Main > Everything Else
BYOCT
<< < (2/3) > >>
danny_galaga:
I built the car perfectly standard to the 'kit'. The wheels though are just flat disks, part of the chassis. They actually look ok from some angles, but from most, if it was a real car it would look like it has plywood wheels! So i decided to pimp my ride a little!
Since i printed two copies, i used sections of the spare chassis as 'tyres', and cut out the bits of wheel i'd need. Initially, the tyres had a whole bunch of tabs. But that was a disaster. I came apon a neat solution, As seen in the pics. Tyres are strips 10mm x about 24mm, plus a bit of a tab on the ends.
I attached a little tab on the inside of the wheels, both the original and the inside ones. Then lining everything up, i glued the 'tyre' to the tab on the original wheel first. The tabs are inset just enough to allow the tyres to be flush. When that is dry, then i glued the tyre tabs down, tucking them in nice and neat so the tyres apparent diameter wasn't bigger than the wheel. When i did this, i used the inside wheel to make sure the tyre was spaced properly, but didnt glue them yet. If you have more than a couple of things gluing at the same time it becmes quite difficult to keep everything lined up.
danny_galaga:
Voila!
Bitchin'  8)
danny_galaga:
The other thing that irked me was the back of the drivers seat- that is to say, there isn't one! So i pimped that too using the spare seat print i had. It worked out very nicely, as the dark line that indicated the seat fold now looks like where the top half of the seat meets the bottom
danny_galaga:
All in all, a good bit of fun. Got my brain working on some pleasant problems (",)
This is free to download, so you can't complain. But i will anyway! Unless there's some trick the pros use, i found some of the score lines (indicated by a dotted line) to be really noticable. The windscreen is the worst. They are actually black! Why they couldn't use a slightly darker blue than the windscreen colour is beyond me. Actually, that is about my only gripe! The lack of full depth wheels and back of the seat i would say are down to size constraints. All the parts fit neatly onto four pages. the extra bits would be a 5th page.
Instructions would have been nice too, but it was fun nutting it out on my own (",)
Malenko:
Im so glad this wasnt a "build you own chad tower" thread
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
