as I was originally thinking a 32" would give me a lot more vertical real estate than it really does. Plus a 27" will give me a little more room to mount IR for the lightguns. Also I wanted the cab to be able to be taken apart for easy movement/relocation so the upper half and lower have can easily be separated. 1 of the 3 control panels will be swappable, but technically all will be able to be removed for maintenance or change of layout if I decide I don't like it....
I have seen some peoples designs and tests for one, but it has been years since I have been active here, so I don't know if anyone else has successfully built a rotating CP since the original. If all goes to plan, I start the mockup this weekend.
Just make swappable panels.
A rotating mechanism is just a ton of work and aggravation for no gain.
I considered this, but swappable panels have to be stored. No need for extra clutter in my life. Plus I am an engineer, so the challenge is what makes this desirable.
Sounds awesome! Will definitely be some WOW factor when people see that.... Good luck!
The simple answer would be to store the extra panels inside the cabinet. K.I.S.S.
Also considered this. Makes the cabinet extra large. Something my wife hates about the current cabinet. So no K.I.S.S., as I thought the options through and am doing what I want and what fits me, not the universal dumbed down version of things.
So the two unused panels can fit inside this cabinet if they're on a rotating assembly... But won't fit inside this cabinet if not. :cheers:
So when something is assembled in a manner where there are things sticking out the top and bottom (buttons, joysticks, wiring), they dont store and stack neatly. The bottom compartment would have to be much larger to fit extra panels and the PC. I know because my original build tried to do this it became a messy cluster F in the cabinet. I ended up redoing my first cabinet with an extra wide panel which I dont want this time around.
I dig the idea myself.
Look forward to seeing how you implement it all, especially as regards...
1. Cable management
2. Clearance during rotation
3. Locking mechanism
4. Fit and finish when parked
Very cool idea, but obviously a lot to execute well !
How many panels are we talking about here? If you look up "blip" you will find an excellent example of swappable panels. There are only 2 but the amount of games covered is crazy and the second panel is stored out of sight on the TOP of the cabinet. Check it out: http://forum.arcadecontrols.com/index.php/topic,137295.0/all.html
I think a rotating solution would be really cool if you can pull it off. Those aren't projects we see around here as you can probably tell from the responses. Good luck. :cheers:
I'm glad these kind of ideas died in my head. Much better to just build multiple cabinets.
It has taken me a few years now, but I have come to accept that making room for more cabinets (which play fewer games even!) is the best path in numerous respects.
Groovy engineering is still admirable though.
Got a fair amount of pieces cut out today. I also managed to stain the side panels. If I feel ambitious on Monday, I can probably cut out 90% of all the cabinet pieces if not all of them. The CNC sure makes short work of the cutting.
Nice project! I was going to go the rotating route, but decided to just store hot swappable panels in the cab. Looking forward to seeing this progress!
A few more in progress shots.
I didnt get to testing the rotating panel as I realized I should really stain and clear coat before doing some of the assembly. So I put the edge banding on and started finish work. In my haste, I messed up and flipped a few pieces too soon on their stand off blocks leaving triangle shapes in the stain. They weren't too noticeable until I put the first layer of clear coat on.....oh well, I can live with it.
I just love CNC projects. Everything is so perfect.
Good job so far. If the triangles bother you, I'm sure you could just cut some new pieces in an hour or less. Really curious to see how this is all going to work.
Hey when you post here you need to make sure we can live with it also. Those triangles need to go...lol.
Given the precision of everything else here I can't see how you can proceed without sanding those triangle holidays out and giving those pieces a fresh coat!
Your future self may hate you.
I plan on making new ones, but for testing purposes they can stay. The more I look at them the more I cant look at them.
:lol
Just cover them up with collage of arcade and console characters. Nobody will ever know.
The frame of the control panel getting cut out.
