Main => Driving & Racing Cabinets => Topic started by: mickael28 on May 19, 2018, 08:49:40 am
Hi,
I got a racing games which runs at 60 FPS but I feel it kind of slow.
I've seen in some cases people using a 144hz monitor and some games try to sync with that frequency and run quicker, but I don't have such a monitor to try.
Do you know if there's any software/tool to help speeding up games?, ie, what I'm trying to do is to run the game faster basically...
can't help without more info...what game...what system? TV? Console?pc?
in any case you can't "speed up" a game without either...
duplicating frames to fill missing ones
or
increasing the computation speed to increase the frames being output.
or
reducing the resolution/video settings of the game to have less data to crunch and increase framerate
this results in either...
no more information to display so you end up with 60 frames...each being duplicated 2x each to make 120 frames
or
having a game run unnaturally 2 times fast to make 120 frames per second.
or
not all games/systems have the ability to sacrifice quality for framerate.
there have been experimentations with using 2 frames and creating a frame between the 2 frames to simulate higher framerate.... kind of like "clear frame" like what TV's do to get 120 144 240...etc hz framerates... The TVs have to do some artificial processing work vs. just displaying each frame flat out at perfect speed so you typically end up with display lag...unacceptable in video games.
I've set up a throwaway so I can simply answer this question. By all means delete it afterwards.
First of all, which game is it you're trying to speed up?
Secondly, look up "monitor overclocking". It can be done with easily available tools and when I did it (hardly on the best gaming monitor) I got 70-72Hz out of a 60Hz TV although the color gamut was thrown into a sort of ultra-bright output compared to earlier (not undesirable for me because the colors were dim by default on this particular monitor).
This setup was then checked on a bunch of games and FPS counters and they did report the FPS increasing slightly. It was an undesired effect at the time because it sped the game up "past the author's intent at 60 frames" so I put it back to normal after that but the experiment was useful just so I could see how it could be done.
Going any higher than 72Hz put the monitor into "out of range" and there were warnings given with the overclocking about damaging the monitor or shortening it's lifespan. I pushed it to 75Hz (further than it could tolerate apparently) but changing it back to stock it worked fine afterwards. I don't really understand the science behind it. That's what I tried out, and those were the results I got.
The throwaway's purpose is all done now.. bye bye
