Main => Woodworking => Topic started by: Spawn2k on September 27, 2017, 11:16:11 pm
Im building this cabinet and wanted to do the cp in 3/4 wood. I thought about gluing the bottom and front pieces together and making the top removable to access controls. Should i make the whole thing removable? What would be a good idea on how to do this and give me good support?
I think what im going to do is have the top sit on a ledger and use threaded inserts for wood. I wanted it to look like a wrap around but i guess a few bolts on the outskirts will be fine.
I'd have to see your overall design to give you advice but if you actually want something removable you probably won't want to use screws but rather something like a toggle clamp.
Do you know tight you can get a toggle clamp? How much force is need to pull out? I might toggle clamp the bottom so I can sand/bondo the front edge if needed. This is for an atari warlords coctail I'm making. The original cab had a pice of sheet metal that wrapped arround.
You can get adjustable toggle clamps so you can make them as tight as you want.
I used a piano hinge in the back for the top to open. Control panel was originally just resting on top, which was ok because it was heavy, then I secured it using strips of commercial-grade Velcro. Invisible, very secure, and easier to mess with than some locking mechanism.