The axle for the panel. The flanged bearing fit perfectly inside 1-1/4" PVC pipe and the flange stops the bearing from going too far in the pipe. Used use 3/4" steel tube to tie the PVC to the bearing in my HDPE guide blocks. I just need to go to the hardware store and pick up a couple of shaft collar locks to hold the steel tube in place relative the the bearings.
Drilled some pockets for the pocket screws and got the lower half the cabinet together for testing.
Panel frame has 1/4" bolts with a nylon bushing to act as a guide pin for the HDPE guide blocks.
Overview of the test assembly. All seems to be working as I had hoped. Need to fine tune some things and get my spacings where they need to be.
Also got some goodies with a few more to come in the coming week or so. However, was really wanting an Ultimarc u360 Flight Stick but out of stock and no idea when more will be back in according to Andy.
I am looking for opinions on one of the control panel layouts I am considering. Part of wanting the rotating panel is I want to keep each one relatively simple and avoid the franken-panel look. However I am having a hard time integrating a dedicated 4-way with the plans I have for 2 of the 3 other panels. This image below feels like it is a decent option. Thoughts?
Honestly I’d try and find another spot for the 4-way. Or get some ServoStiks and auto switch. The 2P 6 button layout is elegant and a random joystick will confuse everyone. But I like simple and this cab is anything but simple.
You can place two joysticks almost 100% vertically on top of each other, and you will
have better comfort and space.
Just make a slight diagonal, so that the top stick is abut 2 " more to the left.
This will prevent your wrist from bumping into the lower stick, when rolling the stick
in its full travel circle.
- (o) -
- ooo -
- (o) ooo -
If the above text example shows correctly... The actual vertical height difference would not
be so exaggerated. The bases can be like a cm apart. Just leave enough clearance
for bolts / mounting.
Edit:
That triangle shape looks quite small. If you are planning to use certain real arcade
controls... note that many of them are several inches deep, below the CP surface.
Need to know the layout for all three panels to offer meaningful advice.
You may be able to shift things between panels to make for better layouts all around.
Other panel will be track ball w/ spinner and a u360 Flight stick (assuming they come back in stock sometime in the near future), and the 3rd panel I have not drawn up but it will have a star wars yoke and was possibly going to add "holster" pockets on either side of the yoke for the light guns. Guns may just stay put away and plugged into a panel mounted USB hub is the alternate to that.
I was kind of wanting the dedicated 4-way placed a bit more center of the panel, but I guess it could be on the left side of the track ball and the buttons to the right. I uploaded the sketch of the trackball/spinner panel and a photo of my old panel on the cab to be retired.
A few more progress pics that may help people identify how cable management is done. The design changed a bit during testing as I wanted to push the side frame panels as close to the cab side panels which made me change the way to route the wires (extra hole in CP frame panel) which made the initial plan of routing the cables through the PVC unnecessary. I still put the cables through the PVC as I think it is slightly cleaner routing.
I'm starting to get flashbacks ;D. Good luck with your build, you have an advantage over me. I started out only wanting a rotating monitor. The rotating control panels were an afterthought and designed and built after the cabinet had already been built.
Nothing to update for progress as I managed to fall, hit my head, black out, get a minor brain bleed and spend some "quality" time in the hospital. I can finally start looking at screens for a short period of time again without getting a migraine.
Anyway, since I am still not feeling great and not up to woodworking, I thought I would work on getting the PC setup and try to decide what I want to do with my marquee. I really liked my old CP artwork, but apparently don't have an old copy of it on any of my old backups. Want to try something with the old artwork on the CNC .
I have ZERO recollection of where I found the artwork, I know it is a longshot, but does anyone still around from 15 years ago have this artwork in their collection?
http://forum.arcadecontrols.com/index.php/topic,166063.msg1751269.html#msg1751269
Good luck. It's a lot more work than you think.
I gave up on my rotating project due to lack of time and change of circumstance (suddenly had room for many more cabs, no need for an all-in-one solution).
holy smokes, dude, I hope you're okay, and that there aren't any lingering effects!!!
