Main > Main Forum
Trackball "stutter"/skip?
Pages: << < (3/3)
Smack:
You could try installing the microsoft intellimouse driver package and configuring it from there as well.
Turn off mouse accerlation.
Just a thought. ;)
Smack
PaulG:
I started a similiar thread (didn't find this in the search) and for the most part following the advice of this thread has solved my problems.  The golf games, however, are still an issue I believe.  My main computer is without a video card while its being RMA'ed to ATI, so I can't test out PGA 2004.  I think it's still an issue, however, because if I do a quick down roll and then a hard up roll (or sideways) there's a definite lag.  This is why golf games sucked before for me.  I could only do moderate rolls if I wanted to avoid the "lag", which resulted in weak shots.  I'm also using the Golden Tee trackball (Red boards) with the Mini-pac.  If this is a mini-pac issue, someone please post.  I'll buy Oscars cables if necessary.  Or is this just an accepted problem of not being able to roll back, roll forward too hard in Windows XP?
slicer_d:
I'm interested in know about this.  I'm really looking forward to trying to install a trackball in the next couple of months to mainly play GT and missile command.  But if I cant play a nice game of GT with it without having to worry how fast I spin the ball it would almost be pointless.
So really my Q is do all trackballs do this or is it just for the happs ones?
TalkingOctopus:
--- Quote from: drunkatuw on February 11, 2004, 11:44:53 am ---Sorry to bring this post back from the dead...but I'm having the same problems with my golden tee trackball.  It's got the red PCBs if that matters.  But when I play golden tee (or just going around windows desktop), if I hit the ball too hard, if the cursor starts in the middle of the screen, it goes all the way to the bottom pauses there and then goes forward.  I've tried to adjust the sample rate, but windows xp detects the trackball has some HID Complient device and when I click on properties, there is no advanced settings tab.  So I'm curious if I need a different driver for the trackball, or should I just stick to the classics and forget about golden tee PC?
Note:  I'm running the minipac to connect the trackball thru usb.  I have a wireless ps/2 mouse connected and that does have the advanced settings tab (but that ones shows up as PS/2 Compatible mouse as opposed to HID Complient device).
The reason you don't get those options is because you are connecting it through USB instead of ps/2.  Maybe you should try using one of those green USB->ps/2 convertors that come bundled w/ some mice.
Superdave:
I've got to get in on this also. I have had a Happs 3" T/B for at least 3 yrs. I've got it going through a KE-72. When I first installed it. I had no problems at all. That was using win 98. But then I had the dreaded cpu fan burnout and killed my MOBO. I also installed a new HD to go along w/ the new pc. After a Fresh install of win 98, I have never gotten the thing to work right since. I have also had Win ME, and win 2k w/ no results. I have played with the mouse settings, mame's analog settings, Tried intellimouse drivers. I give up. Sucks too cause Sente Mini golf used to be a quarter grabber for me and at one time it was perfect but I haven't gotten to play it right for what seems like forever. Oh, where's NIVO?? Is he still around here? My screenie was xtrememame on here a long time ago. Just wanted to say Wazzup!
Pages: << < (3/3)
Go to full version
