Main > Everything Else
How a differential works..
protokatie:
WOW! That makes total sense! I had a very very rough idea as to how they worked, but that peg demo really gave me an epiphany!
Nice one!
TOK:
Thanks, I could watch this kind of stuff all day... Look, not even any warnings saying "THESE ARE PROFESSIONAL STUNTMEN IN CONTROLLED CONDITIONS, DON'T TRY THIS AT HOME". ;)
This video also shows without highlighting the bad side of this type of differential... When you get stuck, its always the wheel with no traction that spins! DOH!
danny_galaga:
--- Quote from: TOK on January 24, 2010, 07:28:48 am ---
Actually, i think it was showing a '1 wheel drive' car getting stuck. I could be wrong, but i'm too lazy to go back and look ;D
protokatie:
--- Quote from: danny_galaga on January 25, 2010, 02:05:50 am ---
The above person is right and so are you. A one-wheel-drive car has the dis-advantage that if the drive wheel has no traction, then the car does not move. ALSO in the case of a PASSIVE (IE the one in the vid) differential the wheel that is more apt to move may (in the case of ice or slick mud) be the only wheel to move. So for the type of differential that they showed; if one wheel was on ice and one wheel was on tarmac then the wheel on ice would spin but the one on tarmac would not (for non-UK/Eire's that would be pavement) spin.
It basically breaks down to this: With the type of differential they show in the video (which is still the most common type) you will only have as much traction as the tyre(tire) that has the least grip.
Here in the US, us motorheads (in the UK/Eire also known as people who have too much money to spend on a project car) tend for positrak or a differential that can be LOCKED. ( Too bad I sold my Ford Prefect Ranger 4WD. It was the REAL kind of 4WD, with locking hubs, and a true locked differential (4WD Low))
Never again will I get a truck like that for 400 bucks... :<
TOK:
Protokatie nailed it... I wasn't referring to the one wheel drive non-differential car.
In an open differential like the spoke demo they showed, the wheel in the mud/ice will be the one that spins if the other side has good traction.
That same thing that allows it to turn without binding means you're going to be shoving a board under a tire in the mud even if the other side is on pavement. :angry:
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