I'd come up with something new for that artwork.
Ok - I am back to working on this following the head injury and a well needed 10 day vacation in Mexico. Starting back up on the woodworking, but did get the PC setup with games and emulators working. Also got a 32" monitor to put in the cab.
Feeling better then now it appears?! Good to hear.
Geez-
How was Mexico?
Yes, feeling much better. Mexico was awesome, went diving (to my doctors dismay). Was the first time I have dove in warm water and it was amazing.
Anyway, been working on the cabinet a bunch this weekend. Got LED Blinky configured and starting the panel assembly.
More progress pics.
More
So I bought a piece of 36"x48" black formica about 10 years ago for this project....finally using it.
Making slow progress. Between work and doing other fun things, and the fact I hate finishing work (clear coats)...progress is slow. Hoping to get the last of the 3 control panels done this weekend. T-molding came in this week so I can wrap the front edge of the panels and get it closer to a finished look. A few of the last pieces I needed to cut for the cabinet have also been done.
Didn't finish the 3rd CP last weekend but did make progress, forgot to upload pics.
When I did the design of the rotating panel, I did not have all the parts on hand. I wanted a U360 Flight Stick, but they were out of stock....then I saw the Tron reporoduction sticks and grabbed one. Also, didnt have a star wars yoke, but when I got both my design was about 1/2" or so off for them both to fit well. I ended up having to make some adjustments on the fly. Control panle 3 with the yoke, has a arc cut into it to allow the yoke to rotate the full amount. Had to also adjust the upper part of the contral panel with a hinge so the Tron stick could clear when rotated.
That being said, I did get the panels finished and wired up today, tomorrow will be testing it out to make sure the wiring is good.
Hope your test is a success.
As long as it actually works and plays well you should disregard everything else and just enjoy the ever-loving crap out of it.
It worked well. Panel rotates and no tangled wires etc. The only issues I am having is within the MAME settings itself regarding the device ID's. My Ultimarc Ultra-stik 360 are identified as 1 and 2 in windows and installed in the typical control panel 1 and 2 locations. However, MAME insists as using the P2 position as Joy_1 and P1 position as Joy_2. Tried doing the stable ID configuration, but I can't seem to get it to work. I could always just reset the config file so MAME assigns all P1 joy to used the Joy_2 and vice versa....but it really irritates me.
Photos of the test setup and how the 4 wires (ipac power, ipac USB, USB hub, USB hub power)from the control panel are routed so the CP can rotate the needed 270 degrees to access the 3 panels.
So long time no post/updates, but to be honest I fell into the trap where you get the cab playable without finishing the wood work and become lazy. I also fell down the light gun rabbit hole and messed around with trying to get wiimote cameras to work, but didn't have any success. Fortunately the DFrobot cameras I ordered in January came in and I was able to wire up a gun and mess around with it. Started with a guncon2 shell, but found a printable case that was easier to work with as it was designed for using a Gun4IR setup. So rather than work on a cab, CNC'ed my own pcb's and put time into the light gun and it works quite well. Time to finish the woodworking before the wife gets any more pissed about an unfinished cabinet.
Been busy, been lazy, been sidetracked, etc, etc. I haven't worked on the cabinet in a while and when I did, I didn't post updates. Anyway, after messing around with light guns, I made a new gun and working on the second now (Odcon shell with Gun4ir). Anyway, still need to decide on a marquee and finish the lower panel. The lower panel will have "holsters" for the guns and then I can call the cabinet complete. I want to redo the Launchbox setup and separate the options based upon the different CP on the cabinet.
Fantastic project. How big is your CNC, 4x4 or 4x8? just curious, I am pretty close to pulling the trigger on a OneFinity Elite Foreman, which is a 4x4 setup.
Zeosstud
It cuts an area 4 ft x 5 ft. Its a DIY CNC at Joescnc.com
