Main => Raspberry Pi & Dev Board => Topic started by: proplayer77 on December 16, 2017, 10:17:19 am
Im thinking about making a smaller project before making the full size cabinet. (have gathered all stuff for the full size allready, including wood and electronics :)).
My idea is to make a Amiga (my best gaming machine ever on 80:s) project only.
Im thinking about using the Raspberry 0/1 image : https://retropie.org.uk/
(Have one of these older Raspberrys without other use.)
Any experience on controls, and overall use with pi 1.
Also:
Does anyone have instructions how to add easily emulators for the Raspberry 0/1 version and remove the ones i dont need.
Its going to be one player version to make it small on size.
Might want to check this out.
https://gunkrist79.wixsite.com/amibian
you'll need to overclock on a rpi1 and not sure it will play everything.
if you go with retropi all the info is on their forum and wiki.
Hmm, i have to think about this if you mean i have to overclock the Pi. Maybe i should get a newer Pi to make things more easy :D
amibian is a distro that only emulates amiga.
i'd try that first just to see how it works for you before going out and buying another pi.
Thx, ill check it out!
